Admin
Создатель сайта
Команда форума
- Россия, Москва
- VW Tiguan 2.0 DBGC 2018, VW Touran 1.6 BSE 2008
- Автомобиль
- VW / Audi / Skoda
- Двигатель
- 2,0 BEV, BGD
| Step | Diagnosis | Condition | Function Display group | Channel 1 | Channel 2 | Channel 3 | Channel 4 | Comments |
| 1 | Check DTC memory Clear DTC memory | Engine off Ignition. On | DTC memory content | x | x | x | x | Check fault memory Delete fault memory |
| 2 | Throttle adaptation | Engine off Ignition. On | Basic setting 060 | x | x | x | Adapt I.O. | Do not touch accelerator pedal |
| 3 | Kick-down adaptation (Auto trans. Only) | Engine off Ignition. On | Basic setting 063 | x | x | Kick-down | Adapt I.O. | Depress accelerator fully until I.O. |
| 4 | LDP | Idle | Basic setting 202 | x | x | x | xxxxx100 | Loosen then re-fasten fuel cap prior to test. |
| 5 | Engine warm - up | 3000 rpm | Measured values 04 | RPM | Volts | CTS | IATS | Run until Channel 3 > 80 deg. C |
| 6 | Oxygen sensor B1S1 Heating | Idle | Basic setting 205 | x | x | x | xxxxx100 | I.O. when Ch.4 = xxxxx100 |
| 7 | Catalyst Diagnosis | Brake / Gas | Basic setting 226 | x | x | x | xxxxx100 | I.O. when Ch.4 = xxxxx100 |
| 8 | BGD Engine Only Catalyst Diagnosis Quick Pass Check | RPM briefly to 6K rpm Return to idle | Measured values 005 | x | x | x | x | After 6K rpm increase & return to idle move on to step 9 |
| 9 | Oxygen sensor B1S1 Aging | Brake / Gas 90 sec. Then idle 90 sec. | Basic setting 212 | x | x | x | xxxxx100 | I.O. when Ch.4 = xxxxx100 ** Test drive if nessesary to set. Exit basic setting before test drive |
| 10 | Fuel delivery system | Idle 90 sec. Then Brake / Gas 90 sec. | Basic setting 216 | x | x | x | xxxxx100 | I.O. when Ch.4 = xxxxx100 |
| 11 | Filling registration | Brake / Gas | Basic setting 218 | x | x | x | xxxxx100 | I.O. when Ch.4 = xxxxx100 |
| 12 | Oxygen sensor B1S2 Heater | Brake / Gas | Basic setting 219 | x | x | x | xxxxx100 | I.O. when Ch.4 = xxxxx100 |
| 13 | Oxygen sensor B1S2 Diag. | Brake / Gas | Basic setting 221 | x | x | x | xxxxx100 | I.O. when Ch.4 = xxxxx100 |
| 14 | Oxygen sensor B1S2 Aging | Brake / Gas | Basic setting 224 | x | x | x | xxxxx100 | I.O. when Ch.4 = xxxxx100 |
| 15 | EVAP system | Idle | Basic setting 228 | x | x | x | xxxxx100 | I.O. when Ch.4 = xxxxx100 |
| 16 | Secondary air | Idle | Basic setting 229 | x | x | x | xxxxx100 | I.O. when Ch.4 = xxxxx100 |
| 17 | Readiness status | Idle | Measured values 086 | 00000000 | x | x | x | Readiness code set if all Zeros |
Some test could take several minutes
** Test drive should include a 1st gear 5K rpm acceleration for 3 seconds
then a deceleration for 3 seconds.
Perform only when safe to do so.
