Руководство Fuses and relay Volkswagen Arteon (3H7) 2018 - 2021, предохранители и реле
Admin
Admin
Создатель сайта
Команда форума
Россия, Москва
VW Tiguan 2.0 DBGC 2018, VW Touran 1.6 BSE 2008
Volkswagen Arteon (model 3H7) 2018 -
Fuses
Multifuse fuse strip on fuse holder B -SB-
Fitting location of multifuse fuse strip on fuse holder B -SB- , VW Arteon from March 2017
Note: The fuse strip (multifuse) can be replaced as a complete unit
1 - Fuse holder B -SB
Fuse assignment for multifuse fuse strip on fuse holder B -SB- , battery at front, VW Arteon from March 2017
Note: for models with battery in engine compartment
SlotCurrent flow diagram designationNominal valueFunction / componentTerminal
SBJFuse J on fuse holder B -SBJ-125 AFuse holder C -SC-
Fuse 4 on fuse holder C -SC4- - fuse 14 on fuse holder C -SC14-
Fuse 22 on fuse holder C -SC22-
Fuse 31 on fuse holder C -SC31-
Fuse 38 on fuse holder C -SC38- - fuse 42 on fuse holder C -SC42-
Fuse 53 on fuse holder C -SC53-
Terminal 15 voltage supply relay -J329-
Relay for power sockets -J807-
30
SBGFuse G on fuse holder B -SBG-400 AAlternator -C-30
508508 Threaded connection (30), on E-box-Battery -A-30
SBEFuse E on fuse holder B -SBE-80 APower steering control unit -J500-30
SBKFuse K on fuse holder B -SBK-80 AFuse holder C -SC-
Fuse 1 on fuse holder C -SC1- - fuse 3 on fuse holder C -SC3-
Fuse 15 on fuse holder C -SC15- - fuse 30 on fuse holder C -SC30-
Fuse 43 on fuse holder C -SC43- - fuse 46 on fuse holder C -SC46-
Fuse 50 on fuse holder C -SC50- - fuse 52 on fuse holder C -SC52-
30
SBLFuse L on fuse holder B -SBL-50 ARadiator fan -VX57-30
Fuse assignment for multifuse fuse strip on fuse holder B -SB- , battery at rear, from March 2017
Note: for models with battery in luggage compartment
SBJFuse J on fuse holder B -SBJ-80 ARadiator fan -VX57- 1)30
508508 Threaded connection (30), on E-box-Jump start connection -TV32-30
SBEFuse E on fuse holder B -SBE--not assigned30
SBKFuse K on fuse holder B -SBK-80 APower steering control unit -J500- 1)30
SBLFuse L on fuse holder B -SBL--not assigned30
Fuse holder B -SB-
Fitting location of fuse holder B -SB- , VW Arteon from March 2017
Fuse colours for J-Case fuse:
50 A - red
40 A - green
30 A - pink
Fuse colours for ATO flat fuse:
40 A - orange
30 A - light green
25 A - natural (white)
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
Fuse assignment for fuse holder B -SB- , VW Arteon from March 2017
SB1Fuse 1 on fuse holder B -SB1-25 AABS control unit -J104-30
SB2Fuse 2 on fuse holder B -SB2-40 A
60 A 6)
ABS hydraulic pump -V64-
30
SB3Fuse 3 on fuse holder B -SB3-15 A 1)
30 A 2)
Engine/motor control unit -J623-87
SB4Fuse 4 on fuse holder B -SB4-5 A 2)
10 A 1)
Radiator fan -VX57- 4)
High heat output relay -J360-
Low heat output relay -J359- 2), 4)
Valve for oil pressure control -N428- 1), 4)
Turbocharger air recirculation valve -N249- 1), 4)
Intake manifold flap valve -N316- 1), 4)
Piston cooling jet control valve -N522- 1), 4)
