Admin
Создатель сайта
Команда форума
- Россия, Москва
- VW Tiguan 2.0 DBGC 2018, VW Touran 1.6 BSE 2008
Volkswagen T-Roc (model A11) 2018 -
Fitting locations fuses VW T-Roc: Fuse holder B SB, Fuse holder C SC, Fuse holder D SD
Fitting locations relays VW T-Roc: Relays on fuse holder B SB, Relays on fuse holder C SC, Relay and fuse carrier 1 SR1, Relay and fuse carrier 3 SR3
Multifuse fuse strip on fuse holder B -SB- , from August 2017
Fitting location of multifuse strip on fuse holder B -SB- , VW T-Roc from August 2017
Note: The fuse strip (multifuse) can be replaced as a complete unit.
1 - Fuse holder B -SB
Fuse assignment for multifuse strip on fuse holder B -SB- , VW T-Roc from August 2017
Fuse holder B -SB- , from August 2017
Fitting location of fuse holder B -SB- , VW T-Roc from August 2017
Fuse colours for J-Case fuse:
50 A - red
40 A - green
30 A - pink
Fuse colours for ATO flat fuse:
40 A - orange
30 A - light green
25 A - natural (white)
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
Fuse assignment of fuse holder B -SB- , VW T-Roc from August 2017
1) For models with petrol engine
2) For models with diesel engine
3) According to equipment
4) For models with extended pedestrian protection system
5) For models with extended pedestrian protection system that scans front area
Fuse holder B -SB- , from November 2017
Fitting location of fuse holder B -SB- , VW T-Roc from November 2017
50 A - red
40 A - green
30 A - pink
40 A - orange
30 A - light green
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
Fuse assignment for fuse holder B -SB- , VW T-Roc from November 2017
4) For models with 1.5l petrol engine
6) For models with extended pedestrian protection system that scans front area
Fuse holder B -SB- , from July 2018
Fitting location of fuse holder B -SB- , VW T-Roc from July 2018
50 A - red
40 A - green
30 A - pink
40 A - orange
30 A - light green
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
Fuse assignment for fuse holder B -SB- , VW T-Roc from July 2018
7) For models with exhaust concept, EU6 AG/H/I
8) For models with 2.0l petrol engine
9) For models with all-wheel drive
10) For models with 1.0l petrol engine
11) For models with 2.0l diesel engine
12) For models with dual clutch gearbox 0GC
13) For models with dual clutch gearbox 0CW
Fuse holder B -SB- , from November 2018
Fitting location of fuse holder B -SB- , VW T-Roc from November 2018
50 A - red
40 A - green
30 A - pink
40 A - orange
30 A - light green
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
Fuse assignment for fuse holder B -SB- , VW T-Roc from November 2018
11) For models with dual clutch gearbox 0GC
12) For models with dual clutch gearbox 0CW
Fuse holder C -SC- , from August 2017
Fitting location of fuse holder C -SC- , left-hand drive models, VW T-Roc from August 2017
1 - Fuse holder C -SC
50 A - red
40 A - green
30 A - pink
40 A - orange
30 A - light green
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
Fuse colours, for mini fuses:
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
Fuse assignment of fuse holder C -SC- , VW T-Roc from August 2017
Note: The fuse SC40 is supplied via terminal 15 from the factory and can be supplied via terminal 30 by reconnecting. If a consumer is connected to the electric socket or to the cigarette lighter, ensure that the consumer is disconnected from the voltage supply when the engine is switched off to prevent the drive battery being discharged.
