Руководство Fuses VW Tiguan 2 2016-2021 (AD1, BT1) - предохранители и реле
Admin
Admin
Создатель сайта
Команда форума
Россия, Москва
VW Tiguan 2.0 DBGC 2018, VW Touran 1.6 BSE 2008
Volkswagen Tiguan 2 - fuses
VW Tiguan 2 (AD1) 2016 - 2020
VW Tiguan 2 Rus (BT1) 2017 - 2021
Overview of fuse holders
1 - Fuse holder G -SG-
Fitting location, Fuse assignment, VW Tiguan 2 from January 2016 →
2 - Fuse holder C -SC-
Fitting location, left-hand drive models VW Tiguan 2 →
Fuse assignment, from January 2016 →
Fuse assignment, from May 2016 →
Fuse assignment, from November 2016 →
Fuse assignment, from May 2017 →
Fuse assignment, from November 2017 →
Fuse assignment, from July 2018 →
Fuse assignment, from November 2018 →
2 - Single fuses
Fitting location of single fuses, left-hand drive models VW Tiguan 2
3 - Fuse holder A -SA-
Fitting location →
Fuse assignment, from January 2016, only models with battery in engine compartment →
Fuse assignment, from August 2016, only models with battery in luggage compartment →
Fuse holder B -SB-
Fitting location →
Fitting location of fuse holder G -SG-
2 - 508 Threaded connection (30), on E-box
Fuse assignment for fuse holder G -SG- , VW Tiguan 2 from January 2016, only models with battery in luggage compartment
SlotCurrent flow diagram designationNominal
value
Function/componentsTerminal
SG1Fuse 1 on fuse holder G -SG1-80ASupply for the fuses:
Fuse 3 on fuse holder C -SC3-
Fuse 15 on fuse holder C -SC15- - fuse 20 on fuse holder C -SC20-
Fuse 23 on fuse holder C -SC23- - fuse 28 on fuse holder C -SC28-
Fuse 43 on fuse holder C -SC43- - fuse 45 on fuse holder C -SC45-
Fuse 50 on fuse holder C -SC50-
30
SG2Fuse 2 on fuse holder G -SG2-125 ASupply for the fuses:
Fuse 1 on fuse holder C -SC1-
Fuse 2 on fuse holder C -SC2-
Fuse 5 on fuse holder C -SC5- - fuse 14 on fuse holder C -SC14-
Fuse 22 on fuse holder C -SC22-
Fuse 32 on fuse holder C -SC32- - fuse 42 on fuse holder C -SC42-
Fuse 46 on fuse holder C -SC46-
Fuse 47 on fuse holder C -SC47-
Fuse 49 on fuse holder C -SC49-
Fuse 51 on fuse holder C -SC51- - fuse 53 on fuse holder C -SC53-
30
SG3Fuse 3 on fuse holder G -SG3-125 ASupply for the fuses:
Fuse 4 on fuse holder A -SA4-
Fuse 11 on fuse holder B -SB11-
Fuse 12 on fuse holder B -SB12-
Fuse 33 on fuse holder B -SB33-
Fuse 35 on fuse holder B -SB35-
Fuse 37 on fuse holder B -SB37-
30
Fitting location fuse holder C -SC-
Fitting location of fuse holder C -SC- , LHD models VW Tiguan 2
1 - Fuse holder C -SCFuse colours for J-Case fuse:
50 A - red
40 A - green
30 A - pink
Fuse colours for ATO flat fuse:
40 A - orange
30 A - light green
25 A - natural (white)
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
Fuse colours, for mini fuses:
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
Fuse assignment for fuse holder C -SC- , VW Tiguan 2 from January 2016
value
Function / componentTerminal
SC1Fuse 1 on fuse holder C -SC1-30 AControl unit for reducing agent heater -J891-30
SC2Fuse 2 on fuse holder C -SC2-10 ASteering column electronics control unit -J527- 6)30
SC3not assigned--
SC4not assigned--
SC5Fuse 5 on fuse holder C -SC5-5 AData bus diagnostic interface -J533-30
SC6Fuse 6 on fuse holder C -SC6-5 ASelector lever -E313-30
SC7Fuse 7 on fuse holder C -SC7-10 AHeater and air conditioning controls -EX21-
