Admin
Admin
Создатель сайта
Команда форума
Россия, Москва
VW Tiguan 2.0 DBGC 2018, VW Touran 1.6 BSE 2008
Автомобиль
VW Passat B7
Двигатель
все
Overview of fuses Volkswagen Passat B7
(схема расположения предохранителей Фольксваген Пассат Б7, все модели, все года выпуска)
Volkswagen Passat B7 (model 362) 2011 - 2015
Volkswagen Passat Variant B7 (model 365) 2011 - 2015
1 - Fuse holder D -SD-
2 - Fuse holder F -SF-
3 - Fuse 2 (30) -S205- (60 A)
4 - Fuse holder C -SC-
5 - Safety cutout under dash panel, driver side
6 - Fuse holder B -SB-
7 - Fuse holder A -SA-
Fuse holder D -SD- on right in dash panel VW Passat B7
Fitting location: on right of dash panel, near A-pillar
30 A - green
25 A - clear
20 A - yellow
15 A - blue
10 A - red
7.5 A - brown
5 A - beige
3 A - purple
Note:
Fuses SD13-SD24 are reserved for special purpose vehicles.
Fuse assignment on fuse holder D -SD- , left-hand drive models VW Passat B7
No.​
Current flow diagram designation
Nominal value​
Function/component
Terminal​
1​
Fuse 1 on fuse holder D -SD1-
30 A​
Rear lid control unit -J605-1)
30​
2​
Fuse 2 on fuse holder D -SD2-
30 A​
Rear lid control unit 2 -J756-1)
30​
3​
Fuse 3 on fuse holder D -SD3-
30 A​
Sunroof roller blind control unit -J394-1)
30​
4​
Fuse 4 on fuse holder D -SD4-
15 A​
Electronically controlled damping control unit -J250-
75​
5​
Not assigned
6​
Not assigned
7​
Not assigned
8​
Not assigned
9​
Not assigned
10​
Not assigned
11​
Not assigned
12​
Not assigned
13​
Fuse 13 on fuse holder D -SD13-
-Special vehicles
14​
Fuse 14 on fuse holder D -SD14-
-Special vehicles
15​
Fuse 15 on fuse holder D -SD15-
-Special vehicles
16​
Fuse 16 on fuse holder D -SD16-
Charging station for hand-held 2-way radio -U24-
Charging station 2 for hand-held 2-way radio -U28-
Charging station 2 for torch -U29-
17​
Fuse 17 on fuse holder D -SD17-
-Special vehicles
18​
Fuse 18 on fuse holder D -SD18-
-Special vehicles
19​
Fuse 19 on fuse holder D -SD19-
-Special vehicles
20​
Fuse 20 on fuse holder D -SD20-
-Special vehicles
21​
Fuse 21 on fuse holder D -SD21-
-Special vehicles
22​
Fuse 22 on fuse holder D -SD22-
-Special vehicles
23​
Fuse 23 on fuse holder D -SD23-
-Special vehicles
24​
Fuse 24 on fuse holder D -SD24-
-Special vehicles
1) Only estate
Fuse assignment on fuse holder D -SD- , right-hand drive models VW Passat B7
No.​
Nominal value​
Function/component
Terminal​
1​
15 A​
Trailer detector control unit -J345-
30​
2​
20 A​
30​
3​
15 A​
30​
4​
Not assigned
5​
Not assigned
6​
Not assigned
7​
Not assigned
8​
Not assigned
9​
Not assigned
10​
Not assigned
11​
Not assigned
12​
Not assigned
13​
-Special vehicles
14​
-Special vehicles
15​
-Special vehicles
16​
17​
-Special vehicles
18​
-Special vehicles
19​
-Special vehicles
20​
-Special vehicles
21​
-Special vehicles
22​
-Special vehicles
23​
-Special vehicles
24​
-Special vehicles
Fuse holder F -SF- , rear left in luggage compartment (BWS) VW Passat B7
Fuse colours
30 A - green
25 A - clear
20 A - yellow
15 A - blue
10 A - red
7.5 A - brown