2) For left-hand drive models
3) For right-hand drive models
Fuse holder C -SC- , from July 2018
Fitting location of fuse holder C -SC- left-hand drive models, VW T-Roc from July 2018
Note: For left-hand drive models
50 A - red
40 A - green
30 A - pink
40 A - orange
30 A - light green
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
Fuse assignment for fuse holder C -SC- , VW T-Roc from July 2018
4) For models with remote controlled central locking
5) For models with entry and start authorisation
6) For models with diesel engine
Fuse holder C -SC- , from November 2018
Fitting location of fuse holder C -SC- , left-hand drive models, VW T-Roc from November 2018
50 A - red
40 A - green
30 A - pink
40 A - orange
30 A - light green
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
Fuse assignment for fuse holder C -SC- , VW T-Roc from November 2018
Fuse holder D -SD- , from August 2017
Fitting location of fuse holder D -SD- , VW T-Roc from August 2017
1 - Fuse holder D -SD-
40 A - orange
30 A - light green
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
Fuse assignment of fuse holder D -SD- , VW T-Roc from August 2017
Fuse holder D -SD- , from July 2018
Fitting location of fuse holder D -SD- , VW T-Roc from July 2018
40 A - orange
30 A - light green
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
Fuse assignment for fuse holder D -SD- , VW T-Roc from July 2018
Relay and fuse carrier 1 -SR1- , from August 2017
Note: For models with diesel engine
Fitting location of relay and fuse carrier 1 -SR1- , VW T-Roc from August 2017
1 - Relay and fuse carrier 1 -SR1-
Fuse assignment for relay and fuse carrier 1 -SR1- , VW T-Roc from August 2017
Relays
Relays on fuse holder B -SB- , VW T-Roc from August 2017
1 - Fuse holder B -SBR1 - Starter relay 1 -J906-
R2 - Starter relay 2 -J907-
R3 - Horn relay -J413-
R4 - High heat output relay -J360-
R5 - Main relay -J271-
R5 - Terminal 30 voltage supply relay -J317-
Relays on fuse holder C -SC- , from August 2017
Relays on fuse holder C -SC- , left-hand drive models, VW T-Roc from August 2017
1 - Fuse holder C -SC-
R1 - Relay for reducing agent metering system -J963-
R2 - not assigned
R3 - not assigned
R4 - Terminal 15 voltage supply relay -J329-
R5 - Heated rear window relay -J9-
R6 - Relay for power sockets -J807-
Relay and fuse carrier 1 -SR1- , VW T-Roc from August 2017
R6 - Automatic glow period control unit -J179-
R7 - Low heat output relay -J359-
Relay and fuse carrier 3 -SR3- , VW T-Roc from August 2017
1 - Relay and fuse carrier 3 -SR3-
R8 - Engine component current supply relay -J757-
R9 - Wiper motor relay 1 -J368-
R10 - Wiper motor relay 2 -J369-
| Slot | Current flow diagram designation | Nominal value | Function / component | Terminal |
| SBJ | Fuse J on fuse holder B -SBJ- | 125 A | Fuse holder C -SC- Fuse 4 on fuse holder C -SC4- - fuse 14 on fuse holder C -SC14- Fuse 22 on fuse holder C -SC22- Fuse 31 on fuse holder C -SC31- Fuse 38 on fuse holder C -SC38- - fuse 42 on fuse holder C -SC42- Fuse 53 on fuse holder C -SC53- Terminal 15 voltage supply relay -J329- Relay for power sockets -J807- | 30 |
| SBG | Fuse G on fuse holder B -SBG- | 400 A | Alternator -C- | 30 |
| 508 | 508 Threaded connection (30), on E-box | - | Battery -A- | 30 |
| SBE | Fuse E on fuse holder B -SBE- | 80 A | Power steering control unit -J500- | 30 |