Heater control unit -J65-
Climatronic control unit -J255-
Air conditioning system control unit -J301-
Operating and display unit for rear air conditioning system -E265-
Remote control receiver for auxiliary coolant heater -R149-
Heated rear window relay -J9-
Tyre Pressure Monitoring System control unit -J502-
30
SC8Fuse 8 on fuse holder C -SC8-10 ARotary light switch -EX1-
Electromechanical parking brake button -E538-
Rain and light sensor -G397-
Diagnostic connection -U31-
. Operating unit for driving mode selection -E881-
Anti-theft alarm sensor -G578-
30
SC9Fuse 9 on fuse holder C -SC9-5 ASteering column electronics control unit -J527-30
SC10Fuse 10 on fuse holder C -SC10-7.5 ADisplay unit for front information display and operating unit control unit
-J685-
Control unit for Head-up Display -J898-
30
SC11Fuse 11 on fuse holder C -SC11-25 AControl unit for front left belt tensioner -J854-30
SC12Fuse 12 on fuse holder C -SC12-20 AControl unit 1 for information electronics -J794-
Control unit for navigation system -J856- 10)
30
SC13Fuse 13 on fuse holder C -SC13-15 AElectronically controlled damping control unit -J250-30
SC14Fuse 14 on fuse holder C -SC14-30 AFresh air blower control unit -J126-30
SC15Fuse 15 on fuse holder C -SC15-10 AControl unit for electronic steering column lock -J764-30
SC16Fuse 16 on fuse holder C -SC16-7.5 ATV tuner -RX6-
Two-way signal amplifier for mobile telephone/data services -J984-
Storage compartment with interface for mobile telephone -R265-
Chip card reader -D8-
USB hub -R293-
30
SC17Fuse 17 on fuse holder C -SC17-5 ADash panel insert -KX2-
Control unit in dash panel insert -J285-
Emergency call module control unit and communication unit -J949-
30
SC18Fuse 18 on fuse holder C -SC18-7.5 AControl unit for overhead view camera -J928-30
SC19Fuse 19 on fuse holder C -SC19-7.5 AInterface for entry and start system -J965-30
SC20Fuse 20 on fuse holder C -SC20-7.5 ARelay for reducing agent metering system -J963-
Delivery unit for reducing agent metering system -GX19-
30
SC21Fuse 21 on fuse holder C -SC21-15 AAll-wheel drive control unit -J492-30
SC22Fuse 22 on fuse holder C -SC22-15 ATrailer detector control unit -J345-30
SC23Fuse 23 on fuse holder C -SC23-40 AOnboard supply control unit -J519-30
SC24Fuse 24 on fuse holder C -SC24-30 ASliding sunroof adjustment control unit -J245-
Light 1 for roof contour lighting -L235-
Light 2 for roof contour lighting -L236-
Sunroof roller blind control unit -J394-
30
SC25Fuse 25 on fuse holder C -SC25-30 ADriver door control unit -J386- 1)
Rear left window regulator motor -V26- 1)
Rear driver side door control unit -J926- 1)
Front passenger door control unit -J387- 2)
Rear passenger side door control unit -J927- 2)
Rear right window regulator motor -V27- 2)
30
30
SC26Fuse 26 on fuse holder C -SC26-30 AOnboard supply control unit -J519-30
SC27Fuse 27 on fuse holder C -SC27-30 ADigital sound package control unit -J525--
SC28Fuse 28 on fuse holder C -SC28-25 ATrailer detector control unit -J345-30
SC29not assigned--
SC30not assigned--
SC31Fuse 31 on fuse holder C -SC31-40 AOnboard supply control unit -J519-30
SC32Fuse 32 on fuse holder C -SC32-7.5 A 7)
10 A 7)
Front camera for driver assist systems -R242-
Adaptive cruise control unit -J428-
Parking aid control unit -J446- 7)
