Admin
Создатель сайта
Команда форума
- Россия, Москва
- VW Tiguan 2.0 DBGC 2018, VW Touran 1.6 BSE 2008
Volkswagen Passat B6 (model 3C2) 2006 - 2010
Volkswagen Passat Variant B6 (model 3C5) 2006 - 2010
Fuses Volkswagen Passat B6
Overview of fuses:
1 - Fuse holder D -SD-
2 - Fuse holder F -SF-
3 - Fuse 2 (30) -S205-
4 - Fuse holder C -SC-
5 - Circuit breakers on left under dash panel
6 - Fuse holder B -SB-
7 - Fuse holder A -SA-
Fuse holder A -SA- on fuse holder on E-Box high, in the engine compartment on the left VW Passat B6
Fuse colours
40 A - orange
30 A - green
25 A - white
20 A - yellow
15 A - blue
10 A - red
7.5 A - brown
5 A - beige
3 A - purple
Fuse assignment on fuse holder A -SA- on E-box high, in the engine compartment on the left VW Passat B6
1) Only models with 180A alternator, installed in alternator wire
2) From November 2005
3) From May 2006
4) To April 2006
5) To April 2008
6) From May 2008
Fuse holder A -SA- on fuse holder on E-box low, in the engine compartment on the left
Fuse colours
50 A - red
40 A - orange
30 A - green
25 A - white
20 A - yellow
15 A - blue
10 A - red
7.5 A - brown
5 A - beige
3 A - purple
Fuse assignment on fuse holder A -SA- on E-box low, in the engine compartment on the left VW Passat B6
3) From May 2006
4) To April 2006
5) From November 2006
6) To April 2008
7) From May 2008
Fuse holder B -SB- , on E-box on left in engine compartment (not AXX, AXZ, BLV, BPY, BWA) VW Passat B6 to 04.2005
Fuse colours
50 A - red
40 A - orange
30 A - green
25 A - white
20 A - yellow
15 A - blue
10 A - red
7.5 A - brown
5 A - beige
3 A - purple
Fuse assignment on E-box on left in engine compartment (not AXX, AXZ, BLV, BPY, BWA) VW Passat B6 to 04.2005
1) Only models with diesel engines
2) Only diesel engines and engine code BLY
Fuse holder B -SB- on E-box high, in the engine compartment, on the left
Fuse colours
50 A - red
40 A - orange
30 A - green
25 A - white
20 A - yellow
15 A - blue
10 A - red
7.5 A - brown
5 A - beige
3 A - purple
Fuse assignment on E-box high, on left in engine compartment VW Passat B6
1) To April 2006
2) From May 2006
3) Only models with diesel engines
4) Only RNS 510 and RNS 300, from November 2007
5) From November 2008
6) To October 2008
Fuse holder B -SB- on E-box low on left in engine compartment, VW Passat B6 from 05.2005
Fuse colours
50 A - red
40 A - orange
30 A - green
25 A - white
20 A - yellow
15 A - blue
10 A - red
7.5 A - brown
5 A - beige
3 A - purple
Fuse assignment on E-box low, on left of engine compartment, VW Passat B6 from 05.2005
1) To April 2006
2) From May 2006
4) From November 2008
5) Depends on equipment
6) From November 2006
7) Only models with start/stop system
8) Only models with a petrol engine
9) Only engine code CBAC
10) Only engine code CBFA
Fuse holder C -SC- , dash panel on driver side, VW Passat B6 to April 2008
Fuse colours
50 A - red
40 A - orange
30 A - green
25 A - white
20 A - yellow
15 A - blue
10 A - red
7.5 A - brown
5 A - beige
3 A - purple
Fuse assignment on fuse holder C, on driver's side of dash panel, VW Passat B6 to April 2008
1) To May 2005
2) From May 2006
3) Only for automatic gearbox
4) To November 2005
5) To April 2006
6) From May 2005
7) Only Climatic with supplementary coolant heater
8) Only models with no supplementary coolant heater
9) From November 2006
10) Not with Climatronic
11) Only models with taxi equipment from May 2005
12) Only models with police equipment from May 2005
13) Only models with crime investigation equipment from May 2005
Fuse holder C -SC- , dash panel on driver side, VW Passat B6 from May 2008
Fuse colours
30 A - green
25 A - white
20 A - yellow
15 A - blue
10 A - red
7.5 A - brown
5 A - beige
3 A - purple
Fuse assignment on fuse holder C -SC- , on driver side of dash panel, VW Passat B6 from May 2008
1) Only models with a petrol engine
2) Only models with a diesel engine
3) Only models with a 6-speed automatic gearbox
4) Only models with start/stop system
Fuse holder D -SD- , on front passenger side of dash panel, VW Passat B6 to April 2008
Fuse colours
30 A - green
25 A - white
20 A - yellow
15 A - blue
10 A - red
7.5 A - brown
5 A - beige
3 A - purple
Note: Slot SD11 has been discontinued
Fuse assignment on fuse holder D -SD- , on front passenger side of dash panel, VW Passat B6 to April 2008
1) Only models from May 2005
2) Only models to April 2006
3) Only models from November 2007
4) Only models from May 2006 and to October 2006
5) Only models from May 2006
6) Only models with taxi equipment to May 2005
7) Only models with taxi equipment from May 2005
Fuse holder D -SD- , on front passenger side of dash panel, VW Passat B6 from April 2008
Fuse colours
30 A - green
25 A - white
20 A - yellow
15 A - blue
10 A - red
7.5 A - brown
5 A - beige
3 A - purple
Fuse assignment on fuse holder D -SD- , on front passenger side of dash panel, VW Passat B6 from May 2008
Circuit breakers, on left under dash panel
Fuse assignment VW Passat B6
1) Only models with no memory function
2) Only models with memory function
3) Only models with 12-way seat
Fuse holder F -SF- , rear left in luggage compartment (AXZ, BLV, BWS)
Fuse colours
30 A - green
25 A - white
20 A - yellow
15 A - blue
10 A - red
7.5 A - brown
5 A - beige
3 A - purple
Fuse assignment on fuse holder F -SF- , rear left in luggage compartment (AXZ, BLV, BWS)
1) Only models from May 2006
Fuse 2 (30) -S205-
Fitting location:
In luggage compartment behind left side panel trim -arrow-
Fuse rating:
70A - Saloon
60A - Variant
Overview of fuses:
Fuse colours
40 A - orange
30 A - green
25 A - white
20 A - yellow
15 A - blue
10 A - red
7.5 A - brown
5 A - beige
3 A - purple
| No. | Current Flow Diagram designation | Nominal value | Function/component | Terminal | ||
| 1 | - | Fuse 1 on fuse holder A -SA1- | 150A /180A 1) | - | Alternator -C- | 30 |
| 2 | - | Fuse 2 on fuse holder A -SA2- | 80A | - | Electromechanical power steering motor -V187- | 30 |