5 A - beige
3 A - purple
Fuse assignment on fuse holder F -SF- , rear left in luggage compartment (BWS) VW Passat B7
No.​
Nominal value​
Function/component
Terminal​
1​
Fuse 1 on fuse holder F -SF1-
30 A​
-Left fuse holder (SC12 - SC17, SC27, SC29 - SC31, SC44)
30​
2​
Fuse 2 on fuse holder F -SF2-
80 A​
-Fuses in E-box (SB16 - SB26, SB49, SB50)
30​
3​
Fuse 3 on fuse holder F -SF3-
125 A​
-Power supply E-box
30​
4​
Fuse 4 on fuse holder F -SF4-
5 A​
Onboard supply control unit -J519-
Battery monitoring control unit -J367-
30​
Fuse holder C -SC- , on left of dash panel VW Passat B7
Fitting location of fuse holder C -SC-
Fitting location: on left of dash panel, near A-pillar
30 A - green
25 A - clear
20 A - yellow
15 A - blue
10 A - red
7.5 A - brown
5 A - beige
3 A - purple
Fuse assignment of fuse holder C -SC- , VW Passat B7 from November 2011
Slot​
Nominal value​
Function/component
Terminal​
1​
Fuse 1 on fuse holder C -SC1-
10 A​
High-pressure sender -G65-
Air quality sensor -G238-
Oil level and oil temperature sender -G266-
Fresh air blower relay -J13-
DC/AC converter with socket, 12 V - 230 V -U13-
Automatic anti-dazzle interior mirror -Y7-
Heated rear left seat switch with regulator -E128-
Heated rear right seat switch with regulator -E129-
15​
2​
Fuse 2 on fuse holder C -SC2-
5 A​
Light switch -E1-
Button for TCS and electronic stabilisation program -E256-
Auto-hold button -E540-
ABS control unit -J104-
Power steering control unit -J500-
Control unit for electromechanical parking brake -J540-
15​
3​
Fuse 3 on fuse holder C -SC3-
10 A​
Current supply relay -J16-
Heater element for crankcase breather -N79-
Gas injection valve 1 -N366-
Gas injection valve 2 -N367-
Gas injection valve 3 -N368-
Gas injection valve 4 -N369-
15​
4​
Fuse 4 on fuse holder C -SC4-
10 A​
Rear roller blind switch -E149-
Start/Stop operation button -E693-
Adaptive cruise control unit -J428-
Parking aid control unit -J446-
Park assist steering control unit -J791-
Front camera for driver assist systems -R242-
Diagnostic connection -U31-
15​
5​
Fuse 5 on fuse holder C -SC5-
10 A​
Headlight range control regulator -E102-
Left headlight range control motor -V48-
Right headlight range control motor -V49-
Front left headlight -MX1-4)
15​
6​
Fuse 6 on fuse holder C -SC6-
10 A​
All-wheel drive control unit -J492-
15​
7​
Fuse 7 on fuse holder C -SC7-
5 A​
Control unit in dash panel insert -J285-
Data bus diagnostic interface -J533-
15​
8​
Fuse 8 on fuse holder C -SC8-
10 A​
Front right headlight -MX2-4)
15​
9​
Fuse 9 on fuse holder C -SC9-
10 A​
Airbag control unit -J234-
Front passenger airbag deactivated warning lamp -K145-
15​
10​
Fuse 10 on fuse holder C -SC10-
10 A​
Air mass meter -G70-
Voltage stabiliser -J532-
Fuel pump control unit -J538-Engine control unit -J623-
Terminal 50 voltage supply relay -J682-
Voltage supply relay 2 -J710-
Starter relay 1 -J906-
Starter relay 2 -J907-
15​
11​
Fuse 11 on fuse holder C -SC11-
5 A 6)​
Pedal switch for warning buzzer on front passenger side -F349-6)
