Нужна параметрия
  • Автор темы Ara22
  • Ответы 6
Ara22
Украина, Донецк
Touareg V10TDI AYH Individual 2005г
Нужна параметрия
VW Caddy
Адрес: 55 Номер блока AFS: 5M0907357F (ETKA дает номер 5M0907357F Z0H)
Версия софта: 0111
А что такое параметрия для тебя ?
Может тебе сюда постучаться ?
Это Надо ??
; measuring blocks & basic setting
001,1,Voltage,(Terminal 15)
001,2,Light Status,(Terminal 56b),Display Range: ON/OFF
001,3,Vehicle Speed
001,4,Steering Angle,Sensor (G85)
B001,0,Adjustment Position && Adjustment Learning
B001,1,Status
B001,2,, ,
B001,3,, ,
B001,4,, ,
002,1,Sensor Signal,Front (G78/G289),Range: 0.0...100.0 %
002,2,Sensor Signal,Rear (G76/G77),Range: 0.0...100.0 %
002,3,Actuator Motor,Left Headlight,Range: 0.0...100.0 %
002,4,Actuator Motor,Right Headlight,Range: 0.0...100.0 %
003,0,Cornering Light
003,1,Static Cornering,Light Left
003,2,Static Cornering,Light Right
003,3,Dynamic Cornering,Light Left
003,4,Dynamic Cornering,Light Right
004,1,Sensor Signal,Front (G78),Range: 0.0...100.0 %\nSpecification: 12.5...50.0 %
004,2,Sensor Signal,Rear (G76),Range: 0.0...100.0 %\nSpecification: 50.0...87.5 %
004,3,Movement,Front Suspension,Display Range: -127.0...+128.0 mm
004,4,Movement,Rear Suspension,Display Range: -127.0...+128.0 mm
005,0,Voltage Supply
005,2,Sensor,Voltage Supply
005,3,Voltage Light,Module Left
005,4,Voltage Light,Module Right
006,1,Reverse Gear,engaged,Range: Reverse: No/Reverse: Yes
006,2,Cornering Light,deactived,Range: Yes/No
080,0,Advanced Control Module Identification I
081,0,Advanced Control Module Identification II
082,0,Advanced Control Module Identification III
125,0,CAN-Databus Communication (Powertrain)
125,1,Brake Electronics,(J104),Specification: ABS 1\nDisplay Range: ABS 1/ABS 0
125,2,CAN-Gateway,(J533),Specification: Gateway 1\nDisplay Range: Gateway 1/Gateway 0
125,3,Power Steering,(J500),Specification: Steer. ang. 1\nDisplay Range: Steer. ang. 1/Steer. ang. 0
125,4,Engine,Electronics,Specification: Engine 1\Display Range: Engine 1/Engine 0
127,0,CAN-Databus Communication (Light)
127,1,Left Output,Stage (J667),Specification: LeiMo Left 1\nDisplay Range: LeiMo Left 1/LeiMo Left 0
127,2,Right Output,Stage (J668),Specification: LeiMo Right 1\nDisplay Range: LeiMo Right 1/LeiMo Right 0
; coding
C00,Cornering Lights Headlight Range Control (J745) Coding
C01,0000001 = VW Passat (3C) Left-Hand-Drive / Rest of World
C02,0000003 = VW Eos (1F) Left-Hand-Drive / Rest of World
C03,0000004 = VW Golf/Jetta (1K/5M) Left-Hand-Drive / Rest of World
C04,0000005 = VW Touran (1T) Left-Hand-Drive
C05,0000006 = VW Passat (3C) Right-Hand-Drive / Rest of World
C06,0000007 = VW Passat (3C) Left-Hand-Drive / North America
C07,0000010 = VW Eos (1F) Right-Hand-Drive / Rest of World
C08,0000011 = VW Eos (1F) Left-Hand-Drive / North America
C09,0000012 = VW Golf/Jetta (1K/5M) Right-Hand-Drive / Rest of World
C10,0000013 = VW Golf/Jetta (1K/5M) Left-Hand-Drive / North America
C11,0000014 = VW Touran (1T) Right-Hand-Drive
C12,0000015 = Seat Altea/Toledo (5P) and Leon (1P) Left-Hand-Drive
C13,0000016 = Seat Altea/Toledo (5P) and Leon (1P) Right-Hand-Drive
C14,
C15,Note: In case an Output Stage is being replaced the Subsystem/Slave
C16,cannot be coded directly. Instead recode the Headlight Aim Control
C17,Module with the current Coding this will also code the Subsystems.
; security access
S00,Cornering Lights Headlight Range Control (J745) Security Access
S01,15284 = Adaptation Enabling
; adaptation
A016,0,Tourist Solution
A016,5,Tourist Solution
A016,6,When driving in countries where driving is performed on the
A016,7,opposite side as in the native country the headlights must
A016,8,be changed over to avoid blinding the oncoming traffic.
A016,9,
A016,10,0 = Disabled
A016,11,1 = Enabled
; selective output test
T1540,Headlight Range Control: Adjusting to Lowered Position
T1541,Headlight Range Control: Adjusting to Raised Position
T2625,Headlight Range Control: Adjusting to Delivery Position
T2623,Dynamic Cornering Light: Adjusting to Center Position
T2941,Dynamic Cornering Light: Position Left
T2942,Dynamic Cornering Light: Position Right
T2947,Static Cornering Light Left: up/bright
T2948,Static Cornering Light Left: down/dim
T2949,Static Cornering Light Right: up/bright
T2950,Static Cornering Light Right: down/dim
T2952,Control Circuit for Curve Lighting Warning Light
Неее, параметрия это .xml файл, который через ODIS пишется в EEPROM, конкретного блока упр. это не прошивка, а характеристики работы системы...