| 3 | - | Fuse 3 on fuse holder A -SA3- | 80A 50A 2) | - | Radiator fan control unit -J293- | 30 |
| 4 | - | Fuse 4 on fuse holder A -SA4- | 100A 4) 80A 3) 60A 6) | - | Driver seat adjustment thermal fuse 1 -S44- 4) Front passenger seat adjustment thermal fuse 1 -S46- 4) Left fuse holder (SC32 - SC37) 4) Right fuse holder (SD32 - SD37) 4), 5) Left fuse holder (SC12 - SC17, SC29 - SC31) 3) Right fuse holder (SD12 - SD17, SD28, SD29 - SD31) 3) 5) Right fuse holder (SD1 - SD2)6) | 30 |
| 5 | - | Fuse 5 on fuse holder A -SA5- | 80A | - | Right fuse holder (SD22 - SD27)5) Driver seat adjustment thermal fuse 1 -S44- 3) Front passenger seat adjustment thermal fuse 1 -S46- 3) | 30 |
| 6 | - | Fuse 6 on fuse holder A -SA6- | 100A 4) 80A 3) | - | Left fuse holder (SC12 - SC17, SC29 - SC31) 4) Right fuse holder (SD12 - SD17, SD28, SD29 - SD31) 4) 5) Left fuse holder (SC32 - SC37) 3) | 30 |
| 7 | - | Fuse 7 on fuse holder A -SA7- | 40A | - | ABS control unit -J104- | 30 |
3) From May 2006
4) To April 2006
5) To April 2008
6) From May 2008
Fuse colours
50 A - red
40 A - orange
30 A - green
25 A - white
20 A - yellow
15 A - blue
10 A - red
7.5 A - brown
5 A - beige
3 A - purple
| 1 | - | Fuse 1 on fuse holder A -SA1- | 150A | - | Alternator -C- | 30 |
| 4 | - | Fuse 4 on fuse holder A -SA4- | 60A | - | Driver seat adjustment thermal fuse 1 -S44- 4) Front passenger seat adjustment thermal fuse 1 -S46- 4) Left fuse holder (SC32 - SC37) 4) Right fuse holder (SD32 - SD37) 4) 6) Left fuse holder (SC12 - SC17, SC29 - SC31) 3) Right fuse holder (SD12 - SD17, SD28, SD29 - SD31) 3) 6) | 30 |
| 5 | - | Fuse 5 on fuse holder A -SA5- | 80A 60A7) | - | Right fuse holder (SD22 - SD27) 6) Driver seat adjustment thermal fuse 1 -S44- 3) Front passenger seat adjustment thermal fuse 1 -S46- 3) Right fuse holder (SD1 - SD2) 7) | 30 |
| 6 | - | Fuse 6 on fuse holder A -SA6- | 100A 4) 80A 3) | - | Left fuse holder (SC12 - SC17, SC29 - SC31) 4) Right fuse holder (SD12 - SD17, SD28, SD29 - SD31) 4) 6) Left fuse holder (SC32 - SC37)3) | 30 |
| 7 | - | Fuse 7 on fuse holder A -SA7- | 60A 100A | - | Auxiliary battery charge cable Auxiliary air heater heating element -Z35- High heat output relay -J360- 5 | 30 |
| 8 | - | Fuse 8 on fuse holder A -SA8- | 40A | - | ABS control unit -J104- | 30 |
3) From May 2006
4) To April 2006
6) To April 2008
7) From May 2008
Fuse colours
50 A - red
40 A - orange
30 A - green
25 A - white
20 A - yellow
15 A - blue
10 A - red
7.5 A - brown
5 A - beige
3 A - purple
| F1 | - | Fuse 1 fuse holder B -SB1- | 5A 15A | - | Automatic gearbox control unit -J217- Mechatronic unit for dual clutch gearbox -J743- | 30 |
| F2 | - | Fuse 2 fuse holder B -SB2- | 30A | - | ABS control unit -J104- | 30 |
| F3 | - | Fuse 3 on fuse holder B -SB3- | 20A | - | Convenience system central control unit -J393- | 30 |
| F4 | - | Fuse 4 on fuse holder B -SB4- | 5A | - | Onboard supply control unit -J519- | 30 |
| F5 | - | Fuse 5 fuse holder B -SB5- | 20A | - | Treble tone horn -H2- Bass tone horn -H7- | 30 |
| F6 | - | Fuse 6 fuse holder B -SB6- | - | - | Vacant | 30 |
| F7 | - | Fuse 7 fuse holder B -SB7- | - | - | Vacant | 30 |
| F8 | - | Fuse 8 fuse holder B -SB8- | - | - | Vacant | 87 |
| F9 | - | Fuse 9 on fuse holder B -S9- | - | - | Vacant | 87 |
| F10 | - | Fuse 10 on fuse holder B -SB10- | - | - | Vacant | 87 |
| F11 | - | Fuse 11 on fuse holder B -SB11- | - | - | Vacant | 87 |
| F12 | - | Fuse 12 on fuse holder B -SB12- | - | - | Vacant | 87 |
| F13 | - | Fuse 13 on fuse holder -SB13- | - | - | Vacant | 30 |
| F14 | - | Fuse 14 on fuse holder B -SB14- | - | - | Vacant | 30 |
| F15 | - | Fuse 15 on fuse holder B -SB15- | - | - | Vacant | 87 |
| F16 | - | Fuse 16 on fuse holder B -SB16- | 10A | - | Steering column electronics control unit -J527- | 30 |
| F17 | - | Fuse 17 on fuse holder B -SB17- | 5A | - | Control unit in dash panel insert -J285- | 30 |
| F18 | - | Fuse 18 on fuse holder B -SB18- | 30A | - | Amplifier -R12- Special vehicle control unit -J608- | 30 |
| F19 | - | Fuse 19 on fuse holder B -SB19- | 15A | - | Radio -R Control unit with display for radio and navigation system -J503- Control unit with display for TV, radio, navigation -J506- (Japan) | 30 |
| F20 | - | Fuse 20 on fuse holder B -SB20- | 5A | - | Aerial selection control unit -J515- Mobile telephone operating electronics control unit -J412- | 30 |
| F21 | - | Fuse 21 on fuse holder B -SB21- | - | - | Vacant | 30 |
| F22 | - | Fuse 22 on fuse holder B -SB22- | - | - | Vacant | 30 |
| F23 | - | Fuse 23 on fuse holder B -SB23- | 10A | - | Terminal 15 voltage supply relay -J329- Engine control unit -J623- | 30 |
| F24 | - | Fuse 24 on fuse holder B -SB24- | 10A | - | Data bus diagnostic interface -J533- | 30 |
| F25 | - | Fuse 25 on fuse holder B -SB25- | - | - | Vacant | 30 |
| F26 | - | Fuse 26 on fuse holder B -SB26- | 10A | - | Terminal 30 voltage supply relay -J317- | 30 |
| F27 | - | Fuse 27 on fuse holder B -SB27- | 20A 10A1) | - | N... -Ignition coils with output stages (cylinders 1-4) Ignition transformer -N152- Electric fuel pump 2 relay -J49- Automatic glow period control unit -J179- | 87 |
| F28 | - | Fuse 28 on fuse holder B -SB28- | 25A 30A1) | - | Engine control unit -J623- | 87 |
| F29 | - | Fuse 29 on fuse holder B -SB29- | 15A 10A1) | - | Secondary air pump relay -J299- Exhaust gas recirculation valve -N18- Charge pressure control solenoid valve -N75- Exhaust gas recirculation cooler change-over valve -N345- Lambda probe heater -Z19- Lambda probe 2 heater -Z28- Lambda probe 1 heater after catalytic converter -Z29- | 87 |
| F30 | - | Fuse 30 on fuse holder B -SB30- | 20A | - | Auxiliary heater control unit -J364- | 30 |
| F31 | - | Fuse 31 on fuse holder B -SB31- | 30A | - | Wiper motor control unit -J400- | 30 |
| F32 | - | Fuse 32 on fuse holder B -SB32- | - | - | Vacant | 87 |
| F33 | - | Fuse 33 on fuse holder B -SB33- | - | - | Vacant | 87 |
| F34 | - | Fuse 34 on fuse holder B -SB34- | - | - | Vacant | 87 |
