Kustoji написал(а):Респект! А что за версия?
Kustoji написал(а):Версия эльзы?
;VAG-COM Measuring Block Labels for
;Digifant 1.82 ADD
;Kustoji
0,0,Measuring block
0,1,Vozduh Temp,80...6
0,2,Batt Voltage,128...160
0,3,Coolant Temp,12...4
0,4,Motor nagruzka,40...80
0,5,Lambda Signal,100...255
0,6,Lambda Time Regl
0,7,Lambda Status,0...126
0,8,DPDZ Voltage,11...103
0,9,Injection Time,3...6
0,10,Engine Speed,213...205
1,0,General Engine Data
1,1,Engine Speed,760...840/min
1,2,Coolant Temp,85...108C
1,3,Lambda Sensor,0.00...1.00V
1,4,BIN,--------
;1,4 BIN
; --1----- = kondicioner vkl
; ----1--- = oshibka Lambda regul
; -----1-- = DPDZ vne zony izmerenija
; ------1- = Engine Speed 2000/min
; -------1 = Coolant Temp nige 85C
2,0,General Engine Data
2,1,Engine Speed,760...840/min
2,2,Injection Time,2.00...3.00ms
2,3,Batt Voltage,12.00...15.00V
2,4,Vozduh Temp,20...100C
3,0,General Engine Data
3,1,Engine Speed,760...840/min
3,2,Znachenie obuchenija SHH,19...60%
3,3,Injection Time,2.00...3.00ms
3,4,Otkritie KSHH,0
4,0,General Engine Data
4,1,Engine Speed,760...840/min
4,2,Engine Load,19...31%
4,3,---
4,4,BIN,--------
;4,4 BIN
; 1------- = Vprysk active
; -1------ = Vprysk free
; ----1--- = Pusk, vprysk cherez 180gr
; ----0--- = Pusk, vprysk cherez 360gr
5,0,Throttle Controll
5,1,Engine Speed,760...840/min
5,2,Adsorber,...%
5,3,Signal potreblenija,---
5,4,Sootnoshenie davlenija,174...182
6,0,General Engine Data
6,1,Engine Load,40...80
6,2,Prikladnoe znachenie obuchenija,100...180
6,3,Znachenie obuchenija SHH,19...60
6,4,Znachenie DPDZ pri sbrose,11...103
7,0,General Engine Data
7,1,BIN,--------
7,2,---
7,3,BIN,--------
7,4,BIN,--------
;7,1 BIN
; -----1-- = obogashenie pri DPDZ 100%
; -------1 = vysokie oboroty na HH
; -------0 = nizkie oboroty na HH
;7,3 BIN
; ----0--- = ruchnaja korobka
; ----1--- = avtomat
;7,4 BIN
; ----1--- = DPDZ G69 defect
; ------1- = DTVV G72 defect
; -------1 = MAP G71 defect
8,0,General Engine Data
8,1,Engine Speed,760...840/min
8,2,Obogashenie HH kondicioner vkl,0
8,3,Obogashenie pri uskorenii,0
8,4,Znachenie obuchenija SHH max,16...80
9,0,General Engine Data
9,1,BIN,--------
9,2,Obogashenie HH pri puske holodnogo,0
9,3,Obogashenie HH pri puske progretogo,0
9,4,Obogashenie HH holodnogo,0
;9,1 BIN
; ------01 = motor teplyi
; ------10 = motor gorjachyi
; ------00 = motor holodnyi
10,0,General Engine Data
10,1,Engine Speed,760...840/min
10,2,Engine Load,40...80
10,3,Injection Time,2.00...3.00ms
10,4,---
11,0,General Engine Data
11,1,Vozduh Temp,20...100C
11,2,Coolant Temp,85...108C
11,3,Engine Speed,760...840/min
11,4,Injection Time,2.00...3.00ms
12,0,General Engine Data
12,1,Coolant Temp,85...108C
12,2,Engine Speed,760...840/min