| SBK | Fuse K on fuse holder B -SBK- | 80 A | Fuse holder C -SC- Fuse 1 on fuse holder C -SC1- - fuse 3 on fuse holder C -SC3- Fuse 15 on fuse holder C -SC15- - fuse 30 on fuse holder C -SC30- Fuse 43 on fuse holder C -SC43- - fuse 46 on fuse holder C -SC46- Fuse 50 on fuse holder C -SC50- - fuse 52 on fuse holder C -SC52- | 30 |
| SBL | Fuse L on fuse holder B -SBL- | 50 A | Radiator fan -VX57- | 30 |
50 A - red
40 A - green
30 A - pink
40 A - orange
30 A - light green
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
| SB1 | Fuse 1 on fuse holder B -SB1- | 25 A | ABS control unit -J104- | 30 |
| SB2 | Fuse 2 on fuse holder B -SB2- | 40 A 4) 60 A 5) | ABS control unit -J104- ABS hydraulic pump -V64- | 30 |
| SB3 | Fuse 3 on fuse holder B -SB3- | 15 A 1) 30 A 2) | Engine/motor control unit -J623- | 87 |
| SB4 | Fuse 4 on fuse holder B -SB4- | 5 A 2) 10 A 1) | Radiator fan -VX57- 3) Oil level and oil temperature sender -G266- High heat output relay -J360- Low heat output relay -J359- 2), 3) Glow plug 1 -Q10- 2) Glow plug 3 -QX3- 2) Exhaust camshaft control valve 1 -N318- Camshaft control valve 1 -N205- Activated charcoal filter solenoid valve 1 -N80- Valve for oil pressure control -N428- 1), 3) | 87 |
| SB5 | Fuse 5 on fuse holder B -SB5- | 10 A | Fuel pressure regulating valve -N276- 2), 3) Fuel metering valve -N290- 2), 3) Engine component current supply relay -J757- 1), 3) | 87 |
| SB6 | Fuse 6 on fuse holder B -SB6- | 5 A | Brake light switch -F- | 87 |
| SB7 | Fuse 7 on fuse holder B -SB7- | 10 A 2) | Charge air cooling pump -V188- Coolant valve for gearbox -N488- Turbocharger air recirculation valve -N249- Intake manifold flap valve -N316- Piston cooling jet control valve -N522- Coolant valve for cylinder head -N489- 2), 3) Oil pressure sender -G10- Auxiliary pump for heating -V488- 3) Coolant shut-off valve -N82- 1), 3) Valve for oil pressure control -N428- 2), 3) | 87 |
| SB8 | Fuse 8 on fuse holder B -SB8- | 15 A | Lambda probe 1 before catalytic converter -GX10- 3) Control unit for NOx sender -GX30- 3) Lambda probe 1 after catalytic converter -GX7- 3) | 87 |
| SB9 | Fuse 9 on fuse holder B -SB9- | 5 A 2) 10 A 1) | Automatic glow period control unit -J179- 2), 3) Heater element for crankcase breather -N79- Air mass meter -G70- Ignition coil 3 with output stage -N291- Ignition coil 2 with output stage -N127- Ignition coil 1 with output stage -N70- Activated charcoal filter solenoid valve 1 -N80- Exhaust camshaft control valve 1 -N318- Camshaft control valve 1 -N205- | 87 |
| SB10 | Fuse 10 on fuse holder B -SB10- | 15 A 1) 20 A 2) | Fuel pump control unit -J538- | 87 |
| SB11 | Fuse 11 on fuse holder B -SB11- | 40 A 2) | Auxiliary air heater element -Z35- | 87 |
| SB12 | Fuse 12 on fuse holder B -SB12- | 40 A 2) | Auxiliary air heater element -Z35- | 87 |
| SB13 | Fuse 13 on fuse holder B -SB13- | 30 A | Mechatronic unit for dual clutch gearbox -J743- | 30 |
| SB14 | not assigned | - | - | |
| SB15 | Fuse 15 on fuse holder B -SB15- | 15 A | Horn relay -J413- | 30 |
| SB16 | Fuse 16 on fuse holder B -SB16- | 20 A 1) | Engine component current supply relay -J757- 1), 3) | 30 |
| SB17 | Fuse 17 on fuse holder B -SB17- | 7.5 A | Engine/motor control unit -J623- ABS control unit -J104- | 30 |
| SB18 | Fuse 18 on fuse holder B -SB18- | 5 A | Battery monitor control unit -J367- | 30 |
| SB19 | Fuse 19 on fuse holder B -SB19- | 30 A | Wiper motor relay 1 -J368- Wiper motor relay 2 -J369- | 30 |
| SB20 | Fuse 20 on fuse holder B -SB20- | 10 A | Alarm horn -H12- | 30 |
