Руководство Fuses VW Polo 5 2010-2014 model (6R1) - предохранители и реле
Admin
Admin
Создатель сайта
Команда форума
Россия, Москва
VW Tiguan 2.0 DBGC 2018, VW Touran 1.6 BSE 2008
Автомобиль
VW Polo 5
Двигатель
all
Fuses Volkswagen Polo 5 (model 6R1) 2010 - 2014
Fuses Volkswagen Polo 5 restyling (model 6C1) 2015 - 2017
Предохранители Фольксваген Поло 5
Overview of fuses
1 - Fuse holder A -SA-
Fitting location, Fuse assignment, from May 2009
1 - Fuse holder C -SC-
Fitting location / Fitting location for vehicles with battery in luggage compartment
2 - Fuse holder B -SB-
3 - Fuse holder F -SF-
Fitting location
4 - Fuse assignment on relay carrier
Fitting location
Fuse assignment, from November 2009
Fuse assignment, from May 2012
Fuse assignment in battery fuse holder VW Polo 5
2 - Fuse holder C -SC-
3 - Automatic glow period control unit -J179-
Fuse holder A -SA- VW Polo 5
2 - Fuse holder A -SA-
3 - Auxiliary engine coolant pump relay -J496-
Fuse assignment
Fuse colours
30 A - green
25 A - white
20 A - yellow
15 A - blue
10 A - red
7,5 A - brown
5 A - beige
3 A - purple
No.Current flow diagram designationNominal valueFunction/componentTerminal
SA1Fuse 1 in fuse holder A150A
175A 1)
Alternator -C-30
SA2Fuse 2 in fuse holder A30AGas mode control unit -J659-
(only models with engine code CMAA)
30
SA3Fuse 3 in fuse holder A110AIgnition/starter switch -D
Light switch -E1-
Steering column combination switch -E595-
X-contact relief relay -J59-
Motronic current supply relay -J271-
Low heat output relay -J359-
High heat output relay -J360-
Fuel supply relay -J643-
Fuse 4 -S134-
Fuse 5 -S138-
Fuse 6 -S139-
Fuse 4 on fuse holder B -SB4-
Fuse 20 on fuse holder B -SB20-
Fuse 35 on fuse holder B -SB35-
Fuse 38 on fuse holder B -SB38-
Fuse 57 on fuse holder B -SB57-
30
SA4Fuse 4 in fuse holder A50APower steering control unit -J500-30
SA5Fuse 5 in fuse holder A40AABS control unit -J104-30
SA6Fuse 6 in fuse holder A40A
50A 2)
Radiator fan control unit -J293-30
SA7Fuse 7 in fuse holder A50AAutomatic glow period control unit -J179-30
SC1Fuse 1 on fuse holder C25AABS control unit -J104-30
SC2Fuse 2 on fuse holder C30ARadiator fan thermal switch -F18-
Radiator fan control unit -J293- 4)
30
SC3Fuse 3 on fuse holder C 3)5ARadiator fan control unit -J293- 4)30
SC4Fuse 4 on fuse holder C10A
5A 3)
SC5Fuse 5 on fuse holder C5AOnboard supply control unit -J519-30
SC6Fuse 6 on fuse holder C25AMechatronic unit for dual clutch gearbox -J743-30
1) Only models with start/stop system
2) Only models with battery in luggage compartment
3) from May 2010
4) up to May 2011
Fuse assignment in fuse holder B VW Polo 5
1 - Relay carrier
3 - Diagnostic connector -T16b
Fuse assignment
Fuse colours
30 A - green
25 A - white
20 A - yellow
15 A - blue
10 A - red
7,5 A - brown
5 A - beige
3 A - purple
Fuse holder B -SB- VW Polo 5
1Fuse 1 on fuse holder B -SB1- 1)5AControl unit in dash panel insert -J285- 1)
ABS control unit -J104- 1)
Mobile telephone operating electronics control unit -J412- 1)
30a
2Fuse 2 on fuse holder B -SB2-10ASteering column combination switch -E595-
Onboard supply control unit -J519- (T73b/61)
- Rear window wiper motor -V12-
Windscreen and rear window washer pump -V59- 4)
15
3Fuse 3 on fuse holder B -SB3-5AFuel pump relay -J17-
Engine control unit -J623-
Current supply relay for Simos control unit -J363- 7)
Fuel pump control unit -J538- 2)
