Admin
Создатель сайта
Команда форума
- Россия, Москва
- VW Tiguan 2.0 DBGC 2018, VW Touran 1.6 BSE 2008
Fuses of VW Tiguan I
Volkswagen Tiguan (model: 5N1) 2008 - 2011
Volkswagen Tiguan (model: 5N2) 2012 - 2016
Overview of fuses
1 - Fuses (SA) on fuse holder A
2 - Fuses (SB) on fuse holder B
3 - Fuses (SC) on fuse holder C, in driver's footwell
4 - Thermal fuse, in driver's footwell
Fitting location of fuses (SA) on E-box low, VW Tiguan from November 2007
Specified torque settings
1 - Fuse holder A -SA-
Fuse colours
200 A - purple
150 A - grey
125 A - pink
100 A - blue
80 A - white
70 A - brown
60 A - yellow
50 A - red
40 A - green
30 A - orange
Fuse assignment (SA) on E-box low, VW Tiguan from November 2007
Fitting location of fuses (SA) on E-box low, VW Tiguan from November 2008
Fuse colours
200 A - purple
150 A - grey
125 A - pink
100 A - blue
80 A - white
70 A - brown
60 A - yellow
50 A - red
40 A - green
30 A - orange
Fuse assignment (SA) on E-box low, VW Tiguan from November 2008
1) Depends on equipment
2) Only models with a 1.4l petrol engine
Fuse assignment (SA) on E-box low, VW Tiguan from May 2009
Fitting location of fuses (SA) on E-box low, VW Tiguan from May 2011
Fuse colours
Multifuse strip fuse
Note: The fuse strip (multifuse) must be replaced as a complete unit
Fuse assignment (SA) on E-box low, VW Tiguan from May 2011
1) Only models with a 1.4 l petrol engine
2) Only models with a 2.0 l engine
3) Depends on equipme
Fuse assignment (SA) on E-box low, VW Tiguan from November 2011
Fuses (SB) on E-box on left in engine compartment
Fuse assignment (SB) on E-box low, VW Tiguan from May 2009
1) According to equipment
2) Only models with a diesel engine
3) Only models with petrol engine
4) Only models with a 1.4l petrol engine
5) Only models with start/stop system
6) from November 2010
Fuses (SB) on E-box low on left in engine compartment, VW Tiguan from May 2011
Fuse colours
1 - Fuse holder B -SB-
50 A - red
40 A - orange
30 A - light green
25 A - natural (white)
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
3 A - purple
Fuse assignment for E-box low, VW Tiguan from May 2011
1) Depending on equipment
2) Only models with stop/start system
3) Only models with no stop/start system
4) Only models with a 2.0 l diesel engine
5) Only models with a 2.0 l petrol engine
6) Only models with 1.4 l petrol engine (CAXA)
7) from November 2011
Fuse colours
50 A - red
40 A - orange
30 A - light green
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
3 A - purple
Fuse assignment on fuse holder C, VW Tiguan from November 2007
1) To November 2008
2) from November 2008
1) from November 2008
1) To November 2008
Fuse colours
50 A - red
40 A - orange
30 A - light green
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
3 A - purple
Fuse assignment on fuse holder C, VW Tiguan from May 2009
1) From May 2010
2) up to May 2010
3) According to equipment
4) Only models with start/stop system
Electric cut-out in driver's footwell
A - Driver seat adjustment thermal fuse 1 -S44- 30A
1 - Relay and fuse carrier 1 -SR1-
A - not assigned
B - Front passenger seat adjustment thermal fuse 1 -S46- 30A
C - Driver seat adjustment thermal fuse 1 -S44- 30A
Relays of VW Tiguan
Overview of relay carriers
1 - Relay carrier on E-box
Main relay -J271-
Terminal 30 voltage supply relay -J317-
Additional coolant pump relay -J496-
Motronic current supply relay 2 -J670-
Engine component current supply relay -J757-
