Control units in the rear part of the vehicle
1.1 Overview of the control units (only for vehicles with left-hand drive)
1 - Control unit 2 for lane change assist -J770-
2 - Left antenna module -R108-
3 - Trailer detector control unit -J345-
4 - Control unit for tailgate -J605- only for Octavia III Combi
5 - Auxiliary heating radio controlled receiver -R64-
6 - Heated rear seat control unit -J786-
7 - Inverter with socket, 12 V-230 V -U13-
8 - Control unit for NOx encoder 2 -J881-
9 - Rear left door control unit -J388- / Rear left power window motor -V26-
10 - Front left tensioner igniter control unit -J854-
11 - Driver seat adjustment control unit -J810-
12 - Digital sound package control unit -J525-
13 - Door control unit, driver side -J386-
14 - Window regulator motor driver's side -V147-
15 - Control unit for special vehicles -J608- to July 2018
16 - Voltage stabiliser -J532- to July 2018
17 - Selector lever sensors control unit -J587-
18 - Window regulator front passenger side -V148-
19 - Door control unit, front passenger side -J387-
20 - Control unit for electronically controlled damping -J250-
21 - Front right tensioner igniter control unit -J855-
22 - Sliding sunroof control unit -J245-
23 - Right rear door control unit -J389- / right rear window motor-V27-
24 - Fuel pump control unit -J538-
25 - Fuel gauge sender -G- / Fuel pump for predelivery -G6-
26 - Four-wheel drive control unit -J492-
27 - Control unit for reduction agent heater -J891-
28 - Delivery unit for reduction agent dosing system -GX19-
29 - 2-way amplifier for mobile service -J984-
30 - Rear window wiper motor -V12-
31 - Rear lock lid unit -F256- / engine for central locking system in tailgate -V53-
32 - Control unit for lane change assist -J769-
33 - Rear view camera system -R189-
1.2 Overview of the control units (only for vehicles with right-hand drive)
13 - Door control unit, front passenger side -J387-
14 - Window regulator front passenger side -V148-
18 - Window regulator motor driver's side -V147-
19 - Door control unit, driver side -J386-
1.3 Left antenna module -R108-
1.3.1 Fitting location - Octavia III
A - Left antenna module -R108-
B - 2-pin connector, at wiring harness - T2
1.3.2 Fitting location - Octavia III Combi
1.4 Trailer detector control unit -J345-
1.4.1 Fitting location
In luggage compartment, left -arrow-.
1.4.2 Pin assignment
A - Trailer detector control unit -J345-
B - 10-pin connector, at wiring harness - T10x
C - 6-pin connector, at wiring harness - T6aw
D - 24-pin connector, at wiring harness - T24a
1.5 Control unit for tailgate -J605-
1.5.1 Fitting location
In luggage compartment, left -arrow A-.
1.5.2 Pin assignment
A - Control unit for tailgate -J605-
B - 26-pin connector, at wiring harness - T26c
C - 4-pin connector, at wiring harness - T4bk
D - 5-pin connector, at wiring harness - T5y
1.6 Auxiliary heating radio controlled receiver -R64-
1.6.1 Fitting location
In luggage compartment, left -arrow C-.
1.7 Heated rear seat control unit -J786-
1.7.1 Fitting location
In luggage compartment, left -arrow B-.
1.8 Rear left door control unit -J388- / Rear left power window motor -V26-
1.8.1 Fitting location
At assembly carrier -arrow-.
1.8.2 Pin assignment
A - Rear left door control unit -J388- / Rear left power window motor -V26-
B - 10-pin connector, at wiring harness - T10m
1.9 Front left tensioner igniter control unit -J854-
1.9.1 Fitting location
A - Front left tensioner igniter control unit -J854-
B - 3-pin connector, at wiring harness - T3al
C - 3-pin connector, at wiring harness - T3ae
1.10 Driver seat adjustment control unit -J810-
1.10.1 Fitting location
On the seat frame -arrow-.
1.11 Digital sound package control unit -J525-
1.11.1 Fitting location (only for left-hand drive vehicles):
A - Digital sound package control unit -J525-
B - 38-pin connector, at wiring harness - T38b
C - 2-pin connector, at wiring harness - T2am
1.11.2 Fitting location (only for right-hand drive vehicles):
1.12 Door control unit, driver side -J386-
1.12.1 Fitting location (only for left-hand drive vehicles):
At assembly carrier, in driver door -arrow-.