15​
12​
Fuse 12 on fuse holder C -SC12-
20 A​
Convenience system central control unit -J393-
Front passenger door control unit -J387-17)
Rear passenger side door control unit -J927-17)
30​
13​
Fuse 13 on fuse holder C -SC13-
10 A​
Light switch -E1-
Selector lever -E313-
Handbrake warning lamp -K139-
ABS control unit -J104- T38/15
30​
14​
Fuse 14 on fuse holder C -SC14-
10 A​
Interior monitor send and receive module 1 -G303-
Alarm horn -H12-
30​
15​
Fuse 15 on fuse holder C -SC15-
10 A​
Rain and light sensor -G397-
Heated rear window relay -J9-
Heated windscreen relay -J47-
Climatronic control unit -J255-
Air conditioning system control unit -J301-
Reversing camera system control unit -J772-
Control unit for terminal control and engine start -J942-
Remote control receiver for auxiliary coolant heater -R149-
Tyre Pressure Monitoring System control unit -J502-
30​
16​
Fuse 16 on fuse holder C -SC16-
10 A​
Electronic ignition lock -D9-
Control unit for electronic steering column lock -J764-
30​
17​
Fuse 17 on fuse holder C -SC17-
15 A​
Driver door control unit -J386-17)
Rear driver side door control unit -J926-17)
30​
18​
Fuse 18 on fuse holder C -SC18-
3 A​
15​
19​
Not assigned
20​
Not assigned
21​
Fuse 21 on fuse holder C -SC21-
10 A​
Rear roller blind control unit -J262-
15​
22​
Fuse 22 on fuse holder C -SC22-
20 A​
30​
23​
Fuse 23 on fuse holder C -SC23-
15 A​
Electronically controlled damping control unit -J250-4)
30​
24​
Fuse 24 on fuse holder C -SC24-
20 A​
30​
25​
Fuse 25 on fuse holder C -SC25-
5 A 8)
15 A 7)
30 A 4)​
Emergency assistance call button -E276-
Sunroof roller blind control unit -J394-4)
30​
26​
Fuse 26 on fuse holder C -SC26-
20 A​
30​
27​
Fuse 27 on fuse holder C -SC27-
15 A1)
20 A2)​
Fuel pump control unit -J538-1)
Fuel pump relay -J17-2)
Electric fuel pump 2 relay -J49-2)
151)
302)​
28​
Fuse 28 on fuse holder C -SC28-
30 A​
Driver door control unit -J386-9)
Rear driver side door control unit -J926-9)
Front passenger door control unit -J387-4)
Rear passenger side door control unit -J927-4)
30​
29​
Fuse 29 on fuse holder C -SC29-
20 A​
Heated rear seats control unit -J786-
30​
30​
Fuse 30 on fuse holder C -SC30-
20 A 10)
30 A 11)​
Sliding sunroof adjustment control unit -J245-
30​
31​
Fuse 31 on fuse holder C -SC31-
30 A​
30​
32​
Fuse 32 on fuse holder C -SC32-
30 A​
30​
33​
Fuse 33 on fuse holder C -SC33-
30 A​
Headlight washer system relay -J39-
30​
34​
Fuse 34 on fuse holder C -SC34-
25 A​
Heated front seats control unit -J774-
30​
35​
Fuse 35 on fuse holder C -SC35-
15 A 4)​
Rear lid control unit -J605-4)
30​
36​
Fuse 36 on fuse holder C -SC36-
15 A​
Driver seat lumbar support adjustment switch -E176-
30​
37​
Fuse 37 on fuse holder C -SC37-
20 A 9)
30 A 4)​
Trailer detector control unit -J345-9)
Rear lid control unit 2 -J756-4)
30​
38​
Fuse 38 on fuse holder C -SC38-
40 A 12)​
Fresh air blower relay -J13-14)
Fresh air blower control unit -J126-13)
75​
39​
Fuse 39 on fuse holder C -SC39-
5 A​
