Руководство Fuses VW Polo 6 2018-2022 (AW1, AE1) - предохранители и реле
Admin
Admin
Создатель сайта
Команда форума
Россия, Москва
VW Tiguan 2.0 DBGC 2018, VW Touran 1.6 BSE 2008
Автомобиль
VW Polo 6
Двигатель
all
Fuses Volkswagen Polo 6 (model AW1) 2018 - 2021
Fuses Volkswagen Polo 6 restyling (model AE1) 2022 -
Предохранители Фольксваген Поло 6
Contents:
Fuse holder A -SA-, from June 2017
Fuse holder B -SB-, sales type AW1, from June 2017
Fuse holder B -SB-, sales type AW1, from November 2017
Fuse holder B -SB-, sales type AW1, from November 2018
Fuse holder B -SB,- sales type AW1, from July 2019
Fuse holder B -SB-, sales type AW1, from July 2020
Fuse holder B -SB-, sales type AE1, from June 2021
Fuse holder C -SC-, sales type AW1, from June 2017
Fuse holder C -SC-, sales type AW1, from November 2017
Fuse holder C -SC-, sales type AW1, from July 2018
Fuse holder C -SC-, sales type AW1, from July 2019
Fuse holder C -SC-, sales type AW1, from July 2020
Fuse holder C -SC-, sales type AE1, from June 2021
Fuse holder D -SD-, from November 2017
Fuse holder A -SA-, VW Polo 6
Fitting location of fuse holder A -SA-, VW Polo 6 from June 2017
The fuse strip (multifuse) can be replaced as a complete unit.
1 - Fuse holder A -SA
Fuse assignment for fuse holder A -SA-, VW Polo 6 from June 2017
SlotCurrent flow diagram designationNominal valueFunction / componentTermi
nal
508508 Threaded connection (30), on E-box-Battery -A- 4)
Fuse 4 on fuse holder D -SD4- 3)
30
SA1Fuse 1 on fuse holder A -SA1-250A 3)
350 A 4)
Starter -B
Alternator with voltage regulator -CX1-
30
SA2Fuse 2 on fuse holder A -SA2-80 Anot assigned30
SA3Fuse 3 on fuse holder A -SA3-150 AFuse holder B -SB-
Fuse 10 on fuse holder B -SB10-
Fuse 14 on fuse holder B -SB14-
Fuse 15 on fuse holder B -SB15-
Fuse 20 on fuse holder B -SB20-
Fuse 21 on fuse holder B -SB21-
Fuse 24 on fuse holder B -SB24-
Fuse 26 on fuse holder B -SB26-
Main relay -J271-
Radiator fan 2nd speed relay -J101- 1)2)
Radiator fan relay -J26- 1)2)
Starter relay 1 -J906-
30
SA4Fuse 4 on fuse holder A -SA4-80 AFuse holder C -SC-
Fuse 3 on fuse holder C -SC3-
Fuse 5 on fuse holder C -SC5-
Fuse 6 on fuse holder C -SC6-
Fuse 11 on fuse holder C -SC11- - fuse 19 on fuse holder C -SC19-
Fuse 20 on fuse holder C -SC20-
Fuse 23 on fuse holder C -SC23- - fuse 25 on fuse holder C -SC25-
Fuse 38 on fuse holder C -SC38-
Fuse 48 on fuse holder C -SC48-
30
SA5Fuse 5 on fuse holder A -SA5-125 AFuse holder C -SC-
Fuse 1 on fuse holder C -SC1-
Fuse 8 on fuse holder C -SC8-
Fuse 10 on fuse holder C -SC10-
Fuse 26 on fuse holder C -SC26- - fuse 37 on fuse holder C -SC37-
Fuse 53 on fuse holder C -SC53-
Fuse 59 on fuse holder C -SC59-
Fuse 60 on fuse holder C -SC60-
Fuse 61 on fuse holder C -SC61-
Terminal 15 voltage supply relay -J329-
Terminal 75x voltage supply relay -J694-
30
SA6Fuse 6 on fuse holder A -SA6-80 APower steering control unit -J500-30
1) For petrol engine with no forced induction
2) For models with air conditioning system
3) For models with battery at rear
4) For models with battery at front
Fitting location of fuse holder B -SB-, sales type AW1, VW Polo 6 from June 2017
