19 Блок CAN шины Gateway, платформа А5 1K0 907 530 L can v 2,0
ten70
ten70
Оракул
AD1 R-Line TDI
Данный блок GATEWAY начиная с индекса L поддерживает блок парктроника с визуализацией в штатных магнитоллах III поколения, адаптивный круиз контроль, а так же совместим с новым поколением магнитолл и навигаций (RCD 310, RCD 510, RNS 510...)
Coding (from Index L)
Byte 00 Bit 0  [01] Engine Electronics
Byte 00 Bit 1  [11] Engine Electronics II
Byte 00 Bit 2  [02] Transmission Electronics
Byte 00 Bit 3  [03] Brake Electronics (ABS)
Byte 00 Bit 4  [53] Parking Brake
Byte 00 Bit 5  [04] Steering Angle Sensor (G85)
Byte 00 Bit 6  [44] Steering Assist
Byte 00 Bit 7  [15] Airbags
Byte 01 Bit 0  [55] Xenon Range
Byte 01 Bit 1  [22] All Wheel Drive
Byte 01 Bit 2  [13] Distance Regulation
Byte 01 Bit 3  [14] Suspension Electronics
Byte 01 Bit 4  [4C] Tire Pressure Monitoring II
Byte 01 Bit 5  [10] Park/Steering Assist
Byte 01 Bit 6  [32] Differential Locking
Byte 01 Bit 7  [17] Instrument Cluster
Byte 02 Bit 0  [25] Immobilizer
Byte 02 Bit 1  [09] Central Electronics
Byte 02 Bit 2  [46] Central Convenience
Byte 02 Bit 3  [42] Door Electronics (Driver)
Byte 02 Bit 4  [52] Door Electronics (Passenger)
Byte 02 Bit 5  [62] Door Electronics (Rear Left)
Byte 02 Bit 6  [72] Door Electronics (Rear Right)
Byte 02 Bit 7  [36] Seat Memory (Driver)
Byte 03 Bit 0  [65] Tire Pressure Monitoring
Byte 03 Bit 1  [16] Steering Wheel Electronics
Byte 03 Bit 2  [08] Climate Control
Byte 03 Bit 3  [76] Park Assist
Byte 03 Bit 4  [7D] Auxiliary Heating
Byte 03 Bit 5  [26] Auto Roof
Byte 03 Bit 6  [69] Trailer
Byte 03 Bit 7  [06] Seat Memory (Passenger)
Byte 03 Bit 0  [3D] Special Function
Byte 04 Bit 1  [6D] Trunk Electronic
Byte 04 Bit 2  [63] Easy Entry Driver Side
Byte 04 Bit 3  [73] Easy Entry Passenger Side
Byte 04 Bit 4  [47] Sound System
Byte 04 Bit 5  [75] Telematic/Emergency Call
Byte 04 Bit 6  [37] Navigation
Byte 04 Bit 7  [57] TV-Tuner
Byte 05 Bit 0  [0F] Radio (digital)
Byte 05 Bit 1  [56] Radio (analog)
Byte 05 Bit 2  [77] Telephone
Byte 05 Bit 3  [18] Auxiliary Heater
Byte 05 Bit 4  [1C] Position Sensing
Byte 05 Bit 5  [5D] Operations
Byte 05 Bit 6  [6C] Rear View Camera
Byte 05 Bit 7  [59] Tow Protection
Byte 06 Bit 0  [4F] Central Electronics II
Byte 06 Bit 1  [19] CAN-Gateway (Standard)
Byte 06 Bit 2  [3C] Lane Change Assist
Byte 06 Bit 3  [5C] Lane Maintenance Assist
Byte 07  Manufacturer/Model
Byte 08  Options
Расширенная индификация:
Измеренные блоки:
Длинные коды:
Расположение контактов J533 - диагностического интерфеиса шины данных:
Контакт 1 Клемма 30, предохранитель F24 в коммутационном блоке
Контакт 2 как контакт 1
Контакт 3 не используется
Контакт 4 K- провод (не используется)
Контакт 5 Шина данных Комфорт, CAN-Low
Контакт 6 Шина данных Привод, CAN-Low
Контакт 7 не используется
Контакт 8 Шина данных комбинации приборов, CAN-Low
Контакт 9 Диагностика CAN, CAN-Low
Контакт 10 Шина данных Infotainment, CAN-Low
Контакт 11 клемма 31 (минус АКБ)
Контакт 12 клемма 31 (минус АКБ)
Контакт 13 Проводка активации комбинации приборов
Контакт 14 Клемма 15
Контакт 15 Шина данных Комфорт, CAN-High
Контакт 16 Шина данных Привод, CAN-High
Контакт 17 не используется
Контакт 18 Шина данных комбинации приборов, CAN-High
Контакт 19 Диагностика CAN, CAN-High
Контакт 20 Шина данных Infotainment, CAN-High
Тоесть с индексом Р уже должен работать РНС510, но если погуглить то пишет что 1K0 907 530P 0192 будет разряжать АКБ, где правда?
У меня с буквой М но распиновка явно не такая. Где можно взять правильную?
У чайников всегда что то не так. Они наверно думают, что сами особенные и соответственно все остальное тоже. :LOL:
Хватит срать в обеих темах про гейты. Гугл в нью-васюках такой же как и у всех остальных. :LOL:
Вам не лень извергать из себя продукты жизнедеятельности?
Скачал Эльзу. Там схема оказалась более правильная. Ошибся одним пином когда разъём собирал. В лоб машина не завелась.
Прошу помощи ?
Не отвечают 09 блок и обе задние двери
Достал BCM разобрал, внутри все хорошо. Сегодня проверю питание
Заводится пытается но очень лениво
Чую пора в другую ветку, гетвэй у меня теперь в порядке
