1.9 TDI ASZ медленно набирает обороты и плохо едет
bagdanchik
Красноярск
VW Golf IV 1.9 TDI, ASZ 96 kW 130 hp
Автомобиль
VW Golf 4 2000
Двигатель
1.9 TDI ASZ
Доброго времени суток. Прошу помощи, может кто подскажет где искать проблему.
Двигатель ASZ 1.9 TDI
EGR заглушен.
Логи на 3 передаче:
,Group A:,'003,,,,Group B:,'010,,,,Group C:,'011
,,Engine speed,MAF (specified),MAF (actual),EGR duty cycle,,MAF,Atmos. pressure,Intake air press.,Throttle,,Engine speed,Spec. intake press.,Actual intake press.,D.cycle MAP
,TIME,820-900,230-420,230-420,10-95%,TIME,850-1050,sensor -f96-,2000-2200,100%,TIME,2850-3150,2000-2150,2000-2200,40-95%
Marker,STAMP, /min, мг/ул, мг/ул, %,STAMP, мг/ул, mbar, mbar,%,STAMP, /min, mbar, mbar, %
,0.66,1176,250.0,411.6,84.5,0.02,406.7,999.6,1040.4,0.0,0.34,1176,1020.0,1040.4,21.5
,1.73,1176,850.0,396.9,4.8,1.01,406.7,999.6,1040.4,0.0,1.37,1134,1020.0,1040.4,19.9
,2.80,1260,850.0,441.0,4.8,2.09,431.2,999.6,1050.6,100.0,2.45,1197,1652.4,1081.2,22.3
,3.87,1365,850.0,460.6,4.8,3.15,445.9,999.6,1122.0,100.0,3.51,1323,1754.4,1142.4,20.3
,4.95,1491,850.0,470.4,4.8,4.23,465.5,999.6,1183.2,100.0,4.58,1449,1897.2,1193.4,23.5
,6.03,1617,850.0,494.9,4.8,5.31,470.4,999.6,1234.2,100.0,5.67,1575,1999.2,1254.6,24.7
,7.09,1764,850.0,534.1,4.8,6.37,494.9,999.6,1315.8,100.0,6.73,1743,2091.0,1346.4,24.7
,8.15,1974,850.0,622.3,4.8,7.45,543.9,999.6,1438.2,100.0,7.81,1890,2091.0,1509.6,25.1
,9.23,2205,850.0,749.7,4.8,8.51,695.8,999.6,1764.6,100.0,8.87,2100,2091.0,1907.4,51.8
,10.25,2436,850.0,651.7,4.8,9.57,700.7,999.6,1968.6,100.0,9.91,2352,2091.0,1866.6,45.0
,11.22,2625,850.0,656.6,4.8,10.57,646.8,999.6,1805.4,100.0,10.90,2562,2091.0,1805.4,42.2
,12.31,2814,850.0,676.2,4.8,11.59,661.5,999.6,1866.6,100.0,11.95,2772,2091.0,1897.2,45.0
,13.37,3045,850.0,686.0,4.8,12.65,686.0,999.6,1978.8,100.0,13.01,2961,2091.0,2019.6,47.8
,14.45,3234,850.0,666.4,4.8,13.73,686.0,999.6,2060.4,100.0,14.09,3171,2091.0,2070.6,48.2
,15.51,3423,850.0,646.8,4.8,14.81,656.6,999.6,2019.6,100.0,15.17,3360,2091.0,1999.2,42.6
,16.57,3570,850.0,641.9,4.8,15.86,646.8,999.6,1999.2,100.0,16.21,3528,2091.0,2009.4,41.4
,17.65,3717,850.0,646.8,4.8,16.92,641.9,999.6,2029.8,100.0,17.29,3675,2091.0,2040.0,41.4
,18.73,3843,850.0,656.6,4.8,18.01,651.7,999.6,2070.6,100.0,18.37,3780,2091.0,2080.8,42.6
,19.79,3969,850.0,661.5,4.8,19.06,666.4,999.6,2131.8,100.0,19.43,3927,2091.0,2152.2,46.2
,20.87,4074,850.0,597.8,4.8,20.15,656.6,999.6,2152.2,100.0,20.51,4032,2091.0,2080.8,45.4
,21.94,4137,850.0,592.9,4.8,21.23,588.0,999.6,1958.4,100.0,21.59,4116,2080.8,1938.0,39.8
,23.03,4200,850.0,622.3,4.8,22.31,602.7,999.6,2009.4,100.0,22.67,4179,2070.6,2040.0,41.4
,24.09,4284,850.0,607.6,4.8,23.39,617.4,999.6,2080.8,100.0,23.75,4242,2070.6,2070.6,42.6
,25.11,2835,250.0,387.1,4.8,24.42,416.5,999.6,1662.6,0.0,24.75,3318,1224.0,1387.2,39.8
  • log.zip
    1,3 КБ · Просмотры: 276
@Саня TDI завтра поменяю, отпишусь о результате
Купил новый ДМРВ, поменял и машина поехала намного бодрее, покатаюсь пару дней и отпишусь с новыми логами. Александр, благодарю)
Как и говорил, машина едет намного лучше, сделал новые логи, посмотрите все ли нормально?