For models with sales type AW1
1 - Fuse holder B -SB-
Fuse colours, for J-Case fuse:
50 A - red
40 A - green
30 A - pink
Fuse colour for ATO flat fuse:
40 A - orange
30 A - light green
25 A - natural (white)
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
Fuse assignment for fuse holder B -SB-, sales type AW1, VW Polo 6 from June 2017
Note: For models with sales type AW1
value
nal
SB1Fuse 1 on fuse holder B -SB1-10 A 1)
15 A 2)
Engine/motor control unit -J623-87
SB2Fuse 2 on fuse holder B -SB2-7.5 ACharge air cooling pump -V188- 3)
Fuel pressure regulating valve -N276- 3)
87
SB3Fuse 3 on fuse holder B -SB3-15 ALambda probe 1 before catalytic converter -GX10-
Lambda probe 1 after catalytic converter -GX7-
87
SB4Fuse 4 on fuse holder B -SB4-15 AFuel pump control unit -J538- 2)
Fuel pump relay -J17-1)
87
SB5Fuse 5 on fuse holder B -SB5-7.5 A
4)
10 A
4)
15 A
4)
Radiator fan -VX57-2)
Activated charcoal filter solenoid valve 1 -N80-
Camshaft control valve 1 -N205-
Exhaust camshaft control valve 1 -N318-2)
Valve for oil pressure control -N428- 2)
Oil level and oil temperature sender -G266-
High-pressure valve for gas mode -N372-
87
SB6Fuse 6 on fuse holder B -SB6-20 AIgnition coil 1 with output stage -N70-
Ignition coil 2 with output stage -N127-
Ignition coil 3 with output stage -N291-
87
SB7Fuse 7 on fuse holder B -SB7-15 AVacuum pump for brakes -V192-87
SB8Fuse 8 on fuse holder B -SB8-10 AFuel pump relay -J17-1)
Injector, cylinder 1 -N30-1)
Injector, cylinder 2 -N31-1)
Injector, cylinder 3 -N32-1)
Gas injection valve 1 -N366-4)
Gas injection valve 2 -N367-4)
Gas injection valve 3 -N368-4)
87
SB9Fuse 9 on fuse holder B -SB9-7.5 ABrake light switch -F-87
SB10Fuse 10 on fuse holder B -SB10-7.5 ABattery monitor control unit -J367-
Onboard supply control unit -J519-7)
Data bus diagnostic interface -J533- 8)
30
SB11not assigned--
SB12not assigned--
SB13not assigned--
SB14Fuse 14 on fuse holder B -SB14-7.5 AEngine/motor control unit -J623-
ABS control unit -J104-
Main relay -J271-
30
SB15Fuse 15 on fuse holder B -SB15-30 AMechatronic unit for dual clutch gearbox -J743-30
SB16not assigned--
SB17Fuse 17 on fuse holder B -SB17-7.5 AEngine/motor control unit -J623-50
SB18Fuse 18 on fuse holder B -SB18-30 AStarter -B-50
SB19not assigned--
SB20Fuse 20 on fuse holder B -SB20-40 AABS control unit -J104-30
SB21Fuse 21 on fuse holder B -SB21-25 AABS control unit -J104-30
SB22not assigned--
SB23not assigned--
SB24Fuse 24 on fuse holder B -SB24-30 ARadiator fan thermal switch -F18-30
SB25Fuse 25 on fuse holder B -SB25-20 ARadiator fan -VX57- 1) 5)87
SB26Fuse 26 on fuse holder B -SB26-6)50 ARadiator fan -VX57- 2)30
SB27Fuse 27 on fuse holder B -SB27-30 ARadiator fan -VX57- 1) 5)87
SB28not assigned--
SB29not assigned--
2) For petrol engine with forced induction
3) According to equipment
4) For models with natural gas engine
5) For models with air conditioning system
6) Fitting location on bottom of fuse holder B -SB-
7) For models without separate data bus diagnostic interface
8) For models with separate data bus diagnos