1.12.2 Fitting location (only for right-hand drive vehicles):
1.12.3 Pin assignment
A - Door control unit, driver side -J386-
B - 32-pin connector, at wiring harness - T32b
C - 16-pin connector, at wiring harness - T16c
D - 20-pin connector, at wiring harness - T20b
E - 6-pin connector, at wiring harness - T6s
1.13 Window regulator motor driver's side -V147-
1.13.1 Fitting location (only for left-hand drive vehicles):
1.13.2 Fitting location (only for right-hand drive vehicles):
1.14 Control unit for special vehicles -J608- (to July 2018)
1.14.1 Fitting location
A - Control unit for special vehicles -J608-
B - 12-pin connector, at wiring harness - T12l
C - 16-pin connector, at wiring harness - T16n
D - 16-pin connector, at wiring harness - T16o
1.15 Voltage stabiliser -J532- (to July 2018)
1.15.1 Fitting location
A - Voltage stabiliser -J532-
B - 12-pin connector, at wiring harness - T12m
1.16 Window regulator front passenger side -V148-
1.16.1 Fitting location (only for left-hand drive vehicles):
At assembly carrier, in front passenger door -arrow-.
1.16.2 Fitting location (only for right-hand drive vehicles):
1.17 Door control unit, front passenger side -J387-
1.17.1 Fitting location (only for left-hand drive vehicles):
1.17.2 Fitting location (only for right-hand drive vehicles):
1.17.3 Pin assignment
A - Door control unit, front passenger side -J387-
B - 32-pin connector, at wiring harness - T32c
C - 16-pin connector, at wiring harness - T16d
D - 20-pin connector, at wiring harness - T20c
E - 6-pin connector, at wiring harness - T6t
1.18 Control unit for electronically controlled damping -J250-
1.18.1 Fitting location
A - Control unit for electronically controlled damping -J250-
B - 47-pin connector, at wiring harness - T47a
1.19 Front right tensioner igniter control unit -J855-
1.19.1 Fitting location
A - Front right tensioner igniter control unit -J855-
B - 3-pin connector, at wiring harness - T3am
C - 3-pin connector, at wiring harness - T3af
1.20 Sliding sunroof control unit -J245-
1.20.1 Fitting location
A - Sliding sunroof control unit -J245-
B - 10-pin connector, at wiring harness - T10s
1.21 Right rear door control unit -J389- / right rear window motor-V27-
1.21.1 Fitting location
1.21.2 Pin assignment
A - Right rear door control unit -J389- / right rear window motor-V27-
B - 10-pin connector, at wiring harness - T10n
1.22 Fuel pump control unit -J538-
1.22.1 Fitting location
A - Fuel pump control unit -J538-
B - 5-pin connector, at wiring harness - T5f
1.22.2 Fitting location
B - 6-pin connector, at wiring harness - T6m
1.23 Four-wheel drive control unit -J492-
1.23.1 Fitting location
A - Four-wheel drive control unit -J492-
B - 2-pin connector, at wiring harness - T2k
C - 8-pin connector, at wiring harness - T8o
1.24 Rear lock lid unit -F256- / engine for central locking system in tailgate -V53-
1.24.1 Fitting location
In the tailgate -arrow-.
1.24.2 Pin assignment
A - Rear lock lid unit -F256- / engine for central locking system in tailgate -V53-
B - 4-pin connector, at wiring harness - T4c
1.25 Rear view camera system -R189-
1.25.1 Fitting location
1.26 Control unit for reduction agent heater -J891-
1.26.1 Fitting location (Octavia III)
A - Control unit for reduction agent heater -J891-
B - 4-pin connector, at wiring harness - T4ca
C - 5-pin connector, at wiring harness - T5af
1.26.2 Fitting location (Octavia III Combi)
1.27 Delivery unit for reduction agent dosing system -GX19-
1.27.1 Fitting location
A - Delivery unit for reduction agent dosing system -GX19-
B - 4-pin connector, at wiring harness - T4cb
C - 5-pin connector, at wiring harness - T5ah