Lane change assist control unit -J769-
Lane change assist control unit 2 -J770-
Park assist steering control unit -J791- 7)
15
SC33Fuse 33 on fuse holder C -SC33-5 AAirbag control unit -J234-
Warning lamp for airbag deactivated on front passenger side -K145-
15
SC34Fuse 34 on fuse holder C -SC34-7.5 ARotary light switch -EX1-
Interior mirror -EX5-
Relay for power sockets -J807-
Reversing light switch -F4-
Pressure sender for refrigerant circuit -G805-
Air quality sensor -G238-
Button for TCS and electronic stabilisation program -E256-
15
SC35Fuse 35 on fuse holder C -SC35-10 ADiagnostic connection -U31-
Headlight range control regulator -E102-
Headlight range control and instrument illumination regulator -EX14-
Control unit for cornering light and headlight range control -J745- 11)
Left headlight range control motor -V48-
Right headlight range control motor -V49-
Front left headlight -MX1-
Front right headlight -MX2-
15
SC36Fuse 36 on fuse holder C -SC36-10 A
5 A9)
Front right headlight -MX2-15
15
SC37Fuse 37 on fuse holder C -SC37-10 A
5 A9)
SC38Fuse 38 on fuse holder C -SC38-25 ATrailer detector control unit -J345-30
SC39Fuse 39 on fuse holder C -SC39-30 AFront passenger door control unit -J387- 1)
Rear passenger side door control unit -J927- 1)
Rear right window regulator motor -V27- 1)
Driver door control unit -J386- 2)
Rear driver side door control unit -J926- 2)
Rear left window regulator motor -V26- 2)
30
SC40 4) , 5)Fuse 40 on fuse holder C -SC40-20 A12 V socket -U5-
12 V socket 2 -U18-
12 V socket 3 -U19-
154) / 305)
SC41Fuse 41 on fuse holder C -SC41-25 AControl unit for front right belt tensioner -J855-
30
SC42Fuse 42 on fuse holder C -SC42-40 AOnboard supply control unit -J519-30
SC43Fuse 43 on fuse holder C -SC43-30 AOnboard supply control unit -J519-30
SC44Fuse 44 on fuse holder C -SC44-15 ATrailer detector control unit -J345-30
SC45Fuse 45 on fuse holder C -SC45-15 A 12)Driver seat adjustment control unit -J810-30
SC46Fuse 46 on fuse holder C -SC46-30 ADC/AC converter with socket, 12 V - 230 V -U13-30
SC47Fuse 47 on fuse holder C -SC47-15 ARear window wiper motor -V12-15
SC48not assigned--
SC49Fuse 49 on fuse holder C -SC49-5 AClutch position sender -G476-
Starter relay 1 -J906-
Starter relay 2 -J907-
15
SC50Fuse 50 on fuse holder C -SC50-40 ARear lid control unit -J605-30
SC51Fuse 51 on fuse holder C -SC51-25 AOperating and display unit for rear air conditioning system -E265-30
SC52not assigned--
SC53Fuse 53 on fuse holder C -SC53-30 AHeated rear window relay -J9-15
1) Only for left-hand drive models
2) Only right-hand drive models
3) Smokers version
4) Factory fitted with power supply from terminal 15
5) Power supply via terminal 30 possible
6) Only models with steering wheel heating
7) According to equipment
8) Only models with blind spot monitor
9) Only models with LED headlights
10) Only models with equipment for Korea
11) Only models with static cornering light
12) Thermal fuse
Note: The fuse SC40 is supplied via terminal 15 from the factory and can be supplied via terminal 30 by reconnecting. If a consumer
is connected to the electric socket or to the cigarette lighter, ensure that the consumer is disconnected from the voltage supply
when the engine is switched off to prevent the drive battery being discharged.