Fitting location of fuse holder B -SB-, sales type AW1, VW Polo 6 from November 2017
95086
Fuse assignment for fuse holder B -SB-, sales type AW1, VW Polo 6 from November 2017
value
Function / componentTerminal
15 A 2)
30 A 7)
10 A
8)
Fuel pressure sender for low pressure -G410- 8)
Activated charcoal filter solenoid valve 1 -N80- 8)
Camshaft control valve 1 -N205- 8)
Exhaust camshaft control valve 1 -N318-8)
Valve for oil pressure control -N428- 7)
Coolant valve for cylinder head -N489- 7)
Charge air cooling pump -V188- 3)7)10)
Coolant pump for high-temperature circuit -V467- 7)
Auxiliary pump for heating -V488- 8)
87
SB3Fuse 3 on fuse holder B -SB3-15 ALambda probe 1 after catalytic converter -GX7-
Control unit for NOx sender -GX30- 7)
Control unit 2 for NOx sender -GX46- 7)
87
87
1)
9)
10)
10 A
4)
7)
15 A
1)
8)
Turbocharger air recirculation valve -N249- 8)
Intake manifold flap valve -N316- 8)
Piston cooling jet control valve -N522-8)
Inlet camshaft control valve 1 -N727-
Oil level and oil temperature sender -G266-7)8)10)
Charge pressure control solenoid valve -N75- 2)
87
7.5 A
7)
Automatic glow period control unit -J179-7)
Heater element for crankcase breather -N79- 7)
87
SB7Fuse 7 on fuse holder B -SB7-10 A
8)
15 A
Coolant shut-off valve -N82-8)
Coolant valve for gearbox -N488-8)
87
Injector 2, cylinder 1 -N532-8)
Injector 2, cylinder 2 -N533-8)
Injector 2, cylinder 3 -N534-8)
Injector 2, cylinder 4 -N535-8)
Exhaust cam actuator A for cylinder 1 -N580-8)
Exhaust cam actuator B for cylinder 1 -N581-8)
Exhaust cam actuator A for cylinder 2 -N588-8)
Exhaust cam actuator B for cylinder 2 -N589-8)
Exhaust cam actuator A for cylinder 3 -N596-8)
Exhaust cam actuator B for cylinder 3 -N597-8)
Exhaust cam actuator A for cylinder 4 -N604-8)
Exhaust cam actuator B for cylinder 4 -N605-8)
87
SB10Fuse 10 on fuse holder B -SB10-7.5 ABattery monitor control unit -J367-3)
Onboard supply control unit -J519-11)
Data bus diagnostic interface -J533- 12)
30
SB11not assigned--
SB12not assigned--
SB13not assigned--
Main relay -J271-
30
SB15Fuse 15 on fuse holder B -SB15-30 A 13)
15 A 14)
SB16not assigned--
SB19not assigned--
SB20Fuse 20 on fuse holder B -SB20-60 AABS control unit -J104-30
SB22not assigned--
SB23not assigned--
SB25Fuse 25 on fuse holder B -SB25-20 A 1) 5)
40 A 7)
Radiator fan -VX57-1)5)
Auxiliary air heater element -Z35-7)
87
SB26Fuse 26 on fuse holder B -SB26-6)50 ARadiator fan -VX57-2)30
SB27Fuse 27 on fuse holder B -SB27-30 A 1) 5)
40 A 7)
87
SB28Fuse 28 on fuse holder B -SB28-40 A 7)Auxiliary air heater element -Z35-7)87
SB29not assigned--
7) For models with 1.6l diesel engine
8) For models with 2.0l petrol engine
9) For models with 1.6l petrol engine
10) For models with 1.0l petrol engine
11) For models without separate data bus diagnostic interface
12) For models with separate data bus diagnostic interface
13) For models with dual clutch gearbox 0CW
14) For models with dual clutch gearbox 0D9
Fitting location of fuse holder B -SB-, sales type AW1, VW Polo 6 from November 2018
95086
Fuse assignment for fuse holder B -SB-, sales type AW1, VW Polo 6 from November 2018