Oil level and oil temperature sender -G266-
Turbine changeover valve -N529- 1), 4)
87
SB5Fuse 5 on fuse holder B -SB5-10 AFuel pressure regulating valve -N276- 2), 4)
Fuel metering valve -N290- 2), 4)
Engine component current supply relay -J757- 1), 4)
Turbine changeover valve -N529- 2), 4)
87
SB6Fuse 6 on fuse holder B -SB6-5 ABrake light switch -F-87
SB7Fuse 7 on fuse holder B -SB7-10 A 2)
15 A 7)
Charge air cooling pump -V188-
Coolant valve for gearbox -N488-
Coolant shut-off valve -N82- 1), 4)
Auxiliary pump for heating -V488- 4)
Coolant valve for cylinder head -N489- 2), 4)
Valve for oil pressure control -N428- 2), 4)
87
SB8Fuse 8 on fuse holder B -SB8-15 ALambda probe 1 before catalytic converter -GX10- 4)
Lambda probe 1 after catalytic converter -GX7- 4)
Control unit for NOx sender -GX30- 4)
Control unit for NOx sender 2 -J881- 4)
87
SB9Fuse 9 on fuse holder B -SB9-5 A 2)
10 A 1)
Exhaust flap control unit -J883-
Exhaust flap control unit 2 -J945-
Automatic glow period control unit -J179- 2), 4)
Heater element for crankcase breather -N79-
Air mass meter -G70-
Activated charcoal filter solenoid valve 1 -N80-
Exhaust camshaft control valve 1 -N318-
Camshaft control valve 1 -N205-
87
SB10Fuse 10 on fuse holder B -SB10-15 A 1)
20 A 2)
Fuel pump control unit -J538-87
SB11Fuse 11 on fuse holder B -SB11-40 A 2)Auxiliary air heater element -Z35-87
SB12Fuse 12 on fuse holder B -SB12-40 A 2)Auxiliary air heater element -Z35-87
SB13Fuse 13 on fuse holder B -SB13-30 AAuxiliary hydraulic pump 1 for gearbox oil -V475-30
SB14Fuse 14 on fuse holder B -SB14-40 AHeated windscreen relay -J47-30
SB15Fuse 15 on fuse holder B -SB15-15 AHorn relay -J413-30
SB16Fuse 16 on fuse holder B -SB16-20 A 1)Engine component current supply relay -J757- 1), 4)30
SB17Fuse 17 on fuse holder B -SB17-7.5 AEngine/motor control unit -J623-
Heated windscreen relay -J47- 4)
30
SB18Fuse 18 on fuse holder B -SB18-5 ABattery monitor control unit -J367- 5)
Data bus diagnostic interface -J533- 3)
30
SB19Fuse 19 on fuse holder B -SB19-30 AWiper motor control unit -J400- 4)30
SB20Fuse 20 on fuse holder B -SB20-10 AAlarm horn -H12-30
SB21Fuse 21 on fuse holder B -SB21-30 AHeated windscreen relay 2 -J611-30
SB22Fuse 22 on fuse holder B -SB22-5 AEngine/motor control unit -J623-50
SB23Fuse 23 on fuse holder B -SB23-30 AStarter -B-50
1) For models with petrol engine
2) For models with diesel engine
3) For models with no start/stop system
4) According to equipment
5) For models with battery in engine compartment
6) For models with pedestrian protection system
7) For models with 2.0l bi-turbo engine
Fuse holder B -SB-
Fitting location of fuse holder B -SB- , VW Arteon from November 2017
50 A - red
40 A - green
30 A - pink
40 A - orange
30 A - light green
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
Fuse assignment for fuse holder B -SB- , VW Arteon from November 2017
60 A 6)
30
30 A 2)
10 A 1)
Turbine changeover valve -N529- 1), 4).
