FAQ Understanding Wiring Diagrams Terminology and Symbols
Admin
Admin
Создатель сайта
Команда форума
Россия, Москва
VW Tiguan 2.0 DBGC 2018, VW Touran 1.6 BSE 2008
1.1 Capacitor
Capacitors are a passive electronic component that holds a charge in the form of an electrostatic field. They are often used in combination with transistors in DRAM, acting as storage cells to hold bits. Capacitors typically consist of conducting plates separated by thin layers of dielectric material, such as dry air or mica. The plates on opposite sides of the dielectric material are oppositely charged and the electrical energy of the charged system is stored in the polarized dielectric.
1.2 Connector
Connectors are the part of a cable that plugs into a port or interface to connect one device to another. Most connectors are either male (containing one or more exposed pins) or female (containing holes in which the male connector can be inserted).
Given a relatively fixed voltage in an automotive electrical system (12.6 volts), the current in the circuit is determined by the amount of resistance in the load and in the conductors and connections in the circuit.
Terminals, connectors and splices are used throughout the electrical wiring harness to aid in vehicle assembly and service. Any connection in a circuit creates a place where problems can occur.
Typical connector problems include:
- Disconnected connector
- Terminal backed out
- Terminal corrosion
- Terminal spread too wide
- Improperly made splice
Connector pin numbers are always shown from the mating side of the connector, not the harness side of the connector. If you are back-probing the connector for a voltage check, remember the pin numbering becomes the mirror of what is pictured in the diagram.
Push-on/multi-pin connectors use the “T” designation, and are identified in the legend. For example, T8a/5 designates an 8-pin connector, with the specified wire located in terminal 5 of the connector housing.
Most pin assignments are labeled on the plastic hardshell connector housing and/or the corresponding component. On larger connectors, pin assignments are labeled at either end of a row. For example, the Engine Control Module (ECM) plug often
has 2 or 3 rows of 12 or more terminals. Each row will be marked on each end to facilitate diagnosis.
1.3 Component Code Prefixes
- A - Battery
- B - Starter
- C - Alternator/generator
- D - Ignition/starter switch
- E - Switches — these are usually more complex switches: A/C control head, sunroof regulator
- F - Switches — door, hood, brake, clutch, trunk, multifunction, etc.
- G - Gauges and sensors
- H - Horn
- J - Control modules, relays, electronic relays
- K - Indicator/warning lights
- L - Lights
- M - Lights
- N - Solenoids/inductors/ignition — fuel injectors, purge, ignition coil, ignition module, etc.
- P - Spark plug connector
- Q - Spark plugs
- R - Radio, CD, telephone, navigation
- S - Fuse, circuit breaker, protection device
- T - Wire connector V Motor — window motors, vacuum pumps, etc.
- W - Lights — interior, trunk
- Z - Heating elements — O2 sensor heater, heated seats, heated mirrors, etc
1.4 DIN Standard 72 552
German institute for standards that establishes guidelines for manufacturing and nomenclature.
This standard applies to the terminal designations for circuits. The purpose of the terminal designation system is to enable accurate connection identification from conductors (wires) to various components when diagnosis and repair is necessary.