| F35 | - | Fuse 35 on fuse holder B -SB35- | - | - | Vacant | 30 |
| F36 | - | Fuse 36 on fuse holder B -SB36- | - | - | Vacant | 30 |
| F37 | - | Fuse 37 on fuse holder B -SB37- | - | - | Vacant | 30 |
| F38 | - | Fuse 38 on fuse holder B -SB38- | 10A | - | Radiator fan control unit -J293- Map-controlled engine cooling system thermostat -F265- Exhaust gas recirculation valve -N18- Activated charcoal filter system solenoid valve 1 -N80- Camshaft control valve 1 -N205- Intake manifold flap valve -N316- Intake manifold flap motor -V157- | 87 |
| F39 | - | Fuse 39 on fuse holder B -SB39- | 15A | - | Fuel pressure regulating valve -N276- Clutch position sender -G476- | 87 |
| F40 | - | Fuse 40 on fuse holder B -SB40- | 15A 10A2) | - | NOx sensor control unit -J583- Lambda probe heater -Z19- Lambda probe 1 heater after catalytic converter -Z29- Lambda probe 2 heater after catalytic converter -Z30- Lambda probe 3 heater after catalytic converter -Z64- | 87 |
| F41 | - | Fuse 41 on fuse holder B -SB41- | - | - | Vacant | |
| F42 | - | Fuse 42 on fuse holder B -SB42- | - | - | Vacant | |
| F43 | - | Fuse 43 on fuse holder B -SB43- | - | - | Vacant | |
| F44 | - | Fuse 44 on fuse holder B -SB44- | - | - | Vacant | |
| F45 | - | Fuse 45 on fuse holder B -SB45- | - | - | Vacant | |
| F46 | - | Fuse 46 on fuse holder B -SB46- | - | - | Vacant | |
| F47 | - | Fuse 47 on fuse holder B -SB47- | 40A | - | Onboard supply control unit -J519- Right side light bulb -M3- Left headlight dipped beam bulb -M29- Left headlight main beam bulb -M30- Left tail light bulb -M4- (outer light ring) Right tail light bulb -M2- (inner light ring) | 30 |
| F48 | - | Fuse 48 on fuse holder B -SB48- | 40A | - | Onboard supply control unit -J519- Left side light bulb -M1- Right headlight dipped beam bulb -M31- Right headlight main beam bulb -M32- Right tail light bulb -M2- (outer light ring) Left tail light bulb -M4- (inner light ring) | 30 |
| F49 | - | Fuse 49 on fuse holder B -SB49- | 50A | - | Onboard supply control unit -J519- (supply, terminal 15) | 30 |
| F50 | - | Fuse 50 on fuse holder B -SB50- | 60A | - | Second battery charging circuit relay -J713- | 30 |
| F51 | - | Fuse 51 on fuse holder B -SB51- | - | - | Vacant | 30 |
| F52 | - | Fuse 52 on fuse holder B -SB52- | 60A | - | Heated windscreen -Z2- | 30 |
| F53 | - | Fuse 53 on fuse holder B -SB53- | 50A | - | Onboard supply control unit -J519- (supply, terminal 75) Left fuse holder (SC40 - SC42, SD39) | 30 |
| F54 | - | Fuse 54 on fuse holder B -SB54- | 50A | - | Automatic glow period control unit -J179- Secondary air pump motor -V101- | 30 |
Fuse colours
50 A - red
40 A - orange
30 A - green
25 A - white
20 A - yellow
15 A - blue
10 A - red
7.5 A - brown
5 A - beige
3 A - purple
| F3 | - | Fuse 3 on fuse holder B -SB3- | 20A | - | Convenience system central control unit -J393- 1) Trailer detector control unit -J345- 2) | 30 |
| F6 | - | Fuse 6 fuse holder B -SB6- | 20A | - | Ignition coils with output stages -N...- | 87 |
| F7 | - | Fuse 7 fuse holder B -SB7- | 15A 5A | - | Fuel pressure regulating valve -N276- Clutch position sender -G476- | 87 |
| F8 | - | Fuse 8 fuse holder B -SB8- | 10A | - | Radiator fan control unit -J293- Activated charcoal filter system solenoid valve 1 -N80- Camshaft control valve 1 -N205- Intake manifold flap valve -N316- Exhaust camshaft control valve 1 -N318- Suction jet pump valve -N401- | 87 |
| F9 | - | Fuse 9 on fuse holder B -S9- | 5A | - | Circulation pump relay -J160- | 87 |
| F10 | - | Fuse 10 on fuse holder B -SB10- | 10A | - | Motronic current supply relay 2 -J670- | 87 |
| F11 | - | Fuse 11 on fuse holder B -SB11- | 25A 30A 3) | - | Engine control unit -J623- | 87 |
| F14 | - | Fuse 14 on fuse holder B -SB14- | - | - | Vacant | |
| F15 | - | Fuse 15 on fuse holder B -SB15- | 10A | - | Circulation pump -V55- | 87 |
| F16 | - | Fuse 16 on fuse holder B -SB16- | 5A | - | Steering column electronics control unit -J527- | 30 |
| F19 | - | Fuse 19 on fuse holder B -SB19- | 15A 20A 4) | - | Radio -R Control unit with display for radio and navigation system -J503- Control unit with display for TV, radio, navigation -J506- (Japan) | 30 |
| F20 | - | Fuse 20 on fuse holder B -SB20- | 5A | - | Operating unit for preparation for mobile telephone -E508- 2) Aerial selection control unit -J515- 1) Mobile telephone operating electronics control unit -J412- 2) Telephone transmitter and receiver unit -R36- 1) TV tuner -R78- 5) Satellite digital radio tuner -R190- 5) | 30 |
| F21 | - | Fuse 21 on fuse holder B -SB21- | 10A | - | TV tuner -R78- 6) Satellite digital radio tuner -R190- 6) | 30 |
| F22 | - | Fuse 22 on fuse holder B -SB22- | 7.5A | - | Multimedia system control unit -J650- | 30 |
| F23 | - | Fuse 23 on fuse holder B -SB23- | 10A 5A7) | - | Radiator fan control unit -J293- Magnetic field sender for compass -G197- 2) | 30 |
| F24 | - | Fuse 24 on fuse holder B -SB24- | 5A 10A | - | Data bus diagnostic interface -J533- | 30 |
| F25 | - | Fuse 25 on fuse holder B -SB25- | - | - | Vacant | |
| F26 | - | Fuse 26 on fuse holder B -SB26- | 10A | - | Main relay -J271- Engine control unit -J623- | 30 |
| F27 | - | Fuse 27 on fuse holder B -SB27- | - | - | Vacant | |
| F28 | - | Fuse 28 on fuse holder B -SB28- | - | - | Vacant | |
| F29 | - | Fuse 29 on fuse holder B -SB29- | - | - | Vacant | |
| F32 | - | Fuse 32 on fuse holder B -SB32- | 10A | - | Charge pressure control solenoid valve -N75- Activated charcoal filter system solenoid valve 1 -N80- Turbocharger air recirculation valve -N249- | 87 |
| F33 | - | Fuse 33 on fuse holder B -SB33- | 15A | - | Fuel pressure regulating valve -N276- Lambda probe heater -Z19- Lambda probe 2 heater -Z28- | 87 |
| F34 | - | Fuse 34 on fuse holder B -SB34- | - | - | Vacant | |
| F35 | - | Fuse 35 on fuse holder B -SB35- | 20A | - | Auxiliary heater operation relay -J485- | 29 |
| F36 | - | Fuse 36 on fuse holder B -SB36- | - | - | Vacant | |
| F37 | - | Fuse 37 on fuse holder B -SB37- | - | - | Vacant | |