2 - Relay and fuse carrier 1 -SR1-
Dual tone horn relay -J4-
Heated rear window relay -J9-
Fresh air blower relay -J13-
Fuel pump relay -J17-
X-contact relief relay -J59-
Heated exterior mirror relay -J99-
High heat output relay -J360-
Terminal 15 voltage supply relay 2 -J681-
Terminal 50 voltage supply relay -J682-
Terminal 30 voltage supply relay 2 -J689-
Double washer pump relay 1 -J729-
Double washer pump relay 2 -J730-
Starter relay 1 -J906-
Starter relay 2 -J907-
3 - Relay and fuse carrier 2 -SR2-
Headlight washer system relay -J39-
Electric fuel pump 2 relay -J49-
Low heat output relay -J359-
Auxiliary heater operation relay -J485-
Alarm horn relay -J641-
Fuel pump relay for auxiliary heater -J749-
Relay for supplementary fuel pump -J832-
Trailer voltage supply relay -J941-
Relay for reducing agent metering system -J963-
Relay assignment on E-box low, VW Tiguan from November 2007
1 - Main relay -J271- (100)
Slot A1
1 - Terminal 30 voltage supply relay -J317- (100)
Slot A1
Only models with diesel engine
2 - Engine component current supply relay -J757- (100)
Slot A2
Relay assignment on E-box low, VW Tiguan from May 2011
R1 - Engine component current supply relay -J757-
Only models with 2.0l petrol engine
R1 - Additional coolant pump relay -J496-
Only models with a 1.4 l petrol engine (CAXA)
R1 - Connection bridge
R2 - Terminal 30 voltage supply relay -J317-
R2 - Main relay -J271-
Relay assignment, relay carrier on onboard supply control unit, in driver's footwell, VW Tiguan from November 2007
1 - Terminal 15 voltage supply relay 2, -J681-, (460)
Slot B1
2 - Heated exterior mirror relay -J99- (449)
Slot B2
3 - Heated rear window relay -J9- (53)
Slot B5
4 - Dual tone horn relay -J4- (449)
Slot B6
5 - X-contact relief relay -J59- (460)
Slot B9
6 - Double washer pump relay 2 -J730- (404)
Slot B8
7 - Double washer pump relay 1 -J729- (404)
Slot B7
8 - not assigned
Slot B3
9 - Terminal 30 voltage supply relay 2 -J689- (449)
Slot B4
Relay and fuse carrier 1 -SR1- , VW Tiguan from May 2009
D - Relay and fuse carrier 1 -SR1-
1 - not assigned
2 - not assigned
4 - X-contact relief relay -J59- (53)
5 - Terminal 15 voltage supply relay 2 -J681- (643)
Relay and fuse carrier 1 -SR1- , VW Tiguan from May 2010
1 - High heat output relay -J360- (644)
2 - X-contact relief relay -J59- (644)
3 - Terminal 50 voltage supply relay -J682- (644)
3 - Starter relay 1 -J906- (644)
4 - Fresh air blower relay -J13- (646)
5 - Starter relay 2 -J907- (507)
Relay and fuse carrier 1 -SR1- , VW Tiguan from May 2011
2 - X-contact relief relay -J59- (644)/(645)
3 - Terminal 50 voltage supply relay -J682- (644)/(645)
3 - Starter relay 1 -J906- (644)/(645)
For left-hand drive models only
4 - Fuel pump relay -J17- (646)
For right-hand drive models only
5 - Terminal 50 voltage supply relay -J682- (507)
Models with entry and start authorisation but no start/stop system only
Relay and fuse carrier 2 -SR2- , VW Tiguan from November 2007
1 - Auxiliary heater operation relay -J485- (53)
2 - not assigned
3 - Terminal 50 voltage supply relay -J682- (53)
4 - Fresh air blower relay -J13- (449)
5 - Alarm horn relay -J641- (449)
5 - Headlight washer system relay -J39- (449)
6 - High heat output relay -J360- (370)
7 - Fuel pump relay -J17- (449)
7 - Additional coolant pump relay -J496- (449)
7 - Fuel pump relay for auxiliary heater -J749- (449)
8 - Low heat output relay -J359- (53)
9 - Relay for supplementary fuel pump -J832- (449)