87
87
SB6Fuse 6 on fuse holder B -SB6-7.5 ABrake light switch -F-87
15 A 7)
Control unit for fuel tank leak detection -J909- 8)
87
87
10 A 1)
87
20 A 2)
50 A 8)
30
SB18Fuse 18 on fuse holder B -SB18-7.5 ABattery monitor control unit -J367- 5)
30
SB22Fuse 22 on fuse holder B -SB22-7.5 AEngine/motor control unit -J623-50
8) For American markets
Fuse holder B -SB- , from July 2018
Fitting location of fuse holder B -SB- , VW Arteon from July 2018
50 A - red
40 A - green
30 A - pink
40 A - orange
30 A - light green
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
Fuse assignment for fuse holder B -SB- , VW Arteon from July 2018
60 A 6)
30
30 A 2)
SB4Fuse 4 on fuse holder B -SB4-7.5 A 2)
10 A 1)
87
87
SB7Fuse 7 on fuse holder B -SB7-7.5 A 9)
10 A 2)
15 A 7)
87
87
SB9Fuse 9 on fuse holder B -SB9-10 AExhaust flap control unit -J883-
87
20 A 2)
30
30
SB20not assigned--
SB21Fuse 21 on fuse holder B -SB21-15 AMechatronic unit for dual clutch gearbox -J743-30
9) For 2.0l petrol engine
Fuse holder C -SC-
Fitting location of fuse holder C -SC- LHD models, VW Arteon from March 2017
Note: For left-hand drive models
50 A - red
40 A - green
30 A - pink
40 A - orange
30 A - light green
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
Fuse colours, for mini fuses:
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
Fuse assignment for fuse holder C -SC- , VW Arteon from March 2017
Note: The fuse SC40 is supplied via terminal 15 from the factory and can be supplied via terminal 30 by reconnecting. If a consumer is connected to the electric socket or to the cigarette lighter, ensure that the consumer is disconnected from the voltage supply when the engine is switched off to prevent the drive battery being discharged.
SC1Fuse 1 on fuse holder C -SC1-30 AControl unit for reducing agent heater -J891-30
SC2Fuse 2 on fuse holder C -SC2-10 ASteering column electronics control unit -J527-30
SC3not assigned--
SC4not assigned--
SC5Fuse 5 on fuse holder C -SC5-5 AData bus diagnostic interface -J533-30
SC6Fuse 6 on fuse holder C -SC6-5 ASelector lever -E313-30
SC7Fuse 7 on fuse holder C -SC7-10 AHeater and air conditioning controls -EX21-
Operating and display unit for rear air conditioning system -E265-
Remote control receiver for auxiliary coolant heater -R149-
Heated rear window relay -J9-
Analogue clock -Y
Tyre Pressure Monitoring System control unit -J502-
30
SC8Fuse 8 on fuse holder C -SC8-10 ARotary light switch -EX1-
Electromechanical parking brake button -E538-
Rain and light sensor -G397-
Diagnostic connection -U31-
Anti-theft alarm sensor -G578-
Left background lighting LED -L181-
Right background lighting LED -L182-
Front interior light -WX1-
Control unit for cornering light and headlight range control -J745-
Light for front left door contour lighting -L251-
Light for rear left door contour lighting -L253-
Light for front right door contour lighting -L252-
Light for rear right door contour lighting -L254-
30
SC9Fuse 9 on fuse holder C -SC9-5 ASteering column electronics control unit -J527-30
SC10Fuse 10 on fuse holder C -SC10-7.5 ADisplay unit for front information display and operating unit control unit -J685-
Control unit for Head-up Display -J898-
30
SC11Fuse 11 on fuse holder C -SC11-40 AOnboard supply control unit -J519-30
SC12Fuse 12 on fuse holder C -SC12-20 AControl unit 1 for information electronics -J794-
Control unit for navigation system -J856- 1)
30
SC13Fuse 13 on fuse holder C -SC13-25 AFront left seat belt -NX10-30
SC14Fuse 14 on fuse holder C -SC14-40 AFresh air blower control unit -J126-30
