Где купить муфту компрессора кондиционера на Volkswagen atlas cross sport
Евгений0112
Сыктывкар
VOLKSWAGEN Atlas cross sport
Всем добрый вечер. Подскажите где можно найти муфту компрессора кондиционера на Volkswagen atlas cross sport?
Так как машина не сильно популярная, то например официальный Диллер в нашем городе найти не смог…
    488,6 КБ · Просмотры: 132
не думаю , что там есть муфта
Ну номер запчасти то они могли дать?
Тут не магазин подбора запчастей
VW Atlas 2017 ➤
VW Atlas 2020 ➤
VW Atlas (PA) 2020 ➤
Overview - Belt Pulley, Sanden A/C Compressor
1 - Nut 25 Nm
Note
To protect the A/C compressor input shaft threads, they may be covered with a plastic cap (the plastic cap is not illustrated).
– Hold the belt pulley securely with a commercially available oil filter band wrench to loosen and tighten the hex nut.
– The thread of the nut, which was screwed in with locking compound, must be cleaned (for example, using a thread tap). Otherwise, there is a risk that the input shaft will break off during assembly.
– Clean the threads of the A/C compressor input shaft with a wire brush.
– Insert the nut with locking compound. Locking fluid. Refer to the ⇒ Electronic Parts Catalog (ETKA).
2 - Bolt 12 Nm
– Hold the belt pulley securely with a commercially available oil filter band wrench to loosen and tighten the bolts.
– The threaded bolt holes, into which the self-locking bolts or bolts with locking compound are screwed, must be cleaned (for example with a thread tap). Otherwise there is the risk that the bolts could break
off when they are removed again.
– Clean the threads of the bolts that were installed with locking fluid using a wire brush. Then insert the bolts with locking fluid. Locking fluid. Refer to the ⇒ Electronic Parts Catalog (ETKA).
3 - Drive Plate
The overload protection (securing spring elements), takes over when the torque is excessive (for example, if the A/C compressor runs with resistance) and the belt pulley runs freely without driving the A/C compressor.
The drive plate spring elements dampen vibrations and noise
4 - Circlip
Replace after removing
Install on the proper side, beveled insertion edge -A- faces away from the A/C compressor; flat side faces the A/C compressor
5 - Belt Pulley
With rubber elements -B- and threaded plates -C- for decoupling the belt pulley from A/C compressor input shaft, dampens vibrations and noises
Note
The threaded plates can also be connected to each other by a ring, depending on the version.
♦ For “cold climate” vehicles (for example, central and northern Europe), A/C compressors with a smaller displacement can be installed. On these A/C compressors, the belt pulley is
slightly different from the one illustrated here (the rubber elements -B- are, for example, not present). Refer to ⇒ Electronic Parts Catalog (ETKA).
6 - A/C Compressor
Clean the A/C compressor input shaft before installing the belt pulley.