Note: On relay slots 4, 5, 7, and 9 there are double slots for mini relays
Relay and fuse carrier 2 -SR2- , VW Tiguan from May 2008
2 - not assigned
6 - Relay for supplementary fuel pump -J832- (449)
7 - Low heat output relay -J359- (53)
8 - Fuel pump relay -J17- (449)
8 - Additional coolant pump relay -J496- (449)
8 - Fuel pump relay for auxiliary heater -J749- (449)
9 - High heat output relay -J360- (370)
Note: On relay slots 4, 5, 6, and 8 there are double slots for mini relays
Relay and fuse carrier 2 -SR2- , from May 2009
2 - Terminal 50 voltage supply relay -J682- (53)
3 - not assigned
Slot 4/2
Slot 5/1
Slot 5/2
6 - Electric fuel pump 2 relay -J49- (449)
Slot 6/2
Slot 8/1
Slot 8/1
Slot 8/2
Relay and fuse carrier 2 -SR2- , VW Tiguan from May 2010
1 - Auxiliary heater operation relay -J485- (645)
2 - Electric fuel pump 2 relay -J49- (646)
3 - Terminal 15 voltage supply relay 2 -J681- (644)
4 - Heated rear window relay -J9- (645)
5 - Fuel pump relay -J17- (646)
5 - Additional coolant pump relay -J496- (646)
6 - Headlight washer system relay -J39- (646)
Slot 6/A
6 - Dual tone horn relay -J4- (646)
Slot 6/B
7 - Low heat output relay -J359- (645)
8 - Fuel pump relay for auxiliary heater -J749- (646)
9 - not assigned
Note: Relay slot 6 has a double-slot for mini-relays
Relay and fuse carrier 2 -SR2- , VW Tiguan from May 2011
1 - Low heat output relay -J359- (645)
2 - Fuel pump relay -J17- (646)
Slot 6/A
Slot 6/B
8 - not assigned
9 - not assigned
Relay and fuse carrier 2 -SR2- , VW Tiguan from November 2011
3 - Terminal 15 voltage supply relay 2 -J681- (645)
Slot 6/A
Slot 6/B
8 - not assigned
9 - not assigned
Relay and fuse carrier 2 -SR2- , VW Tiguan from May 2012
2 - Trailer voltage supply relay -J941- (646)
Not for models with a 1.4 l petrol engine (CAXA)
Slot 6/A
Slot 6/B
8 - Trailer voltage supply relay -J941- (646)
9 - not assigned
Relay and fuse carrier 2 -SR2- , VW Tiguan from May 2015
5 - Relay for reducing agent metering system -J963-
Slot 6/A
Slot 6/B
9 - not assigned
Overview of fuses
Fuse colours
200 A - purple
150 A - grey
125 A - pink
100 A - blue
80 A - white
70 A - brown
60 A - yellow
50 A - red
40 A - green
30 A - orange
| No. | Current flow diagram designation | Nominal value | Function/component | Terminal | ||
| 1 | - | SA1-Fuse 1 on fuse holder A | 150A 200A Metal strip | - - - | C-Alternator (90A/120A) C-Alternator (140A) C-Generator (180A), 200A fuse integrated in wiring harness | 30a |
| 2 | - | SA2-Fuse 2 on fuse holder A | 80A | - | J500-Power steering control unit V187-Electromechanical power steering motor | 30a |
| 3 | - | SA3-Fuse 3 on fuse holder A | 80A 50A 1) | - | J293-Radiator fan control unit V7-Radiator fan V177-Radiator fan 2 | 30a |
| 4 | - | SA4-Fuse 4 on fuse holder A | 40A 80A 1) | - | J359-Low heat output relay J360-High heat output relay1) Z35-Auxiliary air heater element | 30a |
| 5 | - | SA5-Fuse 5 on fuse holder A | 80A 100A | -- | SC20-SC20·-SC24,·SC42-SC52, fuses on fuse holder C in driver's footwell SC20-optional equipment, SC20-SC24, SC42-SC56, fuses on fuse holder C in driver's footwell | 30a |
| 6 | - | 508-Threaded connection (30), on E-box | - | - | Supply terminal 30 | 30 |
| 7 | - | SA6-Fuse 6 on fuse holder A | 40A 1) 80A | - | J359-Low heat output relay1) J360-High heat output relay Z35-Auxiliary air heater element | 30a |
| 8 | - | SA7-Fuse 7 on fuse holder A | 50A | - | J345-Trailer detector control unit/preparation for tow coupling | 30a |
Fuse colours