| F38 | - | Fuse 38 on fuse holder B -SB38- | - | - | Vacant | |
| F39 | - | Fuse 39 on fuse holder B -SB39- | - | - | Vacant | |
| F40 | - | Fuse 40 on fuse holder B -SB40- | - | - | Vacant | |
| F44 | - | Fuse 44 on fuse holder B -SB44- | 10A | - | Fuel system diagnostic pump -V144- | 87 |
| F45 | - | Fuse 45 on fuse holder B -SB45- | 10A | - | Lambda probe heater -Z19- Lambda probe 1 heater after catalytic converter -Z29- Lambda probe 2 heater after catalytic converter -Z30- Heating for Lambda probe 3 for bank 1 -Z92- Heating for Lambda probe 3 for bank 2 -Z93- | 87 |
| F46 | - | Fuse 46 on fuse holder B -SB46- | 10A | - | Lambda probe 1 heater after catalytic converter -Z29- | |
| F51 | - | Fuse 51 on fuse holder B -SB51- | - | - | Vacant | |
| F54 | - | Fuse 54 on fuse holder B -SB54- | - | - | Vacant | 30 |
1) To April 2006
2) From May 2006
6) To October 2008
Fuse colours
50 A - red
40 A - orange
30 A - green
25 A - white
20 A - yellow
15 A - blue
10 A - red
7.5 A - brown
5 A - beige
3 A - purple
| F1 | - | Fuse 1 fuse holder B -SB1- | 7.5A | - | Multimedia system control unit -J650- | 30 |
| F3 | - | Fuse 3 on fuse holder B -SB3- | 20A | - | Treble tone horn -H2- Bass tone horn -H7- Onboard supply control unit -J519- | 30 |
| F4 | - | Fuse 4 on fuse holder B -SB4- | 20A 25A | - | Convenience system central control unit -J393- 1) Trailer detector control unit -J345- 2) | 30 |
| F5 | - | Fuse 5 fuse holder B -SB5- | 5A | - | Battery monitor control unit -J367- Onboard supply control unit -J519- | 30 |
| F6 | - | Fuse 6 fuse holder B -SB6- | 5A 15A | - | Automatic gearbox control unit -J217- Mechatronic unit for dual clutch gearbox -J743- | 30 |
| F7 | - | Fuse 7 fuse holder B -SB7- | 15A 20A 30A | - - - | Radio -R Control unit with display for TV, radio, navigation -J506- (Japan) Control unit with display for radio and navigation system -J503- Voltage stabiliser -J532- | 30 |
| F8 | - | Fuse 8 fuse holder B -SB8- | 30A | - | Mechatronic unit for dual clutch gearbox -J743- | 30 |
| F9 | - | Fuse 9 on fuse holder B -S9- | 5A | - | Steering column electronics control unit -J527- | 30 |
| F10 | - | Fuse 10 on fuse holder B -SB10- | 20A | - | Fuel pump relay -J17- 3) Automatic glow period control unit -J179- 3) N...-Ignition coils with final output stages (cylinders 1-4) | 87 |
| F11 | - | Fuse 11 on fuse holder B -SB11- | 5A | - | Control unit in dash panel insert -J285- 7) | 30 |
| F12 | - | Fuse 12 on fuse holder B -SB12- | 5A | - | Mobile telephone operating electronics control unit -J412- Aerial selection control unit -J515- 1) Operating unit for preparation for mobile telephone -E508- 2) TV tuner -R78- 4) Satellite digital radio tuner -R190- 4) | 30 |
| F13 | - | Fuse 13 on fuse holder -SB13- | 10A | - | Main relay -J271- Terminal 30 voltage supply relay -J317- Engine control unit -J623- | 30 |
| F14 | - | Fuse 14 on fuse holder B -SB14- | 30A 25A | - - | Engine control unit -J623- 3) Engine control unit -J623- 8) | 87 |
| F15 | - | Fuse 15 on fuse holder B -SB15- | 10A 5A 6) | - | Data bus diagnostic interface -J533- | 30 |
| F16 | - | Fuse 16 on fuse holder B -SB16- | 5A 10A | - | Secondary air pump relay -J299- Exhaust gas recirculation valve -N18- 3) Charge pressure control solenoid valve -N75- 3) Turbocharger air recirculation valve -N249- 3) Intake manifold flap valve -N316- Exhaust gas recirculation cooler change-over valve -N345- Lambda probe heater -Z19- Lambda probe 2 heater -Z28- | 87 |
| F17 | - | Fuse 17 on fuse holder B -SB17- | 10A 40A | - - | Fuel tank shut-off valve 1 -N361- Fuel tank shut-off valve 2 -N362- Fuel tank shut-off valve 3 -N363- Low heat output relay -J359- 6) | 30 |
| F18 | - - - | Fuse 18 on fuse holder B -SB18- | 5A 10A 30A | - - - | Low heat output relay -J359- 6) High heat output relay -J360- 6) Continued coolant circulation pump -V51- Reducing-agent heater control unit -J891- | 87 |
| F19 | - | Fuse 19 on fuse holder B -SB19- | 30A | - | Amplifier -R12- Special vehicles | 30 |
| F20 | - - - | Fuse 20 on fuse holder B -SB20- | 5A 10A 10) 15A | Supplementary fuel pump relay -J832- Radiator fan control unit -J293- 9 Automatic glow period control unit -J179- 9) Clutch position sender -G476- Activated charcoal filter system solenoid valve 1 -N80- Camshaft control valve 1 -N205- Turbocharger air recirculation valve -N249- Intake manifold flap valve -N316- Secondary air inlet valve -N112- Clutch position sender -G476- Fuel pressure regulating valve -N276- | 87 | |
| F21 | - | Fuse 21 on fuse holder B -SB21- | 20A | - | Auxiliary heater control unit -J364- | 30 |
| F22 | - | Fuse 22 on fuse holder B -SB22- | 30A | - | Wiper motor control unit -J400- | 30 |
| F23 | - | Fuse 23 on fuse holder B -SB23- | 5A 10A | - | Magnetic field sender for compass -G197- Automatic glow period control unit -J179- Map-controlled engine cooling system thermostat -F265- Radiator fan control unit -J293- Activated charcoal filter system solenoid valve 1 -N80- Variable intake manifold change-over valve -N156- Camshaft control valve 1 -N205- Intake manifold flap valve -N316- Intake manifold flap motor -V157- Lambda probe heater -Z19- Lambda probe 1 heater after catalytic converter -Z29- | 87 |
| F24 | - | Fuse 24 on fuse holder B -SB24- | 10A 5) 15A 5) | - | NOx sensor control unit -J583- Lambda probe heater -Z19- Lambda probe 1 heater after catalytic converter -Z29- Lambda probe 2 heater after catalytic converter -Z30- Lambda probe 3 heater after catalytic converter -Z64- | 87 |
| F25 | - | Fuse 25 on fuse holder B -SB25- | 40A | - | Onboard supply control unit -J519- Left side light bulb -M1- Right headlight dipped beam bulb -M31- Right headlight main beam bulb -M32- Right tail light bulb -M2- (outer light ring) Left tail light bulb -M4- (inner light ring) | 30 |
| F26 | - | Fuse 26 on fuse holder B -SB26- | 40A | - | Onboard supply control unit -J519- Right side light bulb -M3- Left headlight dipped beam bulb -M29- Left headlight main beam bulb -M30- Left tail light bulb -M4- (outer light ring) Right tail light bulb -M2- (inner light ring) | 30 |
