Руководство Fuses and Relay VW Taos (CL1) 2021 -, предохранители и реле
Admin
Admin
Создатель сайта
Команда форума
Россия, Москва
VW Tiguan 2.0 DBGC 2018, VW Touran 1.6 BSE 2008
Volkswagen Taos Mex (CL1) 2021 -
Volkswagen Taos Arg (CQ1) 2021 -
Component Locations: Fuses
Fuse Panel A -SA- from October 2020
Fuse Panel B -SB- from October 2020
Fuse Panel C -SC- from October 2020
Fuse Panel 1 -ST1- from October 2020
Fuse Panel 2 -ST2- from October 2020
Relay
Rear Window Defogger Relay -J9-
A/C Clutch Relay -J44-
Motronic Engine Control Module Power Supply Relay -J271-
Secondary air injection pump relay -J299-
Vacuum Pump Relay -J318-
Terminal 15 Power Supply Relay -J329-
Wiper motor relay 1 -J368-
Wiper motor relay 2 -J369-
Horn Relay -J413-
Remote Start System Relay -J471- (For VW Taos with engine remote start)
Sockets Relay -J807-
Starter Relay 1 -J906-
Starter Relay 2 -J907-
Fuse Panel A -SA-, from October 2020
Location Fuse Panel A -SA-, from October 2020
Note: The fuse strip (multi-fuse) must be replaced as a complete unit
Assignment Fuse Panel A -SA-, from October 2020
LocationDesignation in Wiring DiagramNominal Value Function / ComponentTerminal
SA1 Fuse 1 (On Fuse Panel A) -SA1- 125 A Supply for Fuses:
Fuse 4 (On Fuse Panel C) -SC4--Fuse 12 (On Fuse Panel C) -SC12-
Fuse 14 (On Fuse Panel C) -SC14-
Fuse 52 (On Fuse Panel C) -SC52-
Fuse 39 (On Fuse Panel C) -SC39-
Fuse 53 (On Fuse Panel C) -SC53-
Fuse 42 (On Fuse Panel C) -SC42-
Fuse 40 (On Fuse Panel C) -SC40-
Fuse 32 (On Fuse Panel C) -SC32- Fuse 35 (On Fuse Panel C) -SC35-
Fuse 49 (On Fuse Panel C) -SC49-
30
SA2 Fuse 2 (on Fuse Panel A) -SA2- 400 A Generator with Voltage Regulator -CX1- 30
SA3 Fuse 3 (on Fuse Panel A) -SA3- 80 A Power Steering Control Module -J500- 30
SA4 Fuse 4 (On Fuse Panel A) -SA4- 80 A Supply for Fuses:
Fuse 15 (On Fuse Panel C) -SC15-- Fuse 19 (On Fuse Panel C) -SC19-
Fuse 21 (On Fuse Panel C) -SC21-
Fuse 23 (On Fuse Panel C) -SC23--Fuse 27 (On Fuse Panel C) -SC27-
Fuse 43 (On Fuse Panel C) -SC43--Fuse 45 (On Fuse Panel C) -SC45-
Fuse 30 (On Fuse Panel C) -SC30-
Fuse 51 (On Fuse Panel C) -SC51-
Fuse 2 (On Fuse Panel C) -SC2-
30
SA5 Fuse 5 (On Fuse Panel A) -SA5- 50 A Radiator Fan -VX57- 30
Fuse Panel B -SB-, from October 2020
Location Fuse Panel B -SB-, from October 2020
1 - Fuse Panel B -SB
Assignment Fuse Panel B -SB-, from October 2020
SB1Fuse 1 (On Fuse Panel B) -SB1-25 AABS Control Module -J104-30
SB2Fuse 2 (On Fuse Panel B) -SB2-40 A
60 A 4)
SB3Fuse 3 (On Fuse Panel B) -SB3-15 AEngine/Motor Control Module -J623-87
SB4Fuse 4 (On Fuse Panel B) -SB4-10 AEthanol concentration sensor -G708-
Radiator Fan -VX57-
- Radiator Fan Control Module -J293-
- Radiator Fan -V7-
Oil Level Thermal Sensor -G266-
Camshaft Adjustment Valve 1 -N205-
Intake camshaft adjustment valve 1 -N727-
Intake Manifold Runner Control Valve -N318-
EVAP Canister Purge Regulator Valve 1 -N80-
Oil Pressure Regulation Valve -N428-
Low Heat Output Relay -J359- 5)
87
SB5Not used---
SB6Fuse 6 (On Fuse Panel B) -SB6-7.5 ABrake Lamp Switch -F-87