200 A - purple
150 A - grey
125 A - pink
100 A - blue
80 A - white
70 A - brown
60 A - yellow
50 A - red
40 A - green
30 A - orange
| 1 | - | SA1-Fuse 1 on fuse holder A | 150A 200A | - - - | C-Alternator (90A/120A) C-Alternator (140A) C-Generator (180A), 200A fuse integrated in wiring harness | 30a |
| 4 | - | SA4-Fuse 4 on fuse holder A | 80A | - | J293-Radiator fan control unit2) J360-High heat output relay1) Z35-Auxiliary air heater element | 30a |
| 6 | - | SA6-Fuse 6 on fuse holder A | 40A | - | J359-Low heat output relay1) Z35-Auxiliary air heater element | 30a |
| 7 | - | TV2-Terminal 30 wiring junction | - | - | 508-Threaded connection (30), on E-box | 30 |
| -SA1- | B | Fuse 1 on fuse holder A | 150A 200A 1) | - | Alternator -C- | 30a |
| -SA2- | C | Fuse 2 on fuse holder A | 80A | - | Power steering control unit -J500- Electromechanical power steering motor -V187- | 30a |
| -SA3- | E | Fuse 3 on fuse holder A | 80A 50A 1) | - | Radiator fan control unit -J293- Radiator fan -V7- Radiator fan 2 -V177- | 30a |
| -SA4- | H | Fuse 4 on fuse holder A | 80A | - | Radiator fan control unit -J293- 2) High heat output relay -J360- 1) Auxiliary air heater element -Z35- | 30a |
| -SA5- | D | Fuse 5 on fuse holder A | 80A | - | SC20 - SC24, SC43 - SC53, fuses on fuse holder C | 30a |
| -SA6- | F | Fuse 6 on fuse holder A | 40A | - | Low heat output relay -J359- 1) Auxiliary air heater element -Z35- | 30a |
| -TV2- | - | Terminal 30 wiring junction | - | - | 508 Threaded connection (30), on E-box | 30 |
| -SA7- | - | Fuse 7 on fuse holder A | 50A | - | Trailer detector control unit -J345- | 30a |
Fuse colours
| SA1 | B | Fuse 1 on fuse holder A -SA1- | 200A | Alternator -C- | 30a |
| SA2 | C | Fuse 2 on fuse holder A -SA2- | 80A | Power steering control unit -J500- | 30a |
| SA3 | G | Fuse 3 on fuse holder A -SA3- | 50A | Fuse 40 on fuse holder C -SC40- Trailer detector control unit -J345- | 30a |
| SA4 | E | Fuse 4 on fuse holder A -SA4- | 60A | Radiator fan control unit -J293- 2) | 30a |
| SA5 | D | Fuse 5 on fuse holder A -SA5- | 80A | Fuse holder C -SC- SC20 - SC24 SC43 - SC53 | 30a |
| 508 | 508 Threaded connection (30), on E-box | Terminal 30 wiring junction -TV2- | 30a | ||
| SA6 | H | Fuse 6 on fuse holder A -SA6- | 70A | Radiator fan control unit -J293- 1) High heat output relay -J360- 3) | 30a 30a |
| SA7 | - | Not assigned | - | - | |
| SA8 | F | Fuse 8 on fuse holder A -SA8- | 40A | Low heat output relay -J359- 3) | 30a |
| SA4 | E | Fuse 4 on fuse holder A -SA4- | 50A | Radiator fan control unit -J293- 2) | 30a |
| 508 | 508 Threaded connection (30), on E-box- | - | Terminal 30 wiring junction -TV2- | 30a | |
| F1 | - | Fuse 1 on fuse holder B -SB1- | - | - | -Vacant | - |
| F2 | - | Fuse 2 on fuse holder B -SB2- | - | - | -Vacant | - |
| F3 | - | Fuse 3 on fuse holder B -SB3- | 5A | - | Onboard supply control unit -J519- (T52a/24) | 30a |
| F4 | - | Fuse 4 on fuse holder B -SB4- | 30A | - | ABS control unit -J104- ABS hydraulic unit -N55- | 30a |
| F5 | - | Fuse 5 on fuse holder B -SB5- | - | - | -Vacant | - |
| F6 | - | Fuse 6 on fuse holder B -SB6- | 5A | - | Control unit in dash panel insert -J285- Steering column electronics control unit -J527- | 30a |
| F7 | - | Fuse 7 on fuse holder B -SB7- | 40A | - | Terminal 15 voltage supply relay 2 -J681- | 30a |
| F8 | - | Fuse 8 on fuse holder B -SB8- | 25A | - | Control unit with display for radio and navigation -J503- Radio -R TV tuner -R78- 1) Satellite digital radio tuner -R190- Multimedia system control unit -J650- | 30a |
