Вообще то сначало датчик давления тормозов попробуй поменять, отрицательного давления не может быть.
Это лишь показывает, что с ним проблема.
Basic Setting
Sensor for Steering Angle (G85)
Prerequisites:
* Start the vehicle.
* Turn the steering wheel one turn to the right and one turn to the left.
* Drive in a short distance straight line on a level surface at a speed not higher than 20 km/h.
* If the steering wheel is straight during the test drive then stop the vehicle with the wheels pointed straight.
* Ensure that the steering wheel is not moved again.
* Keep the engine running and do not switch off the ignition.
* System voltage at least 12.0 V.
[Select]
[03 - Brake Electronics]
[Coding-II - 11]
OR (if Coding-II is not available)
[Security Access - 16]
Enter 40168, to enable the basic setting.
[Do it!]
[Basic Settings - 04]
Group 060
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
After a successful basic setting, field 2 should say "OK".
[Done, Go Back]
To make sure the basic setting was succesful, check the sensor again.
[Measuring Blocks - 08]
Group 004
[Go!]
Check field 1, the value has to be between -1.5 and +1.5 °.
[Done, Go Back]
[Close Controller, Go Back - 06]
Note: After successful basic setting, the Steering Limit Stop needs to be adapted too.
Lateral Acceleration Sensor (G200)
Prerequisites:
[Select]
Group 004
[Go!]
Check field 2, the value has to be between -1.5 and +1.5 m/s².
[Done, Go Back]
[Coding-II - 11]
[Do it!]
Group 063
[Go!]
[ON/OFF/Next]
[Done, Go Back]
Group 004
[Go!]
[Done, Go Back]
Brake Pressure Sensor 1 (G201)
Prerequisites:
[Select]
Group 005
[Go!]
Check field 1, the value has to be between -8.0 and +8.0 bar.
[Done, Go Back]
[Coding-II - 11]
[Do it!]
Group 066
[Go!]
[ON/OFF/Next]
[Done, Go Back]
Group 005
[Go!]
Check field 1, the value has to be between -3.8 and +3.8 bar.
[Done, Go Back]
Longitudinal Acceleration Sensor (G251)
Prerequisites:
[Select]
Group 004
[Go!]
Check field 4, the value has to be between -1.5 and +1.5 m/s².
[Done, Go Back]
[Coding-II - 11]
[Do it!]
Group 069
[Go!]
[ON/OFF/Next]
[Done, Go Back]
Group 006
[Go!]
Check field 1, the value has to be between -1.5 and +1.5 m/s².
[Done, Go Back]
Tire Pressure Monitoring System Reset
Prerequisites:
* Ignition ON
[Select]
Group 042
[Go!]
[ON/OFF/Next]
[Done, Go Back]