SB7Fuse 7 (On Fuse Panel B) -SB7-10 ASecondary Air Injection Solenoid Valve -N112- 1)
Charge air cooling pump -V188-
Fuel Tank Leak Detection Module -GX36- 1)
Tank Switch-Off Valve -N288- 1)
87
SB8Fuse 8 (On Fuse Panel B) -SB8-10 AOxygen Sensor 1 After Catalytic Converter -GX7-
- Heater for Oxygen Sensor 1 After Catalytic Converter -Z29-
- Oxygen sensor after catalytic converter -G130-
Oxygen Sensor 1 Before Catalytic Converter -GX10-
- Oxygen Sensor Heater -Z19-
- Heated oxygen sensor -G39-
87
SB9Fuse 9 (On Fuse Panel B) -SB9-20 AIgnition Coil 1 with Power Output Stage -N70-
Ignition Coil 2 with Power Output Stage -N127-
Ignition Coil 3 with Power Output Stage -N291-
Ignition Coil 4 with Power Output Stage -N292-
87
SB10Fuse 10 (On Fuse Panel B) -SB10-15 AFuel Pump Control Module -J538-87
SB11Fuse 11 (On Fuse Panel B) -SB11- 1)40 ASecondary air injection pump motor -V101-
87
SB12Not used---
SB13Sicherung 13 auf Sicherungshalter B -SB13- 6)30 ATransmission fluid auxiliary hydraulic pump 1 -V475-30
SB14Sicherung 14 auf Sicherungshalter B -SB14- 5)30 AAuxiliary heater heating element -Z35-
Relay and fuse panel 1 -SR1-
30
SB15Fuse 15 (On Fuse Panel B) -SB15-15 AHorn Relay -J413-30
SB16Not used---
SB17Fuse 17 (On Fuse Panel B) -SB17-7.5 AABS Control Module -J104-
30
SB18Fuse 18 (On Fuse Panel B) -SB18-7.5 ABattery Monitoring Control Module -J367-
Data Bus on Board Diagnostic Interface -J533-
30
SB19Fuse 19 (On Fuse Panel B) -SB19-30 AWiper motor relay 1 -J368-
30
SB20Not used---
SB21Fuse 21 (On Fuse Panel B) -SB21-15 A
30 A 7)
Dual-Clutch Transmission Mechatronic -J743-
Transmission Control Module -J217-
30
SB22Fuse 22 (On Fuse Panel B) -SB22-7.5 AEngine/Motor Control Module -J623-50
SB23Fuse 23 (On Fuse Panel B) -SB23-30 AStarter -B-50
SB24Fuse 24 (On Fuse Panel B) -SB24- 5)30 AAuxiliary heater heating element -Z35-87a
SB25Not used---
SB26Not used---
SB27Not used---
SB28Not used---
SB29Not used---
SB30Not used---
SB31Not used---
SB32Fuse 23 (On Fuse Panel B) -SB32- 5)30 AAuxiliary heater heating element -Z35-87a
SB33Not used---
SB34Not used---
SB35Not used---
SB36Fuse 36 (On Fuse Panel B) -SB36-15 ALeft Front Headlamp -MX1-30a
SB37Not used---
SB38Fuse 38 (On Fuse Panel B) -SB38-15 ARight Front Headlamp -MX2-30a
1) Only for vehicles with 1,5L TFSI
2) Only for vehicles with 1.4L gasoline engine
3) For vehicles with windshield defogger
4) Depending on equipment
5) Only for vehicles with Auxiliary air heating
6) Only for vehicles with DSG transmission
7) Only for vehicles with 6-speed transmission and Tiptronic
Fuse Panel C -SC-, from October 2020
Location Fuse Panel C -SC-, from October 2020
1 - Fuse Panel C -SC
Assignment Fuse Panel C -SC-, from October 2020
Note: The SC40 fuse is supplied with terminal 15 at the factory and can be supplied with terminal 30 by repositioning it. If equipment is connected to the socket or the cigarette lighter, make sure the equipment is disconnected from the power supply when the engine is off to prevent the battery from draining
SC1Not used---
SC2Fuse 2 (On Fuse Panel C) -SC2- 8)10 ASteering Column Electronics Control Module -J527- 8)30