Reversing light switch -F4-
Mechatronic unit for dual clutch gearbox -J743-
15​
40​
Fuse 40 on fuse holder C -SC40-
20 A​
Rear window wiper motor -V12-
Windscreen and rear window washer pump -V59-
75​
41​
Fuse 41 on fuse holder C -SC41-
20 A​
Cigarette lighter -U1-
Rear cigarette lighter -U9-
75​
42​
Fuse 42 on fuse holder C -SC42-
15 A​
12 V socket -U5-
75​
43​
Fuse 43 on fuse holder C -SC43-
20 A 15)​
Auxiliary heater control unit -J364-15)
30​
44​
Fuse 44 on fuse holder C -SC44-
30 A​
Driver door control unit -J386-4)
Rear driver side door control unit -J926-4)
Front passenger door control unit -J387-9)
Rear passenger side door control unit -J927-9)
30​
45​
Fuse 45 on fuse holder C -SC45-
20 A 15)​
Auxiliary heater operation relay -J485-15)
30​
46​
Not assigned
47​
Fuse 47 on fuse holder C -SC47-
5 A 3)​
Analogue clock -Y-3)
TV tuner -R78-3)
Mobile telephone operating electronics control unit -J412-3)
Control unit for navigation system -J856-3,16)
30​
48​
Fuse 48 on fuse holder C -SC48-
5 A 3)​
Control unit in dash panel insert -J285-3)
30​
49​
Fuse 49 on fuse holder C -SC49-
-Vacant
1) Only models with a petrol engine
2) Only models with a diesel engine
3) Only models with start/stop system
4) Only right-hand drive models
5) Only models with xenon headlights
6) Only applicable to special vehicles
7) Only models with trailer socket
8) Only models with emergency call module
9) Only left-hand drive models
10) Only VW Passat B7 saloon
11) Only VW Passat B7 estate
12) Only models with auxiliary heating
13) Only models with Climatronic
14) Only models with Climatic
15) Only models with second battery
16) Only models with equipment for Korea
17) Only VW Passat CC
Fuse assignment of fuse holder C -SC- , VW Passat B7 from May 2012
Slot​
Nominal value​
Function/component
Terminal​
1​
10 A​
15​
2​
5 A​
Light switch -E1-
15​
3​
10 A​
15​
4​
10 A​
15​
5​
10 A​
15​
6​
10 A​
15​
7​
5 A​
15​
8​
10 A​
15​
9​
10 A​
15​
10​
10 A​
15​
11​
5 A 6)​
15​
12​
20 A​
30​
13​
10 A​
Light switch -E1-
30​
14​
10 A​
Alarm horn -H12-
30​
15​
10 A​
30​
16​
10 A​
30​
17​
-Vacant
18​
3 A​
15​
19​
Not assigned
20​
Not assigned
21​
10 A​
15​
22​
20 A​
30​
23​
15 A​
30​
24​
20 A​
30​
25​
5 A 8)
15 A 7)
30 A 4)​
30​
26​
20 A​
30​
27​
15 A1)
20 A2)​
151)
302)​
28​
30 A​
30​
29​
20 A​
30​
30​
20 A 10)
30 A 11)​
30​
31​
30 A​
30​
32​
30 A​
30​
33​
30 A​
30​
34​
25 A​
30​
35​
15 A 4)​
Driver seat lumbar support adjustment switch -E176-9)
30​
36​
15 A​
Driver seat lumbar support adjustment switch -E176-4)
Trailer voltage supply relay -J941-
30​
37​
20 A 9)
30 A 4)​
30​
38​
40 A 12)​
75​
39​
5 A​
15​
40​
20 A​
75​
41​
20 A​
75​
42​
15 A​
12 V socket -U5-
75​
43​
20 A 15)​
30​
44​
30 A​
30​
45​
20 A 15)​
30​
46​
Not assigned
47​
5 A 3)​
TV tuner -R78-3)
30​
48​
5 A 3)​
30​
49​
-Vacant
Safety cutout under dash panel VW Passat B7, driver side
A - Not assigned
B - Driver seat adjustment thermal fuse 1 -S44-
Fuse holder B -SB- on E-box low VW Passat B7
Fitting location
