How To Set Readiness Code 2,8L Engine Code AHA
Admin
Admin
Создатель сайта
Команда форума
Россия, Москва
VW Tiguan 2.0 DBGC 2018, VW Touran 1.6 BSE 2008
Автомобиль
VW / Audi / Skoda
Двигатель
2,8 AHA
Step Diagnosis ConditionFunction
Display group
Channel 1 Channel 2 Channel 3 Channel 4 Comments
1Check DTC memory
Clear DTC memory
Engine off
Ignition. On
DTC memory
content
x x x xCheck fault memory
Delete fault memory
2 Throttle adaptationEngine off
Ignition. On
Basic setting
098
x x x Adapt I.O. Do not touch accelerator pedal
3 LDP IdleBasic setting
071
x x x Syst. i.O.
4 Engine warm - up 3000 RPMMeasured values
04
RPM Volts CTS IATS Run until Channel 3 > 80 deg. C
5Oxygen sensor B1S1
Response time
1800 to 2200 RPMBasic setting
034
x x x B1S1 i.O. *
6Oxygen sensor B2S1
Response time
035
x x x B2S1 i.O. *
7 Catalyst Diagnosis B1 1800 to 2200 RPMBasic setting
046
x x x KAT B1 i.O. *
8 Catalyst Diagnosis B2 1800 to 2200 RPMBasic setting
047
x x x KAT B2 i.O. *
9 EVAP purge valve IdleBasic setting
070
x x x Evap. i.O. *
10 Secondary air IdleBasic setting
077
x x x Syst. i.O. *
11 Readiness status IdleMeasured values
086
00000000 x x x Readiness code set if all Zeros
Some test could take several minutes
If RC not set, check DTC's.
If no DTC's, perform test drive