Fuse assignment for fuse holder C -SC- , VW Tiguan 2 from May 2016
value
SC3not assigned--
SC4not assigned--
30
30
-J685-
30
30
USB hub -R293-
30
30
30
30
30
30
SC29not assigned--
SC30not assigned--
10 A 7)
15
15
15
15
5 A9)
15
5 A9)
30
12 V socket 2 -U18-
12 V socket 3 -U19-
154) / 305)
30
SC45Fuse 45 on fuse holder C -SC45-15 A12)Driver seat adjustment control unit -J810-30
SC48not assigned--
15
SC52not assigned--
3) Smokers version
12) Thermal fuse
Fuse assignment for fuse holder C -SC- , VW Tiguan 2 from November 2016
value
SC3not assigned--
SC4not assigned--
30
30
-J685-
30
30
USB hub -R293-
30
30
30
30
30
30
SC29not assigned--
SC30not assigned--
10 A 7)
15
15
15
15
5 A9)
15
5 A9)
30
12 V socket 2 -U18-
12 V socket 3 -U19-
154) / 305)
30
SC48not assigned--
15
SC52not assigned--
3) Smokers version
12) Thermal fuse
Fuse assignment for fuse holder C -SC- , VW Tiguan 2 from May 2017
value
SC3not assigned--
SC4not assigned--
30
30
-J685-
30
SC11Fuse 11 on fuse holder C -SC11-40 AOnboard supply control unit -J519-30
30
SC13Fuse 13 on fuse holder C -SC13-25 AControl unit for front left belt tensioner -J854-30
USB hub -R293-
30
30
30
SC23Fuse 23 on fuse holder C -SC23-30 ASliding sunroof adjustment control unit -J245-
30
SC24Fuse 24 on fuse holder C -SC24-30 AOnboard supply control unit -J519-30
30
30
SC27Fuse 27 on fuse holder C -SC27-30 AOnboard supply control unit -J519--
SC29not assigned--
SC30not assigned--
SC31not assigned--
10 A 7)
15
15
15
15
5 A9)
5 A9)
Front left headlight -MX1-15
30
12 V socket 2 -U18-
12 V socket 3 -U19-
154) / 305)
30
SC43Fuse 43 on fuse holder C -SC43-30 ADigital sound package control unit -J525-30
SC48not assigned--
15
SC52Fuse 52 on fuse holder C -SC52-15 AElectronically controlled damping control unit -J250-30
3) Smokers version
12) Thermal fuse
Fuse assignment for fuse holder C -SC- , VW Tiguan 2 from November 2017
value
SC3not assigned--
SC4not assigned--
SC5Fuse 5 on fuse holder C -SC5-7.5 AData bus diagnostic interface -J533-30
SC6Fuse 6 on fuse holder C -SC6-7.5 ASelector lever -E313-30
30
SC8Fuse 8 on fuse holder C -SC8-7.5 ARotary light switch -EX1-
30
SC9Fuse 9 on fuse holder C -SC9-7.5 ASteering column electronics control unit -J527-30
-J685-
30
30
SC14Fuse 14 on fuse holder C -SC14-40 AFresh air blower control unit -J126-30
USB hub -R293-
30
SC17Fuse 17 on fuse holder C -SC17-7.5 ADash panel insert -KX2-
30
SC20Fuse 20 on fuse holder C -SC20-7.5 A 7)
10 A 7)
30
SC23Fuse 23 on fuse holder C -SC23-20 ASliding sunroof adjustment control unit -J245-
30
SC24Fuse 24 on fuse holder C -SC24-40 AOnboard supply control unit -J519-30
30
30
SC29not assigned--
SC30not assigned--
SC31not assigned--
10 A 7)
15
SC33Fuse 33 on fuse holder C -SC33-7.5 AAirbag control unit -J234-
15
15
SC35Fuse 35 on fuse holder C -SC35-7.5 ADiagnostic connection -U31-
15
5 A9)
15
7.5 A9)
30
12 V socket 2 -U18-
12 V socket 3 -U19-
154) / 305)
30
SC48not assigned--
SC49Fuse 49 on fuse holder C -SC49-7.5 AClutch position sender -G476-
15
3) Smokers version
12) Thermal fuse
Fuse assignment for fuse holder C -SC- , VW Tiguan 2 from July 2018
value
SC1Fuse 1 on fuse holder C -SC1-20 A 9)
30 A
SC2Fuse 2 on fuse holder C -SC2-10 ASteering column electronics control unit -J527- 5)30
