Сброс межсервисных интервалов автомобилей VW при помощи кнопок на приборке
  • Автор темы ten70
  • Ответы 38
  • Просмотры 282К
ten70
ten70
Оракул
AD1 R-Line TDI
VW Beetle 1998 – 1999
OEL or OIL – Oil service
1. Press and hold Button A
2. Switch ignition on
3. The letters OEL or OIL will appear
4. Release button A
5. Press and release button A
6. The letters INSP will appear in the display
7. Press and hold button A until --- appears
8. Release button A
INSP – Inspection service
1. Press and hold button A
2. Switch the ignition on
3. The letters INSP will appear
4. Release button A
6. The letters OEL or OIL will appear
8. Release button A
If required clear the OEL or OIL indicator as described above
VW Beetle 1999 – 2000
3. Release button A
4. The letters “service” will appear in the display
5. Press and hold button A until the word “service” is erased
6. Switch ignition off
VW Beetle 2000 – 2002
Vehicles on fixed interval servicing can be reset as follows:
3. Release button A
6. Switch the ignition off
VW Lupo 1998 – 2002
VW Polo 1999 – 2002
VW Polo Classic / Estate 1999 – 2002
OIL – Oil service
3. Keep button A depressed until --- appears in the display
4. Release button A
5. Switch ignition off
4. Release button A
6. If required clear the OIL indicator as previously described
VW Polo (excluding 1.9D AEF engine) 1994 – 1997
VW Polo Classic / Estate (excluding 1.9D 1Y engine) 1996 – 1999
VW Golf/Vento/Cabrio(excluding 1.9D 1Y engine 1996 -)1991 – 2002
VW Caddy (excluding 1.9D 1Y engine) 1996 – 2002
OEL – Oil service
1. Switch the ignition on
2. Press and hold button A
3. Release button A
4. The letters OEL will appear
5. Press the clock minute button B until ------ appears in the display
6. Switch the ignition on until the letters IN00 appear in the display
IN01 – Inspection service
3. Switch the ignition off
4. Release button A
6. The letters IN01 will appear
7. Press clock minute button B until ------ appears in the display
8. Press button A to display OEL
9. Press button B to display -------
10. Switch on the ignition until the letters IN00 appear in the display
IN02 – Inspection service
4. Release button A
5. The letters IN01 will appear
6. Press clock minute button B until ------ appears in the display
7. Press button A to display IN01
8. Press button B to display ------
9. Repeat the procedure to reset OEL
10. Switch the ignition on until the letters IN00 appear in the display
VW Polo 1.9D (AEF engine) 1995 – 1997
VW Polo Classic / Estate (1Y engine) 1996 – 1999
VW Golf / Vento 1.9D (1Y engine) 1996 – 1999
VW Caddy 1.9D (1Y engine) 1996 – 2002
OEL – Oil service
4. Release button A
5. The letters OEL will appear
7. Switch the ignition on until the letters INSP-0 appears in the display
INSP-1 – Inspection service
2. Press and hold button a
4. Release button A
5. The letters INSP-1 will appear
7. Press button A to display OEL
9. Switch ignition on until the letters INSP-0 appear in the display
INSP-2 – Inspection service
4. Release button A
6. The letters INSP-2 will appear
8. Press button A to display INSp-1
10. Repeat the procedure to reset OEL
11. Switch the ignition on until the letters INSP-0 appear in the display
VW Polo 1998 – 1999
OIL – Oil service
3. Keep the button depressed until ---- appears in the display
4. Release button A
5. Switch the ignition off
3. Keep button A depressed until ---- appears in the display
4. Release button A
6. If required clear the OIL indicator by following previous procedure
VW Golf / Bora 1997 – 1999
OIL – Oil service
3. The letters OIL will appear
4. Release button A
5. Turn button B to the right until ------ appears
4. Release button A
7. Turn button B to the right until ------ appears
8. If required clear the OIL indicator by following the previous procedure
VW Golf / Bora 1999 – 2000
VW Passat 1999 – 2000
3. The word service will appear
4. Release button A
5. Turn button B to the right to reset the display
VW Passat 1996 – 1999
OEL – Oil service
3. Release button A
4. The word OEL will appear in the display
5. For models with a digital clock turn button B to the right until ---- appears in the display
6. For models with an analogue clock pull out button B until ---- appears in the display
1. Press ad hold button A
3. Release button A
4. Press and release button A
5. The work INSP will appear in the trip recorder
6. For models with a digital clock turn button B to the right until ---- appears in the display
7. For models with an analogue clock pull out button B until ---- appears in the display
8. If required clear the OIL or OEL indicator as previously described
VW Golf / Bora 2000 - 2002
VW Passat 2000 – 2002
VW Sharan 2000 – 2002
Vehicles on fixed interval servicing can be reset as follows.
