Triangle
Оракул
Если с тем что под торпедой всё ясно как и почти ясно с предохранителями в салоне, то по этому ничего толком не могу найти.
No. | Current Flow Diagram designation | Nominal value | Function/component | Terminal | ||
1 | - | S1 - Fuse 1 in fuse holder | 10 A | - | Heated washer jets | X |
2 | - | S2 - Fuse 2 in fuse holder | 10 A | - | Turn signal system and hazard warning lights system | 75x |
3 | - | S3 - Fuse 3 in fuse holder | 5 A | - | Glove compartment light | 58a |
4 | - | S4 - Fuse 4 in fuse holder | 5 A | - | X - Number plate light | 58a |
5 | - | S5 - Fuse 5 in fuse holder | 7.5 A | - | Convenience electrics, cruise control system (GND) Climatronic heated driver seat control unit heated front passenger seat control unit | 15a |
6 | - | S6 - Fuse 6 in fuse holder | 5 A | - | Central locking | 15a |
7 | - | S7 - Fuse 7 in fuse holder | 10 A | - | Reversing light | 15a |
8 | - | S8 - Fuse 8 in fuse holder | 5 A | - | Telephone aerial | 15a |
9 | - | S9 - Fuse 9 in fuse holder | 5 A | - | Anti-lock brake system (ABS) | 15a |
10 | - | S10 - Fuse 10 in fuse holder | 5 A | - | Engine management petrol engines | 30a |
11 | - | S11 - Fuse 11 in fuse holder | 10 A | - | Dash panel insert, selector lever lock solenoid | 15a |
12 | - | S12 - Fuse 12 in fuse holder | 10 A | - | Self-diagnosis connection voltage supply, telephone system | 30a |
13 | - | S13 - Fuse 13 in fuse holder | 10 A | - | Brake lights | 54 |
14 | - | S14 - Fuse 14 in fuse holder | 10 A | - | Interior illumination, central locking | 30a |
15 | - | S15 - Fuse 15 in fuse holder | 5 A | - | Dash panel insert, automatic gearbox | 30a |
16 | - | S16 - Fuse 16 in fuse holder | 10 A | - | Magnetic clutch, radiator fan run-on | 30a |
17 | - | S17 - Fuse 17 in fuse holder | - | - | Vacant | |
18 | - | S18 - Fuse 18 in fuse holder | 10 A | - | Left headlight main beam | 56a |
19 | - | S19 - Fuse 19 in fuse holder | 10 A | - | Right headlight main beam | 56a |
20 | - | S20 - Fuse 20 in fuse holder | 10 A | - | Right headlight dipped beam, headlight range control | 56b |
21 | - | S21 - Fuse 21 in fuse holder | 10 A | - | Left headlight dipped beam | 56b |
22 | - | S22 - Fuse 22 in fuse holder | 5 A | - | Side light right | 58R |
23 | - | S23 - Fuse 23 in fuse holder | 5 A | - | Side light left | 58L |
24 | - | S24 - Fuse 24 in fuse holder | 20 A | - | Windscreen wiper system | 75x |
25 | - | S25 - Fuse 25 in fuse holder | 25 A | - | Fresh air blower air conditioning system, Climatronic | 75x |
26 | - | S26 - Fuse 26 in fuse holder | 20 A | - | Heated rear window heated exterior mirror (for models without electric window regulator) | 75x |
27 | - | S27 - Fuse 27 in fuse holder | 10 A | - | Rear window wiper system | 75x |
28 | - | S28 - Fuse 28 in fuse holder | 15 A | - | Fuel pump / pre-supply pump | 75x |
29 | - | S29 - Fuse 29 in fuse holder | 15 A 10 A | - - | Engine management petrol engines engine management diesel engines | 15a |
30 | - | S30 - Fuse 30 in fuse holder | 20 A | - | Sliding/tilting sunroof | 30a |
31 | - | S31 - Fuse 31 in fuse holder | 20 A | - | Automatic gearbox | 15a |
32 | - | S32 - Fuse 32 in fuse holder | 20 A | - | Engine management, injectors engine management diesel engines | 87 |
33 | - | S33 - Fuse 33 in fuse holder | 20 A | - | Headlight washer system (HWS) | 30a |
34 | - | S34 - Fuse 34 in fuse holder | 10 A | - | Engine management | 87 |
35 | - | S35 - Fuse 35 in fuse holder | 30 A | - | Trailer socket | 30a |
36 | - | S35 - Fuse 36 in fuse holder | 15 A | - | Fog light and rear fog light | X |
37 | - | S37 - Fuse 37 in fuse holder | 10 A | - | S-contact | 86s |
38 | - | S38 - Fuse 38 in fuse holder | 15 A | - | Luggage compartment light, central locking | 30a |
39 | - | S39 - Fuse 39 in fuse holder | 15 A | - | Hazard warning lights system | 30a |
40 | - | S40 - Fuse 40 in fuse holder | 20 A | - | Dual tone horn | 30a |
41 | - | S41 - Fuse 41 in fuse holder | 15 A | - | Cigarette lighter | 30a |
42 | - | S42 - Fuse 42 in fuse holder | 25 A | - | Radio system | 30a |
43 | - | S43 - Fuse 43 in fuse holder | 10 A | - | Engine management | 87 |
44 | - | S44 - Fuse 44 in fuse holder | 10 A | - | Seat heating | 30a |
Uzver© написал(а):Дак там обсуждалось что наверное они... Ну ладно, а реле... Блин некого поставить чтобы послушал их...
yurik_l написал(а):Вам ссылку давали на книжку месяц назад, скачайте и читайте на радость себе и людям![]()
adn1271 написал(а):S162 - Heated pin heating 50 A
S163 - Engine management 50 A
S164 - Radiator fan 40 A
S176 - Interior 110 A
S177 - Alternator (90 A), 110 A
- Alternator (120 A), 150 A
S178 - ABS (pump) 30 A
S179 - ABS 30 A
S180 - Radiator fan 30 A
//ipicture.ru/uploads/080522/YWay6F72K5.png
Uzver© написал(а):Возможно я пропустил но в книжке я не нашел этой коробочки, или англоязычные книжки посмотреть?
yurik_l написал(а):Книжка на русском языке скачивается с этого же сайта из раздела "Документация"![]()
Uzver© написал(а):А может стоит сбавить обороты? Еще раз перечитал всю 12 главу и схемы, нет там ничего про эту коробку.
