Streaker
УчастничеГ
Сделал диагностику Фольксваген Гольф 4, двиг. AGN, помогите разобраться, что значат эти ошибки?
Address 01: Engine Labels: None
Part No: 06A 906 018 CM
Component: 1,81 R4/5V MOTR HS V02
Coding: 04000
Shop #: WSC 00000
8 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - Intermittent
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-00 - -16502 - Engine Coolant Temp. Sensor (G62): Signal too High
P0118 - 35-10- Intermittent
1249 - Fuel Injector for Cylinder 1 (N30) 29-10 - Short to Ground - Intermittent
1250 - Fuel Injector for Cylinder 2 (N31) 29-10 - Short to Ground - Intermittent
1251 - Fuel Injector for Cylinder 3 (N32) 29-10 - Short to Ground - Intermittent
1252 - Fuel Injector for Cylinder 4 (N33) 29-10 - Short to Ground - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10- Intermittent
Readiness: N/A
Address 08: Auto HVAC Labels: 3Bx-907-044.1bl Part No: 3B1 907 044 A Component: CLIMATRONIC S 9.0 Coding: 01000 Shop #: WSC 01317
2 Faults Found:
01206 - Signal for Duration of Ignition Off Time
35-10 - - - Intermittent 01274 - Air Flow Flap Positioning Motor (V71)
35-10- Intermittent
Address 46: Central Conv. Labels: 1 J0-959-799.1bl Part No: 1J0 959 799 Q Component: 4C Zentral-SG Komf. 0001 Coding: 04097 Shop #: WSC 01317
Part No: 1J1959801C
Component: 4C Txrsteuerger. FSOOOlr
Part No: 1J1959802D
Component: 4C Txrsteuerger. BFOOOlr
Part No: 1J4959811C
Component: 4C Txrsteuerger. HLOOOlr
Part No: 1J4959812C
Component: 4C Txrsteuerger. HROOOlr
2 Faults Found:
00943 - Heated Exterior Mirror; Driver Side (Z4) 35-00- -
00930 - Locking Module for Central Locking; Rear Left (F222) 27-10 - Implausible Signal - Intermittent
Заранее благодарю.
Coding: 04000
Shop #: WSC 00000
8 Faults Found:
Readiness: N/A
2 Faults Found:
35-10- Intermittent
Part No: 1J1959801C
Part No: 1J1959802D
Part No: 1J4959811C
Part No: 1J4959812C
2 Faults Found:
Заранее благодарю.