12,3,Engine Load,40...80
12,4,Injection Time,2.00...3.00ms
13,0,General Engine Data
13,1,Znachenie obuchenija SHH max,3...36
13,2,Znachenie obuchenija SHH min,8...36
13,3,Batt Voltage,12.00...15.00V
13,4,Engine Speed,760...840/min
14,0,General Engine Data
14,1,Lambda regulirovanie,0.255
14,2,Lambda regulirovanie,~
14,3,Lambda Sensor,0.00...1.00V
14,4,Injection Time,2.00...3.00ms
15,0,General Engine Data
15,1,Engine Load,40...80
15,2,DPDZ naprjagenie,11...103
15,3,Znachenie DPDZ pri sbrose,11...103
15,4,Engine Speed,760...840/min
16,0,General Engine Data
16,1,BIN,--------
16,2,BIN,--------
16,3,BIN,--------
16,4,BIN,--------
;16,1 BIN
; ----11-- = rabota neprogretogo dvigatelja
; ----10-- = smes` bogataja
; ----00-- = smes` bednaja
;16,2 BIN
;16,3 BIN
; -1------ = polnaja nagruzka
; --0----- = lambda regulirovanie ne aktivno
; ------11 = NTC2 sensor Coolant Temp defect
; ------01 = proverochnyi regim
; ------00 = rabochyi regim
;16,4 BIN
; -------1 = kondicioner vkl
ECU-1 - Стартер "+" (красный-зеленый) - F/5 + коричневый-красный
ECU-2 - ДК "сигнал" (черный)
ECU-3 - Реле топливного насоса "-" (желтый-голубой) - G1/3 (контакт реле 3/85)
ECU-4 - КСХХ "-" (белый) ("+" черный G2/4 "S15 10A")
ECU-5 - Клапан Адсорбера "-" (зеленый-желтый)-("+" красный G2/9)
ECU-6 - ДТВВ (коричневый-черный)
ECU-7 - ДПДЗ "-" (коричневый-красный => коричневый-белый)
ECU-8 - Датчик Холла "+" (красный-белый)-("-" коричневый-белый ECU-7)
ECU-9 - ДТВВ (голубой-белый)
ECU-10 - ДТОЖ (коричневый-зеленый)-("-" коричневый-белый ECU-7)
ECU-11 - ДПДЗ (красный-голубой)
ECU-12 - Форсунки "-" (коричневый-желтый) рампа (коричневый)-("+" красный Z1 реле топливного насоса)
ECU-13 - Выход температуры ОЖ для панелей с МК (желтый-красный) G2/3 => U2/9 => панель приборов T28/23
ECU-14 - Питание ECU через реле "+" (черный-желтый) (контакт реле 6/87)
ECU-15 - Муфта кондиционера (зеленый)
ECU-16 - Выход сигнала скорости для панелей с МК (белый-желтый) => (голубой-белый) W/1 => U2/2 => (пурпурный) панель приборов T28/7
ECU-17 - ДПДЗ (красный-белый)
ECU-18 - Датчик Холла "сигнал" (зеленый-белый)
ECU-19 - ДК "-" (красный) + экран (черный)
ECU-20 - "К-линия" (серый-белый)
ECU-21 - Выход сигнала расхода топлива для панелей с МК (пурпурный-черный) => панель приборов T28/26
ECU-22 - Включение реле контроллера "+"
ECU-23 - МЗ "управление" (зеленый-красный)-("+" черный G1/4 + ДС (черный-белый)-("-" коричневый)
ECU-24 - Сигнал на авт.коробку (зеленый-черный) G1/12
ECU-25 - Сигнал на авт.коробку (желтый-красный)
Подогрев ДК
"+" (красный-белый) C1/8 "S18 20A"
"-" (коричневый-черный)
Замок зажигания
"30" Аккумулятор (черный-желтый)
"15" Зажигание (черный)
"Х" Разгрузка (черный-голубой)
"50" Стартер (красный-черный)