DIN standards for terminal designations are shown below:
- 1 - Ignition coil, ignition distributor — low voltage
- 1a - To contact breaker I (ignition distributor with two separate circuits)
- 1b - To contact breaker II (ignition distributor with two separate circuits)
- 4 - Ignition coil, ignition distributor — high voltage
- 4a - From ignition coil I (ignition distributor with two separate circuits)
- 4b - From ignition coil II (ignition distributor with two separate circuits)
- 15 - Switched (+) downstream of battery (output of ignition/driving switch)
- 15a - Output at ballast resistor to ignition coil and starter
- 17 - Glow plug and starter switch — start
- 19 - Glow plug and starter switch — preheat
- 30 - Input from battery (+) term., direct 12/24 V seriesparallel battery switch
- 30a - Input from (+) terminal of battery II
- 31 - Battery negative terminal, or ground, direct
- 31a - Return line to battery II, negative (12/24 V seriesparallel battery switch)
- 31b - Return line to battery negative terminal, or ground via switch or relay (switched negative)
- 31c - Return line to battery I, negative (12/24 V seriesparallel battery switch)
- 50 - Starter control (direct)
Electric Motors
- 32 - Return line
- 33 - Main terminal connection
- 33a - Self-parking switch-off
- 33b - Shunt fi eld
- 33f - For second lower-speed range
- 33g - For third lower-speed range
- 33h - For fourth lower-speed range
- 33L - Counter-clockwise rotation
- 33R - Clockwise rotation
Starters
- 45 - Separate starter relay, output; starter, input (main current) Two-starter parallel operation C — starting relay for engagement current
- 45a - Output, starter I, input, starters I and II
- 45b - Output, starter II
- 48 - Terminal ON starter and ON start-repeating relay for monitoring starting
Turn-Signal Flashers (Pulse Generators)
- 49 - Input
- 49a - Output
- 49b - Output, second circuit
- 49c - Output, third circuit
Starter Control
- 50a - Series-parallel battery switch — output for starter control
- 50b - With parallel operation of two starters with sequential control Starting relay for sequential control of the engagement current during parallel operation of two starters
- 50c - Input at starting relay for starter I
- 50d - Input at starting relay for starter II
- 50e - Start-locking relay input
- 50f - Start-locking relay output
- 50g - Start-repeating relay input
- 50h - Start-repeating relay output
Wiper Motors
- 53 - Wiper motor, input (+)
- 53a - Wiper (+), self-parking switch-off
- 53b - Wiper (shunt winding)
- 53c - Electric windshield-washer pump
- 53e - Wiper (brake winding)
- 53l - Wiper motor with permanent magnet and third brush (for higher speed)
Lighting
- 55 - Fog lamp
- 56 - Headlamp
- 56a - High beam, high-beam indicator lamp
- 56b - Low beam
- 56d - Headlamp-fl asher contact
- 57a - Parking lamp
- 57L - Parking lamp, left
- 57R - Parking lamp, right
- 58 - Side-marker, tail, license plate, and instrument panel lamps
- 58b - Dimmer
- 58d - Dimmer
- 58L - License-plate lamp, left
- 58R - License-plate lamp, right
Alternators and Voltage Regulators
- 61 - Alternator charge-indicator lamp
- B+ - Battery positive
- B- - Battery negative
- D+ - Dynamo positive
- D- - Dynamo negative
- DF - Dynamo fi eld DF1 Dynamo fi eld 1
- DF2 - Dynamo fi eld 2
- U,V,W - Alternator terminals
- 75 - Radio, cigarette lighter
- 76 - Speakers
Switches
Break Contact (NC) and Changeover Switches
- 81 - Input
- 81a - Output 1, NC side
- 81b - Output 2, NC side
Multiple-Position Switches
- 83 - Input
- 83a - Output, position 1
- 83b - Output, position 2
- 83L - Output, left-hand position
- 83R - Output, right-hand position
Relays/Current Relays
- 84 - Input, actuator and relay contact
- 84a - Output, actuator
- 84b - Output, relay contact
- 85 - Output, actuator (end of winding to ground or negative)
- 86 - Input, actuator (start of winding)
- 86a - Start of winding or 1st winding
- 86b - Winding tap or 2nd winding
Relay Contact for Break (NC) and Changeover Contacts
- 87 - Input
- 87a - Output 1 (NC side)
- 87b - Output 2 87c Output 3
- 87z - Input 1
- 87y - Input 2
- 87x - Input 3
Relay Contact for Make (NO) Contact and Changeover Contacts
- 88 - Input
- 88a - Output 1
- 88b - Output 2
- 88c - Output 3
- 88z - Input 1
- 88y - Input 2
- 88x - Input 3
Directional Signals (Turn Signal Flashers)
- C - Indicator lamp 1
- C2 - Indicator lamp 2
- C0 - Main terminal connection for separate indicator circuits actuated by the turn signal switch
- C3 - Indicator lamp 3 (e.g., when towing two trailers)
- L - Turn-signal lamps, left
- R - Turn-signal lamps, right
1.5 Diode
Normal Diode
Zener Diode
Light Sensitive Diode
Diodes are an electric component that conducts electric current in only one direction, functioning as a one-way valve. Diodes typically are made from semiconductor materials such as silicon, germanium or selenium and are uses as voltage regulators, signal rectifiers, oscillators and signal modulators/demodulators.