| F27 | - | Fuse 27 on fuse holder B -SB27- | 60A | - | Heated windscreen -Z2- | 30 |
| F28 | - - | Fuse 28 on fuse holder B -SB28- | 40A 50A | - - | Secondary air pump motor -V101- Automatic glow period control unit -J179- 3) | 30 |
| F29 | - | Fuse 29 on fuse holder B -SB29- | 50A | - | Onboard supply control unit -J519- X-contact relief relay -J59- | 30 |
| F30 | - | Fuse 30 on fuse holder B -SB30- | 50A | - | Onboard supply control unit -J519- | 3 |
1) To April 2006
2) From May 2006
Fuse colours
50 A - red
40 A - orange
30 A - green
25 A - white
20 A - yellow
15 A - blue
10 A - red
7.5 A - brown
5 A - beige
3 A - purple
| 1 | Fuse 1 on fuse holder C -SC1- | 10A | - | Diagnosis connection -T16- | 15 | |
| 2 | - | Fuse 2 on fuse holder C -SC2- | 5A | - | TCS and ESP button -E256- AUTOHOLD button -E540- | 15 |
| 3 | - | Fuse 3 on fuse holder C -SC3- | 5A | - | Power steering control unit -J500- | 15 |
| 4 | - | Fuse 4 on fuse holder C -SC4- | 5A | - | Brake light switch -F- | 15 |
| 5 | - | Fuse 5 on fuse holder C -SC5- | 10A | - | Headlight range control regulator -E102- Power output module for left headlight -J667- Left headlight range control motor -V48- Right headlight range control motor -V49- | 15 |
| 6 | - | Fuse 6 on fuse holder C -SC6- | 5A | - | Trailer detector control unit -J345- | 15 |
| 7 | - | Fuse 7 on fuse holder C -SC7- | 5A | - | Control unit in dash panel insert -J285- Data bus diagnostic interface -J533- | 15 |
| 8 | - | Fuse 8 on fuse holder C -SC8- | 5A | - | Rear roller blind switch -E149- 1) Garage door operating unit -E284- 1) Rear roller blind control unit -J262- 1) Automatic anti-dazzle interior mirror -Y7- | 15 |
| 9 | Fuse 9 on fuse holder C -SC9- | 10A | - | All-wheel drive control unit -J492- | 15 | |
| 10 | - | Fuse 10 on fuse holder C -SC10- | 5A | - | Main relay -J271- Engine control unit -J623- Motronic current supply relay 2 -J670- | 15 |
| 11 | - | Fuse 11 on fuse holder C -SC11- | 5A | - | Crash data recorder button -E497- (Police) Taximeter -G41- (Taxi) Mirror taxi meter -G511- (Taxi) Crash data recorder -J754- Tachograph coupling point (Police) Special signal system coupling point (Police) Warning buzzer for pedal switch on front passenger side -F349- (Driving school) | 15 |
| 12 | - | Fuse 12 on fuse holder C -SC12- | 10A | - | Driver door control unit -J386- Rear right door control unit -J389- 2) | 30 |
| 13 | - | Fuse 13 on fuse holder C -SC13- | 10A | - | Lighting switch -E1- Diagnosis connection -T16- | 30 |
| 14 | - | Fuse 14 on fuse holder C -SC14- | 5A | - | Electronic steering column lock control unit -J764- | 30 |
| 15 | - | Fuse 15 on fuse holder C -SC15- | 5A | - | Onboard supply control unit -J519- (30g) Front interior light -W1- | 30 |
| 16 | - | Fuse 16 on fuse holder C -SC16- | 10A | - | Electronic ignition lock -D9- | 30 |
| 17 | - | Fuse 17 on fuse holder C -SC17- | 10A | - | Interior monitor send and receive module 1 -G303- Rain and light sensor -G397- Vehicle inclination sender -G384- Alarm horn -H12- Remote control receiver for auxiliary coolant heater -R149- | 30 |
| 18 | - | Fuse 18 on fuse holder C -SC18- | - | - | Vacant | - |
| 19 | - | Fuse 19 on fuse holder C -SC19- | - | - | Vacant | - |
| 20 | - | Fuse 20 on fuse holder C -SC20- | - | - | Vacant | - |
| 21 | - | Fuse 21 on fuse holder C -SC21- | - | - | Vacant | - |
| 22 | - | Fuse 22 on fuse holder C -SC22- | 10A 5A | - | Air mass meter -G70- Electric fuel pump 2 relay -J49- | 15 |
| 23 | - | Fuse 23 on fuse holder C -SC23- | 10A | - | Heater element for crankcase breather -N79- (cold-climate countries) | 15 |
| 24 | - | Fuse 24 on fuse holder C -SC24- | 5 A 20A 3) | - | Reversing light switch -F4- Multifunction switch -F125- Automatic gearbox control unit -J217- Mechatronic unit for dual clutch gearbox -J743- | 15 |
| 25 | - | Fuse 25 on fuse holder C -SC25- | 10A | - | Injectors -N....- 4) Garage door operating unit -E284- 5) | 15 |
| 26 | - | Fuse 26 on fuse holder C -SC26- | 10A | - | Rear roller blind switch -E149- 6) Rear roller blind control unit -J262- 6) | 15 |
| 27 | - | Fuse 27 on fuse holder C -SC27- | 5A | - | Fresh air blower relay -J13- 7) Climatronic control unit -J255- 8) | 15 |
| 28 | - | Fuse 28 on fuse holder C -SC28- | 20A | - | Trailer detector control unit -J345- 2) | 30 |
| 29 | - | Fuse 29 on fuse holder C -SC29- | 20A | - | Trailer detector control unit -J345- (left tail light, brake light, right/left turn signal) 5) Control unit for electromechanical parking brake -J540- 2) | 30 |
| 30 | - | Fuse 30 on fuse holder C -SC30- | 15A | - | Trailer detector control unit -J345- (right tail light, rear fog light, reversing lights) 5) Control unit for electromechanical parking brake -J540- 2) | 30 |
| 31 | - | Fuse 31 on fuse holder C -SC31- | 25A 15A 9) | - | Trailer detector control unit -J345- 5) Fuel pump relay -J17- Electric fuel pump 2 relay -J49- Fuel pump control unit -J538- 9) | 30 |
| 32 | - | Fuse 32 on fuse holder C -SC32- | 30A | - | Onboard power supply control unit -J519- (heated rear window) | 30 |
| 33 | - | Fuse 33 on fuse holder C -SC33- | 20A | - | Sliding sunroof control unit -J245- | 30 |
| 34 | - | Fuse 34 on fuse holder C -SC34- | 15A | - | Fuel system pressurisation pump -G6- | 30 |
| 35 | - | Fuse 35 on fuse holder C -SC35- | 30A 25A 9) | - | Headlight washer system relay -J39- Headlight washer system pump -V11- | 30 |
| 36 | - | Fuse 36 on fuse holder C -SC36- | 20A | - | Auxiliary heater operation relay -J485- 10) | 30 |
| 37 | - | Fuse 37 on fuse holder C -SC37- | 25A | - | Heated front seats control unit -J774- | 30 |
| 38 | - | Fuse 38 on fuse holder C -SC38- | 15A | - | Trailer detector control unit -J345- 2) Cigarette lighter -U1- 5) Rear cigarette lighter -U9- 5) | 30 |
| 39 | - | Fuse 39 on fuse holder C -SC39- | 40A | - | Fresh air blower control unit -J126- (Climatronic) Air conditioning system control unit -J301- | 30 |