4. Release button A
VW Sharan (models with trip computer) 1995 – 2000
OEL – Oil service
3. Four dashes will appear in the display
4. Switch the ignition off
5. Release button A
1. Press and hold reset button A
5. Release button A
6. Clear the OEL indicator as previously described
5. Release button A
6. Clear the OEL and IN01 indicators as previously described
VW Sharan (models with adjustment button for trip recorder) 1995 – 2000
4. Release button A
5. Turn button B to the right until the word service is erased
VW Transporter T4 1999 -
OEL – Oil Service
3. Release button A
4. The word OEL or OIL will appear
5. Turn button B to the right until ---- appears in the display
3. Release button A
VW Transporter TDI 05 1999 – 2002
VW Transporter V6 24V 2000 – 2002
4. Release button A
Info:
Vehicles with long life service intervals (some Audi/Skoda/Seat/VW) cannot be reset using these procedures, only cars (some Audi/Skoda/Seat/VW) with fixed interval servicing can be reset. It’s a VAG thing.
I take No Responsibility over your actions whatever may happen, you reset your service light at your own risk
If your service light wont go out on your first try have a few tries sometimes its hard to do.
Please note where “– “is shown, this means tested up to year 2002
I hope you find these procedures informative and useful.
Disclaimer
Resetting your service light is not a substitute for servicing your vehicle. Obey your manufacturer's suggested service intervals.
KSE написал(а):
А как на 5 гольфе скинуть эти показания? Спасибо!
C vwvortex:
Service indicator can be reset without a VAG COM.
Here's how:
1. Keys out of ignition- press and hold in trip odometer reset button "0.0" on right hand side of display
2. Still holding this button down, insert key into ignition and put to the on position without starting the car.
3. Display will read "service now"
4. let go of the "0.0" button and depress the "m" button on the left hand side of the display. this will re-set the service reminder. There is no confirmation on the display other than the words "service now" will disappear.
You can confirm that the service reminder has been reset, or check how many miles/days remain until service at any time by taking key out of the ignition and holding in the trip reset "0.0" button for between 3 and 5 seconds. The MFD will display miles and hours until next service.
Обнуление Service-индикатора (индикатора периодичности ТО) на VW Passat B5
Когда наступает срок проведения очередного техобслуживания на нижнем счетчике
(счетчике суточного пробега) спидометра загорается одно из следующих обозначений
требуемого вида технического обслуживания:
– смена масла – service OEL или service Oil;
– инспекционное обслуживание – service INSP.
Приблизительно через минуту после запуска двигателя исчезает показание обозначения
необходимого технического обслуживания.
Сервисное предприятие Фольксваген, которое проводит техническое обслуживание
после осуществления работ, используя специальное оборудование V.A.G. 1551,
устанавливает service-индикатор в исходное (нулевое) положение.
Если техническое обслуживание было проведено не в сервисном предприятии
Фольксваген, сервис-индикатор следует установить в исходное положение.
Кнопка (1) обнуления service-индикатора, показания которого высвечиваются на индикаторе суточного пробега (2)
Расположение кнопки (1) установки часов и управления service-индикатором
ПОРЯДОК ВЫПОЛНЕНИЯ
1. При выключенном зажигании нажмите, и удерживайте в нажатом положении, кнопку установки на нуль под спидометром, см. рис. Кнопка (1) обнуления service-индикатора, показания которого высвечиваются на индикаторе суточного пробега (2). 2. Включите зажигание и отпустите кнопку установки на нуль лишь тогда, когда на
дисплее появятся штрихи – одно из изображений необходимого вида технического
обслуживания. Если повторно нажать кнопку установки на нуль, то service-индикатор переключится на режим service INSP, см. рис. Расположение кнопки (1) установки
часов и управления service-индикатором.
3. Минутную кнопку установки часов с цифровой индикацией поверните вправо, а на
часах со стрелочной индикацией кнопку вытяните. На дисплее появится следующая
индикация "service–".
4. Выключите зажигание.
____________________
Предупреждение
При отключенной аккумуляторной батарее показания service-индикатора после
техобслуживания сохраняются.
Если после ремонта сменен спидометр необходимо заново запрограммировать service-индикатор.
Эта операция должна осуществляться в сервисном предприятии Фольксваген. Если же service-индикатор заново не запрограммирован, необходимо проводить работы по техническому обслуживанию автомобиля по "Сервисной книжке" а не по service-индикатору.
