Ошибка после обновления рейки 18178 - invalid data record
  • Автор темы A1eek
  • Ответы 1
A1eek
Москва
Golf 7
Обновил рейку 5Q0 909 144 T 1072 до 5Q0 909 144 AA 1081. Вылезла нестираемая ошибка:
1 Fault Found:
B2005 00 [009] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 108799 km
Date: 2019.07.09
Time: 12:29:54
Motor status: 00
System status: Waiting for start request
Supply voltage: 12.00 V
Temperature: 44.0 °C
KFC: 47
KFA: 00 02
Environmental conditions: 5F
uAdSensI_U1V2Filtered_gdu16: 1.21 V
uAdSensI_U5VFiltered_xdu16: 5.09286 V
uioUdNotFilt_xdu16: 12.20 V
uAdSensI_SwitchedKl30_xdu16: 12.16 V
NoInitCause_AsicSens: [0x00] ASC_CTRL_SAS_NO_ERR
NoInitCause_RackPos_Rohwert: 00 00
RP_VALCNTSAV: not activated
RP_DIAGJOB: not activated
RP_RPS: not activated
RP_KMN_RACKPOS_SET: not activated
RP_STARTUP: not activated
RP_L2PLAUSI: not activated
RP_INDEXPLAUSI: not activated
RP_WHLSPDPLAUSI: not activated
RP_RUKUCNTR: not activated
RP_UNDERVOLT: not activated
RP_CNTERR: not activated
Возврат на предыдущую прошивку от ошибки не избавил. Всё работет, на приборке ошибок нет, но если залезть в блок, то видна ошибка.