SC3Not used---
SC4Not used---
SC5Fuse 5 (On Fuse Panel C) -SC5-7.5 AData Bus on Board Diagnostic Interface -J533-
Remote Start System Relay -J471- 1) 2)
30
SC6Fuse 6 (On Fuse Panel C) -SC6-7.5 ASelector lever -E313-30
SC7Fuse 7 (On Fuse Panel C) -SC7-10 AHeater and A/C Controls -EX21-
30
SC8Fuse 8 (On Fuse Panel C) -SC8-7.5 ADiagnostic Connection -U31-
Electromechanical Parking Brake Button -E538-
Humidity, rain and light recognition sensor -G823-
Rotary Light Switch -EX1-
Parking brake button -EX12-
Instrument Panel Contour Illumination Lamp 1 -L243-
Instrument Panel Contour Illumination Lamp 2 -L244-
Sensor für Diebstahlwarnanlage -G578- 7)
Instrument Panel Contour Illumination Lamp 3 -L245-
Passenger Side Door Ambient Lighting Lamp -W87-
Driver Side Door Ambient Lighting Lamp -W86-
30
SC9Fuse 9 (On Fuse Panel C) -SC9-7.5 ASteering Column Electronics Control Module -J527-30
SC10Fuse 10 (On Fuse Panel C) -SC10-7.5 AFront Information Display Control Head -J685-30
SC11Fuse 11 (On Fuse Panel C) -SC11-40 AVehicle Electrical System Control Module -J519-30
SC12Fuse 12 (On Fuse Panel C) -SC12-20 AInformation Electronics Control Module 1 -J794-
Navigation system control module -J856-
30
SC13Not used---
SC14Fuse 14 (On Fuse Panel C) -SC14-40 AFresh Air Blower Control Module -J126-30
SC15Not used---
SC16Fuse 16 (On Fuse Panel C) -SC16-7.5 AStorage Compartment with Cell Phone Interface -R265-
USB-Anschluss 1 -U41- 7)
30
SC17Fuse 17 (On Fuse Panel C) -SC17-7.5 AInstrument Cluster -KX2-
Control Module for Emergency Call Module and Communication Unit -J949-
30
SC18Fuse 18 (On Fuse Panel C) -SC18-7.5 ARear Lid Handle -EX37-
Rearview Camera -R189-
30
SC19Fuse 19 (On Fuse Panel C) -SC19-7.5 AAccess/Start System Interface -J965-30
SC20Sicherung 20 auf Sicherungshalter C -SC20- 9)15 AVacuum Pump Relay -J318- 9)-
SC21Fuse 21 (On Fuse Panel C) -SC21-15 AAll Wheel Drive Control Module -J492-30
SC22Not used---
SC23Fuse 23 (On Fuse Panel C) -SC23-20 ASunroof Control Module -J245-30
SC24Fuse 24 (On Fuse Panel C) -SC24-40 AVehicle Electrical System Control Module -J519-30
SC25Fuse 25 (On Fuse Panel C) -SC25-30 ADriver Door Control Module -J386-
Left rear window regulator motor -V26-
30
30
SC26Fuse 26 (On Fuse Panel C) -SC26-30 AVehicle Electrical System Control Module -J519-30
SC27Fuse 27 (On Fuse Panel C) -SC27-30 AVehicle Electrical System Control Module -J519-30
SC28Not used---
SC29Fuse 29 (On Fuse Panel C) -SC29- 1), 2)5 ARefrigerant Circuit Pressure Sensor -G805-15
SC30Fuse 30 (On Fuse Panel C) -SC30- 1), 2)10 ARemote Start System Relay -J471- 1) 2)30
SC31Not used---
SC32Fuse 32 (On Fuse Panel C) -SC32-7.5 ABlind Spot Detection Control Module -J1086-
Blind Spot Detection Control Module 2 -J1087-
Parking Aid Control Module -J446-
Driver Assistance Systems Front Camera -R242-
Control Module for Adaptive Cruise Control -J428-
15
SC33Fuse 33 (On Fuse Panel C) -SC33-7.5 AAirbag Control Module -J234-
Front Passenger Airbag -Disabled- Indicator Lamp -K145-
15
SC34Fuse 34 (On Fuse Panel C) -SC34-7.5 ARotary Light Switch -EX1-
Interior Rearview Mirror -EX5-
