Volkswagen Transporter (7H) / Фольксваген Транспортер Т5 (7H): электрооборудование
Volkswagen Transporter T5 (7H) - Wiring Diagrams (eng.)
Полные электросхемы для Фольксваген Транспортер Т5 (7H) с 2003 года выпуска.
1.9L 63 kW - Turbodiesel engine (unit injectors), engine code AXC
1.9L 77 kW - Turbodiesel engine (unit injectors), engine code AXB
2.5L 96 kW - Turbodiesel engine (unit injectors), engine code AXD
2.5L 128 kW - Turbodiesel engine (unit injectors), engine code AXE
2.0L 85 kW - Motronic, engine code AXA
3.2L 173 kW - engine (Motronic), engine code BDL
3.2L 173 kW - engine (Motronic), engine code BKK
3.2L 173 kW - engine (Motronic), engine code BDM
2.5L 96 kW - Turbodiesel engine, engine code BNZ
2.5L 128 kW - Turbodiesel engine, engine code BPC
1.9L 75 kW - Turbodiesel engine, engine code BRS
1.9L 62 kW - Turbodiesel engine, engine code BRR
6-speed automatic gearbox (09K)
Auxiliary coolant heater Thermo Top Z / C-B, Thermo Top Z / C-D
Anti-lock brake system (ABS) with electronic differential lock (EDL) and traction control system (TCS) and electronic stabilisation program (ESP) и многое другое.
2616 страниц! 62 Mb.
https://vwts.ru/vw/t5/vw-t5-2003-wiring-diagrams-eng.pdf
поиском по номеру разьема в pdf распиновка делается за 5 минут....
