Admin
Создатель сайта
Команда форума
- Россия, Москва
- VW Tiguan 2.0 DBGC 2018, VW Touran 1.6 BSE 2008
4-cylinder common rail engine (1.6 l and 2.0 l, 4 V, turbocharger, EA 288)
Engine code: DCYA, DDMA, DFGA, DFGB, CRFC, CYKB, DFHA, DCYB, DGDB, DBGA, CRGA, DFGC, CYKC, DBGC, CRGB, CRFZ, CRFD, DGTE, DFFA, DGTC, DGTD.
VW Tiguan 2 с 2016 года выпуска, Tiguan 2 RUS с 2017 года выпуска
VW T-Roc с 2018 года выпуска
VW T-Cross с 2019 года выпуска
VW Polo 6 с 2018 года выпуска
Contents:
00 - Technical data
1 Safety information
1.1 Safety regulations for working on fuel supply
1.2 Safety measures when working on vehicles with a start/stop system
1.3 Safety precautions when using testers and measuring instruments during a road test
1.4 Safety precautions when working on the cooling system
1.5 Safety precautions when working on the SCR system
1.6 Safety precautions when working on exhaust system
2 Identification
2.1 Engine number/engine data
3 Repair instructions
3.1 Rules for cleanliness
3.2 Foreign objects in engine
3.3 Contact corrosion
3.4 Routing and attachment of lines
3.5 Fitting radiator and condensers
4 Technical data
4.1 Coolant
10 - Removing and installing engine
1 Removing and installing engine
1.1 Removing engine
1.2 Separating engine and gearbox
1.3 Securing engine on engine and gearbox support
1.4 Installing engine
2 Assembly mountings
2.1 Assembly overview – assembly mountings
2.2 Removing and installing engine mounting
2.3 Removing and installing gearbox mounting
2.4 Removing and installing pendulum support
2.5 Supporting engine in installation position
2.6 Adjusting assembly mountings
2.7 Checking adjustment of assembly mountings
3 Engine cover panel
3.1 Removing and installing engine cover
13 - Crankshaft group
1 Cylinder block (pulley end)
1.1 Assembly overview - cylinder block (pulley end)
1.2 Assembly overview - sealing flange, belt pulley end
1.3 Removing and installing poly-V belt
1.4 Removing and installing tensioner for poly V-belt
1.5 Removing and installing vibration damper
1.6 Removing and installing bracket for ancillaries
1.7 Removing and installing engine support
1.8 Removing and installing sealing flange on pulley end
1.9 Renewing caps in cylinder block (pulley end)
2 Cylinder block, gearbox end
2.1 Assembly overview - cylinder block, gearbox end
2.2 Removing and installing flywheel
2.3 Removing and installing sealing flange on gearbox side
2.4 Renewing caps in cylinder block (gearbox end)
3 Crankshaft
3.1 Assembly overview - crankshaft
3.2 Crankshaft dimensions
3.3 Measuring axial clearance of crankshaft
3.4 Renewing needle bearing in crankshaft
4 Pistons and conrods
4.1 Assembly overview - pistons and conrods
4.2 Removing and installing pistons
4.3 Measuring piston projection at TDC
4.4 Checking pistons and cylinder bores
4.5 Checking radial clearance of conrods
15 - Cylinder head, valve gear
1 Cylinder head
1.1 Assembly overview - cylinder head
1.2 Assembly overview - cylinder head cover
1.3 Removing and installing cylinder head
1.4 Removing and installing cylinder head cover
1.5 Removing and installing injector seals
1.6 Removing and installing camshaft housing
1.7 Checking compression
2 Toothed belt drive
2.1 Assembly overview - toothed belt cover
2.2 Assembly overview - toothed belt
2.3 Removing and installing toothed belt guard
2.4 Removing and installing toothed belt
2.5 Removing toothed belt from camshaft
3 Valve gear
3.1 Assembly overview - valve gear
3.2 Measuring axial play of camshaft
3.3 Removing and installing camshaft oil seal
3.4 Removing and installing camshaft adjuster
3.5 Removing and installing camshaft control valve 1 N205
3.6 Checking hydraulic compensation elements
3.7 Removing and installing valve stem seals
3.8 Removing and installing control valve for the camshaft adjuster
4 Inlet and exhaust valves
4.1 Checking valve guides
4.2 Checking valves
4.3 Valve dimensions
17 - Lubrication
1 Sump, oil pump
1.1 Assembly overview - sump/oil pump
1.2 Engine oil:
1.3 Removing and installing sump