Control unit for structure-borne sound -J869- Gas mode control unit
-J659- 2)
15
4Fuse 4 on fuse holder B -SB4- 9)2ASteering column combination switch -E595- 9)30
5Fuse 5 on fuse holder B -SB5-5AABS control unit -J104- 11)30
6Fuse 6 on fuse holder B -SB6-5AControl unit in dash panel insert -J285-15
7Fuse 7 on fuse holder B -SB7-5AHeadlight range control regulator -E102-
Left number plate light -X4-
Right number plate light -X5-
Onboard supply control unit -J519- 1)
58
8Fuse 8 on fuse holder B -SB8- 4)10AInjector, cylinder 1 -N30-
Injector, cylinder 2 -N31-
Injector, cylinder 3 -N32-
Injector, cylinder 4 -N33-
87
8Fuse 8 on fuse holder B -SB8- 3)10ALambda probe heater -Z19-
Lambda probe 1 heater after catalytic converter -Z29-
Activated charcoal filter solenoid valve 1 -N80-
87
9Fuse 9 on fuse holder B -SB9-5A
7.5A 2)
TCS and ESP button -E256-
Tyre Pressure Loss Indicator button -E492-
Steering angle sender -G85-
Start/Stop operation button -E693- 1)
Data bus diagnostic interface -J533- 1) Voltage stabiliser 2 -J570- 1) 8)
15
10Fuse 10 on fuse holder B -SB10- 5)5ACruise control system switch -E45-
Brake light switch -F
Clutch pedal switch -F36-
15
10Fuse 10 on fuse holder B -SB10- 10)2ASteering column combination switch -E595- 10)15
11Fuse 11 on fuse holder B -SB11-10A
5A 3)
Left headlight range control motor -V48-
Right headlight range control motor -V49-
Cruise control system switch -E45- 6)
Onboard supply control unit -J519- (T73a/44) 6)
Control unit for cornering light and headlight range control -J745-
15
12Fuse 12 on fuse holder B -SB12-5AMirror adjustment switch -E43-15
13Fuse 13 on fuse holder B -SB13-5AMechatronic unit for dual clutch gearbox -J743-
Selector lever -E313-
15
14Fuse 14 on fuse holder B -SB14-5AAirbag control unit -J234-
Front passenger airbag deactivated warning lamp -K145-
15
15Fuse 15 on fuse holder B -SB15-5ALeft washer jet heater element -Z20-
Right washer jet heater element -Z21-
15
16Fuse 16 on fuse holder B -SB16-5AParking aid control unit -J446-15
17Fuse 17 on fuse holder B -SB17-10AWindscreen and rear window washer pump -V59- 3)53c
18Fuse 18 on fuse holder B -SB18-5ARear fog light cut-out contact switch -F216-
Rear left fog light bulb -L46- Onboard supply control unit -J519- (T73a/
6) 6)
55a
19Fuse 19 on fuse holder B -SB19-5AOnboard supply control unit -J519- (T73a/42)
- Ignition/starter switch -D- , S-contact
75
20Fuse 20 on fuse holder B -SB20-5ASteering angle sender -G85-
Fuel supply relay -J643- 2) 3)
Terminal 30 voltage supply relay -J317- 2) 3)
Low heat output relay -J359- 3)
High heat output relay -J360- 3)
30
21Fuse 21 on fuse holder B -SB21-10AOnboard supply control unit -J519- (T73a/66)
- Driver side reading light -W19-
- Front passenger reading light -W13-
- Interior light with switch-off delay -W15-
- Driver side illuminated vanity mirror -W20-
- Front passenger side illuminated vanity mirror -W14-
- Left footwell light -W9-
- Right footwell light -W10-
- Right luggage compartment light -W35-
- Rear centre reading light -W44-
30
22Fuse 22 on fuse holder B -SB22-5ADiagnostic connection -U31-
Climatronic control unit -J255-
Air conditioning system control unit -J301-
Ignition key withdrawal lock solenoid -N376-
30
23Fuse 23 on fuse holder B -SB23-5ASelector lever -E313-
Rain sensor -G213-
Onboard supply control unit -J519- (T73b/39)
30
24Fuse 24 on fuse holder B -SB24-5A
10A 10)