on E-box low, on left in engine compartment
Fuse colours:
50 A - red
40 A - orange
30 A - green
25 A - clear
20 A - yellow
15 A - blue
10 A - red
7.5 A - brown
5 A - beige
3 A - purple
Fuse assignment of fuse holder B -SB- on E-box low, VW Passat B7 from November 2010
Slot​
Nominal value​
Function/component
Terminal​
SB1​
Fuse 1 on fuse holder B -SB1-
7.5 A​
Only models with Rear Seat Entertainment (RSE)
SB2​
Fuse 2 on fuse holder B -SB2-
30 A​
30​
SB3​
Fuse 3 on fuse holder B -SB3-
20 A​
Treble horn -H2-
Bass horn -H7-
Dual tone horn relay -J4-
30​
SB4​
Fuse 4 on fuse holder B -SB4-
25 A​
30​
SB5​
Fuse 5 on fuse holder B -SB5-
5 A​
Battery monitor control unit -J367-
30​
SB6​
Fuse 6 on fuse holder B -SB6-
5 A17)
15 A16)​
Automatic gearbox control unit -J217-
30​
SB7​
Fuse 7 on fuse holder B -SB7-
15 A 6,7)
20 A 5,7)
30 A 1)​
Radio -R-
Control unit with display for radio and navigation -J503-
Voltage stabiliser -J532-(1
30​
SB8​
Fuse 8 on fuse holder B -SB8-
30 A​
Mechatronics unit for dual clutch gearbox -J743-
30​
SB9​
Fuse 9 on fuse holder B -SB9-
5 A​
Steering column electronics control unit -J527-
30​
SB10​
Fuse 10 on fuse holder B -SB10-
20 A​
Ignition coil 1 with output stage -N70-
Ignition coil 2 with output stage -N127-
Ignition coil 3 with output stage -N291-
Ignition coil 4 with output stage -N292-
Fuel pressure regulating valve -N276-
Fuel metering valve -N290-
87​
SB11​
Fuse 11 on fuse holder B -SB11-
5 A​
30​
SB12​
Fuse 12 on fuse holder B -SB12-
5 A​
TV tuner -R78-
Analogue clock -Y-
Control unit for navigation system -J856-14)
30​
SB13​
Fuse 13 on fuse holder B -SB13-
10 A​
Motronic engine control module power supply relay -J271-
Terminal 30 voltage supply relay -J317-
30​
SB14​
Fuse 14 on fuse holder B -SB14-
25 A 3)
30 A 2)​
87​
SB15​
Fuse 15 on fuse holder B -SB15-
5 A​
30​
SB16​
Fuse 16 on fuse holder B -SB16-
10 A 9)
15 A 8)​
Charge pressure control solenoid valve -N75-2)
Exhaust gas recirculation cooler changeover valve -N345-
Magnetic clutch for supercharger -N421-3)
Continued coolant circulation relay -J151-3)
Continued coolant circulation pump -V51-3)
Coolant circulation pump 2 -V178-
87​
SB17​
Fuse 17 on fuse holder B -SB17-
10 A
20 A18)
40 A 10)​
Fuel tank shut-off valve 1 -N361-
Fuel tank shut-off valve 2 -N362-
Fuel tank shut-off valve 3 -N363-
Coolant circulation pump -V50-
Low heat output relay -J359-10)
87​
SB18​
Fuse 18 on fuse holder B -SB18-
10 A 9)
30 A 8)​
Fuel quality sender -G446-
High-pressure valve for gas mode -N372-
87​
SB19​
Fuse 19 on fuse holder B -SB19-
30 A​
Amplifier -R12-
Special vehicle control unit -J608-11)
30​
SB20​
Fuse 20 on fuse holder B -SB20-
5 A
15 A 12), 15)​
Brake light switch -F-
Clutch position sender -G476-
High heat output relay -J360-
Engine component current supply relay -J757-
87​
SB21​
Fuse 21 on fuse holder B -SB21-
20 A​
30​
SB22​
Fuse 22 on fuse holder B -SB22-
30 A​
Wiper motor control unit -J400-
30​
SB23​
Fuse 23 on fuse holder B -SB23-
10 A​
Automatic glow period control unit -J179-
