Admin
Создатель сайта
Команда форума
- Россия, Москва
- VW Tiguan 2.0 DBGC 2018, VW Touran 1.6 BSE 2008
- Автомобиль
- VW Passat B3
- Двигатель
- PB, PF
Digifant ignition and injection system (1.8 ltr. engine)
Engine code: PB, PF
01 Self diagnosis, Electrical check
Electrical check of the Digifant ignition and injection system
24 Fuel system, Digifant
- Fitting location - General view
- Servicing fuel injection part
- Technical data
- Safety measures
- Rules for cleanliness
- Idling adjustment
- Checking idling stabilization
- Checking Lambda probe and Lambda regulation (engine code letters: PF)
- Checking overrun cut-off and full throttle enrichment
- Checking and adjusting idling and full throttle switch (vehicles with manual gearbox)
- Checking and adjusting throttle valve potentiometer (vehicles with automatic gearbox)
- Checking fuel pressure regulator and holding pressure
- Checking injectors
- Checking intake air preheating
- Basic setting of the throttle valve
28 Ignition system
- Servicing ignition part
- Adjustment data, spark plugs
- Safety measures
- Installing distributor
- Checking and adjusting ignition timing
- Checking ignition timing control and knock sensor
- Checking ignition part of the Digifant system
A - Checking TCI-H switch unit (N41)
В - Checking Hall sender (G40)
C - Checking ignition/switching function of Digifant control unit (J169)
Engine code: PB, PF
- Technical data
- Safety measures
- Idling adjustment
28 Ignition system
- Safety measures