Четверг,04,Август,2022,19:11:51
038 906 019 CJ,,1.9l R4 EDC 0000SG 1086,
,0.71,1512,850.0,509.6,4.8,0.02,475.3,989.4,1071.0,20.0,0.34,1470,1499.4,1071.0,33.9
,1.79,1680,850.0,602.7,4.8,1.06,534.1,989.4,1152.6,100.0,1.43,1617,2019.6,1213.8,25.1
,2.86,1890,850.0,803.6,4.8,2.14,651.7,989.4,1356.6,100.0,2.51,1806,2091.0,1458.6,28.7
,3.93,2163,850.0,931.0,4.8,3.23,945.7,989.4,1795.2,100.0,3.59,2079,2091.0,1958.4,57.0
,4.98,2436,850.0,896.7,4.8,4.28,901.6,989.4,1907.4,100.0,4.64,2331,2091.0,1866.6,49.4
,5.98,2667,850.0,906.5,4.8,5.32,906.5,989.4,1897.2,100.0,5.64,2604,2091.0,1917.6,51.0
,7.00,2919,850.0,921.2,4.8,6.32,911.4,989.4,1948.2,100.0,6.64,2856,2091.0,1958.4,47.0
,8.06,3171,850.0,945.7,4.8,7.37,926.1,989.4,2029.8,100.0,7.72,3087,2091.0,2060.4,48.2
,9.14,3381,850.0,891.8,4.8,8.43,916.3,989.4,2091.0,100.0,8.77,3318,2091.0,2101.2,50.2
,10.22,3570,850.0,862.4,4.8,9.50,877.1,989.4,2050.2,100.0,9.86,3528,2091.0,2029.8,48.2
,11.28,3738,850.0,867.3,4.8,10.56,862.4,989.4,2019.6,100.0,10.92,3696,2091.0,2040.0,47.0
,12.36,3906,850.0,862.4,4.8,11.64,862.4,989.4,2060.4,100.0,12.00,3864,2091.0,2080.8,46.6
,13.42,4053,850.0,857.5,4.8,12.73,862.4,989.4,2091.0,100.0,13.07,4011,2091.0,2101.2,46.6
,14.50,4200,850.0,837.9,4.8,13.78,842.8,989.4,2091.0,100.0,14.14,4137,2080.8,2091.0,47.8
,15.59,3192,255.0,494.9,4.8,14.87,823.2,989.4,2080.8,17.3,15.22,3780,1213.8,1570.8,39.8
,16.66,1827,245.0,475.3,4.8,15.94,460.6,989.4,1224.0,0.0,16.31,2247,1173.0,1162.8,39.8
,17.70,903,250.0,465.5,73.3,17.02,441.0,989.4,1101.6,0.0,17.37,1134,1020.0,1081.2,23.5
,18.71,861,250.0,455.7,84.5,18.02,450.8,989.4,1050.6,0.0,18.36,882,1009.8,1040.4,19.9
  • log.zip
    1,1 КБ · Просмотры: 241
Если все устраивает,то нормально.Чуток на низах недодувает турбина,но не криминал.Можно вакуум замерять на актуаторе.Какой расходомер поставили?Он тоже слегка занижает,но на много лучше предыдущего.Впуск проверялся на герметичность?
Проверяли впуск дымогенератором, все ок, Расходомер поставили Bosch 0281002757. Вакуум замерили только от вакуумника -0.8. Клапан N75 стоит новый Pierburg, с ним проблем нету.