value
15 A 2)
30 A 7)
10 A
8)
Fuel metering valve -N290-10)
Charge air cooling pump -V188- 3)7)10) 15)
87
87
87
SB5Fuse 5 on fuse holder B -SB5-10 ARadiator fan -VX57-2)
Inlet cam actuator for cylinder 2 -N583-15)
Exhaust cam actuator for cylinder 2 -N587-15)
Inlet cam actuator for cylinder 3 -N591-15)
Exhaust cam actuator for cylinder 3 -N595-15)
Oil level and oil temperature sender -G266-7)8)10)15)
Charge pressure control solenoid valve -N75- 7)
87
7.5 A
7)
87
8)
15 A
87
SB8Fuse 8 on fuse holder B -SB8-10 AInjector, cylinder 1 -N30-1)
Injector, cylinder 4 -N33-1)
87
30
SB11not assigned--
SB12not assigned--
SB13not assigned--
Electronic stabilisation program control unit -J981-
Main relay -J271-
30
15 A 14)
SB16not assigned--
SB19not assigned--
SB22not assigned--
SB23not assigned--
40 A 7)
87
40 A 7)
87
7)
SB29not assigned--
15) For models with 1.5l petrol engine
Fitting location of fuse holder B -SB-, sales type AW1, VW Polo 6 from July 2019
95086
Fuse assignment for fuse holder B -SB-, sales type AW1, VW Polo 6 from July 2019
value
1)
15 A
2)
30 A
7)
10 A
8)
87
87
87
87
7.5 A
7)
87
8)
15 A
87
87
30
SB11not assigned--
SB12Fuse 12 on fuse holder B -SB12-10 AMagnetic clutch relay -J44-30
SB13not assigned--
Main relay -J271-
30
13)
15 A
14)
SB16not assigned--
SB19not assigned--
SB22not assigned--
SB23not assigned--
1)5)
40 A
7)
87
1)5)
40 A
7)
87
7)
SB29not assigned--
Fitting location of fuse holder B -SB-, sales type AW1, VW Polo 6 from July 2020
95086
Fuse assignment for fuse holder B -SB-, sales type AW1, VW Polo 6 from July 2020
value
15 A 2)
30 A 7)
10 A
8)
Auxiliary pump for heating -V488-8)17)
87
87
Engine component current supply relay -J757-17)
87
Valve for oil pressure control -N428-2)8)
Piston cooling jet control valve -N522-8)10)
Oil level and oil temperature sender -G266- 7)8)10)15)17)
87
7.5 A
7)
87
8)
15 A
87
SB8Fuse 8 on fuse holder B -SB8-10 AEngine component current supply relay -J757-8)
87
30
SB11Fuse 11 on fuse holder B -SB11-30 AAuxiliary hydraulic pump 1 for gearbox oil -V475-16)30
SB13not assigned--
Main relay -J271-
30
15 A 14) 16)
SB16not assigned--
SB19not assigned--
SB22not assigned--
SB23not assigned--
40 A 7)
87
40 A 7)
87
SB29not assigned--
8) For models with 2.0l petrol engine with engine code CZPC, DKZC
16) For models with dual clutch gearbox 0GC
17) For models with 2.0l petrol engine with engine code DNND
Fitting location of fuse holder B -SB-, sales type AE1, VW Polo 6 from June 2021
95086
Fuse assignment for fuse holder B -SB-, sales type AE1, VW Polo 6 from June 2021
Note: For models with sales type AE1
value
15 A 2)
10 A
7)
Fuel pressure sender for low pressure -G410- 7)
Activated charcoal filter solenoid valve 1 -N80- 7)
Camshaft control valve 1 -N205- 7)
Fuel metering valve -N290-8)
Exhaust camshaft control valve 1 -N318-7)
Valve for oil pressure control -N428- 8)
Charge air cooling pump -V188- 3)8)13)
Auxiliary pump for heating -V488-7)15)
87
87
Engine component current supply relay -J757-15)
87
Turbocharger air recirculation valve -N249- 7)
Intake manifold flap valve -N316- 7)
Valve for oil pressure control -N428-2)7)
