Руководство Fitting locations engine DADA, DACA, DACB, DPBA, DPBE, DPCA, DFYA - технические характеристики, расположение компонентов
Admin
Admin
Создатель сайта
Команда форума
Россия, Москва
VW Tiguan 2.0 DBGC 2018, VW Touran 1.6 BSE 2008
Engine DADA, DACA, DACB, DPBA, DPBE, DPCA, DFYA: 4-cylinder direct injection engine 1.5 L, 4V, EA 211, turbocharger
Engine specifications
Engine codeDADADACADACBDPBADPBEDPCADFYA
Exhaust emission standardEU 6EU 6EU 6EU 6EU 6EU 6EU 6
Displacement cm 3
Power kW at rpm
Torque Nm at rpm
Bore ∅ mm
Stroke mm
Compression ratio
Valves per cylinder
Charging
RON min.
Injection, ignition system
Firing order
1,495
110/5000
250/1500-3500
74.5
85.7
10.5
4
Turbo‐charger
(traditional)
95 unleaded (E10)
Bosch Motronic MG 1
1-3-4-2
1495
96/5000
200/1400-4000
74.5
85.7
12.5 – Miller cycle
4
Turbo‐charger (variable
turbo‐charger geometry)
95 unleaded (E10)
Bosch Motronic MG 1
1-3-4-2
1498
96/5000-6000
220/1750-3500
74.5
85.9
12.5 – Miller cycle
4
95 unleaded (E10)
Bosch Motronic MG 1
1-3-4-2
1495
96/5000
200/1400-4000
74.5
85.7
12.5 – Miller cycle
4
95 unleaded (E10)
Bosch Motronic MG 1
1-3-4-2
1498
96/5000-6000
220/1750-3500
74.5
85.9
12.5 – Miller cycle
4
95 unleaded (E10)
Bosch Motronic MG 1
1-3-4-2
1495
110/5000
250/1500-3500
74.5
85.7
10.5
4
Turbo‐charger
(wastegate)
95 unleaded (E10)
Bosch Motronic MG 1
1-3-4-2
1498
110/5000
250/1500-3500
74.5
85.9
10.5
4
Turbocharger
(wastegate)
95 unleaded (E10)
Bosch Motronic MG 1 - CS011
1-3-4-2
1.5l petrol engine, DADA, DPCA, from front
1 - Pressure sensor for activated charcoal filter air flushing -GX44-
2 - Activated charcoal filter solenoid valve 1 -N80-
3 - Engine temperature regulation module -GX33-
4 - Inlet camshaft position sender -G1002-
5 - Charge pressure sender -GX26-
6 - Knock sensor 1 -G61-
7 - Engine speed sender -G28-
8 - Charge air cooling pump -V188-
9 - Air conditioner compressor regulating valve -N280-
10 - Alternator with voltage regulator -CX1-
11 - Fuel pressure sender -G247-
12 - Vacuum pump for brakes -V192-
13 - Oil pressure sender -G10-
14 - Injector, cylinder 1 -N30-
15 - Injector, cylinder 2 -N31-
16 - Injector, cylinder 3 -N32-
17 - Injector, cylinder 4 -N33-
1.5l petrol engine, DADA, DPCA, from above
1 - Exhaust camshaft control valve 1 -N318-
2 - Exhaust camshaft position sender -G1003-
3 - Exhaust cam actuator for cylinder 2 -N587-
4 - Exhaust gas pressure sensor 1 -G450-
5 - Exhaust cam actuator for cylinder 3 -N595-
6 - Fuel metering valve -N290-
7 - Ignition coil 4 with output stage -N292-
8 - Ignition coil 3 with output stage -N291-
9 - Inlet cam actuator for cylinder 3 -N591-
10 - Inlet cam actuator for cylinder 2 -N583-
11 - Ignition coil 2 with output stage -N127-
12 - Ignition coil 1 with output stage -N70-
1.5l petrol engine, DADA, DPCA, from right
1 - Inlet camshaft control valve 1 -N727-
2 - Intake manifold sender -GX9-
3 - Throttle valve module -GX3-
4 - Valve for oil pressure control -N428-
1.5l petrol engine, DADA, DPCA, from rear
1 - Lambda probe 1 before catalytic converter -GX10-
2 - Lambda probe 1 after catalytic converter -GX7-
3 - Oil level and oil temperature sender -G266-
4 - Engine outlet coolant temperature sender -G82-
5 - Coolant temperature sender -G62-
6 - Charge pressure control module -GX34-