SC3not assigned--
SC4not assigned--
30
Parking brake button -EX12-
Control unit for cornering light and headlight range control -J745- 6)
30
-J685-
30
Control unit for navigation system -J856- 7)
30
USB hub -R293-
30
SC17Fuse 17 on fuse holder C -SC17-5A 6)
7.5 A 6)
30
SC20Fuse 20 on fuse holder C -SC20-7.5 A 11), 12)
10 A 9), 10)
15 A 13)
30
30
30
30
SC29not assigned--
SC30not assigned--
SC31not assigned--
SC32Fuse 32 on fuse holder C -SC32-10 AFront camera for driver assist systems -R242-
Parking aid control unit -J446- 6)
Park assist steering control unit -J791- 6)
15
15
15
15
SC36Fuse 36 on fuse holder C -SC36-5 AFront right headlight -MX2-15
15
SC37Fuse 37 on fuse holder C -SC37-5 AFront left headlight -MX1-
30
SC40 3) , 4)Fuse 40 on fuse holder C -SC40-20 A12 V socket -U5-
12 V socket 2 -U18-
12 V socket 3 -U19-
153) / 304)
30
SC45Fuse 45 on fuse holder C -SC45-15 A8)Driver seat adjustment control unit -J810-30
SC48not assigned--
15
3) Factory fitted with power supply from terminal 15
4) Power supply via terminal 30 possible
5) Only models with steering wheel heating
6) According to equipment
7) Only models with equipment for Korea
8) Thermal fuse
9) For emission standard Euro 6 AG/H/I
10) For emission standard Euro 6 BG/H/I
11) For emission standard Euro 6 ZD/E/F
12) For models with Euro 6 plus emission standard
13) For models with 1.5l petrol engine
Fuse assignment for fuse holder C -SC- , VW Tiguan 2 from November 2018
value
30 A
SC3not assigned--
SC4Fuse 4 on fuse holder C -SC4-7.5 AAlarm horn -H12-30
30
30
-J685-
30
30
USB hub -R293-
30
30
10 A 9), 10)
15 A 13)
30
30
30
30
SC29not assigned--
SC30not assigned--
SC31Fuse 31 on fuse holder C -SC31-30 ARear lid control unit -J605-30
15
15
15
15
SC36Fuse 36 on fuse holder C -SC36-7.5 AFront right headlight -MX2-15
15
SC37Fuse 37 on fuse holder C -SC37-7.5 AFront left headlight -MX1-
30
12 V socket 2 -U18-
12 V socket 3 -U19-
153) / 304)
30
SC48not assigned--
15
SC50not assigned--
8) Thermal fuse
1 - Holder
A - Front passenger seat adjustment thermal fuse 1 -S46- , thermal fuse 15 A
B - not assigned
C - USB charging socket fuse -S356- , fuse rating 7.5 A
D - not assigned
E - not assigned
F - not assigned
G - not assigned
Fitting location of fuse holder B -SB-
The fitting locations are identical on LHD and RHD models VW Tiguan 2.
1 - Fuse holder B -SB-
50 A - red
40 A - green
30 A - pink
40 A - orange
30 A - light green
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
Fuse assignment for fuse holder B -SB- , VW Tiguan 2 from January 2016
value
SB1Fuse 1 on fuse holder B -SB1-40 AABS control unit -J104-30
SB2Fuse 2 on fuse holder B -SB2-40 AABS control unit -J104-30
SB3Fuse 3 on fuse holder B -SB3-15 A 1)
30 A 2)
Engine/motor control unit -J623-87
SB4Fuse 4 on fuse holder B -SB4-5 A 2)
10 A 1)
Oil level and oil temperature sender -G266-
Radiator fan control unit -J293-
Relay for reducing agent metering system -J963- 2)
Activated charcoal filter solenoid valve 1 -N80- 1)
Piston cooling jet control valve -N522- 6)
Turbocharger air recirculation valve -N249- 6)
Intake manifold flap valve -N316- 6)
Camshaft control valve 1 -N205- 1)
Exhaust camshaft control valve 1 -N318- 1)