Radiator fan control unit -J293-
Additional coolant pump relay -J496-
Activated charcoal filter solenoid valve 1 -N80-
Camshaft control valve 1 -N205-
Turbocharger air recirculation valve -N249-
Intake manifold flap valve -N316-
Valve for oil pressure control -N428-
87​
SB24​
Fuse 24 on fuse holder B -SB24-
10 A2.9)
15 A​
Lambda probe heater -Z19-
Lambda probe 1 heater after catalytic converter -Z29-
Control unit for NOx sender 2 -J881-8)
87​
SB25​
Fuse 25 on fuse holder B -SB25-
40 A​
30​
SB26​
Fuse 26 on fuse holder B -SB26-
40 A​
30​
SB27​
Fuse 27 on fuse holder B -SB27-
60 A​
30​
SB28​
Fuse 28 on fuse holder B -SB28-
50 A​
Automatic glow period control unit -J179-2)
30​
SB29​
Fuse 29 on fuse holder B -SB29-
50 A​
Fuse 38 on fuse holder C -SC38-13)
Fuse 40 on fuse holder C -SC40- to fuse 42 on fuse holder C -SC42-
X-contact relief relay -J59-
30​
SB30​
Fuse 30 on fuse holder B -SB30-
50 A​
Terminal 15 voltage supply relay -J329-
Fuse 1 on fuse holder C -SC1- to fuse 11 on fuse holder C -SC11-
Fuse 19 on fuse holder C -SC19-
Fuse 20 on fuse holder C -SC20-
Fuse 18 on fuse holder C -SC18-1)
30​
1) Only models with start/stop system
2) Only models with diesel engines
3) Only models with a petrol engine
4) Depends on equipment
5) Only models with navigation system
6) Only models with radio
7) Only models with start/stop system
8) Only models with reducing agent metering system
9) Only models without reducing agent metering system
10) Only models with auxiliary air heater
11) Only applicable to special vehicles
12) for CNG models only
13) Only models with air conditioning system/Climatronic
14) Only models with equipment for Korea
15) Only ethanol vehicles
16) Only models with dual clutch gearbox (DSG)
17) Only models without dual clutch gearbox (DSG)
18) Only VW Passat B7 with 1.8 l and 2.0 l petrol engines
Fuse assignment of fuse holder B -SB- on E-box low, VW Passat B7 from November 2011
Slot​
Nominal value​
Function/component
Terminal​
SB1​
Not assigned
SB2​
30 A​
30​
SB3​
20 A​
Treble horn -H2-
Bass horn -H7-
30​
SB4​
20 A​
30​
SB5​
5 A​
30​
SB6​
15 A​
30​
SB7​
15 A 6,7)
20 A 5,7)
30 A 1)​
Radio -R-
30​
SB8​
30 A​
30​
SB9​
5 A​
30​
SB10​
20 A​
87​
SB11​
5 A​
30​
SB12​
5 A​
TV tuner -R78-
Analogue clock -Y-
30​
SB13​
10 A​
30​
SB14​
25 A 3)
30 A 2)​
87​
SB15​
5 A​
30​
SB16​
10 A 9)
15 A 8)​
87​
SB17​
10 A
40 A 10)​
87​
SB18​
10 A 9)
30 A 8)​
87​
SB19​
30 A​
Amplifier -R12-
30​
SB20​
5 A
15 A 12), 15)​
87​
SB21​
20 A​
30​
SB22​
30 A​
30​
SB23​
10 A​
87​
SB24​
10 A2.9)
15 A​
87​
SB25​
40 A​
30​
SB26​
40 A​
30​
SB27​
60 A​
30​
SB28​
50 A​
30​
SB29​
50 A​
30​
SB30​
40 A​
30​
Fuse assignment of fuse holder B -SB- on E-box low, VW Passat B7 from May 2012
Slot​
Nominal value​
Function/component
Terminal​
SB1​
15 A 12), 15)​
Mechatronic unit for dual clutch gearbox -J743-12), 15)
30​
SB2​
30 A​
30​
SB3​
20 A​
Treble horn -H2-
Bass horn -H7-
30​
SB4​
15 A​
30​
SB5​
5 A​
30​
SB6​
15 A 2), 16)
40 A 12), 17)​
Mechatronic unit for dual clutch gearbox -J743-2), 16)
