Может двигатель DGUA?
Обозначения датчика какое? G247 ?
VW Tiguan NF [BW2] (2018 - 2021)
Tiguan MEX 2017 ➤
2.0L TFSI DGUA, DTEA, front view
A - 8-pin connector -T8z-, black / 8-pin connector -T8aa-, black
B - 8-pin connector -T8y-, black / 8-pin connector -T8ac-, black
C - 14-pin connector -T144l-, black / 14-pin connector -T14s-, black
1 - Cylinder 1 fuel injector 2 -N532-
2 - Cylinder 2 fuel injector 2 -N533-
3 - Cylinder 3 fuel injector 2 -N534-
4 - Cylinder 4 fuel injector 2 -N535-
5 - Camshaft position sensor -G40-
6 - Oil pressure switch, level 3 -F447-
7 - Engine speed sensor -G28-
8 - Engine temperature control module -GX33-
Engine temperature control actuator -N493-
9 - A/C compressor regulator valve -N280-
10 - Throttle valve control module -GX3-
EPC throttle drive -G186-
EPC throttle drive angle sensor 1 -G187-
11 - Generator with voltage regulator -CX1-
12 - Fuel pressure sensor -G247-
13 - Low fuel pressure sensor -G410-
2.0L TFSI DGUA, DTEA, rear view
1 - Oxygen sensor 1 before catalytic converter -GX10-
Heated oxygen sensor -G39-
2 - Exhaust Pressure Sensor 1 -G450-
3 - Oxygen sensor 1 after catalytic converter -GX7-
Oxygen sensor after catalytic converter -G130-