SC15Fuse 15 on fuse holder C -SC15-10 AControl unit for electronic steering column lock -J764-30
SC16Fuse 16 on fuse holder C -SC16-7.5 ATwo-way signal amplifier for mobile telephone/data services -J984-
USB charging socket 1 -U37-
Storage compartment with interface for mobile telephone -R265-
USB hub -R293-
30
SC17Fuse 17 on fuse holder C -SC17-7.5 ADash panel insert -KX2-
Emergency call module control unit and communication unit -J949-
30
SC18Fuse 18 on fuse holder C -SC18-7.5 AControl unit for overhead view camera -J928-
Rear lid handle -EX37-
Rear overhead view camera -R246-
30
SC19Fuse 19 on fuse holder C -SC19-7.5 AInterface for entry and start system -J965-30
SC20Fuse 20 on fuse holder C -SC20-7.5 ARelay for reducing agent metering system -J963-30
SC21Fuse 21 on fuse holder C -SC21-15 AAll-wheel drive control unit -J492-30
SC22Fuse 22 on fuse holder C -SC22-15 ATrailer detector control unit -J345-30
SC23Fuse 24 on fuse holder C -SC24-30 ASliding sunroof adjustment control unit -J245-30
SC24Fuse 23 on fuse holder C -SC23-40 AOnboard supply control unit -J519-30
SC25Fuse 25 on fuse holder C -SC25-30 ADriver door control unit -J386-
Rear driver side door control unit -J926-
30
30
SC26Fuse 26 on fuse holder C -SC26-30 AOnboard supply control unit -J519-30
SC27Fuse 27 on fuse holder C -SC27-30 AOnboard supply control unit -J519--
SC28Fuse 28 on fuse holder C -SC28-25 ATrailer detector control unit -J345-30
SC29not assigned--
SC30not assigned--
SC31not assigned--
SC32Fuse 32 on fuse holder C -SC32-10 AFront camera for driver assist systems -R242-
Adaptive cruise control unit -J428-
Parking aid control unit -J446-
Lane change assist control unit -J769-
Lane change assist control unit 2 -J770-
15
SC33Fuse 33 on fuse holder C -SC33-5 AAirbag control unit -J234-15
SC34Fuse 34 on fuse holder C -SC34-7.5 AInterior mirror -EX5-
Reversing light switch -F4-
Pressure sender for refrigerant circuit -G805-
Air quality sensor -G238-
Centre switch module in dash panel -EX22-
Switch module 1 in centre console -EX23-
Control unit for structure-borne sound -J869-
15
SC35Fuse 35 on fuse holder C -SC35-10 ADiagnostic connection -U31-15
SC36Fuse 36 on fuse holder C -SC36-5 AFront right headlight -MX2-15
SC37Fuse 37 on fuse holder C -SC37-5 AFront left headlight -MX1-15
SC38Fuse 38 on fuse holder C -SC38-25 ATrailer detector control unit -J345-30
SC39Fuse 39 on fuse holder C -SC39-30 AFront passenger door control unit -J387-
Rear passenger side door control unit -J927-
30
SC40Fuse 40 on fuse holder C -SC40-20 A12 V socket -U5-
12 V socket 2 -U18-
12 V socket 3 -U19-
15
SC41Fuse 41 on fuse holder C -SC41-25 AFront right seat belt -NX11-30
SC42Fuse 42 on fuse holder C -SC42-40 AOnboard supply control unit -J519-30
SC43Fuse 43 on fuse holder C -SC43-40 ADigital sound package control unit -J525-30
SC44Fuse 44 on fuse holder C -SC44-15 ATrailer detector control unit -J345-30
SC45Fuse 45 on fuse holder C -SC45-15 ADriver seat adjustment control unit -J810-
Front left seat cushion fan 1 -V514-
Front left seat backrest fan 1 -V512-
30
SC46Fuse 46 on fuse holder C -SC46-30 ADC/AC converter with socket, 12 V - 230 V -U13-30
SC47not assigned--
SC48not assigned--
SC49Fuse 49 on fuse holder C -SC49-5 AClutch position sender -G476-
Starter relay 1 -J906-
Starter relay 2 -J907-
15
SC50Fuse 50 on fuse holder C -SC50-40 ARear lid control unit -J605-30
SC51Fuse 51 on fuse holder C -SC51-25 AOperating and display unit for rear air conditioning system -E265-30
SC52Fuse 52 on fuse holder C -SC52-15 AElectronically controlled damping control unit -J250-30
SC53Fuse 53 on fuse holder C -SC53-30 AHeated rear window relay -J9-15