The arrow of the circuit symbol shows the direction in which the current can flow. Diodes are the electrical version of a valve and early diodes were actually called valves.
1.6 Fuse
Normal Fuse
Thermal Fuse
A component installed in series with a circuit, designed to disrupt the circuit when carrying more than its specified amperage. Fuses are placed in circuits to protect other components in the circuit from damage.
Fuses are used to prevent excessive current from damaging other components in a circuit. There are various types including standard fuses, thermal fuses (circuit breakers) and strip fuses.
Fuses use the component designation S .
1.7 LED (Light-emitting Diode)
An LED is a light-emitting diode semiconductor device used to transmit light into a fiber in response to an electrical signal. It typically has a broad spectral width.
The diode is created such that light emitted at a p-n junction is proportional to the bias current; color output depends on the material used.
1.8 Module
A transistorized, rather than analog, switching circuit that relies on one or inputs to control the switching of a logic circuit.
Control Modules can make the task of reading and interpreting wiring diagrams more difficult because multiple signals enter and/or exit, but the internal schematic is not always shown.
Some control modules may be integrated with other components.
Take, for example, the window motor with control module. Both the motor and the control module are combined to make a single component.
The symbol below represents the combined components.
1.9 Motor
Single Speed Motor
Two Speed Motor
A motor is driven by electromotive force.
A device that converts electrical energy into rotational motion. On late model vehicles, the speed of most motors is controlled using PWM circuits. If a motor has low output, checking the motor amperage can determine if the problem is electrical or mechanical. Increasing the electrical resistance in a motor circuit will decrease the amperage in the circuit, while increasing the mechanical load on the motor shaft will increase the amperage in the circuit.
The direction of motor rotation can be changed by reversing the polarity of the signals to the motor.
1.10 Potentiometer or Rheostat
A resistor that varies its resistance based on a mechanical input. A three wire variable resistor that is used as a voltage divider. A reference voltage (usually 5 volts or battery voltage) and ground are placed across a resistance element. A wiper is moved across the element to produce an infinitely variable voltage signal from zero up to the reference voltage, which is measured on the third wire. In automotive applications, potentiometers are commonly used as position sensors for motors or measuring throttle plate position.
A rheostat, or potentiometer, varies its resistance based on mechanical input. An example of this is the Throttle Position Sensor (TPS) on a Motronic equipped car.
1.11 Relay
Component that uses a low current to switch a high current circuit. It contains a winding that is used to magnetically move a set of points (switch), similar to the operation of a solenoid. When an on/off signal is supplied to the winding, a magnetic field is generated which changes the position of the switch. Depending on the design of the relay, the switch may be normally open or normally closed in its rest state. The most common type of relay is a four wire relay, which uses two wires for the control circuit and two wires for the switched circuit. Relays that use more than four wires are usually variations of this design, usually containing multiple control and switched circuits. If a relay contains logic circuits, it is generally considered a control unit although it may still be called a relay.
Like solenoids, relays also produce an inductive kick. Volkswagen relays have a built in suppression circuit consisting of a resistor placed parallel to the winding.
Although there are numerous types of relays used in VW and Audi vehicles, two major distinctions might be made, conventional mechanical relays and solid state relays.
Solid state relays are actually transistors– miniaturized electronic components that have a purpose similar to mechanical relays.
Transistors, like relays, allow a circuit with low current to control a circuit with high current.
- Mechanical relays are always shown with the coil deenergized.
- Solid state relays may be part of a Relay Box/Junction Block.
If they are a transistor and they fail, the entire relay box/Junction Block must be replaced.
1.12 Resistor
Normal Resistor
A commonly used symbol is the resistor, used to create a voltage drop in a circuit.
A component that creates a voltage drop in a circuit. Resistors can be used for measurement of current flow, as well as to drop the applied voltage for certain consumers.
Resistors are an electronic component that resists, limits or regulates the flow of electrical current in an electronic circuit.
Since the device has resistance it is used in a circuit for protection and current control.
A standard resistor has a fixed resistance.