Piston cooling jet control valve -N522-7)8)
Inlet cam actuator for cylinder 2 -N583-13)
Exhaust cam actuator for cylinder 2 -N587-13)
Inlet cam actuator for cylinder 3 -N591-13)
Exhaust cam actuator for cylinder 3 -N595-13)
Oil level and oil temperature sender -G266-7)8)13)15)
87
87
SB7Fuse 7 on fuse holder B -SB7-10 A 7)
15 A 2)
Coolant shut-off valve -N82-7)
Coolant valve for gearbox -N488-7)
Vacuum pump for brakes -V192-2)
87
SB8Fuse 8 on fuse holder B -SB8-10 AEngine component current supply relay -J757-7)
Injector 2, cylinder 1 -N532-7)
Injector 2, cylinder 2 -N533-7)
Injector 2, cylinder 3 -N534-7)
Injector 2, cylinder 4 -N535-7)
Exhaust cam actuator A for cylinder 1 -N580-7)
Exhaust cam actuator B for cylinder 1 -N581-7)
Exhaust cam actuator A for cylinder 2 -N588-7)
Exhaust cam actuator B for cylinder 2 -N589-7)
Exhaust cam actuator A for cylinder 3 -N596-7)
Exhaust cam actuator B for cylinder 3 -N597-7)
Exhaust cam actuator A for cylinder 4 -N604-7)
Exhaust cam actuator B for cylinder 4 -N605-7)
87
Onboard supply control unit -J519-9)
Data bus diagnostic interface -J533- 10)
30
SB11Fuse 11 on fuse holder B -SB11-30 AAuxiliary hydraulic pump 1 for gearbox oil -V475-14)30
SB13not assigned--
Main relay -J271-
30
SB15Fuse 15 on fuse holder B -SB15-30 A 11)
15 A 12) 14)
SB16not assigned--
SB19not assigned--
Suppression filter -C10-16)
30
SB22not assigned--
SB23not assigned--
SB25Fuse 25 on fuse holder B -SB25-20 A 1) 5)Radiator fan -VX57-1)5)87
SB26Fuse 26 on fuse holder B -SB26-6)50 A 2)Radiator fan -VX57-2)30
SB27Fuse 27 on fuse holder B -SB27-30 A 1) 5)Radiator fan -VX57-1)5)87
SB28not assigned--
SB29not assigned--
7) For models with 2.0l petrol engine with engine code CZPC, DKZC
8) For models with 1.0l petrol engine
9) For models without separate data bus diagnostic interface
10) For models with separate data bus diagnostic interface
11) For models with dual clutch gearbox 0CW
12) For models with dual clutch gearbox 0D9
13) For models with 1.5l petrol engine
14) For models with dual clutch gearbox 0GC
15) For models with 2.0l petrol engine with engine code DNND
16) For models with battery in luggage compartment
Fuse holder C -SC-, sales type AW1, VW Polo 6
Fitting location of fuse holder C -SC-, sales type AW1, VW Polo 6 from June 2017
Note: For left-hand drive models
1 - Fuse holder C -SC-
50 A - red
40 A - green
30 A - pink
40 A - orange
30 A - light green
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
Fuse colours, for mini fuses:
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
Fuse assignment for fuse holder C -SC-, sales type AW1, VW Polo 6 from June 2017
value
SC1Fuse 1 on fuse holder C -SC1-20 ATrailer detector control unit -J345-30
SC2not assigned--
SC3Fuse 3 on fuse holder C -SC3-30 AAmplifier -R12-30
SC4not assigned--
SC5Fuse 5 on fuse holder C -SC5-30 ASliding sunroof adjustment control unit -J245-30
SC6Fuse 6 on fuse holder C -SC6-40 AOnboard supply control unit -J519-30
SC7not assigned--
SC8Fuse 8 on fuse holder C -SC8-30 AFresh air blower control unit -J126-30
SC9not assigned--
