moiPASSATtdi
Любитель VW
Столкнулся с проблемой по стиранию краша на модуле аербега, прилагаю скан
Chassis Type: 9N - VW Polo
Scan: 01 02 03 08 09 15 17 19 37 44 45 46 56 76
Mileage: 58150km/36132miles
Address 01: Engine Labels: Redir Fail!
Part No: 045 906 019 BP
Component: 1,4l R3 EDC 0000SG 8395
Coding: 00002
Shop #: WSC 00788
WVWZZZ9NZ8Y191107 VWZ5Z0H2111293
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes Labels: 6R0-907-37x-ABS.lbl
Part No SW: 6Q0 907 379 AF HW: 6Q0 907 379 AF
Component: ABS 8.0 front H05 0002
Revision: 00000000 Serial number: 00000000000000
Coding: 0002136
Shop #: WSC 00788 785 00200
Address 08: Auto HVAC Labels: 6Q0-820-045.lbl
Part No: 6Q0 820 045
Component: Klimaanlage X0850
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q2 937 049 F
Component: 0009 BN-SG. 2S36
Coding: 01038
Shop #: WSC 00788
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 K
Component: 17 AIRBAG VW51 0N 0010
Coding: 12599
Shop #: WSC 00788
7 Faults Found
00595 - Crash Data Stored
35-00 - -
01214 - Crash Data for Belt Tensioner Stored
35-00 - -
00588 - Airbag Igniter; Driver Side (N95)
32-00 - Resistance too High
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
33-00 - Resistance too Low
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
00589 - Airbag Igniter 1; Passenger Side (N131)
29-10 - Short to Ground - Intermittent
32-10 - Resistance too High - Intermittent
Address 17: Instruments Labels: Redir Fail!
Part No: 6Q0 920 804 J
Component: KOMBIINSTRUMENT AGD V04
Coding: 01131
Shop #: WSC 00000
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 01K1 GATEWAY CAN 2S36
Coding: 00014
Shop #: WSC 00788
Address 44: Steering Assist Labels: 6Q0-423-156.lbl
Part No: 6R0 423 156
Component: LenkhilfeTRW V272
Coding: 10110
Shop #: WSC 00000
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 E
Component: 5F Komfortgerбt 0002
Coding: 00017
Shop #: WSC 00788
А вот и решение проблемы, подходит практически для любых ЭБУ семейства VAG
1 Надо найти ЭБУ аербека. Обычно он прячется справа от водителя рядом с педалью газа. Можно визуально не видеть, Я нащупал рукой он спрятан за пластмасской номер 2 (См в Ельзе)
позиция номер 3, Клемма поз 2 и гайки поз 1
Откручиваем его (три гайкина 10). (Предварительно отключив клеммы аккумулятора ОБЯЗАТЕЛЬНО) и вытаскиваем клемму. Она жёстко зафиксированна. И несём домой.(Пробовал подключатся в машине через общий разьём не получилось .Диагностика аэрбегов идёт через КАН ,А он сам работает через К линию .
Дома вам понадобится комп или ноут ,Адаптер с + и - на 12 вольт (У меня был на 4,7 А вых. от монитора) И конечно кабель VAGCOM KKL. Лучше с COM портом. Но за неимением я использывал УСБ ККЛ производства КНР .
Схема поключения проста
+12V подаем на ногу 26
"-" - на корпус блока либо нога 51
К-линия - на ногу 54
ИЛИ
либо по простому:
держим блок разъемом к себе:
самый правый пин в нижнем ряду - GND
самый правый пин в верхнем ряду - 12V
первый задействованный пин влево от GND - K-Line
Я "-" сажал на корпус модуля ЭБУ.Внимание запитывать нужно как и модуль так и ККЛ адаптер иначе не работает.
Для поключения модуля я использывал клемки от компа.Знаете такие маленькие .Они подходят от кнопок корпуса компа к матер.плате. Очень удобно. А к Адаптеру ККЛ использывал обыкновенные авто клеммы типа "мамы" (Оторвал где то на разборке).
Запитываем всё и начинается самое интересное
Надо считать дамп, нарыл немного программ...
Лично я смог считать вот этой:
vw_airbag_resseter_tool_1.0.0.1.rar
Скачал прогу VW airbag reset tool. Подсоединил УСБ адаптер к авто и к компу с ОС XP. Потом посмотрел СОМ порт в диспетчере устройств (Здесь внимание). В VW airbag reset tool выбрал СОМ 1 порт.
