How To Set Readiness Code 2,0L and 2,8L Engine ABA, AAA
Admin
Admin
Создатель сайта
Команда форума
Россия, Москва
VW Tiguan 2.0 DBGC 2018, VW Touran 1.6 BSE 2008
Автомобиль
VW / Audi / Skoda
Двигатель
2,0 ABA and 2,8 AAA
StepDiagnosisConditionFunction
Display group
Channel 1Channel 2Channel 3Channel 4Comments
1Check DTC memory
Clear DTC memory
Engine off
Ignition. On
DTC memory
content
xxxxCheck fault memory
Delete fault memory
2Throttle adaptationEngine off
Ignition. On
Basic setting
098
xxxAdapt. I.O.Do not touch accelerator pedal
3LDP
If installed
IdleBasic setting
153
xxxSyst. OKLoosen then re-fasten fuel cap
prior to test.
4Engine warm - up3000 rpmMeasured values
103
xCTSxxx1xxx00Coolant temp > 80 deg. C
5Oxys B1S1
Diag.
IdleBasic setting
131
xxxxxxxx100
6Oxys B1S1
Part load
Road testBasic setting
125
xxxx1x1xxxx* 2nd gear. Momentary full throttle from
4600 rpm then decel. Repeat until
values in Ch. 4 obtained. *
7Oxys B1S1
Idle
IdleBasic setting
125
xxx0xx1x100
8Oxys B1S1
Diag.
RPM
2200-2800
Basic setting
130
xxxxxxxx100
Catalyst Diag. RPM
2700-3300
Basic setting
136
xxx1111x100
Secondary Air
If installed
IdleBasic setting
160
xxxxx11x100
EVAP systemIdleBasic setting
150
xxx1110x100
Readiness statusIdleMeasured values
100
00000000xxxReadiness code set if all Zeros
Some test could take several minutes