Valve for oil pressure control -N428- 1)
Coolant valve for cylinder head -N489- 1)
High heat output relay -J360- 2)
Exhaust gas recirculation cooler changeover valve -N345- 2)
Low heat output relay -J359- 2)
Charge pressure control solenoid valve -N75- 2)
87
SB5Fuse 5 on fuse holder B -SB5-10 AFuel pressure regulating valve -N276- 2)
Fuel metering valve -N290- 2)
Engine component current supply relay -J757-
Secondary air system -GX24- 6)
Exhaust cam actuator A for cylinder 1 -N580- 6)
Exhaust cam actuator B for cylinder 1 -N581- 6)
Exhaust cam actuator A for cylinder 2 -N588- 6)
Exhaust cam actuator B for cylinder 2 -N589- 6)
Exhaust cam actuator A for cylinder 3 -N596- 6)
Exhaust cam actuator B for cylinder 3 -N597- 6)
Exhaust cam actuator A for cylinder 4 -N604- 6)
Exhaust cam actuator B for cylinder 4 -N605- 6)
Camshaft control valve 1 -N205- 2)
87
SB6Fuse 6 on fuse holder B -SB6-5 ABrake light switch -F-87
SB7Fuse 7 on fuse holder B -SB7-7.5 A 6)
10 A 2)
15 A 8)
Auxiliary pump for heating -V488- 2), 6)
Exhaust flap control unit -J883-
Fuel metering valve -N290- 4), 7)
Circulation pump -V55- 7)
Coolant shut-off valve -N82- 6)
Coolant valve for gearbox -N488-
Coolant circulation pump -V50-
Coolant pump for high-temperature circuit -V467-
Charge air cooling pump -V188-
Fuel pressure regulating valve -N276- 1)
Valve for oil pressure control -N428- 2)
Coolant valve for cylinder head -N489- 2)
87
SB8Fuse 8 on fuse holder B -SB8-10 A 1)
15 A 2)
Lambda probe 1 before catalytic converter -GX10-
♦ Lambda probe heater -Z19-
Lambda probe 1 after catalytic converter -GX7-
♦ Lambda probe 1 heater after catalytic converter -Z29-
NOx sender -G295- 2)
87
SB9Fuse 9 on fuse holder B -SB9-5 A 2)
10 A 1)
20 A 7)
Air mass meter -G70- 2)
Ignition coil 1 with output stage -N70- 1)
Ignition coil 2 with output stage -N127- 1)
Ignition coil 3 with output stage -N291- 1)
Ignition coil 4 with output stage -N292- 1)
Heater element for crankcase breather -N79- 2)
87
SB10Fuse 10 on fuse holder B -SB10-15 A 1)
20 A 2), 5)
Fuel pump control unit -J538-87
SB11Fuse 11 on fuse holder B -SB11-40 AAuxiliary air heater element -Z35- 2)87
SB12Fuse 12 on fuse holder B -SB12-40 AAuxiliary air heater element -Z35- 2)87
SB13Fuse 13 on fuse holder B -SB13-15 AMechatronic unit for dual clutch gearbox -J743- 10)30
SB14Fuse 14 on fuse holder B -SB14-40 AHeated windscreen relay -J47-30
SB15Fuse 15 on fuse holder B -SB15-15 AHorn relay -J413-30
SB16Fuse 16 on fuse holder B -SB16-20 AEngine component current supply relay -J757- 6)-
SB17Fuse 17 on fuse holder B -SB17-7.5 AMain relay -J271- 1)
Terminal 30 voltage supply relay -J317- 2)
30
SB18Fuse 18 on fuse holder B -SB18-5 ABattery monitor control unit -J367-30
SB19Fuse 19 on fuse holder B -SB19-30 AWindscreen wiper motor -V- 10)30
SB20Fuse 20 on fuse holder B -SB20-10 AAlarm horn -H12-30
SB21not assigned--
SB22Fuse 22 on fuse holder B -SB22-5 AEngine/motor control unit -J623-50
SB23Fuse 23 on fuse holder B -SB23-30 AStarter -B-50
SB24Fuse 24 on fuse holder B -SB24-40 AAuxiliary air heater element -Z35- 2)87
SB25not assigned--
SB26not assigned--
SB27not assigned--
SB28not assigned--
SB29not assigned--
SB30not assigned--
SB31not assigned--