Low heat output relay -J359-12), 17)
30​
SB7​
15 A 6,7)
20 A 5,7)
30 A 1)​
Radio -R-
30​
SB8​
30 A​
30​
SB9​
5 A​
30​
SB10​
20 A​
87​
SB11​
5 A​
30​
SB12​
5 A​
TV tuner -R78-
Analogue clock -Y-
30​
SB13​
10 A​
30​
SB14​
25 A 3)
30 A 2)​
87​
SB15​
5 A​
30​
SB16​
10 A 9)
15 A 8)​
87​
SB17​
10 A
40 A 10)​
87​
SB18​
10 A 9)
15A12) 15)
30 A8)​
87​
SB19​
30 A​
Amplifier -R12-
30​
SB20​
5 A​
87​
SB21​
20 A​
30​
SB22​
30 A​
30​
SB23​
10 A​
87​
SB24​
10 A2.9)
15 A​
87​
SB25​
40 A​
30​
SB26​
40 A​
30​
SB27​
60 A​
30​
SB28​
50 A​
30​
SB29​
50 A​
30​
SB30​
40 A​
30​
16) Only for petrol engine with forced induction
17) Only for petrol engine without forced induction
Fuse holder B -SB- on E-box high VW Passat B7
Fitting location
on E-box high, on left in engine compartment
Fuse colours:
50 A - red
40 A - orange
30 A - green
25 A - clear
20 A - yellow
15 A - blue
10 A - red
7.5 A - brown
5 A - beige
3 A - purple
Fuse assignment of fuse holder B -SB- on E-box high, VW Passat B7 from November 2010
Slot​
Nominal value​
Function/component
Terminal​
SB1​
5 A 1)
15 A 2)​
30​
SB2​
30 A​
30​
SB3​
25 A​
30​
SB4​
5 A​
SB5​
20 A​
Treble horn -H2-
Bass horn -H7-
30​
SB6​
20 A​
Ignition coil 5 with output stage -N323-
Ignition coil 6 with output stage -N324-
87​
SB7​
15 A​
87​
SB8​
5 A 3)
10 A​
Exhaust camshaft control valve 1 -N318-
87​
SB9​
5 A​
Circulation pump relay -J160-
87​
SB10​
Fuse 10 on fuse holder B -SB10-​
10 A​
Lambda probe 2 heater after catalytic converter -Z30-
87​
SB11​
25 A​
87​
SB12​
10 A 3)
20A​
Lambda probe 2 heater -Z28-
87​
SB13​
Not assigned
SB14​
Not assigned
SB15​
10 A​
87​
SB16​
5 A​
30​
SB17​
5 A​
30​
SB18​
30 A​
Amplifier -R12-
SB19​
15 A 6.7)
20 A 5.7)​
Radio -R-
Voltage stabiliser -J532-(4
30​
SB20​
5 A​
Analogue clock -Y-
TV tuner -R78-
Control unit for navigation system -J856-8)
30​
SB21​
Not assigned
SB22​
7.5 A​
SB23​
Not assigned
SB24​
5 A​
30​
SB25​
Not assigned
SB26​
10 A​
30​
SB27​
Not assigned
SB28​
Not assigned
SB29​
Not assigned
SB30​
20 A​
30​
SB31​
Fuse 31 on fuse holder B -SB31-
30 A​
30​
SB32​
Not assigned
SB33​
Not assigned
SB34​
Not assigned
SB35​
Fuse 35 on fuse holder B -SB35-
20 A​
30​
SB36​
Not assigned
SB37​
Not assigned
SB38​
Not assigned
SB39​
Not assigned
SB40​
Not assigned
SB41​
Not assigned
SB42​
Not assigned
SB43​
Not assigned
SB44​
Not assigned
SB45​
Not assigned
SB46​
Not assigned
SB47​
Fuse 47 on fuse holder B -SB47-
40 A​
30​
SB48​
Fuse 48 on fuse holder B -SB48-
40 A​
30​
SB49​
Fuse 49 on fuse holder B -SB49-
50 A​
Fuse 6 on fuse holder C -SC6- to fuse 11 on fuse holder C -SC11-
Fuse 18 on fuse holder C -SC18-4)
30​
SB50​
Not assigned
SB51​
Fuse 51 on fuse holder B -SB51-
60 3)​
High heat output relay -J360-3)
30​
SB52​
Fuse 52 on fuse holder B -SB52-
60 A​
30​
SB53​
Fuse 53 on fuse holder B -SB53-
50 A​
30​
SB54​
Fuse 54 on fuse holder B -SB54-
50​
Automatic glow period control unit -J179-3)
30​
1) Only models with automatic gearbox
2) Only models with dual clutch gearbox
3) Only for countries with hot climate