Fuse holder C -SC-
Fitting location of fuse holder C -SC- left-hand drive models, VW Arteon from July 2018
1 - Fuse holder C -SC
50 A - red
40 A - green
30 A - pink
40 A - orange
30 A - light green
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
Fuse assignment for fuse holder C -SC- , VW Arteon from July 2018
SC3not assigned--
SC4Fuse 4 on fuse holder C -SC4-7.5 A 2)
10 A 3)
Alarm horn -H12-30
SC5Fuse 5 on fuse holder C -SC5-7.5 AData bus diagnostic interface -J533-30
SC6Fuse 6 on fuse holder C -SC6-7.5 ASelector lever -E313-30
Analogue clock -Y
30
SC8Fuse 8 on fuse holder C -SC8-7.5 ARotary light switch -EX1-
30
SC9Fuse 9 on fuse holder C -SC9-7.5 ASteering column electronics control unit -J527-30
SC10Fuse 10 on fuse holder C -SC10-10 ADisplay unit for front information display and operating unit control unit -J685-
30
30
USB hub -R293-
30
30
30
SC20Fuse 20 on fuse holder C -SC20-7.5 A 2)
10 A 2)
15 A 4)
Vacuum pump relay -J318- 4)
30
SC23Fuse 24 on fuse holder C -SC24-20 ASliding sunroof adjustment control unit -J245-30
30
30
SC29not assigned--
SC30Fuse 30 on fuse holder C -SC30-10 A 3)Remote starting system relay -J471- 3)30
SC31Fuse 31 on fuse holder C -SC31-30 ARear lid control unit -J605-30
15
SC33Fuse 33 on fuse holder C -SC33-7.5 AAirbag control unit -J234-15
15
SC35Fuse 35 on fuse holder C -SC35-7.5 ADiagnostic connection -U31-15
SC36Fuse 36 on fuse holder C -SC36-7.5 AFront right headlight -MX2-15
SC37Fuse 37 on fuse holder C -SC37-7.5 AFront left headlight -MX1-15
30
12 V socket 2 -U18-
12 V socket 3 -U19-
15
30
SC47not assigned--
SC48not assigned--
SC49Fuse 49 on fuse holder C -SC49-7.5 AClutch position sender -G476-
15
SC50not assigned--
1) For models with equipment for Korea
2) According to equipment
3) For American markets
4) For 1.5l petrol engine
Fuse holder C -SC-
Fitting location of fuse holder C -SC- , left-hand drive models, VW Arteon from November 2018
50 A - red
40 A - green
30 A - pink
40 A - orange
30 A - light green
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
Fuse assignment for fuse holder C -SC- , VW Arteon from November 2018
SC3not assigned--
10 A 3)
Alarm horn -H12-30
Analogue clock -Y
30
30
30
30
USB hub -R293-
30
30
30
10 A 2)
15 A 4)
30
30
30
SC29Fuse 29 on fuse holder C -SC29-5 A 3)Remote starting system relay -J471- 3)30
15
15
30
12 V socket 2 -U18-
12 V socket 3 -U19-
15
30
SC47not assigned--
SC48not assigned--
15
SC50not assigned--
Fuse holder D -SD-
Fitting location of fuse holder D -SD- , VW Arteon from March 2017
1 - Fuse holder D -SD
40 A - orange
30 A - light green
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
Fuse assignment for fuse holder D -SD- , VW Arteon from March 2017
SD1not assigned--
SD2not assigned--
SD3Fuse 3 on fuse holder D -SD3-15 AMechatronic unit for dual clutch gearbox -J743-30
SD4not assigned--
SD5Fuse 5 on fuse holder D -SD5-30 AWiper motor control unit -J400-30
SD6not assigned--
SD7Fuse 7 on fuse holder D -SD7-20 AAuxiliary heater control unit -J364-30
SD8not assigned--
Fitting location of fuse holder D -SD- , from July 2018
SD1not assigned--
SD2not assigned--
SD3Fuse 3 on fuse holder D -SD3-30 AHeated windscreen relay 2 -J611- 1)30
SD4Fuse 4 on fuse holder D -SD4-30 AHeated windscreen relay 2 -J611- 2)30
SD6not assigned--
SD8not assigned--
1) For models with battery in engine compartment
2) For models with battery in luggage compartment
Fuse holder G -SG-
Fitting location of fuse holder G -SG- , VW Arteon from March 2017
1 - Fuse holder G -SG-
2 - Supply 508 Threaded connection (30), on E-box
Note: The fuse strip (multifuse) can be replaced as a complete unit.