Temperature Dependent Resistor
A temperature dependent resistor or thermistor is a two wire sensor that utilizes a resistor whose resistance varies with temperature. The thermistors used in most automotive applications have a Negative Temperature Coefficient (NTC), where the resistance of the thermistor decreases as the temperature increases. In a Positive Temperature Coefficient (PTC) thermistor, the resistance of the thermistor increases as the temperature increases. NTC thermistors are commonly used as temperature sensors. The temperature value is not obtained by reading the sensor resistance directly, but instead by placing a reference voltage (usually 5 volts) and ground across the sensor and then reading the resulting voltage drop.
A temperature dependent resistor varies its resistance based on temperature. This type of resistor is used as the Engine Coolant Temperature (ECT) sensor on an engine management system, or the Interior Temperature sensor on models with climate control When a resistor is used as a sensor, it generally carries a component designator “G.”
1.13 Sensors
1.13.1 Analog Sensors
Thermistor
A two wire sensor that utilizes a resistor whose resistance varies with temperature. The thermistors used in most automotive applications have a Negative Temperature Coefficient (NTC), where the resistance of the thermistor decreases as the temperature increases. In a Positive Temperature Coefficient (PTC) thermistor, the resistance of the thermistor increases as the temperature increases. NTC thermistors are commonly used as temperature sensors. The temperature value is not obtained by reading the sensor resistance directly, but instead by placing a reference voltage (usually 5 volts) and ground across the sensor and then reading the resulting voltage drop.
Potentiometer
Inductive Sensor: A two wire sensor that measures the rotation of a shaft. Unlike other sensors, this sensor does not have an external power supply. Instead, it contains a permanent magnet
that creates a magnetic field which collapses and expands when a sensor wheel is rotated through it, generating an AC sine wave signal. The frequency of the signal varies with changes in the RPM of the sensor wheel. Many crankshaft position (RPM) sensors and older ABS wheel speed sensors are inductive sensors.
Knock Sensor: A two wire sensor that is used to measure spark knock in an engine. This sensor uses a crystal material that generates an AC voltage when mechanical stress is applied to it (piezoelectric effect) when spark knock occurs. During installation, a knock sensor must be properly torqued to read spark knock correctly.
Analog Signal
An electrical signal whose amplitude can be measured at an infinite number of positions along the waveform.
1.13.2 Digital Sensors
Hall Sensors and Switches
A two or three wire electronic sensor that produces a variable frequency square wave signal. Power and ground are supplied to a Hall Effect Transistor which is located in a magnetic field generated by a permanent magnet. As the magnet field is altered by moving the magnet in relation to the transistor or by moving a shutter wheel through the magnetic field, the reference voltage is alternately pulled high or low resulting in a square wave signal.
Hall Sensors are often used to measure the position of rotating components such as camshaft position sensors.
Digital Signal
An electrical signal with an instantaneous change in amplitude (called a pulse) from low to high and high to low. Since the change in state is instantaneous, the amplitude can only be measured in two positions, high or low.
The pulse shown is a positive pulse, because the normal state of the waveform is low and the pulse goes high. However, with a negative pulse, the normal state of the waveform is high and the pulse goes low.
1.14 Solenoid
Used to actuate other components, a solenoid consists of a coil of wire wrapped around an iron core. When a current is passed through a wire, a magnetic field is induced. This magnetic "pull" is used to operate other components.
Solenoids are used to actuate many different components, including fuel injectors and relays.
A solenoid is a coil of wire wrapped around an iron core. When current is passed through the wire, a magnetic field is induced. This pulls a set of contacts in the relay closed, either opening or closing the circuit.
1.15 Switch
Normally Closed Switch
Normally Open Switch
The switch is another component used to control current flow. The basic symbols for an open and closed switch are shown in illustration SSP 8730/22. An example of this simple two-position switch would be a glove compartment light switch. A simple switch uses the component designation “F.” There are many types of designs, including mechanically actuated, pressure actuated, temperature actuated and momentary.
Manually Operated Switch
Pressure Operated Switch
Oil pressure switch (pressure actuated)
Thermally Operated Switch
Cooling fan thermo-switch (temperature actuated)
Mechanically Operated Switch
Brake Switch -F- (mechanically operated)
Complex Circuit with Multiple Switches
More complex circuits may require a switch with multiple sets of contacts. An example of this would be the cruise control switch.
