Руководство Fitting locations petrol engine CYRB, CYRC, DMFA технические характеристики, расположение компонентов
Admin
Admin
Создатель сайта
Команда форума
Россия, Москва
VW Tiguan 2.0 DBGC 2018, VW Touran 1.6 BSE 2008
Автомобиль
VW Touareg 3 2.0 2018
Двигатель
CYRB, CYRC, DMFA
4-cyl. direct injection engine (2.0 l, 4 V, EA 888 Gen III, turbocharger, chain drive). Engine data
CodesCYRBCYRCDMFA
Manufactured from04.2018 ->04.2018 ->07.2018 ->
Exhaust emission standard
Displacement l
Power kW at rpm
Torque Nm at rpm
Bore Diameter, mm
Stroke mm
Compression ratio
RON
Injection system
Firing order
Charging
Camshaft timing adjustment
Valvelift system
Secondary air injection
Valves per cylinder
Oil pressure control
EU 6
2.0
185 at 5000 … 6000
370 at 1600 … 4500
82.5
92.8
9.6:1
95
Direct injection and intake manifold injection
1-3-4-2
Exhaust turbocharger
Yes
Yes
No
4
Yes
EU 6
2.0
183 at 5000 … 6000
370 at 1600 … 4500
82.5
92.8
9.6:1
95
1-3-4-2
Yes
Yes
No
4
Yes
C6b without RDE
2.0
180 at 5000 … 6000
370 at 1600 … 4500
82.5
92.8
9.6:1
95
Direct injection
1-3-4-2
Yes
Yes
Yes
4
Yes
Fitting locations 2.0l petrol engine, CYRB, CYRC, DMFA, from front
1 - Turbocharger air recirculation valve -N249-
2 - Exhaust camshaft control valve 1 -N318-
3 - Camshaft control valve 1 -N205-
4 - Oil pressure switch for reduced oil pressure -F378-
5 - Piston cooling jet control valve -N522-
6 - Oil pressure switch -F22-
7 - Sender 2 for secondary air pressure -G610-
8 - Valve for oil pressure control -N428- 4
2.0l petrol engine, CYRB, CYRC, DMFA, from above
A - 8-pin connector -T8at- , black/
8-pin connector -T8ay- , black
1 - Ignition coil 1 with output stage -N70-
2 - Ignition coil 2 with output stage -N127-
3 - Ignition coil 3 with output stage -N291-
4 - Ignition coil 4 with output stage -N292-
5 - Hall sender 2 -G163-
6 - Fuel pressure regulating valve -N276-
7 - Injector, cylinder 4 -N33-
8 - Intake manifold flap valve -N316-
9 - Intake manifold sender -GX9-
10 - Throttle valve module -GX3-
11 - Injector, cylinder 3 -N32-
12 - Knock sensor 1 -G61-
13 - Fuel pressure sender -G247-
14 - Injector, cylinder 2 -N31-
15 - Injector, cylinder 1 -N30-
16 - Intake manifold flap potentiometer -G336-
17 - Fuel pressure sender for low pressure -G410-
18 - Activated charcoal filter solenoid valve 1 -N80-
2.0l petrol engine, CYRB, CYRC, DMFA, from left
A - 8-pin connector -T8as- , black/
8-pin connector -T8az- , black
B - 14-pin connector -T14af- , black/
14-pin connector -T14aj- , black
1 - Injector 2, cylinder 1 -N532-
2 - Injector 2, cylinder 2 -N533-
3 - Injector 2, cylinder 3 -N534-
4 - Injector 2, cylinder 4 -N535-
5 - Hall sender -G40-
6 - Secondary air inlet valve -N112-
7 - Coolant temperature sender -G62-
8 - Stage 2 oil pressure switch -F446-
9 - Engine speed sender -G28-
10 - Actuator for engine temperature regulation -N493-
11 - Oil level and oil temperature sender -G266-
12 - Air conditioner compressor regulating valve -N280-
13 - Alternator with voltage regulator -CX1-
2.0l petrol engine, CYRB, CYRC, DMFA, from right
1 - Actuator 8 for camshaft adjustment -F373-
2 - Actuator 7 for camshaft adjustment -F372-
3 - Actuator 6 for camshaft adjustment -F371-
4 - Actuator 5 for camshaft adjustment -F370-
5 - Actuator 4 for camshaft adjustment -F369-
6 - Actuator 3 for camshaft adjustment -F368-
7 - Air filter bypass flap valve -N275-
8 - Actuator 2 for camshaft adjustment -F367-
9 - Actuator 1 for camshaft adjustment -F366-
10 - Charge pressure control module -GX34-
11 - Lambda probe 1 before catalytic converter -GX10-
12 - Starter -B-
13 - Lambda probe 1 after catalytic converter -GX7-
