Admin
Создатель сайта
Команда форума
- Россия, Москва
- VW Tiguan 2.0 DBGC 2018, VW Touran 1.6 BSE 2008
- Автомобиль
- VW Passat B6
- Двигатель
- AXX, AXZ, BKC, BMP, BLF, BKP, BMA, BLS, BLR, BLY, BZB, CAXA, CDGA, CAWB, CBAC, CBFA, CCTA, CGYA etc.
Relay Volkswagen Passat B6
Overview of relay carriers
1 - Heated windscreen relay -J47-
2 - Relay carrier on onboard supply control unit
In driver footwell
3 - Relay carrier 1
on left under dash panel
4 - Relay carrier 2
5 - Relay carrier on E-box
on left in engine compartment
6 - Additional relay carrier
Relay locations on electronics box, in left engine compartment (box high)
A1 - Current bridge
A2 - Circulation pump relay -J160- (100)
A3 - Motronic current supply relay 2 -J670- (167)
A4 - Main relay -J271- (100)
petrol engines only
A4 - Terminal 30 voltage supply relay -J317- (100)
diesel engines only
Relay locations on electronics box, in engine compartment left (High box), only BKC, BMP, BLF, BKP, BMA, BLS, BLR, BLY VW Passat B6 up to 04.2005
A1 - Main relay -J271- (458)
petrol engines only
A1 - Terminal 30 voltage supply relay -J317- (458)
diesel engines only
A2 - Secondary air pump relay -J299- (100)
A3 - Not assigned
A4 - Not assigned
Relay locations on electronics box, in left engine compartment (Low box)
A1 - Current bridge
For diesel engines only
A1 - Secondary air pump relay -J299- (100)
Only BSE, BSF, BYT, BZB, CBFA
A1 - Auxiliary coolant pump relay -J496- (100)
Only CAXA
A1 - Relay for gas shut-off valves -J908- (100)
Only CDGA
A1 - Engine component current supply relay -J757- (100)
Only BZB, CAWB, CCTA, CGYA
A2 - Main relay -J271- (458)/(100)
petrol engines only
A2 - Terminal 30 voltage supply relay -J317- (458)/(100)
diesel engines only
Position of Relays in Auxiliary Relay Carrier under Electronics Box, in engine compartment, left (VW Passat B6 to November 2005 and from November 2006)
Note: The additional relay carrier is located under the E-box and is only visible when the E-box is removed.
C1 - Starter relay 1 -J906- (643)
C2 - Automatic glow period control unit -J179- (457)
C3 - Continued coolant circulation relay -J151- (449)
applicable up to October 2007
C3 - Not assigned
From November 2007
C4 - Low heat output relay -J359- (53)
C5 - High heat output relay -J360- (100)
C5 - High heat output relay -J360- (370)
may occur as deviating ID number from May 2010
C6 - Starter relay 2 -J907- (489)
Relay position assignment on additional relay carrier under electronics box in left engine compartment (VW Passat B6 from November 2005)
1 - Additional relay carrier, under electronics box in engine compartment, left
Relay positions in relay carrier 1, under left dash panel
1 - Auxiliary heater operation relay -J485- (53)
Only Climatic
- Voltage monitoring relay -J813-
Only with Multimedia RSE
2 - Continued coolant circulation relay -J151- (449)
only for 1.8 l / 2.0 l TFSI and 1.4 l BiTFSI
- Electric fuel pump 2 relay -J49- (449)
Only for Common-rail diesel engines
- Current supply relay -J16- (449)
applicable from May 2009
Only 6-cylinder petrol engines and 1.6L / 77 kW Common Rail diesel
3 - Fresh air blower relay -J13- (404), from May 2008 (449)
only auxiliary coolant heater
4 - Fuel pump relay -J17- (404), from May 2008 (449)
5 - Electric fuel pump 2 relay -J49- (404), from May 2008 (449)
6 - Headlight washer system relay -J39- (53)
7 - Terminal 50 voltage supply relay -J682- (433), from November 2006 (53)
Only vehicles with 0GT emissions standard from November 2009
Relay assignment, relay carrier on onboard supply control unit, in driver's footwell
B1 - Terminal 15 voltage supply relay -J329- (460)
B2 - Not assigned
B3 - Not assigned
B4 - Terminal 30 voltage supply relay 2 -J689- (449)
B5 - Heated rear window relay -J9- (53)
B6 - Dual tone horn relay -J4- (449)
B7 - Double washer pump relay 1 -J729- (404)
B8 - Double washer pump relay 2 -J730- (404)
B9 - X-contact relief relay -J59- (460)
Relay positions in relay carrier 2, under left dash panel
A - Isolation relay for powertrain CAN bus -J788- (479)
B - Not assigned
C - Second battery charging circuit relay -J713- (478)
D - Alarm horn relay -J641- (53)
American markets only
Location: In plenum chamber next to engine control unit -arrow
In driver footwell
3 - Relay carrier 1
4 - Relay carrier 2
A1 - Current bridge
petrol engines only
diesel engines only
petrol engines only
diesel engines only
A3 - Not assigned
A4 - Not assigned
A1 - Current bridge
Only CAXA
Only CDGA
petrol engines only
diesel engines only
C3 - Not assigned
From November 2007
Only Climatic
B2 - Not assigned
B3 - Not assigned
B - Not assigned
Fuses Volkswagen Passat B6 (3C) 2006 - 2010, предохранители
Volkswagen Passat B6 (model 3C2) 2006 - 2010 Volkswagen Passat Variant B6 (model 3C5) 2006 - 2010 Fuses Volkswagen Passat B6 Overview of fuses: 1 - Fuse holder D -SD- 2 - Fuse holder F -SF- 3 - Fuse 2 (30) -S205- 4 - Fuse holder C -SC- 5 - Circuit breakers on left under dash panel 6 - Fuse...
vwts.ru
