mishustik
Wednesday,04,February,2009,12:53:13:28503
VCDS Version: Release 805.1
Data version: 20080823
Address 01: Engine
Control Module Part Number: 7L0 907 401 F
Component and/or Version: 3.0L V6TDI G000AG 0040
Software Coding: 0011775
Work Shop Code: WSC 31414
1 Fault Found:
013128 - Control Circuit for Controller for Turbocharger 1 (J724): Electrical Malfunction
P3348 - 005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 0
Fault Frequency: 52
Mileage: 18966 km
Time Indication: 0
Date: 2008.12.02
Time: 00:17:52
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Temperature: 13.5°C
Duty Cycle: 80.9 %
Voltage: 11.93 V
Duty Cycle: 88.8 %
Readiness: 1 1 0 0 0
Address 19: CAN Gateway
Control Module Part Number: 6N0 909 901
Component and/or Version: J533 GW-K-CAN TP20 7018
Software Coding: 7FE2E78940056002
Work Shop Code: WSC 00161
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 9
Reset counter: 50
Mileage: 18966 km
Time Indication: 0
Date: 2008.12.02
Time: 00:01:43
Address 03: ABS Brakes
Control Module Part Number: 7L0 907 379 K
Component and/or Version: ESP ALLRAD MK25E1 0302
Software Coding: 0004482
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 43
Reset counter: 10
Mileage: 18966 km
Time Indication: 0
Date: 2008.12.02
Time: 00:14:20
Freeze Frame:
Count: 128
Count: 4353
Count: 294
Count: 1
Address 17: Instruments
Control Module Part Number: 7L6 920 885 J
Component and/or Version: J0285 KOMBI-INST. 7018
Software Coding: 0007101
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 9
Reset counter: 50
Mileage: 18966 km
Time Indication: 0
Date: 2008.12.02
Time: 00:01:43
Более всего волнует первая ошибка по двигателю. Я так понял это блок управления поворотными лопатками турбины. Вроде как адаптацию просит. Как? Как-бы ее побороть.
Машинка была стукнута. И пришлось запускать двигатель со снятым интеркулером. Датчики с интеркулеров не отсоединялись. Хотя может быть она проявилась и в другое время. Но я предполагаю, что именно из-за этого. Ну и если по остальным ошибкам подскажете, то-же огромное спаибо, хотя по ним инфу кое-какую нарыл.
Address 01: Engine
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 52
Mileage: 18966 km
Time Indication: 0
Date: 2008.12.02
Time: 00:17:52
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Temperature: 13.5°C
Duty Cycle: 80.9 %
Voltage: 11.93 V
Duty Cycle: 88.8 %
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 9
Reset counter: 50
Mileage: 18966 km
Time Indication: 0
Date: 2008.12.02
Time: 00:01:43
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 43
Reset counter: 10
Mileage: 18966 km
Time Indication: 0
Date: 2008.12.02
Time: 00:14:20
Freeze Frame:
Count: 128
Count: 4353
Count: 294
Count: 1
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 9
Reset counter: 50
Mileage: 18966 km
Time Indication: 0
Date: 2008.12.02
Time: 00:01:43