| SB21 | not assigned | - | - | |
| SB22 | Fuse 22 on fuse holder B -SB22- | 5 A | Engine/motor control unit -J623- | 50 |
| SB23 | Fuse 23 on fuse holder B -SB23- | 30 A | Starter -B- | 50 |
50 A - red
40 A - green
30 A - pink
40 A - orange
30 A - light green
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
| SB2 | Fuse 2 on fuse holder B -SB2- | 40 A 5) 60 A 6) | ABS control unit -J104- ABS hydraulic pump -V64- | 30 |
| SB4 | Fuse 4 on fuse holder B -SB4- | 5 A 2) 10 A 1) | Radiator fan -VX57- 3) Oil level and oil temperature sender -G266- High heat output relay -J360- Low heat output relay -J359- 2), 3) Glow plug 1 -Q10- 2) Glow plug 3 -QX3- 2) Exhaust camshaft control valve 1 -N318- Camshaft control valve 1 -N205- Inlet cam actuator for cylinder 2 -N583- Exhaust cam actuator for cylinder 2 -N587- Inlet cam actuator for cylinder 3 -N591- Exhaust cam actuator for cylinder 3 -N595- Charge pressure control solenoid valve -N75- 3) Inlet camshaft control valve 1 -N727- Activated charcoal filter solenoid valve 1 -N80- Valve for oil pressure control -N428- 1), 3) | 87 |
| SB7 | Fuse 7 on fuse holder B -SB7- | 10 A 2) | Charge air cooling pump -V188- Coolant valve for gearbox -N488- Turbocharger air recirculation valve -N249- Intake manifold flap valve -N316- Piston cooling jet control valve -N522- Coolant valve for cylinder head -N489- 2), 3) Oil pressure sender -G10- Auxiliary pump for heating -V488- 3) Exhaust flap control unit -J883- 4) Coolant shut-off valve -N82- 1), 3) Valve for oil pressure control -N428- 2), 3) | 87 |
| SB8 | Fuse 8 on fuse holder B -SB8- | 15 A | Lambda probe 1 before catalytic converter -GX10- 3) Control unit for NOx sender -GX30- 3) Control unit 2 for NOx sender -GX46- 3) Lambda probe 1 after catalytic converter -GX7- 3) | 87 |
| SB9 | Fuse 9 on fuse holder B -SB9- | 5 A 2) 10 A 1) | Automatic glow period control unit -J179- 2), 3) Heater element for crankcase breather -N79- Air mass meter -G70- Ignition coil 4 with output stage -N292- Ignition coil 3 with output stage -N291- Ignition coil 2 with output stage -N127- Ignition coil 1 with output stage -N70- Activated charcoal filter solenoid valve 1 -N80- Exhaust camshaft control valve 1 -N318- Camshaft control valve 1 -N205- | 87 |
50 A - red
40 A - green
30 A - pink
40 A - orange
30 A - light green
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
| SB4 | Fuse 4 on fuse holder B -SB4- | 5 A 2) 7.5 A 2) 7) 10 A 1) | Radiator fan -VX57- 3) Oil level and oil temperature sender -G266- High heat output relay -J360- Low heat output relay -J359- 2), 3) Glow plug 1 -Q10- 2) Glow plug 3 -QX3- 2) Exhaust camshaft control valve 1 -N318- Camshaft control valve 1 -N205- Inlet cam actuator for cylinder 2 -N583- Exhaust cam actuator for cylinder 2 -N587- Inlet cam actuator for cylinder 3 -N591- Exhaust cam actuator for cylinder 3 -N595- Charge pressure control solenoid valve -N75- 3) Inlet camshaft control valve 1 -N727- Activated charcoal filter solenoid valve 1 -N80- Valve for oil pressure control -N428- 1), 3) | 87 |
| SB6 | Fuse 6 on fuse holder B -SB6- | 7.5 A | Brake light switch -F- | 87 |
| SB7 | Fuse 7 on fuse holder B -SB7- | 7.5 A 8) 9) 10 A | Charge air cooling pump -V188- Heater element for crankcase breather -N79- Coolant valve for gearbox -N488- Turbocharger air recirculation valve -N249- Intake manifold flap valve -N316- Piston cooling jet control valve -N522- Coolant valve for cylinder head -N489- 2), 3) Oil pressure sender -G10- Auxiliary pump for heating -V488- 3) Exhaust flap control unit -J883- 4) Coolant shut-off valve -N82- 1), 3) Valve for oil pressure control -N428- 2), 3) | 87 |