Оригинал
Обнуление Service-индикатора (индикатора периодичности ТО) на VW Golf III/Polo 6N1
Включив зажигание своего автомобиля вы обнаруживаете, что на дисплее высвечиваются следующие символы: OEL, IN01 или IN02. Что же они обозначают:
OEL - пришла пора менять масло в двигателе;
IN01 - пора провести техническое обслуживание (ТО-1);
IN02 - пора провести техническое обслуживание (ТО-2).
Сброс OEL (замена масла) производится так:
• Включить зажигание
• Нажать и удерживать кнопку (А)
• Выключить зажигание
• Отпустить кнопку (А)
• На дисплее одометра спидометра высветятся буквы "OEL"
• Нажать кнопку минут часов (В) пока на дисплее не высветится "----"
Сброс IN01 (диагностика) производится так:
• На дисплее одометра спидометра высветится "IN01"
• Как описано выше, сбросить индикатор "OEL"
Сброс IN02 (диагностика) производится так:
• На дисплее одометра спидометра высветится "IN02"
• Как описано выше, сбросить индикатор "OEL" и "IN01"
Обнуление Service-индикатора (индикатора периодичности ТО) на VW Sharan
• Нажать кнопку сброса (А)
• На дисплее высветитятся четыре прочерка "----"
• Нажать и держать кнопку сброса (А)
• На дисплее высветиться четыре прочерка "----"
Оригинал здесь.
Сброс интервалов ТО VW Polo 1.2 12v, Skoda Fabia и многих других
PS Огромный респект! ten70 & Admin
Ребята, скажите как это сделать на Шкоде Октавии Тур 1U 2008г.
Прочитайте эту тему, в ней разговор идет о VW... :rtfm:
О сеатах здесь:
По остальным ищите похожую приборку и пробуйте или ищите инфу сами.
Нажимал, держал, зажигание включал, ждал - ни чего не изменилось......
Что-ли только через шнурок можно сбросить?
Уважаемые Фольцеводы подскажите пожалуйста на Джетте 2008г на дисплее пробега при включении зажигания вылезла такая хрень: изображение рожкового ключа и под ним 7700 км, через несколько секунд добавляется изображение часов и под ними 20.может кто сталкивался? :unknw: пробег больше 11000км.
оказалось что эт межсервисный интервал сбрасывается так же. просто про такие значки нигде не читал. :blum:
Подскажите пожалуйста, как это сделать на Пассате В6 2008г. Заранее благодарен!
А на phaeton 2006г как сбросить, не подскажете?
Большое спасибо за данную информацию :good: Помогло сбросить сервис на моей Борьке.
Добавлю для сброса сервисного интервала на VW-Jetta 2007 года
на панели загорается "гаечный ключ"
СБРОС ИНТЕРВАЛА
- при выключенном зажигании нажимаем и удерживаем нажатой клавишу сброса [0.0]
-Включаем зажигание
-отпускаем клавишу сброса счетчика суточного пробега и в течении 20 секунд нажимаем клавишу настройки времени [MIN]
И это все. данные сброшены, на дисплее ничего не увидешь и не происходит
для КОНТРОЛЯ сбросился интервал или нет, а также можно посмотреть сколько чего осталось до ТО, если перед числами стоит знак "-" значит ТО просрочено или не было сброшено делаем:
-Зажигание выключено, авто не подвижно
- нажимаем и удерживаем клавишу [0.0] дольше 2 секунд на дисплее появиться км до ТО дни до ТО
При обнулении Service-индикатора на VW Sharan нажал чего то лишнего. Теперь все измерения идут в милях. Если кто знает подскажите как вернуть назад км?
Почему-то у меня ничего не происходит. В чём проблема? У меня Фольксваген Гольф 3 "Мексиканец", может там как-то по особенному?
Сброс индикатора периодичности обслуживания на VW Passat B6:
1. Нажмите и удерживайте кнопку Сервисного меню [1].
2. Не отпуская кнопку включите зажигание и нажмите кнопку min для регулировки часов [2].
3. Выключите зажигание.
Если индикатор периодичности обслуживания сбрасывается вручную, автомобиль кодируется на фиксированный интервал, т.е. через каждые 15.000 км или 12 месяцев.
Как купил машину постоянно горит контрольная лампочка "низкого давления в шинах". Как отключить Эту опцию или привести всё в норму?
VW POLO 2001 г.в. горит service OIL ! сбрасывал по инструкции (нажать кнопку держать, включить зажигание, загорятся черточки, выключить зажигание, отпустить кнопку) все работает по инструкции, но после того как вынешь и вновь вставишь ключ в зажигание вновь загорается service OIL ! уровень масла нормальный ! как убрать сообщение !? только путем провода в сервисе или еще есть способ !? отпишите в Личку кто знает, буду признателен )