1.4 Removing and installing lower part of sump
1.5 Removing and installing upper part of sump
1.6 Removing and installing oil pump
1.7 Removing and installing oil level and oil temperature sender G266
2 Engine oil cooler
3 Oil filter, oil pressure switch
3.1 Assembly overview - oil filter housing, oil pressure switch
3.2 Removing and installing oil pressure switch F1
3.3 Removing and installing oil pressure switch for reduced oil pressure F378
3.4 Checking oil pressure
3.5 Removing and installing oil filter housing
3.6 Removing and installing oil pressure regulating valve N428
4 Oil circuit
4.1 Removing and installing oil supply line
4.2 Removing and installing oil return line for turbocharger
19 - Cooling
1 Cooling system/coolant
1.1 Connection diagram - coolant hoses
1.2 Checking cooling system for leaks
1.3 Draining coolant
1.4 Filling with coolant
1.5 Checking filling quality of cooling system
1.6 Checking electric vacuum pump VAS 6096/2
1.7 Flushing cooling system
2 Coolant pump, regulation of cooling system
2.1 Assembly overview - coolant pump, thermostat
2.2 Assembly overview - electric coolant pump
2.3 Assembly overview - coolant temperature sender
2.4 Removing and installing electric coolant pump
2.5 Removing and installing coolant pump
2.6 Removing and installing thermostat
2.7 Checking thermostat
2.8 Removing and installing coolant valve for cylinder head N489
2.9 Removing and installing coolant temperature sender G62
2.10 Removing and installing radiator outlet coolant temperature sender G83
3 Coolant pipes
3.1 Assembly overview - coolant pipes
3.2 Removing and installing coolant pipes
4 Radiator, radiator fan
4.1 Assembly overview - radiator/radiator fan
4.2 Assembly overview – radiator cowl and radiator fan
4.3 Removing and installing radiator
4.4 Removing and installing water radiator for charge air cooling circuit
4.5 Removing and installing radiator cowl
4.6 Removing and installing radiator fan
21 - Turbocharging/supercharging
1 Turbocharger
1.1 Assembly overview - turbocharger
1.2 Removing and installing turbocharger
1.3 Renewing vacuum unit for turbocharger
1.4 Removing and installing connection for turbocharger
2 Charge air system
2.1 Assembly overview - charge air system
2.2 Removing and installing charge pressure sender G31
2.3 Checking charge air system for leaks
2.4 Removing and installing air pipe
2.5 Checking charge air cooler for leaks
23 - Mixture preparation - injection 44
1 Injection system
1.1 Schematic overview - fuel system
1.2 Overview of fitting locations - injection system
1.3 Filling/bleeding fuel system
1.4 Checking fuel system for leaks
2 Vacuum system
2.1 Connection diagram - vacuum system
2.2 Checking vacuum system
3 Injectors/high-pressure accumulator (rail)
3.1 Assembly overview - injectors
3.2 Assembly overview - fuel rail
3.3 Adapting correction values for injectors
3.4 Testing injectors
3.5 Checking return flow rate of injectors with engine running
3.6 Checking return flow rate of injectors at starter speed
3.7 Testing jammed-open injectors
3.8 Removing and installing injectors
3.9 Removing and installing high-pressure lines
3.10 Removing and installing fuel rail
4 Air filter
4.1 Assembly overview - air filter housing
4.2 Removing and installing air filter housing
4.3 Removing and installing air guide on lock carrier
5 Intake manifold
5.1 Assembly overview – intake manifold
5.2 Removing and installing intake manifold
5.3 Removing and installing throttle valve module J338
6 Senders and sensors
6.1 Removing and installing fuel pressure regulating valve N276
6.2 Checking fuel pressure regulating valve N276
6.3 Removing and installing fuel pressure sender G247
6.4 Removing and installing air mass meter G70/intake air temperature sender G42
6.5 Removing and installing pressure differential sender G505
6.6 Removing and installing exhaust gas pressure sensor 1 G450
6.7 Removing and installing NOx sender 2 G687
6.8 Removing and installing charge air temperature sender ahead of charge air cooler G810