| SB8 | Fuse 8 on fuse holder B -SB8- | 10 A 4) 10) 15 A | Lambda probe 1 before catalytic converter -GX10- 3) Control unit for NOx sender -GX30- 3) Control unit 2 for NOx sender -GX46- 3) Lambda probe 1 after catalytic converter -GX7- 3) | 87 |
| SB9 | Fuse 9 on fuse holder B -SB9- | 5 A 2) 20 A 1) | Automatic glow period control unit -J179- 2), 3) Air mass meter -G70- Ignition coil 4 with output stage -N292- Ignition coil 3 with output stage -N291- Ignition coil 2 with output stage -N127- Ignition coil 1 with output stage -N70- Activated charcoal filter solenoid valve 1 -N80- Exhaust camshaft control valve 1 -N318- Camshaft control valve 1 -N205- | 87 |
| SB13 | Fuse 13 on fuse holder B -SB13- | 30 A | Auxiliary hydraulic pump 1 for gearbox oil -V475- | 30 |
| SB18 | Fuse 18 on fuse holder B -SB18- | 5 A 11) 7.5 A | Battery monitor control unit -J367- | 30 |
| SB20 | not assigned | - | 30 | |
| SB21 | Fuse 21 on fuse holder B -SB21- | 15 A 12) 30 A 13) | Mechatronic unit for dual clutch gearbox -J743- | - |
| SB22 | Fuse 22 on fuse holder B -SB22- | 5 A 11) 7.5 A | Engine/motor control unit -J623- | 50 |
50 A - red
40 A - green
30 A - pink
40 A - orange
30 A - light green
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
| SB9 | Fuse 9 on fuse holder B -SB9- | 10 A 2) 20 A 1) | Automatic glow period control unit -J179- 2), 3) Air mass meter -G70- Ignition coil 4 with output stage -N292- Ignition coil 3 with output stage -N291- Ignition coil 2 with output stage -N127- Ignition coil 1 with output stage -N70- Activated charcoal filter solenoid valve 1 -N80- Exhaust camshaft control valve 1 -N318- Camshaft control valve 1 -N205- | 87 |
| SB18 | Fuse 18 on fuse holder B -SB18- | 7.5 A | Battery monitor control unit -J367- | 30 |
| SB21 | Fuse 21 on fuse holder B -SB21- | 15 A 11) 30 A 12) | Mechatronic unit for dual clutch gearbox -J743- | - |
| SB22 | Fuse 22 on fuse holder B -SB22- | 7.5 A | Engine/motor control unit -J623- | 50 |
50 A - red
40 A - green
30 A - pink
40 A - orange
30 A - light green
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
| SC1 | Fuse 1 on fuse holder C -SC1- | 30 A | Control unit for reducing agent heater -J891- | 30 |
| SC2 | Fuse 2 on fuse holder C -SC2- | 10 A | Steering column electronics control unit -J527- | 30 |
| SC3 | not assigned | - | - | |
| SC4 | not assigned | - | - | |
| SC5 | Fuse 5 on fuse holder C -SC5- | 5 A | Data bus diagnostic interface -J533- | 30 |
| SC6 | Fuse 6 on fuse holder C -SC6- | 5 A | Selector lever -E313- | 30 |
| SC7 | Fuse 7 on fuse holder C -SC7- | 10 A | Heater and air conditioning controls -EX21- Remote control receiver for auxiliary coolant heater -R149- Heated rear window relay -J9- | 30 |
| SC8 | Fuse 8 on fuse holder C -SC8- | 10 A | Rotary light switch -EX1- Electromechanical parking brake button -E538- Rain and light sensor -G397- Diagnostic connection -U31- Anti-theft alarm sensor -G578- Operating unit for driving mode selection -E881- Control unit for cornering light and headlight range control -J745- | 30 |
| SC9 | Fuse 9 on fuse holder C -SC9- | 5 A | Steering column electronics control unit -J527- | 30 |
| SC10 | Fuse 10 on fuse holder C -SC10- | 7.5 A | Display unit for front information display and operating unit control unit -J685- CD player -R89- | 30 |
