Ошибки 005697, 005488, 005705 и другие Не заводится Touran 2,0 TDI
Griga74
Россия
VW Touran 2.0 TDI 2008
Доброго дня! Помогите пожалуйста, утром машина не завелась и выдала "винегрет" ошибок:
005697 - Please check DTC Memory of A/C Controller
P1641 - 000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Mileage: 208320 km
Time Indication: 0
Date: 2000.00.00
Time: 17:59:17
Freeze Frame:
RPM: 798 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.21 V
Bin. Bits: 00101011
Temperature: 93.6°C
(no units): 0.0
005488 - Engine Start Blocked by Immobilizer
P1570 - 000 - - - MIL ON
Freeze Frame:
Fault Status: 11110000
Fault Priority: 1
Fault Frequency: 1
Mileage: 208320 km
Time Indication: 0
Date: 2000.00.00
Time: 07:13:16
Freeze Frame:
RPM: 1197 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.40 V
Bin. Bits: 00101100
Bin. Bits: 11000000
(no units): 33.0
005705 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 0
Reset counter: 0
Mileage: 0 km
Time Indication: 0
Date: 2000.00.00
Time: 07:16:11
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.93 V
Bin. Bits: 00101100
Torque: 0.0 Nm
Bin. Bits: 00000000
005685 - Powertrain Data Bus: Missing Message from A/C Controller
P1635 - 000 - - - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Mileage: 208320 km
Time Indication: 0
Date: 2000.00.00
Time: 07:16:12
Freeze Frame:
RPM: 0 /min
Speed: 3.0 km/h
Load: 0.0 %
Voltage: 11.93 V
Bin. Bits: 11101100
Bin. Bits: 00000000
(no units): 112.0
00985 - Right Tail Light (M2)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 155
Mileage: 207158 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.75 V
ON
ON
OFF
OFF
OFF
00156 - Control Circuit for Windshield Washer Pump
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 195
Mileage: 208320 km
Time Indication: 0
Freeze Frame:
Raw, Form. N/A: 000 000 135
Voltage: 11.80 V
ON
ON
OFF
OFF
OFF
02398 - Control Circuit for Rear Windshield Washer Pump
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 195
Mileage: 208320 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.80 V
ON
ON
OFF
OFF
OFF
00834 - Signal for Activation of Heated Rear Window
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 195
Mileage: 208320 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.80 V
ON
ON
OFF
OFF
OFF
02071 - Local Databus
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 195
Mileage: 208320 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.80 V
ON
ON
OFF
OFF
OFF
01321 - Control Module for Airbags (J234)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 195
Mileage: 208320 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.80 V
ON
ON
OFF
OFF
OFF
01314 - Engine Control Module
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 195
Mileage: 208320 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.80 V
ON
ON
OFF
OFF
OFF
00059 - Terminal 30 for Interior Lighting
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 195
Mileage: 208320 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.85 V
ON
OFF
OFF
OFF
OFF
01520 - Rain and Light Recognition Sensor (G397)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 195
Mileage: 208320 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.80 V
ON
ON
OFF
OFF
OFF
01309 - Power Steering Control Module (J500)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 195
Mileage: 208320 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.80 V
ON
ON
OFF
OFF
OFF
01316 - ABS Control Module
Freeze Frame:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 195
Mileage: 208320 km
Time Indication: 0
Date: 2000.00.00
Time: 07:16:12
01320 - Control Module for Climatronic (J255)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 195
Mileage: 208320 km
Time Indication: 0
Date: 2000.00.00
Time: 07:16:12
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 254
Mileage: 206364 km
Time Indication: 0
Date: 2000.00.00
Time: 10:36:10
00473 - Control Module for Elect. Park/Hand Brake (J540)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 82
Mileage: 206364 km
Time Indication: 0
Date: 2000.00.00
Time: 10:36:10
Это написано красным жирным вверху любой страницы каждой темы этого раздела.
Диагностика и неисправности
Правила раздела: В данном разделе форума обсуждаются проблемы связанные ТОЛЬКО с диагностикой систем впрыска двигателей, все остальные вопросы просьба обсуждать в соответствующих разделах. Темы с безсодержательным заголовком или без указания в заголовке кода ошибки или блинк-кода, будут без предупреждения перенесены в раздел "Оперативные вопросы". В заголовке темы пишите плз. полный (5-значный) код ошибки или 4-х значный блинк-код.
Читать правила https://vwts.ru/forum/faq/boardrules/
Читать Самые частые ошибки новичков https://vwts.ru/forum/topic/200350/
пункт два
Первый и последний раз название темы отредактировано так чтобы соответствовало правилам. Все последующие темы с несоответствующим правилам названием тем будут без всяких предупреждений перенесены в раздел "Оперативные вопросы"
Из всего букета ошибок первым разбираться с иммобилайзером.
1. зарядите\замените акб
2. устраните обрывы в электропроводке+выгоните мышей,пожравших проводку...или посушите авто ,как вариант.....авто промокло\ утонуло на рыбалке\забыли закрыть окна в дождь ...и тп...и п.д