As you can see in illustration above, there are multiple sets of contacts within the assembly. Depending on the position of the switch, various sets of contacts are open or closed. Careful study of the symbols allows the technician to follow the circuit through the switch under any condition.
A complex switch uses the component designation “E”
1.16 Solenoid
A two wire electromechanical device used to control the flow of liquids, gasses or the operation of mechanical components. To operate the solenoid, an on/off, PWM or variable frequency signal (commonly a switched ground) is supplied to a winding inside the solenoid, which in turn generates a magnetic field that moves a plunger. Depending on the design of the solenoid, the plunger may be normally open or normally closed in its rest state. A fuel injector is an example of a solenoid.
When the signal to the solenoid is switched off and the magnetic field around the winding collapses, the winding produces a phenomenon called “inductive kick”. Inductive kick is a high voltage pulse that is injected back into the control circuit and is similar in principal to the pulse produced by an ignition coil, although the voltage is much lower (generally around 30 to 60 volts).
1.17 Symbols
Airbag Spiral Spring
Antenna With Amplifier
Battery
Camshaft Sensor
Cigarette Lighter
Clock, Analog
Clock, Digital
Control Motor
Crankshaft Sensor
Distributor
Generator
Glow Plug
Heated O2 Sensor
Heater Element
Horn
Ignition Coil
Instrument Gauge
Interior Light
Light Bulb, Single Filament
Light Bulb, Dual Filament
Magnetic Clutch
Malfunction Indicator
Radio
Rear Window Defogger
Slip Contact
Solenoid Valve
Speaker
Speed Sensor
Starter
Spark Plug
Transistor
Wiper Motor
1.17.1 Diodes
Diode
Zener Diode
LED (Light Emitting Diode)
1.17.2 Switches
Push Button Switch
Multiple Switch
1.17.3 Wiring
Wire Junction
Disconnected Wire Terminal
Multi Point Connection
Push On Connector
Connected Wire Terminal
1.18 Transistor
Transistor is a device composed of semiconductor material that amplifies a signal or opens or closes a circuit.
1.19 Wire
- A wire is a single conductor which usually has an outer layer of insulation
1.19.1 Wire Type
Single core wire
Single core wire: It consists of a solid wire with a plastic coating.
A - Strand
B - Insulating materials
Stranded wire
Stranded wire: It consists of many fine strands of wire covered with an outer plastic coating.
A - Strand
Co-axial wire (cable)
- Co-axial wire (cable): It consists of insulated central wire which is used for signal, screen wires which are connected to 0 Volt to shield any electrical interference, and an outer sheath.
A - Signal wire
B - Insulation wire
C - Screen fine wires
D - Sheath
1.19.2 Wire color
Wire color is used to assist identify different circuit. It usually consists of one of two color: Base and Tracer. The base color is the dominant wire color whereas the tracer is thin color line.
Note
The brown colored wire - whether is solid brown or traced brown - is typically used for ground or controlled ground.
Circuit color abbreviation summary
German
Abbreviation
English
Abbreviation
Explanation
blbl/lbBlue
brbrBrown
geylYellow
gndgGreen
rordRed
swbkBlack
liviViolet
wswtWhite
1.19.3 Wire Gauge
- Wire gauge: The term gague is essentially a standard measure of thickness. A rule of thumb when understanding wire gauge :
the lower the gauge number, the higher the bead.
Metric Gauge Size in mm2America Wire Gauge (AWG) Size
.3522
.5020
.7518
1.0016
1.5014
2.5012
4.0010
6.008
16.04
25.02
35.02
1.19.4 Wire Layout
In this example we will identify a basic wire layout.
1 - Wire connection
2 - Circuit color - base circuit color covers 60%
3 - Harness inline connector
4 - Wire gauge
5 - Wire color
1.19.5 Wire Connection
Wire connection: it is two or more spliced wires together of the same circuit function. There are two types of spliced wires:
negative connection or positive connection wires.
The vehicle chassis acts as a common Ground conductor throughout the vehicle, and is identified by the line at the bottom of the wiring diagram above the current track numbers. This Ground line will also show Grounds that are welded connections in the harness. The number in the circle will be repeated in the legend with a description of the Ground connection.
