Помогите с расшифровками ошибок И диагнозом Polo 6R
  • Автор темы DEH
  • Ответы 4
DEH
user posted image
Питер
Tiguan DBG DSG7 4motion 2018 x 2
Приветствую!
Присматриваю еще машинку в семью! Сделал диагностику, чет много!
Кто в курсе насколько критично?
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Sporadic communication error 1000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine Labels: 03C-906-024-BXW.lbl
Part No SW: 03C 906 024 BJ HW: 03C 906 024 BH
Component: CGGB MM4HV 8997
Revision: --H09--- Serial number:
Coding: 0000077
Shop #: WSC 31414 790 31414
VCID: 67DD5D1755980F26359-5072
1 Fault Found:
28793 - No Communication with ABS Brake Control Module
U0121 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 127
Mileage: 18885 km
Time Indication: 0
Date: 2058.14.10
Time: 21:00:22
Freeze Frame:
Bin. Bits: 00000001
Load: 31.9 %
Lambda: 0.0 %
Speed: 0.0 km/h
Temperature: 32.0°C
Absolute Pres.: 401.6 mbar
RPM: 830 /min
Readiness: 0000 0000
Address 02: Auto Trans Labels: 0AM-300-04x.lbl
Part No SW: 0AM 300 052 A HW: 0AM 927 769 D
Component: GSG DSG AG7 431 2710
Revision: 00043014 Serial number: CU501107306437
Coding: 0000020
VCID: 29591B2F830CF956E3D-5000
1 Fault Found:
005995 - Gear Selector 2 Cannot be Regulated
P176B - 000 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 1
Mileage: 18528 km
Time Indication: 0
Date: 2057.14.30
Time: 11:56:58
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 6R0 907 379 AE HW: 6R0 907 379 AC
Component: ABS8.2 front H04 0001
Revision: --------
Coding: 200224E3016E00B9042E24E380D300000200
VCID: 8109E38F1CFC51161BD-80D4
No fault code found.
Address 08: Auto HVAC (J301) Labels: 6R0-820-045.clb
Part No SW: 6R0 820 045 G HW: 6R0 820 045 G
Component: Man AC 02 0101
Revision: 0002S 02
VCID: 326BFC436DDABA8E527-8067
2 Faults Found:
01316 - ABS Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 2
Reset counter: 127
Mileage: 18885 km
Time Indication: 0
Date: 2010.14.10
Time: 21:00:23
00819 - High Pressure Sensor (G65)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 143
Mileage: 19230 km
Time Indication: 0
Date: 2010.14.29
Time: 02:24:58
Freeze Frame:
Temperature: -1.0°C
Time: 5.90 s
Time: 0.00 s
Voltage: 11.20 V
Absolute Pres.: 0.0 bar
Time: 0.00 s
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 K HW: 6R0 937 087
Component: BCM PQ25 H+4 H46 0251
Revision: BF046001 Serial number: 0434 197110487
Coding: 24B02BBF08A10000003008002D2B0DD00040410F60060000200000000000
VCID: 4581B79FCC543D36E75-8010
Subsystem 1 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 008 1611
Coding: 18BC30
Subsystem 2 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 008 1611
Coding: 08BC30
Subsystem 3 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Coding: 08BC32
Subsystem 4 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Coding: 08BC32
3 Faults Found:
00447 - Function Limitation due to Over-Voltage
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 145
Time Indication: 0
00968 - Right Turn Signals
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 2
Fault Frequency: 254
Reset counter: 145
Mileage: 17507 km
Time Indication: 0
Date: 2056.14.31
Time: 21:29:17
00967 - Left Turn Signals
Freeze Frame:
Fault Priority: 2
Reset counter: 145
Mileage: 17507 km
Time Indication: 0
Date: 2056.14.31
Time: 21:29:17
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Component: VW10Airbag00G H08 0020
Revision: -------- Serial number: 003GW0004RUQ
Coding: 003047
ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
ROD: EV_AirbaVW10BPAVW250_VW24.rod
VCID: 4999BBAFE84CD95603D-801C
2 Faults Found:
12854016 - Implausible Data Received from Instrument Panel Control Module
U0423 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 19
Reset counter: 127
Mileage: 18885 km
Date: 2058.14.10
Time: 21:00:18
12656896 - No Communication with ABS Brake Control Module
U0121 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 127
Mileage: 18885 km
Date: 2058.14.10
Time: 21:00:22
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6R0 920 860 H HW: 6R0 920 860 H
Component: KOMBI H03 0505
Serial number: 00000000000000
Coding: 140E01
Shop #: WSC 31414 790 50316
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
VCID: 3979CB6FB8AC49D693D-806C
1 Fault Found:
13893888 - Function Restricted due to Exessive Voltage
U1401 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 145
Mileage: 0 km
Date: 2059.14.20
Time: 12:36:50
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 H46 0251
Revision: BF046001
Coding: 002200
VCID: F0EFB64B2356489EE43-80A5
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 127
Mileage: 18885 km
Time Indication: 0
Date: 2058.14.10
Time: 21:00:17
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 0505
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
ROD: EV_Immo_UDS_VDD_RM09_VN35.rod
VCID: EADBA4230D8AB24EAA7-80BF
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 10150
Shop #: WSC 31414
VCID: 2F6DF537EAE897663D9-807A
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 5M0 035 156 D HW: 5M0 035 156 D
Component: Radio 553 0555
Revision: R0553006 Serial number: VWZ5Z1L0558177
Coding: 0000020002
Shop #: WSC 00000 000 31414
VCID: 2A5BE423450AF24EEA7-807F
End ---------------------------------------------------------------------
Похоже на генератор (слишком высокая напруга), и/или жгут где перетёрся...
Ладно ок, сокращаем до минимума недающего мне спать
1 Fault Found:
Это в дсг, что это?
и
Кондей проверить возможности зимой нету
Проверить давление с системе кондиционирования,запустить компрессор.
Минус на улице, это бесполезно