SC10Fuse 10 on fuse holder C -SC10-20 ATrailer detector control unit -J345-30
SC11Fuse 11 on fuse holder C -SC11-7.5 ARelay for gas shut-off valves -J908-1)30
SC12Fuse 12 on fuse holder C -SC12-7.5 AFront left seat belt -NX10-2)
Front right seat belt -NX11-3)
30
SC13Fuse 13 on fuse holder C -SC13-7.5 ARain and light sensor -G397-
Diagnostic connection -U31-
Rotary light switch -EX1-
Steering column electronics control unit -J527-
30
SC14Fuse 14 on fuse holder C -SC14-10 ASteering column electronics control unit -J527-30
SC15Fuse 15 on fuse holder C -SC15-7.5 ADash panel insert -KX2-30
SC16Fuse 16 on fuse holder C -SC16-40 AOnboard supply control unit -J519-30
SC17Fuse 17 on fuse holder C -SC17-30 ARear right door control unit -J389-
Driver door control unit -J386- 3)
Front passenger door control unit -J387-2)
30
SC18Fuse 18 on fuse holder C -SC18-30 AOnboard supply control unit -J519-30
SC19Fuse 19 on fuse holder C -SC19-25 AControl unit 1 for information electronics -J794-30
SC20Fuse 20 on fuse holder C -SC20-30 AOnboard supply control unit -J519-30
SC21Fuse 21 on fuse holder C -SC21-30 AControl unit for reducing agent heater -J891-30
SC22not assigned--
SC23Fuse 23 on fuse holder C -SC23-7.5 ARear lid handle -EX37-
Rear lid handle release button -E234-
30
SC24Fuse 24 on fuse holder C -SC24-5 AChip card reader control unit -J676-
Storage compartment with interface for mobile telephone -R265-
USB hub -R293-
Transmission and reception stabilisation control unit -R308-
TV tuner -R78-
CD player -R89-
Display unit for front information display and operating unit control unit -J685-
30
SC25Fuse 25 on fuse holder C -SC25-7.5 ASteering column electronics control unit -J527-4)30
SC26Fuse 26 on fuse holder C -SC26-7.5 AData bus diagnostic interface -J533-30
SC27Fuse 27 on fuse holder C -SC27-7.5 AElectronically controlled damping control unit -J250-30
SC28Fuse 28 on fuse holder C -SC28-7.5 AAnti-theft alarm sensor -G578-30
SC29Fuse 29 on fuse holder C -SC29-7.5 AAnti-theft alarm system horn -H8-30
SC30Fuse 30 on fuse holder C -SC30-7.5 AFront left seat belt -NX10-3)
Front right seat belt -NX11-2)
30
SC31Fuse 31 on fuse holder C -SC31-7.5 A
5)
15 A
6)
Heater and air conditioning controls -EX21-30
SC32Fuse 32 on fuse holder C -SC32-7.5 ASteering column electronics control unit -J527-30
SC33Fuse 33 on fuse holder C -SC33-30 ADriver door control unit -J386- 2)
Front passenger door control unit -J387-3)
Rear left door control unit -J388-
30
SC34not assigned--
SC35Fuse 35 on fuse holder C -SC35-40 AOnboard supply control unit -J519-30
SC36Fuse 36 on fuse holder C -SC36-20 AOnboard supply control unit -J519-30
SC37Fuse 37 on fuse holder C -SC37-30 ASeat heating control unit -J882-30
SC38Fuse 38 on fuse holder C -SC38-30 AOnboard supply control unit -J519-30
SC39Fuse 39 on fuse holder C -SC39-10 AAdaptive cruise control unit -J428-
Parking aid control unit -J446-
Blind Spot Monitor control unit -J1086-
Blind Spot Monitor control unit 2 -J1087-
15
SC40Fuse 40 on fuse holder C -SC40-7.5 ADiagnostic connection -U31-
Front left headlight -MX1-7)
Front right headlight -MX2-7)
Headlight range control regulator -E102-