SB32not assigned--
SB33Fuse 33 on fuse holder B -SB33-15 AMechatronic unit for dual clutch gearbox -J743- 9)30
SB34not assigned--
SB35Fuse 34 on fuse holder B -SB34-30 AWindscreen wiper motor -V- 9)30
SB36not assigned--
SB37Fuse 37 on fuse holder B -SB37-20 AAuxiliary heater control unit -J364-30
SB38not assigned--
1) for models with petrol engine only
2) for models with diesel engine only
3) Only models with no start/stop system
4) According to equipment
5) Only models with petrol engine and all-wheel drive
6) Only models with 2.0l petrol engine
7) Only models with 1.4l petrol engine
8) Only models with bi-turbo diesel engine
9) Only models with battery in luggage compartment
10) Only models with no battery in luggage compartment
Fuse assignment for fuse holder B -SB- , VW Tiguan 2 from May 2016
value
SB1Fuse 1 on fuse holder B -SB1-25AABS control unit -J104-30
30 A 2)
10 A 1)
87
87
10 A 2)
15 A 8)
Exhaust flap control unit -J883- 1), 4)
87
15 A 2)
87
10 A 1)
20 A 7)
87
20 A 2), 5)
30
30
SB21Fuse 21 on fuse holder B -SB21-30 AHeated windscreen relay 2 -J611- 1130
SB25not assigned--
SB26not assigned--
SB27not assigned--
SB28not assigned--
SB29not assigned--
SB30not assigned--
SB31not assigned--
SB32not assigned--
SB34not assigned--
SB36not assigned--
SB38not assigned--
11) Only models with heated windscreen (4GX)
Fuse assignment for fuse holder B -SB- , VW Tiguan 2 from May 2017
value
SB2Fuse 2 on fuse holder B -SB2-40 A 12)
60 A 13)
30 A 2)
10 A 1)
87
87
10 A 2)
15 A 8)
87
15 A 2)
87
10 A 1)
20 A 7)
87
20 A 2), 5)
30
30
SB25not assigned--
SB26not assigned--
SB27not assigned--
SB28not assigned--
SB29not assigned--
SB30not assigned--
SB31not assigned--
SB32not assigned--
SB34not assigned--
SB36not assigned--
SB38not assigned--
12) Only models with no pedestrian protection system
13) Only models with pedestrian protection system
Fuse assignment for fuse holder B -SB- , VW Tiguan 2 from November 2017
value
60 A 13)
30 A 2)
SB4Fuse 4 on fuse holder B -SB4-7.5 A 2)
10 A 1)
87
87
SB6Fuse 6 on fuse holder B -SB6-7.5 ABrake light switch -F-87
10 A 2)
15 A 8)
87
15 A 2)
87
SB9Fuse 9 on fuse holder B -SB9-7.5 A 2)
10 A 1)
20 A 7)
87
20 A 2), 5)
30
SB18Fuse 18 on fuse holder B -SB18-7.5 ABattery monitor control unit -J367-
30
SB22Fuse 22 on fuse holder B -SB22-7.5 AEngine/motor control unit -J623-50
SB25not assigned--
SB26not assigned--
SB27not assigned--
SB28not assigned--
SB29not assigned--
SB30not assigned--
SB31not assigned--
SB32not assigned--
SB34not assigned--
SB36not assigned--
SB38not assigned--
Fuse assignment for fuse holder B -SB- , VW Tiguan 2 from July 2018
value
60 A 13)
30 A 2)
10 A 1)
Inlet cam actuator for cylinder 2 -N583- 1)
Exhaust cam actuator for cylinder 2 -N587- 1)
Inlet cam actuator for cylinder 3 -N591- 1)
Exhaust cam actuator for cylinder 3 -N595- 1)
87
Injector 2, cylinder 1 -N532- 1)
Injector 2, cylinder 2 -N533- 1)
Injector 2, cylinder 3 -N534- 1)
Injector 2, cylinder 4 -N535- 1)
Inlet cam actuator A for cylinder 1 -N576- 1)
Inlet cam actuator B for cylinder 1 -N577- 1)
Inlet cam actuator A for cylinder 2 -N584- 1)
Inlet cam actuator B for cylinder 2 -N585- 1)
Inlet cam actuator A for cylinder 3 -N592- 1)
Inlet cam actuator B for cylinder 3 -N593- 1)