Подал питание с блока питания на УСБ адаптер и модуль - есть подключние. Но прога air.exe не видит модуль (Она работает через реальный СОМ порт а не FTDI), зато видит другая прога VW airbag resseter tool через COM1 порт.
Нажал кнопку read ecu ver и понеслось
Please wait before open controller ...
open controller... ...
Open controller OK!
Protocol : KWP1281
Reading part number ...
Send Ack to ECU ...
Reading ECU component ...
Send Ack to ECU ...
Send Ack to ECU ...
Please waitting for Coding and WSC ...
Read ECU information OK!
Open controller OK!
Protocol : KWP1281
Send Ack to ECU ...
Send Ack to ECU ...
Send Ack to ECU ...
clear DTC ... ...
Please watting for read DTC ...
DTCs found.0DTC
потом read eeprom, потом save to file (Желательно сделать пару раз и сохранить копию в файл отдельно на всякий пожарный). Получится дамп с расширением *.bin вашего модуля с crash date и кучей ошибок. Далее открыл этот файл в любом hex редакторе(В гугле наберите HEX redaktor Я использывал Hex Editor Neo 4.7), затер нужные сектора значениями FF и 00 (у всех может быть по разному, универсального варианта нет, мне пришлось долго собирать информацию). Ну и в конце концов опять все подсоединил, опять нажал read eeprom, потом load file, потом write eeprom, побежали циферки и ждём окончания. Теперь нужно все обесточить. Все обратно ставим модуль на машину обязательно прикручиваем.Еще один момент, блок не заработает на авто до тех пор, пока не будет прикручен гайками к корпусу авто, поскольку его минус (при рабочем состоянии) это корпус, на ногу в разъеме земля не приходит,подключаем акку, заходим в вагком, стираем ошибки и желтая лампа на приборке гаснет.Можно стереть сразу на столе ВАГКОМом.
Ну и напоследок, те кто захотят работать УСБ адаптером в Висте/ХР со снятым модулем столкнутся с проблемой при комутации. Дело в том что обязательно нужно подавать питание с АКБ как на УСБ адаптер, так и на модуль подушки безопасности, при этом сигнал К-линия нужно брать с 54 пина модуля на 7 пин в колодке ОБД2 УСБ адаптера, иначе просто ничего не будет работать.
При исправлении дампа надо быть черезвычайно внимательным. Обязательно сохраняйте копию вашего дампа. Код модуля даст инфо какая микруха там стоит и как исправлять ваш дамп.Где и что менять. Вот к примеру
Sensor.exe
Menu
R –Com port adress
Defalut COM1 adress 3F8.
T – airbag unit type
6Q0 ...1C0 (hc908)vw5
6Q0 .........C – (hc12)vw6
1J0 ...vw3
6N0...vw2
O – Read EEPROM in airbag unit
Z – Write EEPROM (in screen) to airbag unit
K – clear DTC
W – Version airbag unit
P – File operations:
Z – Save EEPROM to file
O – Read EEPROM in file
airbag 6N0....VW2.
key W -version
key T and choice 6N0....
key O read EEPROM
key P and Z – save backup.
dump
0100: FF 00 8A 00 2E 45 00 FF FF FF 30 33 FF FF FF FF ¦ _.Ő..E.___03____
0110: FF FF FF FF FF FF 51 FF FF FF FF FF FF FF 00 FF ¦ ______Q_______._
0120: FF FF FF FF FF FF B8 FF FF FF FF FF FF FF 08 FF ¦ ______Ş_______ _
0130: FF 00 FF B8 FF FF FF FF FF FF FF FF FF FF FE FE ¦ _._Ş____________
0140: FE FE 08 FF FF FF FF FF FF 04 00 00 00 FF FF FF ¦ __ ______ ...___
0150: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ¦ ________________
0160: AA AA AA AA AA 45 47 29 25 FF FF FF FF FF FF FF ¦ EG)%_______
0170: 80 80 08 04 08 04 04 42 01 CC 04 E1 00 34 03 7E ¦ ÇÇ B ¦ ß.4 ~
0180: FF 02 FF FF FF FF 08 FF FF FF FF FF FF 5C 5C 5C ¦ _ ____ ______\\\
0190: 93 39 76 23 57 32 32 11 57 68 68 68 99 99 66 66 ¦ ô9v#W22 WhhhÖÖff
01A0: 2F 21 21 21 90 FF FC FC FC F4 00 01 7E 00 00 FF ¦ /!!!É_ŘŘآ. ~.._
01B0: 48 76 DE 02 7F 00 DC 01 CC 0E 0C 01 00 00 D6 49 ¦ HvŮ ._ ¦ ..ÍI
01C0: AA 00 7F 05 40 00 01 7E 00 00 FF 48 76 DE 02 7F ¦ . @. ~.._HvŮ
01D0: 00 DC 01 CC 0E 0C 01 00 00 D6 49 AA 00 7F 05 40 ¦ ._ ¦ ..ÍI . @
01E0: 00 01 7E 00 00 FF 48 76 DE 02 7F 00 DC 01 CC 0E ¦. ~.._HvŮ ._ ¦
01F0: 0C 01 00 00 D6 49 AA 00 7F 05 40 81 E8 00 45 AA ¦ ..ÍI . @üŔ.E
$ 0110 - 011F range of DTC-replace to FF. $ 0170 - 0183 (crash data) – replace to FF.
