Admin
Создатель сайта
Команда форума
- Россия, Москва
- VW Tiguan 2.0 DBGC 2018, VW Touran 1.6 BSE 2008
1.6L Engine DGTE, DGTC, DGTD 4-cylinder common rail, 4V, turbocharger, EA 288
Engine specifications:
1.6l diesel engine, DGTC, DGTD, from front
1 - Fuel metering valve -N290-
2 - Hall sender -G40-
3 - Charge air temperature sender after charge air cooler -G811-
4 - Charge pressure sender -G31-
5 - Exhaust gas recirculation valve 1 -GX5-
6 - Oil pressure switch for reduced oil pressure -F378-
7 - Oil pressure switch -F1-
8 - Charge air cooling pump -V188-
9 - Air conditioner compressor regulating valve -N280-
10 - Valve for oil pressure control -N428-
11 - Alternator with voltage regulator -CX1-
1.6l diesel engine, DGTC, DGTD, from above
1 - Injector, cylinder 1 -N30-
2 - Pressure differential sender -G505-
3 - Injector, cylinder 2 -N31-
4 - Injector, cylinder 3 -N32-
5 - Injector, cylinder 4 -N33-
6 - Fuel pressure regulating valve -N276-
7 - Glow plug 4 -Q13-
8 - Glow plug 3 -QX3-
9 - Glow plug 2 -Q11-
10 - Glow plug 1 -Q10-
11 - Fuel temperature sender -G81-
12 - Coolant valve for cylinder head -N489-
13 - Fuel pressure sender -G247-
1.6l diesel engine, DGTC, DGTD, from left
1 - Intake air temperature sender -G42-
2 - Heater element for crankcase breather -N79-
3 - Coolant temperature sender -G62-
4 - Engine speed sender -G28-
5 - Throttle valve module -GX3-
1.6l diesel engine, DGTC, DGTD, from rear
1 - Position sender for charge pressure positioner -G581-
2 - Lambda probe 1 before catalytic converter -GX10-
3 - NOx sender -G295-
4 - Exhaust gas temperature sender 3 -G495-
5 - Injector for reducing agent -N474-
6 - Exhaust gas temperature sender 2 -G448-
7 - Exhaust gas temperature sender 1 -G235-
8 - Exhaust gas temperature sender 4 -G648-
9 - Auxiliary pump for heating -V488-
10 - Oil level and oil temperature sender -G266-
11 - Exhaust gas recirculation valve 2 -GX6-
12 - Charge pressure control solenoid valve -N75-
| Engine code | DGTE | DGTC | DGTD |
| Injection system Exhaust emissions fulfil Displacement l Power kW at rpm Torque Nm at rpm Bore Diameter, mm Stroke mm Compression ratio Fuel: acc. to Firing order Exhaust gas recirculation | Delphi EU 6 1.598 85/3250 to 4000 250/1750 to 3200 79.5 80.5 16.2 DIN EN 590 1–3–4–2 yes | Delphi EU 6 1.598 59/2750 to 4800 230/1400 to 2400 79.5 80.5 16.2 DIN EN 590 1–3–4–2 yes | Delphi EU 6 1.598 70/2750 to 4600 250/1500 to 2600 79.5 80.5 16.2 DIN EN 590 1–3–4–2 yes |
| Exhaust gas temperature regulation Balancer shafts Charging Charge air cooling Lambda regulation Emission control module or particulate filter installed SCR catalytic converter Valves per cylinder | yes no Turbo‐charger yes 1 lambda probe Emission control module yes 4 | yes no Turbo‐charger yes 1 lambda probe Emission control module yes 4 | yes no Turbo‐charger yes 1 lambda probe Emission control module yes 4 |