4) Only models with start/stop system
8) Only models with equipment for Korea
Fuse assignment of fuse holder B -SB- on E-box high, VW Passat B7 from November 2011
Slot​
Nominal value​
Function/component
Terminal​
SB1​
5 A 1)
10 A 2)​
30​
SB2​
30 A​
30​
SB3​
15 A​
30​
SB4​
-Vacant
SB5​
20 A​
Treble horn -H2-
Bass horn -H7-
30​
SB6​
20 A​
87​
SB7​
15 A​
87​
SB8​
5 A 3)
10 A​
87​
SB9​
5 A​
87​
SB10​
10 A​
87​
SB11​
25 A
30 A 3)​
87​
SB12​
10 A 3)
20A​
87​
SB13​
Not assigned
SB14​
Not assigned
SB15​
10 A​
87​
SB16​
5 A​
30​
SB17​
5 A​
30​
SB18​
30 A​
Amplifier -R12-
SB19​
15 A 6.7)
20 A 5.7)
30 A 4)​
Radio -R-
30​
SB20​
5 A​
Analogue clock -Y-
TV tuner -R78-
30​
SB21​
Not assigned
SB22​
Not assigned
SB23​
Not assigned
SB24​
5 A​
30​
SB25​
Not assigned
SB26​
10 A​
30​
SB27​
Not assigned
SB28​
Not assigned
SB29​
Not assigned
SB30​
20 A​
30​
SB31​
30 A​
30​
SB32​
Not assigned
SB33​
Not assigned
SB34​
Not assigned
SB35​
20 A
40 A 3)​
Low heat output relay -J359-3)
30​
SB36​
Not assigned
SB37​
Not assigned
SB38​
Not assigned
SB39​
Not assigned
SB40​
Not assigned
SB41​
Not assigned
SB42​
Not assigned
SB43​
Not assigned
SB44​
Not assigned
SB45​
Not assigned
SB46​
Not assigned
SB47​
40 A​
30​
SB48​
40 A​
30​
SB49​
50 A​
30​
SB50​
Not assigned
SB51​
60 3)​
30​
SB52​
60 A​
30​
SB53​
50 A​
30​
SB54​
50​
30​
Fuse holder A -SA-
Fuse holder A -SA- , on E-box low VW Passat B7
Multifuse strip fuse
Note: The fuse strip (multifuse) must be replaced as a complete unit.
Fuse assignment of fuse holder A -SA- , on E-box low VW Passat B7
Screw location​
Nominal value​
Function/component
Terminal​
SA1​
Fuse 1 on fuse holder A -SA1-
150 A
180 A1)​
Alternator -C-
30​
SA2​
Fuse 2 on fuse holder A -SA2-
80 A​
Electromechanical power steering motor -V187-
30​
SA3​
Fuse 3 on fuse holder A -SA3-
50 A​
30​
SA4​
Fuse 4 on fuse holder A -SA4-
60 A​
Fuse 12 on fuse holder C -SC12- to fuse 17 on fuse holder C -SC17- ,
fuse 22 on fuse holder C -SC22- to fuse 27 on fuse holder C -SC27- ,
fuse 28 on fuse holder C -SC28- ,
fuse 44 on fuse holder C -SC44- ,
fuse 46 on fuse holder C -SC46-
30​
SA5​
Fuse 5 on fuse holder A -SA5-
80 A​
Fuse 29 on fuse holder C -SC29- to fuse 31 on fuse holder C -SC31-
30​
SA6​
Fuse 6 on fuse holder A -SA6-
70 A​
Fuse 32 on fuse holder C -SC32- to fuse 37 on fuse holder C -SC37-
30​
SA7​
Fuse 7 on fuse holder A -SA7-
60 A​
Second battery charging circuit relay -J713-
30​
SA8​
Fuse 8 on fuse holder A -SA8-
40 A​
30​
1) Only VW Passat B7 with 180 A alternator, fitted in alternator wire
Fuse holder A -SA- , on E-box high VW Passat B7
Fuse colours for MIDI fuse:
30 A - orange
40 A - green
50 A - red
60 A - yellow
70 A - brown
80 A - white
100 A - blue
125 A - pink
150 A - grey
200 A - purple
Fuse assignment of fuse holder A -SA- , on E-box high VW Passat B7
Screw location​
Nominal value​
Function/component
Terminal​
SA1​
150 A
/180 A1)​
Alternator -C-
30​
SA2​
80 A​
30​
SA3​
60 A​
30​
SA4​
50 A​
30​
SA5​
Not assigned
SA6​
80 A​
30​
SA7​
40 A​
30​