| 40 | - | Fuse 40 on fuse holder C -SC40- | 5A | - | Lighting switch -E1- | 75 |
| 41 | - | Fuse 41 on fuse holder C -SC41- | 40A 5) 15A | - | Fresh air blower -V2- 5 Fresh air blower relay -J13- 5) Cigarette lighter -U1- 2) Rear cigarette lighter -U9- 2) | 75 |
| 42 | - | Fuse 42 on fuse holder C -SC42- | 15A | - | Windscreen and rear window washer pump -V59- Rear window wiper motor -V12- | 75 |
| 43 | - | Fuse 43 on fuse holder C -SC43- | 20A | - | Auxiliary heater control unit -J364- | 30 |
| 44 | - | Fuse 44 on fuse holder C -SC44- | 20A | - | Auxiliary heater operation relay -J485- | 30 |
| 45 | - | Fuse 45 on fuse holder C -SC45- | 25A | - | 12V socket -U5- 12V socket 3 -U19- 11) | 30 |
| 46 | - | Fuse 46 on fuse holder C -SC46- | 5A | - | 2-way radio unit switch -E72- Engine continues to run with no key button -E489- Crash data recorder -J754- Tachograph coupling point | 30 |
| 47 | - | Fuse 47 on fuse holder C -SC47- | 15A | - | Taxi meter -G41- 11) Mirror taxi meter -G511- 11) Taxi roof sign warning lamp -K222- 11) Interior light warning lamp -K224- 11) Taxi silent alarm bulb -L128- 11) Alarm button illumination lamp -L180- 11) Luggage compartment light on left -W18- 12) Two-way radio coupling point, in luggage compartment 12) 13) Glove compartment coupling point 11) Luggage compartment coupling point 11) | 30 |
| 48 | - | Fuse 48 on fuse holder C -SC48- | 20A | - | Charger coupling point 12) | 75 |
| 49 | - | Fuse 49 on fuse holder C -SC49- | - | - | Vacant |
1) To May 2005
2) From May 2006
4) To November 2005
5) To April 2006
6) From May 2005
Fuse colours
30 A - green
25 A - white
20 A - yellow
15 A - blue
10 A - red
7.5 A - brown
5 A - beige
3 A - purple
| 1 | - | Fuse 1 on fuse holder C -SC1- | 10A | - | Rear roller blind switch -E149- Rear roller blind motor -V91- | 15 |
| 2 | - | Fuse 2 on fuse holder C -SC2- | 5A | - | TCS and ESP button -E256- AUTOHOLD button -E540- ABS control unit -J104- Control unit for electromechanical parking brake -J540- | 15 |
| 3 | - | Fuse 3 on fuse holder C -SC3- | 5A | - | Lighting switch -E1- Brake light switch -F Oil level and oil temperature sender -G266- Power steering control unit -J500- | 15 |
| 4 | - | Fuse 4 on fuse holder C -SC4- | 5A | - | Electronically controlled damping control unit -J250- Trailer detector control unit -J345- Control unit for bend lighting and headlight range control -J745- Diagnosis connection -T16- | 15 |
| 5 | - | Fuse 5 on fuse holder C -SC5- | 10A | - | Switch and instrument illumination regulator -E20- Headlight range control regulator -E102- Power output module for left headlight -J667- Left headlight range control motor -V48- | 15 |
| 6 | - | Fuse 6 on fuse holder C -SC6- | 10A | - | All-wheel drive control unit -J492- | 15 |
| 8 | - | Fuse 8 on fuse holder C -SC8- | 10A | - | Power output module for right headlight -J668- Right headlight range control motor -V49- | 15 |
| 9 | - | Fuse 9 on fuse holder C -SC9- | 10A | - | Airbag control unit -J234- Seat occupied recognition control unit -J706- Front passenger side airbag deactivated warning lamp -K145- | 15 |
| 10 | - | Fuse 10 on fuse holder C -SC10- | 10A | - | Tiptronic switch -F189- Air mass meter -G70- Fuel pump control unit -J538- Main relay -J271- Engine control unit -J623- Motronic current supply relay 2 -J670- | 15 |
| 11 | - | Fuse 11 on fuse holder C -SC11- | 5A | - | Crash data recorder button -E497- (Police) Taximeter -G41- (Taxi) Mirror taxi meter -G511- (Taxi) Crash data recorder -J754- Tachograph coupling point (Police) Special signal system coupling point (Police) Warning buzzer for pedal switch on front passenger side -F349- (Driving school) | |
| 12 | - | Fuse 12 on fuse holder C -SC12- | 10A | - | Driver door control unit -J386- Front passenger door control unit -J387- | 30 |
| 13 | - | Fuse 13 on fuse holder C -SC13- | 10A | - | Lighting switch -E1- Tiptronic switch -F189- Diagnosis connection -T16- | 30 |
| 14 | - | Fuse 14 on fuse holder C -SC14- | 10A | - | Alarm horn relay -J641- (only for USA and Canada) Alarm horn -H12- | 30 |
| 15 | - | Fuse 15 on fuse holder C -SC15- | 5A | - | Onboard supply control unit -J519- (30g) Front interior light -W1- Interior monitor send and receive module 1 -G303- | 30 |
| 16 | - | Fuse 16 on fuse holder C -SC16- | 10A | - | Electronic ignition lock -D9- Electronic steering column lock control unit -J764- | 30 |
| 17 | - | Fuse 17 on fuse holder C -SC17- | 5A | - | Electromechanical parking brake button -E538- ABS control unit -J104- | 30 |
| 18 | - | Fuse 18 on fuse holder C -SC18- | 10A | - | Heater element for crankcase breather -N79- (cold-climate countries) | 15 |
| 19 | - | Fuse 19 on fuse holder C -SC19- | 7.5A | - | Adaptive cruise control unit -J428- Parking aid control unit -J446- Lane departure warning control unit -J759- Park assist steering control unit -J791- | - |
| 20 | - | Fuse 20 on fuse holder C -SC20- | 5A | - | Garage door operating unit -E284- (not right-hand drive) | 15 |
| 21 | - | Fuse 21 on fuse holder C -0ASC21- Fuse 20 on fuse holder C -SC20- | 10A | - | Automatic anti-dazzle interior mirror -Y7- Heated rear left seat switch with regulator -E128- Heated rear right seat switch with regulator -E129- High-pressure sender -G65- Air quality sensor -G238- Fresh air blower relay -J13- Left washer jet heater element -Z20- Right washer jet heater element -Z21- Air conditioning system control unit -J301- Voltage monitoring relay -J813- (RSE Multimedia system) | 15 |
| 22 | - | Fuse 22 on fuse holder C -SC22- | 20A | - | Control unit for electromechanical parking brake -J540- | 30 |
| 23 | - | Fuse 23 on fuse holder C -SC23- | 15A | - | Trailer detector control unit -J345- | 30 |
| 24 | - | Fuse 24 on fuse holder C -SC24- | 20A | - | Control unit for electromechanical parking brake -J540- | 30 |
| 25 | - | Fuse 25 on fuse holder C -SC25- | 20A | - | Trailer detector control unit -J345- | 30 |