15
SC35Fuse 35 (On Fuse Panel C) -SC35-7.5 ADiagnostic Connection -U31-15
SC36Not used---
SC37Not used---
SC38Not used---
SC39Fuse 39 (On Fuse Panel C) -SC39-30 AFront Passenger Door Control Module -J387-
Right rear window regulator motor -V27-
30
SC40
5) 6)
Fuse 40 (On Fuse Panel C) -SC40-20 A12 V Socket 2 -U18-
12 V Socket -U5-
155) /
306)
SC41Not used---
SC42Fuse 42 (On Fuse Panel C) -SC42-40 AVehicle Electrical System Control Module -J519-30
SC43Fuse 43 (On Fuse Panel C) -SC43-30 ADigital Sound System Control Module -J525-30
SC44Not used---
SC45Fuse 45 (On Fuse Panel C) -SC45-15 ALeft Front Seat Adjustment Control Head -EX33-
Driver Seat Lumbar Support Adjustment Switch -E176-
Left Front Seat Cushion Fan 1 -V514-
Left Front Seat Backrest Fan 1 -V512-
30
SC46Fuse 46 (On Fuse Panel C) -SC46-7.5 AUSB Charging Socket 1 -U37-30
SC47Fuse 47 (On Fuse Panel C) -SC47-15 ARear Window Wiper Motor -V12-15a
SC48Not used---
SC49Fuse 49 (On Fuse Panel C) -SC49-7.5 AStarter Relay 1 -J906-
Remote Start System Relay -J471- 2)
15
SC50Not used---
SC51Not used---
SC52Not used---
SC53Fuse 53 (On Fuse Panel C) -SC53-30 ARear Window Defogger Relay -J9-15
1) Only for vehicles with remote start
2) Only for vehicles with preparation for remote start
3) Only for vehicles with Blind spot detection
4) Only for vehicles without remote start
5) Supplied from terminal 15 at the factory
6) Supply via terminal 30 possible
7) Depending on equipment
8) Only for vehicles with heated steering wheel
9) Only for vehicles with 1,4l TFSI
Single Fuses , from October 2020
Location Single Fuses, from October 2020
1 - Bracket
2 - Fuse Panel 2 -ST2-
3 - Fuse panel 6 -ST6-
4 - Fuse Panel 5 -ST5-
Assignment Single Fuses, from October 2020
A Front Passenger Power Seat Adjustment Circuit Breaker 1 -S46- 15 A Right Front Seat Backrest Fan 1 -V516-
Right Front Seat Cushion Fan 1 -V518-
30
B Not used - -
C Seat Belt Latch Release Solenoid Fuse -S69- 7.5 A Passenger Occupant Detection System Control Module -J706- 15
Relays on Fuse Panel B -SB-, from October 2020
1 - Fuse Panel B -SB-
R1 - Starter Relay 1 -J906-
R2 - Starter Relay 2 -J907-
R3 - Horn Relay -J413-
R4 - Secondary air injection pump relay -J299-
R5 - Motronic Engine Control Module Power Supply Relay -J271-
Relays onFuse Panel C -SC-, from October 2020
1 - Fuse Panel C -SCR1 - Vacuum Pump Relay -J318-
R2 - A/C Clutch Relay -J44-
R3 - Not used
R4 - Terminal 15 Power Supply Relay -J329-
R5 - Rear Window Defogger Relay -J9-
R6 - Sockets Relay -J807-
Relay and Fuse Panel 3 -SR3-, from October 2020
1 - Relay and Fuse Panel 3 -SR3-
R8 - Not used
R9 - Wiper motor relay 1 -J368-
R10 - Wiper motor relay 2 -J369-
Relays on Fuse Panel 1 -ST1-, from October 2020
1 - Fuse Panel 1 -ST1-
R1 - Remote Start System Relay -J471-
- For vehicles with engine remote start
- for vehicles with preparation for remote engine start
Расположение предохранителей для российского Фольксваген Таос:
Расположение реле для российского Фольксваген Таос:
Точки соединения с массой Volkswagen Taos:
VW Taos component locations (расположение компонентов)