Switch module 1 in centre console -EX23-
Reversing light switch -F4-
Automatic anti-dazzle interior mirror -Y7-
15
SC41Fuse 41 on fuse holder C -SC41-7.5 AExterior mirror adjuster -EX11-15
SC42Fuse 42 on fuse holder C -SC42-7.5 AStarter relay 1 -J906-
Starter relay 2 -J907-
Clutch position sender -G476- 8)
Pressure sender for refrigerant circuit -G805-5)
15
SC43Fuse 43 on fuse holder C -SC43-15 ARear window wiper motor -V12-
Washer pump relay -J576- 9)
15
SC44Fuse 44 on fuse holder C -SC44-7.5 AAirbag control unit -J234-
Warning lamp for airbag deactivated on front passenger side -K145-
15
SC45Fuse 45 on fuse holder C -SC45-7.5 AFront left headlight -MX1-10)15
SC46Fuse 46 on fuse holder C -SC46-7.5 AFront right headlight -MX2-10)15
SC47not assigned-
SC48Fuse 48 on fuse holder C -SC48-7.5 AControl unit for electronic steering column lock -J764-
Interface for entry and start system -J965-
30
SC49Fuse 49 on fuse holder C -SC49-7.5 ARelay for reducing agent metering system -J963-30
SC50not assigned--
SC51not assigned--
SC52not assigned--
SC53Fuse 53 on fuse holder C -SC53-7.5 AIgnition key withdrawal lock solenoid -N376-11)
Selector lever -E313-
30
SC54not assigned--
SC55Fuse 55 on fuse holder C -SC55-20 ACigarette lighter -U1-75
SC56Fuse 56 on fuse holder C -SC56-30 AHeater and air conditioning controls -EX21-75
SC57not assigned--
SC58Fuse 58 on fuse holder C -SC58-7.5 AWindscreen and rear window washer pump -V59-53
SC59Fuse 59 on fuse holder C -SC59-10 AOnboard supply control unit -J519-30
SC60Fuse 60 on fuse holder C -SC60-30 ATrailer detector control unit -J345-30
SC61Fuse 61 on fuse holder C -SC61-30 ATrailer detector control unit -J345-30
1) For models with natural gas engine
2) For left-hand drive models
3) For right-hand drive models
4) For models with multifunction steering wheel
6) For models with Climatronic
7) For models with halogen headlights
8) For models with manual gearbox
10) For models with LED headlights
11) For models with no entry and start authorisation
Fitting location of fuse holder C -SC-, sales type AW1, VW Polo 6 from November 2017
95087
Fuse assignment for fuse holder C -SC-, sales type AW1, VW Polo 6 from November 2017
value
SC2not assigned--
SC4not assigned--
SC7not assigned--
SC9not assigned--
30
30
30
SC22not assigned--
30
USB hub -R293-
TV tuner -R78-
CD player -R89-
30
30
5)
15 A
6)
30
SC34not assigned--
15
15
Control unit for structure-borne sound -J869-12)
15
SC43Fuse 43 on fuse holder C -SC43-15 AWasher pump relay -J576- 9)
Left washer jet heater element -Z20-
Right washer jet heater element -Z21-
15
15
SC47not assigned-
30
SC50not assigned--
SC51not assigned--
SC52not assigned--
30
SC54not assigned--
SC57not assigned--
12) For models with 2.0l petrol engine
Fitting location of fuse holder C -SC-, sales type AW1, VW Polo 6 from July 2018
95087
Fuse assignment for fuse holder C -SC-, sales type AW1, VW Polo 6 from July 2018
value
SC2not assigned--
SC4not assigned--
SC7not assigned--
SC9not assigned--
30
30
30
SC22not assigned--
30
USB hub -R293-
TV tuner -R78-
CD player -R89-
30
30
SC31Fuse 31 on fuse holder C -SC31-7.5 A 5)