| 26 | - | Fuse 26 on fuse holder C -SC26- | 15A | - | Electronically controlled damping control unit -J250- | 30 |
| 27 | - | Fuse 27 on fuse holder C -SC27- | 15A 1) 20A 2) | - | Fuel pump relay -J17- 2) Electric fuel pump 2 relay -J49- 2) Fuel pump control unit -J538- 1) Relay for supplementary fuel pump -J832- 2) | 30 1) 15 2) |
| 28 | - | Fuse 28 on fuse holder C -SC28- | 10A | - | Rear left door control unit -J388- Rear right door control unit -J389- Convenience system central control unit -J393- | 30 |
| 29 | - | Fuse 29 on fuse holder C -SC29- | 25A | - | Heated rear seats control unit -J786- | 30 |
| 30 | - | Fuse 30 on fuse holder C -SC30- | 20A | - | Sliding sunroof control unit -J245- | 30 |
| 31 | - | Fuse 31 on fuse holder C -SC31- | 30A | - | DC/AC converter with socket, 12V-230V -U13- Converter with socket, 12V-115V -U27- (only for American markets) | 30 |
| 33 | - | Fuse 33 on fuse holder C -SC33- | 30A | - | Headlight washer system relay -J39- Headlight washer system pump -V11- | 30 |
| 34 | - | Fuse 34 on fuse holder C -SC34- | 25A | - | Heated front seats control unit -J774- | 30 |
| 35 | - | Fuse 35 on fuse holder C -SC35- | 30A | - | Rear left door control unit -J388- Rear right door control unit -J389- | 30 |
| 36 | - | Fuse 36 on fuse holder C -SC36- | 15A | - | Driver seat lumbar support adjustment switch -E176- Rake adjustment button -E421- Backrest adjustment button -E425- | 30 |
| 37 | - | Fuse 37 on fuse holder C -SC37- | 10A | - | Magnetic field sender for compass -G197- Rain and light sensor -G397- Climatronic control unit -J255- Air conditioning system control unit -J301- Reversing camera system control unit -J772- Remote control receiver for auxiliary coolant heater -R149- Voltage monitoring relay -J813- (RSE Multimedia system) | 30 |
| 38 | - | Fuse 38 on fuse holder C -SC38- | 40A | - | Fresh air blower relay -J13- Fresh air blower control unit -J126- (Climatronic) Air conditioning system control unit -J301- (Climatic) | 75 |
| 39 | - | Fuse 39 on fuse holder C -SC39- | 15 A3 5A | - | Multifunction switch -F125- 3 Automatic gearbox control unit -J217- 3) Reversing light switch -F4- Mechatronic unit for dual clutch gearbox -J743- | 15 |
| 40 | - | Fuse 40 on fuse holder C -SC40- | 15A | - | Second battery charging circuit relay -J713- Washer pump -V5- Rear window wiper motor -V12- | 75 |
| 41 | - | Fuse 41 on fuse holder C -SC41- | 20A | - | Cigarette lighter -U1- 2) Rear cigarette lighter -U9- 2) | 75 |
| 42 | - | Fuse 42 on fuse holder C -SC42- | 15A | - | 12V socket -U5- | 75 |
| 43 | - | Fuse 43 on fuse holder C -SC43- | 20A | - | Auxiliary heater control unit -J364- (only with auxiliary battery) | 30 |
| 44 | - | Fuse 44 on fuse holder C -SC44- | 30A | - | Driver door control unit -J386- Front passenger door control unit -J387- | 30 |
| 45 | - | Fuse 45 on fuse holder C -SC45- | 20A | - | Auxiliary heater operation relay -J485- (only with auxiliary battery) | 30 |
| 46 | - | Fuse 46 on fuse holder C -SC46- | - | - | Vacant | |
| 47 | - | Fuse 47 on fuse holder C -SC47- | 10A | - | Telephone transmitter and receiver unit -R36- 4) | 30 |
| 48 | - | Fuse 48 on fuse holder C -SC48- | 5A | - | Control unit in dash panel insert -J285- 4) | 30 |
Fuse colours
30 A - green
25 A - white
20 A - yellow
15 A - blue
10 A - red
7.5 A - brown
5 A - beige
3 A - purple
| 1 | - | Fuse 1 on fuse holder D -SD1- | 5A | - | Magnetic field sender for compass -G197- 1) | 15 |
| 2 | - | Fuse 2 on fuse holder D -SD2- | 5A | - | Control unit for electromechanical parking brake -J540- ABS control unit -J104- | 15 |
| 3 | - | Fuse 3 on fuse holder D -SD3- | 5A | - | Magnetic field sender for compass -G197- 2) Parking aid control unit -J446- | 15 |
| 4 | - | Fuse 4 on fuse holder D -SD4- | 5A | - | Adaptive cruise control unit -J428- | 15 |
| 5 | - | Fuse 5 on fuse holder D -SD5- | 10A | - | Power output module for right headlight -J668- (only models with gas discharge headlights) | 15 |
| 6 | - | Fuse 6 on fuse holder D -SD6- | 5A | - | Tiptronic switch -F189- | 15 |
| 7 | - | Fuse 7 on fuse holder D -SD7- | 5A | - | Control unit for cornering light and headlight range control -J745- (only for gas discharge headlamp) | 15 |
| 8 | - | Fuse 8 on fuse holder D -SD8- | 5A | - | High-pressure sender -G65- Oil level and oil temperature sender -G266- | 15 |
| 9 | - | Fuse 9 on fuse holder D -SD9- | 10A | - | Front passenger side airbag deactivated warning lamp -K145- Airbag control unit -J234- Seat occupied recognition control unit -J706- | 15 |
| 10 | - | Fuse 10 on fuse holder D -SD10- | 5A | - | Fuel pump control unit -J538- (BLF, BLR, BLY, AXX, BPY, BLX, BVX, BVY, BVZ, BWA) | 15 |
| 11 | - | Fuse 11 on fuse holder D -SD11- | - | - | Vacant | |
| 12 | - | Fuse 12 on fuse holder D -SD12- | 10A | - | Front passenger door control unit -J387- Rear right door control unit -J389- 2) | 30 |
| 13 | - | Fuse 13 on fuse holder D -SD13- | 10A | - | Parking aid control unit -J446- 2 | 30 |
| 14 | - | Fuse 14 on fuse holder D -SD14- | 5A | - | Reversing camera system control unit -J772- 3) | 30 |
| 15 | - | Fuse 15 on fuse holder D -SD15- | 5A | - | Climatronic control unit -J255- Air conditioning system control unit -J301- | 30 |
| 16 | - | Fuse 16 on fuse holder D -SD16- | 5A | - | Tiptronic switch -F189- | 30 |
| 17 | - | Fuse 17 on fuse holder D -SD17- | 5A | - | Electromechanical parking brake warning lamp -K213- ABS control unit -J104- | 30 |
| 18 | - | Fuse 18 on fuse holder D -SD18- | - | - | Vacant | |
| 19 | - | Fuse 19 on fuse holder D -SD19- | - | - | Vacant | |
| 20 | - | Fuse 20 on fuse holder D -SD20- | - | - | Vacant | |
| 21 | - | Fuse 21 on fuse holder D -SD21- | - | - | Vacant | |
| 22 | - | Fuse 22 on fuse holder D -SD22- | 30A | - | DC/AC converter with socket, 12V-230V -U13- Converter with socket, 12V-115V -U27- (only American markets) | 30 |
| 23 | - | Fuse 23 on fuse holder D -SD23- | 30A | - | Rear left door control unit -J388- Rear right door control unit -J389- | 30 |