| SC11 | Fuse 11 on fuse holder C -SC11- | 40 A | Onboard supply control unit -J519- | 30 |
| SC12 | Fuse 12 on fuse holder C -SC12- | 20 A | Control unit 1 for information electronics -J794- | 30 |
| SC13 | Fuse 13 on fuse holder C -SC13- | 25 A | Front left seat belt -NX10- 2) Front right seat belt -NX11- 3) | 30 |
| SC14 | Fuse 14 on fuse holder C -SC14- | 40 A | Fresh air blower control unit -J126- | 30 |
| SC15 | Fuse 15 on fuse holder C -SC15- | 10 A | Control unit for electronic steering column lock -J764- | 30 |
| SC16 | Fuse 16 on fuse holder C -SC16- | 7.5 A | Transmission and reception stabilisation control unit -R308- Storage compartment with interface for mobile telephone -R265- USB hub -R293- | 30 |
| SC17 | Fuse 17 on fuse holder C -SC17- | 7.5 A | Dash panel insert -KX2- Emergency call module control unit and communication unit -J949- | 30 |
| SC18 | Fuse 18 on fuse holder C -SC18- | 7.5 A | Rear lid handle -EX37- | 30 |
| SC19 | Fuse 19 on fuse holder C -SC19- | 7.5 A | Interface for entry and start system -J965- | 30 |
| SC20 | Fuse 20 on fuse holder C -SC20- | 7.5 A | Relay for reducing agent metering system -J963- | 30 |
| SC21 | Fuse 21 on fuse holder C -SC21- | 15 A | All-wheel drive control unit -J492- | 30 |
| SC22 | Fuse 22 on fuse holder C -SC22- | 15 A | Trailer detector control unit -J345- | 30 |
| SC23 | Fuse 24 on fuse holder C -SC24- | 30 A | Sliding sunroof adjustment control unit -J245- | 30 |
| SC24 | Fuse 23 on fuse holder C -SC23- | 40 A | Onboard supply control unit -J519- | 30 |
| SC25 | Fuse 25 on fuse holder C -SC25- | 30 A | Driver door control unit -J386- | 30 |
| SC26 | Fuse 26 on fuse holder C -SC26- | 30 A | Onboard supply control unit -J519- | 30 |
| SC27 | Fuse 27 on fuse holder C -SC27- | 30 A | Onboard supply control unit -J519- | - |
| SC28 | Fuse 28 on fuse holder C -SC28- | 25 A | Trailer detector control unit -J345- | 30 |
| SC29 | not assigned | - | - | |
| SC30 | not assigned | - | - | |
| SC31 | not assigned | - | - | |
| SC32 | Fuse 32 on fuse holder C -SC32- | 10 A | Front camera for driver assist systems -R242- Adaptive cruise control unit -J428- Parking aid control unit -J446- | 15 |
| SC33 | Fuse 33 on fuse holder C -SC33- | 5 A | Airbag control unit -J234- | 15 |
| SC34 | Fuse 34 on fuse holder C -SC34- | 7.5 A | Interior mirror -EX5- Relay for power sockets -J807- Reversing light switch -F4- Pressure sender for refrigerant circuit -G805- Air quality sensor -G238- Electromechanical parking brake button -E538- | 15 |
| SC35 | Fuse 35 on fuse holder C -SC35- | 10 A | Diagnostic connection -U31- | 15 |
| SC36 | Fuse 36 on fuse holder C -SC36- | 5 A | Front right headlight -MX2- | 15 |
| SC37 | Fuse 37 on fuse holder C -SC37- | 5 A | Front left headlight -MX1- | 15 |
| SC38 | Fuse 38 on fuse holder C -SC38- | 25 A | Trailer detector control unit -J345- | 30 |
| SC39 | Fuse 39 on fuse holder C -SC39- | 30 A | Front passenger door control unit -J387- | 30 |
| SC40 | Fuse 40 on fuse holder C -SC40- | 20 A | 12 V socket 2 -U18- 12 V socket 3 -U19- | 15 |
| SC41 | Fuse 41 on fuse holder C -SC41- | 25 A | Front right seat belt -NX11- 2) Front left seat belt -NX10- 3) | 30 |
| SC42 | Fuse 42 on fuse holder C -SC42- | 40 A | Onboard supply control unit -J519- | 30 |
| SC43 | Fuse 43 on fuse holder C -SC43- | 40 A | Digital sound package control unit -J525- | 30 |