6.9 Removing and installing charge air temperature sender after charge air cooler G811
6.10 Removing and installing fuel temperature sender G81
6.11 Removing and installing control unit for NOx sender GX30
6.12 Removing and installing temperature and pressure sender for low-pressure fuel system GX20
7 Engine/motor control unit
7.1 Removing and installing engine control unit J623
7.2 Removing and installing engine control unit J623 (with protective housing)
8 High-pressure pump
8.1 Assembly overview - high-pressure pump
8.2 Removing and installing high-pressure pump
9 Lambda probe
9.1 Assembly overview - Lambda probe
9.2 Removing and installing Lambda probe
26 - Exhaust system
1 Exhaust pipes and silencers
1.1 Assembly overview – silencers
1.2 Assembly overview - front exhaust pipe
1.3 Removing and installing front exhaust pipe
1.4 Separating exhaust pipes from silencers
1.5 Removing and installing silencer
1.6 Aligning exhaust system free of stress
1.7 Checking exhaust system for leaks
1.8 Installation position of clamp
1.9 Align end exhaust pipes
1.10 Removing and installing bracket for front exhaust pipe
2 Emission control
2.1 Assembly overview – emission control
2.2 Removing and installing catalytic converter
2.3 Removing and installing particulate filter
2.4 Removing and installing emission control module
2.5 Removing and installing exhaust flap control unit J883
3 SCR system (selective catalytic reduction)
3.1 Assembly overview - tank for reducing agent
3.2 Assembly overview - reducing agent supply line
3.3 Assembly overview - delivery module for reducing agent
3.4 Assembly overview – filler tube for reducing agent tank
3.5 Removing and installing reducing agent tank
3.6 Removing and installing front section of reducing agent supply line
3.7 Removing and installing delivery module for reducing agent
3.8 Removing and installing injector for reduction agent N474
3.9 Removing and installing control unit for reducing-agent heater J891
3.10 Assembly overview - injector for reducing agent
3.11 Draining reducing agent tank
3.12 Removing and installing rear section of reducing agent supply line
3.13 Removing and installing filler pipe for reducing agent tank
3.14 Disconnecting reducing agent supply line
3.15 SCR - resetting learnt values
4 Exhaust gas temperature regulation
4.1 Assembly overview – exhaust gas temperature regulation
4.2 Removing and installing exhaust gas temperature sender 1 G235
4.3 Removing and installing exhaust gas temperature sender 2 G448
4.4 Removing and installing exhaust gas temperature sender 3 G495
4.5 Removing and installing exhaust gas temperature sender 4 G648
5 Exhaust gas recirculation
5.1 Assembly overview – exhaust gas recirculation
5.2 Assembly overview - exhaust gas recirculation valve 1 GX5
5.3 Removing and installing exhaust gas recirculation cooler
5.4 Removing and installing exhaust gas recirculation valve 1 GX5
5.5 Removing and installing exhaust gas recirculation valve 2 GX6
5.6 Removing and installing exhaust gas recirculation temperature sensor G98
5.7 Checking exhaust gas recirculation cooler for leaks
28 - Glow plug system
1 Glow plug system
1.1 Assembly overview - glow plug system
1.2 Removing and installing glow plug
1.3 Removing and installing automatic glow period control unit J179
1.4 Removing and installing Hall sender G40
1.5 Removing and installing engine speed sender G28
vwts.ru
Contents:
00 - Technical data
2 Identification
4 Technical data
4.1 Coolant
1.1 Removing engine
3 Crankshaft
1 Cylinder head
3 Valve gear
4.2 Checking valves
17 - Lubrication
1 Sump, oil pump
1.2 Engine oil:
2 Engine oil cooler
4 Oil circuit
19 - Cooling
3 Coolant pipes
1 Turbocharger
2 Charge air system
1 Injection system
2 Vacuum system
4 Air filter
5 Intake manifold
9 Lambda probe
26 - Exhaust system
2 Emission control
1 Glow plug system
Скачивание файла -engine-dcya-ddma-dfga-dfgb-crfc-cykb-dfha-dcyb-dgdb-dbga-crga-dfgc-cykc-dbgc-crgb-crfz-crfd-dgte-dffa-dgtc-dgtd-repair-manual-eng.pdf
Документация по ремонту VW Skoda Audi Seat - repair manual
