в этом то и проблема что в инструкции ничего нету. а как вообще на других сигналках прописывают ,где можно почитать инструкцию о прописке и для чего на брелке приклеен номер 1, SETUP
STANDARD
ress to lock door. and enter standard security mode. DRIVING : Press to lock door .
2, DISARM
ARMED: Press to disarming .with the door unlocked. DRIVING : Press to unlock door .
ANTI-HI JACK MODE: Press to disarming mode of antihijack .
NORMAL OR CAUTIONARY MODE: When keeping pressing the key for 2 seconds
The baggage compartment at the back is opened automatically .
3, © MUTE SECURITY
STANDARD: Press to lock the door. with enter mute security mode. DRINVING: Still Press for two seconds to enter antihijack mode.
4, CAR LOCATOR FIRE STARTER
STANDARD OR ARMED: Press once, the siren will chirp 15 " .with lights flashing for car location identity, until press any button to release.
DRIVING: Press © once, the siren will chirpl 5 " .with lights flashing for assist, until press any button to release.
MAIN FUNCTIONS
1 - STANDARD(AUDIBLE&VISIBLE)ARMING
Press ® to lock the door ,5 " later the system will enter Standard security mode with
siren chirping and lights flashing. 2. MUTE SECURITY ARMING
Press @ to lock the door, 5" later. the system will enter mute security mode only
with lights flashing. 3* TRIGGER WARNING
^"^-^"Trigger type Arming status"*^^ Trigger by impacting Trigger by switch ignKion(door\acc.on.foot braking)
Standard Arming siren alarming for 30 " the starter-kill locked with lights flashing and for avoidingignition.
Mute arming Lights flashing for 30 " and thestarter-kill locked for avoiding ignition. Siren alarming for 30 " with lights flashingand the starter-kiit locked for avoiding ignition
4. RECYCLE MUTE SECURITY ARMING
When alarming,press lock® or mute® keys pause sounding but system still under cautionary mode.press unlocks ($) key remove alarm. 5, DISARMING & AUTOMATIC REARMING
Press @ once to disarm. and the door unlocked, if the alarm is disarmed accidentally, it will automatically resume to last armed status if the car isn' t opened within 25 ".
OTHER FUNCTIONS
1. ANTI-HIJACK MODE
When a driver feels threatened during driving,he can press @ for 2 "to activate antihijack mode, then turn signal lighting 2.5 scconds.at the sametime,driver can pressing (£) then speakers sounding and turn signal twinking,system enter into antihijack mode.press© remove arm.
2. EMERGENCY(adopted by four buttons)
When feel worry during driving, press © for 2 ". the siren will Chirp30 " with the lights flashing until press any button to release. 3, ARMING REMIND
When parking, the alarm will beep three times with the lights flashing in 10 " after all the doors are closed to remind you to arm the system.
4, DOOR STATUS REMINDER
If door is not closed properly when set arming, the siren and lights will indicates three times for reminding, you shall check and reclose the door, otherwise. the siren will go off in 10.
5, CENTRAL LOCK AUTOMATION
After the car starting riding for 15 ". the central lock will lock automatically upon foot braking, when ignition OFF, the central lock will unlock automatically.When driving, you may also press ® to lock or @ to unlock the door.
6, REMOTE CONTROL FOR OPENING BAGGAGE COMPARTMENT:
When cautionary or parking mode, keeping pressing the key @ for 2 seconds, the baggage compartment is opened automati cally .which makes it convenient for carrying baggage
7, EMERGENT REMOVAL BUTTON:
In the state of alert against theft of the car, if the remote control panel Is lost, the alert must be removed emergently .The car owner must use key to open the door, while the burglar alarm horn works.Then turn the key to the position of ignition, and open and close the door for three times continuously while keeping stepping on the foot brake, thus removing the alert of antitheft system.
8, CAR LOCATION (adopted by four button)
Press © once, the siren will chirp 15 "with light flashing for car location identity. But can press any button to release.
9, TRIGGER STATUS MEMORY
(1 )Under cantionary mode,press and keys and car engine start while speaker sounds and turn signal twinklel tims.it will start again,2times if cannot start succcssfully.the car shall be in cautionary mode under 3 times failure on start with indication of sounds 2 times.speakers sounds 4 times and turn signal twinklel times if hand brake not on duty.system will back to cautionary mode(Remote start warm up cool down,user have to put the car on free gear also pulled hand brake,otherwise,there will be accident ,and we never be responsi bility to this matter.the normal warming up time about 5 minutes,there is 3 times start chance,you can check followings reasons start in 3 times normally)
1 )Check the electric souree lines connections between fire line toACC and relay. 2)Make sure if there is need to pull winddoor under cold car
3)Check the connections of purple testing line (2)After start successfully .press ©car engine will off and back to cautionary mode.If user have not press® ® and also not open car door and acc electric door lock,engine will be off in 5 minutes while speaker sounds
2 times,system back to cautionary automatically.system back to cautionary mode.(If user not press @ then open the car door or ACC electric door lock make engine off autom atically.system back to cautionary mode.) (3)Upon ignition,press® to unlock then switch on ACC power for driving system shall enter back to standard mode after warning once with flash in 30 seconds if ony unlock or press® to open your car door but not switch on acc power.
10, POWER-OFF MEMORY
The system will remember all the data be fore power off .and resume to the last status in 5 "after system is repowered, this feature is to defeat a thief who tries to steal by destroying the power supply system.
11, PARKING REMINDER
Direction lights flashing against door opening during parking, the direction lights will flash upon door opening as warning and reminding purpose for the comings behind.
12, SMART LED INDICATOR ARMED: LED flash twice, pausel"
TRIGGERED BY IMPACT: LED flash three times, pausel" TRIGGERED BY SWITCH IGNITION, LED flash 2 " .pause 2 " DISARMING BY TRIGGERED: LED stay solid flash 3 "
13, LEARNING ROUNTINE
Link the special short circuit fool of learning remote on main unit, press any key on this remote, and after learning two of those, then you can check the remote whether works or not by pressing any key onit and thus check this learning process success or not. Besides all old remotes will be delete if the news are learn.что к чему ничего не понимаю по английски,а перевести грамотно нигде не могу.