Inlet cam actuator A for cylinder 4 -N600- 1)
Inlet cam actuator B for cylinder 4 -N601- 1)
Engine component current supply relay -J757- 1)
87
10 A 2)
15 A 8)
87
15 A 2)
87
SB9Fuse 9 on fuse holder B -SB9-10 A 1)
20 A2)
Ignition coil 1 with output stage -N70- 1), 14)
Ignition coil 2 with output stage -N127- 1), 14)
Ignition coil 3 with output stage -N291- 1), 14)
Ignition coil 4 with output stage -N292- 1), 14)
87
20 A 2), 5)
SB11Fuse 11 on fuse holder B -SB11-40 A 2)Auxiliary air heater element -Z35- 2)87
SB12Fuse 12 on fuse holder B -SB12-40 A 2)Auxiliary air heater element -Z35- 2)87
SB13Fuse 13 on fuse holder B -SB13-30 A 10)Mechatronic unit for dual clutch gearbox -J743- 10)30
SB16Fuse 16 on fuse holder B -SB16-20 A 6)Engine component current supply relay -J757- 6)
Ignition coil 1 with output stage -N70- 6)
Ignition coil 2 with output stage -N127- 6)
Ignition coil 3 with output stage -N291- 6)
Ignition coil 4 with output stage -N292- 6)
30
30
30
SB21Fuse 21 on fuse holder B -SB21-30 AHeated windscreen relay 2 -J611- 11)30
SB25not assigned--
SB26not assigned--
SB27not assigned--
SB28not assigned--
SB29not assigned--
SB30not assigned--
SB31not assigned--
SB32not assigned--
SB33Fuse 33 on fuse holder B -SB33-15 A 8)
30 A
SB34not assigned--
SB35Fuse 35 on fuse holder B -SB35-30 AWindscreen wiper motor -V- 9)30
SB36not assigned--
SB38not assigned--
14) Not for models with 2.0l petrol engine
Fuse assignment for fuse holder B -SB- , VW Tiguan 2 from November 2018
value
60 A 13)
30 A 2)
10 A 1)
87
87
10 A 2)
15 A 8)
87
15 A 2)
87
SB9Fuse 9 on fuse holder B -SB9-10 A 6)
20 A 7), 15)
87
20 A 2), 5)
30
30
30
SB20not assigned--
SB21Fuse 21 on fuse holder B -SB21-15 AMechatronic unit for dual clutch gearbox -J743-30
SB25not assigned--
SB26not assigned--
SB27not assigned--
SB28not assigned--
SB29not assigned--
SB30not assigned--
SB31not assigned--
SB32not assigned--
SB33Fuse 33 on fuse holder B -SB33-15 A 9)Mechatronic unit for dual clutch gearbox -J743- 9)30
SB34Fuse 34 on fuse holder B -SB34-30 AHeated windscreen relay 2 -J611-30
SB36not assigned--
SB38not assigned--
15) Only models with 1.5l petrol engine
Fitting location of fuse holder A -SA- VW Tiguan 2
1 - Fuse holder A -SA-
508 - Threaded connection (30) on E-box
Multifuse strip fuse
Fuse assignment for fuse holder A -SA- , VW Tiguan 2 from January 2016, only models with battery in engine compartment
Screw
location
value
Function/componentTerminal
SA1Fuse 1 on fuse holder A -SA1-125 ASupply for the fuses:
30
SA2Fuse 2 on fuse holder A -SA2-400 AAlternator with voltage regulator -CX1-30
508508 Threaded connection (30), on E-box-Battery -A-30
SA3Fuse 3 on fuse holder A -SA3-80 APower steering control unit -J500-30
SA4Fuse 4 on fuse holder A -SA4-80 ASupply for the fuses:
30
SA5Fuse 5 on fuse holder A -SA5-50 ARadiator fan -VX57-30
Fuse assignment for fuse holder A -SA- , VW Tiguan 2 from August 2016, only models with battery in luggage compartment
Screw
location
value
SA1Fuse 1 on fuse holder A -SA1-80 ARadiator fan -VX57-30
SA3Fuse 3 on fuse holder A -SA3--not assigned-
SA4Fuse 4 on fuse holder A -SA4-80 APower steering control unit -J500-30
SA5Fuse 5 on fuse holder A -SA5--not assigned-