Ground connections are represented as a line at the bottom of the wiring diagram page, directly above the current track numbers. All ground connections, whether they occur as a splice in a harness, or the final ground source, are numbered and identified in the wiring diagram.
Some components, such as the starter or generator, may receive Ground where they are bolted to the engine or transmission. This is also shown as a thin black line.
Welded connections are used in wiring harnesses to join multiple, smaller gauge wires to a single larger wire which terminates at the fuse relay panel or chassis ground.
Sometimes a welded connection is shown with the thin line not terminating at another wire. This symbolizes that this welded connection is used in other diagrams for the car. The technician may need to reference other diagrams to locate components or Grounds related to this connection.
Internal conductors exist inside components, acting as bridges between the wiring harness and the final consumer. In some components these conductors are labeled in the component. An example would be the 30 circuit (Battery +) in the central/relay panel. In other components the conductor is not labeled. Internal conductors are shown as thin, black lines.
Threaded connectors are commonly used on the bottom of the fuse relay plate to distribute power and ground to components.
The common connectors include battery power, ground, and load reduction (X).
Automotive Electrical Signals Glossary
Amplitude: The voltage level of a signal above or below zero
volts. The signal in the example at left has an amplitude of
2V.
Analog Signal: An electrical signal whose amplitude can be
waveform.
Digital Signal: An electrical signal with an instantaneous
The pulse shown at left is a positive pulse, because the
Sine Wave: An analog signal where the current reverses
direction at regular intervals, also called alternating current
(AC). In automotive applications, sine waves are produced by
either the alternator (unrectified) or inductive sensors (such as
the RPM sensor).
Square Wave: A digital signal that continuously alternates
between on and off. A true square wave is on and off for an
equal length of time. A variation of the square wave is the
rectangular wave, which is on and off for an unequal length of
time, but is usually still called a square wave.
Period: The time required for a signal to complete one cycle.
It can be measured in seconds (s), milliseconds (ms) or
microseconds (μs).
Frequency: The number of times a signal repeats in one
second (cycles per second), measured in Hertz (Hz). The
example at left has a frequency of 3Hz.
The frequency of a signal can be fixed or variable. Any sensor
that measures a rotating component (such as the camshaft
position sensor) generates a variable frequency signal.
Pulse Width: The time that a signal remains on during one
period. It can be measured in seconds (s), milliseconds (ms)
or microseconds (μs).
Pulse width is similar to duty cycle, except duty cycle is
measured in percent (%) instead of time, see duty cycle.
Duty Cycle: The percentage (%) of time a signal remains on
during one period.
Duty cycle is similar to pulse width, except pulse width is
measured in time instead of percent, see pulse width.
Duty cycle is calculated by dividing the pulse width (s, ms or
μs) by the period (s, ms or μs), and then multiplying the result
by 100. For example, a signal with a 50 ms pulse width and a
100 ms period has a 50% duty cycle.
Pulse Width Modulation (PWM): A signal that varies the
pulse width of a signal. It is also called variable duty cycle.
Waveform: The graphic representation of an electrical signal
as displayed on an oscilloscope screen. While waveform is
the preferred name, it is also called a trace or a pattern.
Leading Edge: When viewing a waveform, the change in
vertical height at the beginning of the signal. It is also called
the rising edge or positive edge.
Trailing Edge: When viewing a waveform, the decrease in
vertical height at the end of a signal. It is also called the falling
edge or negative edge.
Networked Signals: A signal that consists of a sequence of
coded pulses (sequence of event signals) used to broadcast
data between a network of control modules. The CAN and
LIN busses use networked signals.
Sawtooth Wave: A signal in which the amplitude
instantaneously rises and then ramps down, giving the
appearance of a sawtooth. Sawtooth signals are used in the
hood switch circuit in late model Volkswagens.
Note: The following lists provide general information on sensors, actuators and their signals. They are not intended to account for every sensor and actuator in the vehicle, and applications include, but are not limited to, those listed.