| SC44 | Fuse 44 on fuse holder C -SC44- | 15 A | Trailer detector control unit -J345- | 30 |
| SC45 | not assigned | - | - | |
| SC46 | not assigned | - | - | |
| SC47 | Fuse 47 on fuse holder C -SC47- | 15 A | Rear window wiper motor -V12- | 15 |
| SC48 | not assigned | - | - | |
| SC49 | Fuse 49 on fuse holder C -SC49- | 5 A | Clutch position sender -G476- | 15 |
| SC50 | Fuse 50 on fuse holder C -SC50- | 40 A | Rear lid control unit -J605- | 30 |
| SC51 | not assigned | - | - | |
| SC52 | Fuse 52 on fuse holder C -SC52- | 15 A | Electronically controlled damping control unit -J250- | 30 |
| SC53 | Fuse 53 on fuse holder C -SC53- | 30 A | Heated rear window relay -J9- | 15 |
50 A - red
40 A - green
30 A - pink
40 A - orange
30 A - light green
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
| SC4 | Fuse 4 on fuse holder C -SC4- | 7.5 A | Alarm horn -H12- | 30 |
| SC5 | Fuse 5 on fuse holder C -SC5- | 7.5 A | Data bus diagnostic interface -J533- | 30 |
| SC6 | Fuse 6 on fuse holder C -SC6- | 7.5 A | Selector lever -E313- | 30 |
| SC7 | Fuse 7 on fuse holder C -SC7- | 7.5 A | Heater and air conditioning controls -EX21- Remote control receiver for auxiliary coolant heater -R149- Heated rear window relay -J9- | 30 |
| SC8 | Fuse 8 on fuse holder C -SC8- | 7.5 A | Rotary light switch -EX1- Electromechanical parking brake button -E538- Rain and light sensor -G397- Diagnostic connection -U31- Anti-theft alarm sensor -G578- Operating unit for driving mode selection -E881- Control unit for cornering light and headlight range control -J745- | 30 |
| SC9 | Fuse 9 on fuse holder C -SC9- | 5 A 4) 7.5 A 5) | Steering column electronics control unit -J527- Ignition/starter switch -D | 30 |
| SC20 | Fuse 20 on fuse holder C -SC20- | 10 A 6) | Relay for reducing agent metering system -J963- | 30 |
| SC23 | Fuse 24 on fuse holder C -SC24- | 20 A | Sliding sunroof adjustment control unit -J245- | 30 |
| SC31 | Fuse 31 on fuse holder C -SC31- | 30 A | Rear lid control unit -J605- | 50 |
| SC33 | Fuse 33 on fuse holder C -SC33- | 7.5 A | Airbag control unit -J234- | 15 |
| SC35 | Fuse 35 on fuse holder C -SC35- | 7.5 A | Diagnostic connection -U31- | 15 |
| SC36 | Fuse 36 on fuse holder C -SC36- | 7.5 A | Front right headlight -MX2- | 15 |
| SC37 | Fuse 37 on fuse holder C -SC37- | 7.5 A | Front left headlight -MX1- | 15 |
| SC49 | Fuse 49 on fuse holder C -SC49- | 7.5 A | Clutch position sender -G476- | 15 |
| SC50 | not assigned | - | 30 | |
50 A - red
40 A - green
30 A - pink
40 A - orange
30 A - light green
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
| SC1 | Fuse 1 on fuse holder C -SC1- | 20 A | Control unit for reducing agent heater -J891- | 30 |
40 A - orange
30 A - light green
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
| SD1 | Fuse 1 on fuse holder D -SD1- | 15 A | Vacuum pump for brakes -V192- | 87 |
| SD2 | not assigned | - | - | |
| SD3 | Fuse 3 on fuse holder D -SD3- | 15 A | Auxiliary hydraulic pump 1 for gearbox oil -V475- | 30 |
| SD4 | not assigned | - | - | |
| SD5 | not assigned | - | - | |
| SD6 | not assigned | - | - | |
| SD7 | Fuse 7 on fuse holder D -SD7- | 20 A | Auxiliary heater control unit -J364- | 30 |
| SD8 | not assigned | - | - |
40 A - orange
30 A - light green
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
| SD3 | not assigned | - | - | |
| A | Auxiliary air heating fuse -S379- | 40 A | Auxiliary air heater element -Z35- | PTC1 |
Relays
R2 - not assigned
R3 - not assigned