key Z Write EEPROM
airbag 6Q0....., 1C0...VW5.
key W -version
key T and choice 6Q0....
key O read EEPROM
0800: 2F 00 52 7A 01 00 52 7A 05 00 52 7A 03 00 52 7D ¦ /.Rz .Rz .Rz .R} 0810: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ¦ ________________
0820: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ¦ ________________
0830: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ¦ ________________
0840: FF FF FF FF FF FF FF FF 7D FF FF FF FF FF FF FF ¦ ________}_______
0850: FF FF 00 00 51 00 52 00 00 65 00 66 65 93 89 76 ¦ __..Q.R..e.feôëv
0860: 21 00 00 43 41 32 21 66 42 86 5F 30 30 33 30 45 ¦ !..CA2!fBć_0030E
0870: 44 30 4C 50 48 4A 51 FF FF FF FF FF FF FF 30 31 ¦ D0LPHJQ_______01
0880: 20 20 FF FF FF FF FF FF FF FF 00 FF FF FF FF FF ¦ ________._____
0890: FF 9E 9E 9E 9E 9E 9E 3E 2E 2E 2E 2C 2C D4 A9 A9 ¦ _××××××>...,,ďęę
08A0: A9 FB 70 00 03 70 00 03 70 00 03 59 19 08 25 1A ¦ ęűp. p. p. Y %
08B0: 33 8D 10 01 09 0A 50 08 00 1C 00 42 00 01 00 00 ¦ 3Ź P. .B. ..
08C0: 00 00 1A 01 86 09 26 2F 1E 06 41 11 0E 48 37 0A ¦ .. ć &/ A H7
08D0: FF 32 28 3B 01 00 00 00 00 1A 01 86 09 26 2F 1E ¦ _2(; .... ć &/ 08E0: 06 41 11 0E 48 37 0A FF 32 28 3B 73 70 1F 19 08 ¦ A H7 _2(;sp¬ 08F0: 25 1A 33 8D 10 01 09 0A 50 08 00 1C 00 42 00 01 ¦ % 3Ź P. .B. 0900: 00 00 00 00 1A 01 86 09 26 2F 1E 06 41 11 0E 48 ¦ .... ć &/ A H
0910: 37 0A FF 32 28 3B 01 00 00 00 00 1A 01 86 09 26 ¦ 7 _2(; .... ć &
0920: 2F 1E 06 41 11 0E 48 37 0A FF 32 28 3B 73 70 1F ¦ / A H7 _2(;sp¬
0930: 1C B9 31 35 FF FF FF FF FF FF FF FF FF FF FF FF ¦ ¦15____________
0940: FF FF FF FF FF FF FF FF FF FF FF FF 62 6A 03 14 ¦ ____________bj ¶
0950: 00 03 43 15 15 09 00 27 2A 85 16 00 67 00 DC 00 ¦. C§§ .'*ů .g._.
0960: 00 40 00 03 43 15 15 09 00 27 2A 85 16 00 67 00 ¦ .@. C§§ .'*ů .g.
0970: DC 4D 00 40 00 FF FF FF FF FF FF FF FF FF FF FF ¦ _M.@.___________
0980: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ¦ ________________
0990: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ¦ ________________
09A0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ¦ ________________
09B0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ¦ ________________
09C0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ¦ ________________
09D0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ¦ ________________
09E0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF AA ¦ _______________
09F0: 23 0F 55 77 FF 80 7E 82 81 81 80 7E 80 80 80 AA ¦ #¤Uw_Ç~éüüÇ~ÇÇÇ
$0800 - 084F range of DTC-replace to FF.