Onboard supply control unit -J519- (T73a/64)
- Heated exterior mirror on driver side -Z4-
- Heated exterior mirror on front passenger side -Z5-
30
25Fuse 25 on fuse holder B -SB25-5AHigh-pressure sender -G65-
Heater control unit -J162-
Trailer detector control unit -J345-
Humidity sender -G355- 1)
Voltage stabiliser -J532- 1)
Voltage stabiliser 2 -J570- 1) 7)
15
26Fuse 26 on fuse holder B -SB26-7.5AAir mass meter -G70-
Oil level and oil temperature sender -G266-
Heater element for crankcase breather -N79-
Starter relay 1 -J906- 1)
Starter relay 2 -J907- 1)
15
27Fuse 27 on fuse holder B -SB27-7.5AReversing light switch -F4-15
28Fuse 28 on fuse holder B -SB28-10ALambda probe -G39-
Lambda probe after catalytic converter -G130-
87
29Fuse 29 on fuse holder B -SB29-10AFuel pressure regulating valve -N276-
Fuel metering valve -N290-
87
30Fuse 30 on fuse holder B -SB30-10ACharge pressure control solenoid valve -N75-
Exhaust gas recirculation cooler changeover valve -N345-
Coolant circulation pump 2 -V178- Heater element relay -925- 2)
87
31Fuse 31 on fuse holder B -SB31-5A 12)
10A 13)
Gas gauge sender -G707- (CMAA)
Additional coolant pump relay -J496- 2)
Air mass meter -G70- 2)
87
32Fuse 32 on fuse holder B -SB32-10A
15A
20A
30A 2)
Fuel gauge sender -G- 4)
Fuel system pressurisation pump -G6- 4)
Gas mode control unit -J659- 2)
87
33Fuse 33 on fuse holder B -SB33-5AClutch position sender -G476-
Brake light switch -F-
87
34Fuse 34 on fuse holder B -SB34-15A
7.5A 2)
Left headlight main beam bulb -M30-
Right headlight main beam bulb -M32- Onboard supply control unit
-J519- (T73a/62) 6)
Left gas discharge bulb control unit -J343- 2)
Right gas discharge bulb control unit -J344- 2)
35Fuse 35 on fuse holder B -SB35-15A
20A 2)
87
36Fuse 36 on fuse holder B -SB36-7.5ARight headlight main beam bulb -M32-87
37Fuse 37 on fuse holder B -SB37-25AHeated driver seat regulator -E94-
Heated front passenger seat regulator -E95-
Heated front seats control unit -J774-
75
38Fuse 38 on fuse holder B -SB38-30AMechatronic unit for dual clutch gearbox -J743-30
39Fuse 39 on fuse holder B -SB39-10A
15A 2)
Right headlight dipped beam bulb -M31-56b
40Fuse 40 on fuse holder B -SB40-30AFresh air blower switch -E9-
Fresh air blower control unit -J126-
75
41Fuse 41 on fuse holder B -SB41-10ARear window wiper motor -V12-75
42Fuse 42 on fuse holder B -SB42-15ACigarette lighter -U1-
12 V socket -U5- 4)
75
43Fuse 43 on fuse holder B -SB43-15A
20A 10)
Onboard supply control unit -J519- (T73b/13)
- Front left turn signal bulb -M5-
- Front right turn signal bulb -M7-
- Rear left turn signal bulb -M6-
- Rear right turn signal bulb -M8-
- Driver side turn signal repeater bulb -L131-
- Front passenger side turn signal repeater bulb -L132-
- Left brake light bulb -M9-
- Right brake light bulb -M10-
- High-level brake light bulb -M25-
30
44Fuse 44 on fuse holder B -SB44-5AAnti-theft alarm ultrasonic sensor -G209-
Alarm horn -H12-
30
45Fuse 45 on fuse holder B -SB45-15A
20A 2)
Control unit with display for radio and navigation -J503-
Multimedia system control unit -J650-
Radio -R
30
46Fuse 46 on fuse holder B -SB46-20AHeadlight washer system relay -J39-
Onboard supply control unit -J519- (T73a/73)
- Treble horn -H2-
- Bass horn -H7-
30
47Fuse 47 on fuse holder B -SB47-20AOnboard supply control unit -J519- (T73a/68)
- Windscreen wiper motor -V-
30