| 24 | - | Fuse 24 on fuse holder D -SD24- | 30A | - | Power latching control unit for rear left door -J762- (Variant) | 30 |
| 25 | - | Fuse 25 on fuse holder D -SD25- | 30A | - | Power latching control unit for rear right door -J763- (Variant) | 30 |
| 26 | - | Fuse 26 on fuse holder D -SD26- | - | - | Vacant | |
| 27 | - | Fuse 27 on fuse holder D -SD27- | 25A | - | Heated rear seats control unit -J786- | 30 |
| 28 | - | Fuse 28 on fuse holder D -SD28- | 15A | - | Fuel pump control unit -J538- (AXZ, BLV) 2) | 30 |
| 29 | - | Fuse 29 on fuse holder D -SD29- | 30A | - | Driver door control unit -J386- Front passenger door control unit -J387- | 30 |
| 30 | - | Fuse 30 on fuse holder D -SD30- | 20A | - | Control unit for electromechanical parking brake -J540- 2) Convenience system central control unit -J393- 4) | 30 |
| 31 | - | Fuse 31 on fuse holder D -SD31- | 20A 15A | - | Control unit for electromechanical parking brake -J540- 2) Fuel pump control unit -J538- 4) | 30 |
| 32 | - | Fuse 32 on fuse holder D -SD32- | - | - | Vacant | |
| 33 | - | Fuse 33 on fuse holder D -SD33- | 20A | - | 12V socket -U5- 2) 12V socket 2 -U18- 2) | 30 |
| 34 | - | Fuse 34 on fuse holder D -SD34- | 15A | - | Fuel pump control unit -J538- (AXX, BPY, BLF, BLR, BLY, BLX, BVX, BVY, BVZ, BWA) 2) | 30 |
| 35 | - | Fuse 35 on fuse holder D -SD35- | 20A | - | Cigarette lighter -U1- 2) Rear cigarette lighter -U9- 2) | 30 |
| 36 | - | Fuse 36 on fuse holder D -SD36- | - | - | Vacant | |
| 37 | - | Fuse 37 on fuse holder D -SD37- | - | - | Vacant | |
| 38 | - | Fuse 38 on fuse holder D -SD38- | 15A | - | 12V socket -U5- 5) | 75 |
| 39 | - | Fuse 39 on fuse holder D -SD39- | 10A | - | Heated driver seat regulator -E94- 2) Heated front passenger seat regulator -E95- 2) Heated rear left seat switch with regulator -E128- 2) Heated rear right seat switch with regulator -E129- 2) Climatronic control unit -J255- Air conditioning system control unit -J301- Second battery charging circuit relay -J713- Left washer jet heater element -Z20- Right washer jet heater element -Z21- | 75 |
| 40 | - | Fuse 40 on fuse holder D -SD40- | 5A | - | Crash data recorder -J754- 6) | |
| 41 | - | Fuse 41 on fuse holder D -SD41- | 15A | - | Taxi meter -G41- 6) Mirror taxi meter -G511- 6) Taxi roof sign warning lamp -K222- 6) Interior light warning lamp -K224- 6) Alarm button illumination lamp -L180- 6) Glove compartment coupling point 6) Luggage compartment coupling point 6) | 30 |
| 42 | - | Fuse 42 on fuse holder D -SD42- | 20A | - | Glove compartment coupling point 6) | 30 |
| 43 | - | Fuse 43 on fuse holder D -SD43- | 5A | - | Control unit for taxi alarm remote control -J601- 6) Special signal system coupling point (Police) Glove compartment coupling point 7) Luggage compartment coupling point 7) | 30 |
| 44 | - | Fuse 44 on fuse holder D -SD44- | 10A | - | Control unit for taxi alarm remote control -J601- 7) 12V socket 3 -U19- 6) Special signal system coupling point (Police) | 30 |
Fuse colours
30 A - green
25 A - white
20 A - yellow
15 A - blue
10 A - red
7.5 A - brown
5 A - beige
3 A - purple
| 1 | - | Fuse 1 on fuse holder D -SD1- | 30A | - | Rear lid control unit 2 -J756- (Variant only) | 30 |
| 2 | - | Fuse 2 on fuse holder D -SD2- | 30A | - | Rear lid control unit -J605- (Variant only) | 30 |
| 3 | - | Fuse 3 on fuse holder D -SD3- | - | - | Vacant | |
| 4 | - | Fuse 4 on fuse holder D -SD4- | - | - | Vacant | 75 |
| 5 | - | Fuse 5 on fuse holder D -SD5- | - | - | Reserved for special vehicles | 30 |
| 6 | - | Fuse 6 on fuse holder D -SD6- | - | - | Reserved for special vehicles | 30 |
| 7 | - | Fuse 7 on fuse holder D -SD7- | - | - | Reserved for special vehicles | 30 |
| 8 | - | Fuse 8 on fuse holder D -SD8- | - | - | Reserved for special vehicles | 30 |
| 9 | - | Fuse 9 on fuse holder D -SD9- | - | - | Reserved for special vehicles | 30 |
| 10 | - | Fuse 10 on fuse holder D -SD10- | - | - | Vacant | |
| 12 | - | Fuse 12 on fuse holder D -SD12- | - | - | Vacant |
| Introduction date | Slot A | Slot B | Slot C | Slot D |
| From November 2004 | Vacant | Vacant | Front passenger seat adjustment thermal fuse 1 -S46- 30A | Fuse in fuse holder -S224- 15A 1) / 30A 2) |
| From November 2005 | Front passenger seat adjustment thermal fuse 1 -S46- 30A | Driver seat adjustment thermal fuse 1 -S44- 15A 1) Fuse in fuse holder -S224- 30A 2) | Vacant | Vacant |
| From November 2006 | Front passenger seat adjustment thermal fuse 1 -S46- 30A | Fuse in fuse holder -S224- 15A 1) / 30A 2) | Vacant | Vacant |
| From November 2007 | Front passenger seat adjustment thermal fuse 1 -S46- 30A | Fuse in fuse holder -S224- 15A 1) / 30A 2) Driver seat adjustment thermal fuse 1 -S44- 30A 3) | Vacant | Vacant |
| From May 2008 | Vacant | Driver seat adjustment thermal fuse 1 -S44- 20A 2) | Vacant | Vacant |
| From May 2009 | Fuse in fuse holder -S223- 3A 4) | Driver seat adjustment thermal fuse 1 -S44- 20A 2) | Vacant | Vacant |
Fuse colours
30 A - green
25 A - white
20 A - yellow
15 A - blue
10 A - red
7.5 A - brown
5 A - beige
3 A - purple
| 1 | - | Fuse 1 on fuse holder F -SF1- | 30A | - | -Left fuse holder (SC12-SC17, SC29-SC31) 1) Right fuse holder (SD12-SD17, SD28, SD29-SD31) 1) | 30 |
| 2 | - | Fuse 2 on fuse holder F -SF2- | 80A | - | -Fuses in E-box (SB16 - SB26, SB49, SB50) | 30 |
| 3 | - | Fuse 3 on fuse holder F -SF3- | 125A | - | -Voltage supply, electronics box | 30 |
| 4 | - | Fuse 4 on fuse holder F -SF4- | 5A | - | Onboard supply control unit -J519- | 30 |
Fuse 2 (30) -S205-
Fitting location:
Fuse rating:
70A - Saloon
60A - Variant
Relay VW Passat B6 схема расположения реле Volkswagen Passat B6
Relay Volkswagen Passat B6 Overview of relay carriers 1 - Heated windscreen relay -J47- 2 - Relay carrier on onboard supply control unit In driver footwell 3 - Relay carrier 1 on left under dash panel 4 - Relay carrier 2 on left under dash panel 5 - Relay carrier on E-box on left in engine...
vwts.ru