Fuse assignment for fuse holder G -SG
SG1Fuse 1 on fuse holder G -SG1-80 AFuse holder C -SC-
SG2Fuse 2 on fuse holder G -SG2-125 AFuse holder C -SC-
SG3Fuse 3 on fuse holder G -SG3-125 AFuse holder D -SD-
Relay and fuse carrier 1 -SR1-
Note: For models with diesel engine
Fitting location of relay and fuse carrier 1 -SR1- , VW Arteon from March 2017
1 - Relay and fuse carrier 1 -SR1-
Fuse assignment for relay and fuse carrier 1 -SR1- , VW Arteon from March 2017
AAuxiliary air heating fuse -S379-40 AAuxiliary air heater element -Z35-PTC1
Individual fuses
Fitting location of individual fuses, LHD models, VW Arteon from March 2017
1 - Holder
2 - Fuse carrier 2 -ST2-
3 - Fuse carrier 1 -ST1-
4 - Fuse carrier 1 -ST1-
Fuse assignment for individual fuses, LHD models, VW Arteon from March 2017
AFront passenger seat adjustment thermal fuse 1 -S46-15 AOperating unit for front right seat adjustment -EX34-
Front right seat cushion fan 1 -V518-
Front right seat backrest fan 1 -V516-
30
BRemote starting system fuse 1 -S250-5 ARemote starting system relay -J471-30
CUSB charging socket fuse -S356-7.5 AUSB charging socket 1 -U37-15
Fitting location of individual fuses, LHD models, from November 2018
30
Bnot assigned--
Relays
Relays on fuse holder B -SB- , VW Arteon from March 2017
1 - Fuse holder B -SB-
R1 - Starter relay 1 -J906-
R2 - Starter relay 2 -J907-
R3 - Horn relay -J413-
R4 - High heat output relay -J360-
R5 - Main relay -J271-
R5 - Terminal 30 voltage supply relay -J317-
Relays on fuse holder C -SC- , LHD models
Relays on fuse holder C -SC- , LHD models, VW Arteon from March 2017
1 - Fuse holder C -SC-
R1 - Relay for reducing agent metering system -J963-
R2 - not assigned
R3 - not assigned
R4 - Terminal 15 voltage supply relay -J329-
R5 - Heated rear window relay -J9-
R6 - Relay for power sockets -J807-
Relays on fuse holder C -SC- , LHD models, VW Arteon from July 2018
R1 - Vacuum pump relay -J318-
For models with 1.5l petrol engine
Up to July 2018, see fitting locations: front part of vehicle
R2 - not assigned
R3 - not assigned
Relay and fuse carrier 1 -SR1- , VW Arteon from March 2017
R6 - Automatic glow period control unit -J179-
R7 - Low heat output relay -J359-
Relay and fuse carrier 3 -SR3- , variant 1, VW Arteon from March 2017
1 - Relay and fuse carrier 3 -SR3-
R8 - not assigned
R9 - Heated windscreen relay -J47-
For models with heated windscreen (4GX)
R10 - Heated windscreen relay 2 -J611-
Relay and fuse carrier 3 -SR3- , variant 2, VW Arteon from March 2017
R8 - Engine component current supply relay -J757-
For models with 2.0l petrol engine
R11 - Heated windscreen relay -J47-
For models with climate windscreen (4GW)
Remote starting system relay -J471- , VW Arteon from November 2017
1 - Holder
R1 - Remote starting system relay -J471-
For models with remote engine start
  • Спасибо!
Реакции: dip