Analyzing Automotive Electrical Signals
Three factors affect automotive signals:
- Amplitude
- Frequency
- Sequence of Events
Amplitude: On/Off, analog, pulse width modulated and duty cycle signals are characterized by the rate of change in amplitude or the time the signal remains in the high or low state. When used in sensor applications, the amplitude or pulse width (duty cycle) of a signal is varied to supply data to a control module. Thermistors, potentiometers, Hall switches and pressure sensors are commonly used in this way.
Frequency: Square and sine wave signals are examples of signals that are characterized by changes in frequency (the number of times they repeat themselves per second). In sensor applications, Hall and inductive sensors are used to provide rotational data such as RPM, CMP and wheel speed sensors.
Sequence of Events: Sequence of event signals are characterized by a series of pulses that can be compared to messages sent by Morse code. By altering the sequence of the pulses, an almost infinite number of coded messages can be quickly and accurately transmitted between different control modules. Networked signals that are used by the CAN and LIN buses are examples of sequence of event signals.
Automotive Electrical Sensors and Actuators
Analog Sensors
Thermistor
: A two wire sensor that utilizes a resistor whose resistance varies with temperature. The thermistors used in most automotive applications have a Negative Temperature Coefficient (NTC), where the resistance of the thermistor decreases as the temperature increases. In a Positive Temperature Coefficient (PTC) thermistor, the resistance of the thermistor increases as the temperature increases.
Potentiometer: A three wire variable resistor that is used as a voltage divider. A reference voltage (usually 5 volts or battery voltage) and ground are placed across a resistance element. A wiper is moved across the element to produce an infinitely variable voltage signal from zero up to the reference voltage, which is measured on the third wire. In automotive applications, potentiometers are commonly used as position sensors for motors or measuring throttle plate position.
Inductive Sensor: A two wire sensor that measures the rotation of a shaft. Unlike other sensors, this sensor does not have an external power supply. Instead, it contains a permanent magnet that creates a magnetic field which collapses and expands when a sensor wheel is rotated through it, generating an AC sine wave signal. The frequency of the signal varies with changes in the RPM of the sensor wheel. Many crankshaft position (RPM) sensors and older ABS wheel speed sensors are inductive sensors.
Digital Sensors
: A two or three wire electronic sensor that produces a variable frequency square wave signal. Power and ground are supplied to a Hall Effect Transistor which is located in a magnetic field generated by a permanent magnet. As the magnet field is altered by moving the magnet in relation to the transistor or by moving a shutter wheel through the magnetic field, the reference voltage is alternately pulled high or low resulting in a square wave signal. Hall Sensors are often used to measure the position of rotating components such as camshaft position sensors.
Pressure Sensor: A three wire electronic sensor that converts pressure measurements into an electrical signal. Power and ground are supplied to a pressure sensing device, which then produces a PWM or analog signal relative to the measured pressure. The third wire transmits the PWM signal to the control module. While majority of automotive pressure sensors fall into this category, there are a small number of pressure sensors that use potentiometers to read pressure (such as in the Routan HVAC system).
Actuators
Solenoid
: A two wire electromechanical device used to control the flow of liquids, gasses or the operation of mechanical components. To operate the solenoid, an on/off, PWM or variable frequency signal (commonly a switched ground) is supplied to a winding inside the solenoid, which in turn generates a magnetic field that moves a plunger. Depending on the design of the solenoid, the plunger may be normally open or normally closed in its rest state. A fuel injector is an example of a solenoid.
Relay: An electromechanical switch that uses a low current input signal to control a high current output signal. It contains a winding that is used to magnetically move a set of points (switch), similar to the operation of a solenoid. When an on/off signal is supplied to the winding, a magnetic field is generated which changes the position of the switch. Depending on the design of the relay, the switch may be normally open or normally closed in its rest state. The most common type of relay is a four wire relay, which uses two wires for the control circuit and two wires for the switched circuit. Relays that use more than four wires are usually variations of this design, usually containing multiple control and switched circuits. If a relay contains logic circuits, it is generally considered a control unit although it may still be called a relay.
Motor: A device that converts electrical energy into rotational motion. On late model vehicles, the speed of most motors is controlled using PWM circuits. If a motor has low output, checking the motor amperage can determine if the problem is electrical or mechanical. Increasing the electrical resistance in a motor circuit will decrease the amperage in the circuit, while increasing the mechanical load on the motor shaft will increase the amperage in the circuit.