$0951 - 09EE range of (crash data). replace to FF ( Warning:$0950must be 00 $9EE must be AA)
key Z Write EEPROM
airbag 6Q0..... C, 1C0....F VW6
key W -version
key T and choice 6Q0....C
key O read EEPROM
0D00: 90 00 46 BF 8D 00 46 BF 02 00 46 BF 05 00 46 BF ¦ É.F+Ź.F+ .F+ .F+ 0D10: 21 00 46 BF 25 00 46 BF 56 00 47 11 01 00 47 11 ¦ !.F+%.F+V.G .G 0D20: 09 00 47 11 FF FF FF FF FF FF FF FF FF FF FF FF ¦ .G ____________ 0D30: FF FB FF FF FF 00 FF FF FF FF FF FF FF FF FF FF ¦ _ű___.__________
0D40: FF FF 1A 06 20 B6 20 B6 00 00 09 0D 3F 04 00 07 ¦ __ Â Â.. ? .
0D50: 00 4C 07 01 00 00 00 00 24 00 82 06 26 1B 1A 04 ¦ .L ....$.é &
0D60: 0C 0A 06 1D 10 07 FF 32 37 3C 01 00 00 00 00 24 ¦ _27< ....$
0D70: 00 82 06 26 1B 1A 04 0C 0A 06 1D 10 07 FF 32 37 ¦ .é & _27
0D80: 3C 80 80 7F 1A 06 20 B6 20 B6 00 00 09 0D 3F 04 ¦ <ÇÇ Â Â..
0D90: 00 07 00 4C 07 01 00 00 00 00 24 00 82 06 26 1B ¦ ..L ....$.é &
0DA0: 1A 04 0C 0A 06 1D 10 07 FF 32 37 3C 01 00 00 00 ¦ _27< ...
0DB0: 00 24 00 82 06 26 1B 1A 04 0C 0A 06 1D 10 07 FF ¦ .$.é & _
0DC0: 32 37 3C 80 80 7F 1C 36 30 32 00 06 06 14 14 06 ¦ 27<ÇÇ 602. ¶¶
0DD0: 01 46 0F 30 31 F1 00 06 06 14 14 06 01 46 0F 30 ¦ F¤01˝. ¶¶ F¤0
0DE0: 31 F1 2C 6D 30 31 54 1F 03 CF 45 54 1F 03 CF 45 ¦ 1˝,m01T¬ ¤ET¬ ¤E
0DF0: 03 14 FF FF FF FF FF FF FF FF FF FF FF FF FF FF ¦ ¶______________
$ 0D00 - 0D4F range DTC and crashdata – replace to FF
airbag 1J0....VW3.
key W -version
key T and choice 1J0....
key O read EEPROM
$ B606 – B67E DTC and crash data– replace to FF.
key Z Write EEPROM
Есть прога для сравнения дампов. Лежит здесь:
https://vwts.ru/diag/139733_compfile.rar
Сомрfile Помогает при сравнении дампов
Ну вроде всё.
Coding: 00002
Shop #: WSC 00788
Coding: 0002136
Coding: 01038
Shop #: WSC 00788
Coding: 12599
Shop #: WSC 00788
7 Faults Found
35-00 - -
35-00 - -
Coding: 01131
Shop #: WSC 00000
Coding: 00014
Shop #: WSC 00788
Coding: 10110
Shop #: WSC 00000
Coding: 00017
Shop #: WSC 00788
ИЛИ
либо по простому:
Open controller OK!
Protocol : KWP1281
Send Ack to ECU ...
Send Ack to ECU ...
Send Ack to ECU ...
Open controller OK!
Protocol : KWP1281
Send Ack to ECU ...
Send Ack to ECU ...
Send Ack to ECU ...
clear DTC ... ...
DTCs found.0DTC
Sensor.exe
Menu
R –Com port adress
1J0 ...vw3
6N0...vw2
K – clear DTC
airbag 6N0....VW2.
key W -version
key O read EEPROM
dump
key Z Write EEPROM
key W -version
key O read EEPROM
key Z Write EEPROM
key W -version
key O read EEPROM
airbag 1J0....VW3.
key W -version
key O read EEPROM
key Z Write EEPROM
Ну вроде всё.