15 A 6)
30
SC34not assigned--
15
15
15
15
15
SC47not assigned-
30
SC50not assigned--
SC51Fuse 51 on fuse holder C -SC51-7.5 AUSB charging socket 1 -U37-75
SC52not assigned--
30
SC54not assigned--
SC57not assigned--
Fitting location of fuse holder C -SC-, sales type AW1, VW Polo 6 from July 2019
95087
Fuse assignment for fuse holder C -SC-, sales type AW1, VW Polo 6 from July 2019
value
SC2not assigned--
SC4not assigned--
SC7not assigned--
SC9not assigned--
SC12Fuse 12 on fuse holder C -SC12-15 AFront left seat belt -NX10-2)
30
30
SC15Fuse 15 on fuse holder C -SC15-7.5 AEmergency call module control unit and communication unit -J949-
30
30
SC22not assigned--
30
USB hub -R293-
TV tuner -R78-
CD player -R89-
30
SC30Fuse 30 on fuse holder C -SC30-15 AFront left seat belt -NX10-3)
30
15 A 6)
30
SC34not assigned--
SC39Fuse 39 on fuse holder C -SC39-10 AFront camera for driver assist systems -R242-
15
15
15
15
15
SC47not assigned-
30
SC50not assigned--
SC52not assigned--
30
SC54not assigned--
SC57not assigned--
Fitting location of fuse holder C -SC-, sales type AW1, VW Polo 6 from July 2020
95087
Fuse assignment for fuse holder C -SC-, sales type AW1, VW Polo 6 from July 2020
value
SC2not assigned--
SC4not assigned--
SC7not assigned--
SC9not assigned--
SC10Fuse 10 on fuse holder C -SC10-25 ATrailer detector control unit -J345-30
30
30
30
30
SC22not assigned--
30
USB hub -R293-
TV tuner -R78-
CD player -R89-
30
30
15 A 6)
Ignition/starter switch -D- 13)
30
30
SC34not assigned--
SC39Fuse 39 on fuse holder C -SC39-7.5 AFront camera for driver assist systems -R242-
15
15
15
15
15
SC47not assigned-
30
SC50not assigned--
SC52not assigned--
30
SC54not assigned--
SC57not assigned--
13) For South Africa
Fitting location of fuse holder C -SC-, sales type AE1, VW Polo 6 from June 2021
95087
Fuse assignment for fuse holder C -SC-, sales type AE1, VW Polo 6 from June 2021
value
SC2not assigned--
SC4not assigned--
SC7not assigned--
SC9not assigned--
30
30
30
SC17Fuse 17 on fuse holder C -SC17-30 ADriver door control unit -J386- 3)
Rear driver side door control unit -J926-3)
Passenger side rear door control unit -J927-2)
30
SC21not assigned--
SC22not assigned--
SC23Fuse 23 on fuse holder C -SC23-7.5 ARear lid handle -EX37-30
Telephone bracket -R126-
USB hub -R293-
TV tuner -R78-
CD player -R89-
30
30
15 A 6)
30
Rear driver side door control unit -J926-2)
Passenger side rear door control unit -J927-3)
30
SC34not assigned--
15
Interior mirror -EX5-
15
15
15
15
SC45not assigned--
SC46not assigned--
SC47not assigned--
30
SC49not assigned--
SC50not assigned--
SC52Fuse 52 on fuse holder C -SC52-15 AFront right headlight -MX2-10)30
Selector mechanism -EX2-
30
SC54Fuse 54 on fuse holder C -SC54-15 AFront left headlight -MX1-10)30
75
SC57not assigned--
Fitting location of fuse holder D -SD-, VW Polo 6 from November 2017
Note: For models with battery at rear
1 - Fuse holder D -SD-
Fuse assignment for fuse holder D -SD-, VW Polo 6 from November 2017
value
SD1not assigned--
SD2not assigned--
SD3not assigned--
SD4Fuse 4 on fuse holder D -SD4-400 AFuse holder A -SA-30