48Fuse 48 on fuse holder B -SB48-25AOnboard supply control unit -J519- (T73a/16)
- Driver side central locking lock unit -F220-
- Front passenger side central locking lock unit -F221-
- Rear left central locking lock unit -F222-
- Rear right central locking lock unit -F223-
- Rear lid lock unit -F256-
- Tank filler flap locking motor -V155-
30
49Fuse 49 on fuse holder B -SB49- 4)30ASliding sunroof adjustment control unit -J245-30
49Fuse 49 on fuse holder B -SB49- 3)15AFuel pump relay -J17- 2)
50Fuse 50 on fuse holder B -SB50-25ADriver door control unit -J386-30
51Fuse 51 on fuse holder B -SB51-25AFront passenger door control unit -J387-30
52Fuse 52 on fuse holder B -SB52-30ARear left door control unit -J388-
Rear right door control unit -J389-
30
53Fuse 53 on fuse holder B -SB53-30AOnboard supply control unit -J519- (T73b/67)
- Heated rear window -Z1-
30
54Fuse 54 on fuse holder B -SB54-15ALeft fog light bulb -L22-
Right fog light bulb -L23-
55
55Fuse 55 on fuse holder B -SB55-15A
20A 2)
Ignition coil 1 with output stage -N70-
Ignition coil 2 with output stage -N127-
Ignition coil 3 with output stage -N291-
Ignition coil 4 with output stage -N292-
87
56Fuse 56 on fuse holder B -SB56-15ALeft daytime running light bulb -L174-
Right daytime running light bulb -L175-
75
57Fuse 57 on fuse holder B -SB57-15AOnboard supply control unit -J519- (T73b/11)30
58Fuse 58 on fuse holder B -SB58-20ABrake servo vacuum pump -V469-87
59Fuse 59 on fuse holder B -SB59-10A
15A 2)
Left headlight dipped beam bulb -M29-56b
60Fuse 60 on fuse holder B -SB60-15A
20A 2)
Control unit with display for radio and navigation -J503- 1)30a
2) According to equipment
3) from May 2010
4) up to May 2010
5) To November 2009
6) from November 2009
7) To November 2010
8) from November 2010
9) up to May 2011
10) from May 2011
11) Only models with battery in luggage compartment
12) Only models with diesel engine
13) Only models with petrol engine
Fuse assignment on relay carrier, VW Polo 5 from May 2009
Fuse colours
30 A - green
25 A - white
20 A - yellow
15 A - blue
10 A - red
7,5 A - brown
5 A - beige
3 A - purple
6Fuse 1 -S131-
Fuse 2 -S132-
Fuse 3 -S133-
40AAuxiliary air heater element -Z35-87
8Fuse 4 -S134-
Fuse 5 -S138-
Fuse 6 -S139-
20A
20A
15A
Trailer detector control unit -J345-30
AFuses in relay plate fuse holder -S3-30ASliding sunroof adjustment control unit -J245-30
Fuse assignment on relay carrier, VW Polo 5 from November 2009
Fuse colours
30 A - green
25 A - white
20 A - yellow
15 A - blue
10 A - red
7,5 A - brown
5 A - beige
3 A - purple
95387
6Fuse 1 -S131-
Fuse 2 -S132-
Fuse 3 -S133-
8Fuse 4 -S134-
Fuse 5 -S138-
Fuse 6 -S139-
15A
20A
20A
Fuse assignment on relay carrier, VW Polo 5 from May 2012
Fuse colours
30 A - green
25 A - white
20 A - yellow
15 A - blue
10 A - red
7,5 A - brown
5 A - beige
3 A - purple
6Fuse 1 -S131-
Fuse 2 -S132-
Fuse 3 -S133-
8Fuse 4 -S134-
Fuse 5 -S138-
Fuse 6 -S139-
15A
20A
20A
Anot assigned
BFuses in relay plate fuse holder -S3-30ASliding sunroof adjustment control unit -J245-30
Fuse holder F -SF- VW Polo 5
1 - 701 Earth point in luggage compartment
2 - Fuse holder F -SF-
3 - Battery isolation igniter -N253-
3 - Battery master/isolator switch -E74-
1Fuse 1 on fuse holder F -SF1-40AABS control unit -J104-30
2Fuse 2 on fuse holder F -SF2-30AABS control unit -J104-30
3Fuse 3 on fuse holder F -SF3-110AB170 Positive connection 2 (30) in interior wiring harness30