| F8 | - | Fuse 8 on fuse holder B -SB8- 5) | 25A | - | Voltage stabiliser -J532- 5) | 30a |
| F9 | - | Fuse 9 on fuse holder B -SB9- | 5A | - | Mobile telephone operating electronics control unit -J412- | 30a |
| F10 | - | Fuse 10 on fuse holder B -SB10- | 5A 1) 10A 1) | -- | Terminal 30 voltage supply relay -J317- Engine control unit -J623- | 30a |
| F11 | - | Fuse 11 on fuse holder B -SB11- | 20A 30A 6) | - | Auxiliary heater control unit -J364- | 30a |
| F12 | - | Fuse 12 on fuse holder B -SB12- | 5A | - | Data bus diagnostic interface -J533- | 30a |
| F13 | - | Fuse 13 on fuse holder B -SB13- | 15A 30A 2) | - | Engine control unit -J623- | 87a |
| F14 | - | Fuse 14 on fuse holder B -SB14- | 20A | - | Fuel pressure regulating valve -N276- Fuel metering valve -N290- Ignition coil 1 with output stage -N70- Ignition coil 2 with output stage -N127- Ignition coil 3 with output stage -N291- Ignition coil 4 with output stage -N292- Magnetic clutch for supercharger -N421- Lambda probe heater -Z19- Lambda probe 1 heater after catalytic converter -Z29- Fuel system diagnostic pump -V144- Fuel pump relay -J17- Automatic glow period control unit -J179- Electric fuel pump 2 relay -J49- | 87a |
| F15 | - | Fuse 15 on fuse holder B -SB15- | 10A 1) 15A 1) 5A 2) | 87a | ||
| F16 | - | Fuse 16 on fuse holder B -SB16- | 30A | - | Onboard supply control unit -J519- (T52c/42) | 30a |
| F17 | - | Fuse 17 on fuse holder B -SB17- | 15A | - | Alarm horn relay -J641- | 30a |
| F18 | - | Fuse 18 on fuse holder B -SB18- | 30A | - | Digital sound package amplifier -R184- | 30a |
| F19 | - | Fuse 19 on fuse holder B -SB19- | 30A | - | Wiper motor control unit -J400- | 30a |
| F20 | - | Fuse 20 on fuse holder B -SB20- | 10A 15A 6) | - | Fuel pressure regulating valve -N276- Coolant circulation pump -V50- 1) | 87a |
| F21 | - | Fuse 21 on fuse holder B -SB21- | 10A 2) 20A 3) | - | Lambda probe heater -Z19- Fuel pump control unit -J538- | 87a |
| F22 | - | Fuse 22 on fuse holder B -SB22- | 5A | - | Clutch position sender -G476- | 87a |
| F23 | - | Fuse 23 on fuse holder B -SB23- | 10A | - | Charge pressure control solenoid valve -N75- Exhaust gas recirculation cooler changeover valve -N345- Fuel pressure regulating valve -N276- 4) Air mass meter -G70- 1) | 87a |
| F24 | - | Fuse 24 on fuse holder B -SB24- | 10A | - | Radiator fan control unit -J293- Low heat output relay -J359- High heat output relay -J360- Additional coolant pump relay -J496- Motronic current supply relay 2 -J670- Charge pressure control solenoid valve -N75- Activated charcoal filter solenoid valve 1 -N80- Camshaft control valve 1 -N205- Turbocharger air recirculation valve -N249- Intake manifold flap valve -N316- Coolant circulation pump 2 -V178- Coolant circulation pump -V50- Fuel pump relay -J17- 1) | 87a |
| F25 | - | Fuse 25 on fuse holder B -SB25- | 40A | - | ABS control unit -J104- | 30a |
| F26 | - | Fuse 26 on fuse holder B -SB26- | 30A | - | Onboard supply control unit -J519- (T52a/1) | 30a |
| F27 | - | Fuse 27 on fuse holder B -SB27- | - | - | -Vacant | - |
| F28 | - | Fuse 28 on fuse holder B -SB28- | 50A | - | Automatic glow period control unit -J179- | 30a |
| F29 | - | Fuse 29 on fuse holder B -SB29- | 50A | - | Driver seat adjustment thermal fuse 1 -S44- Fuse 54 on fuse holder C -SC54- Fuse 55 on fuse holder C -SC55- Fuse 56 on fuse holder C -SC56- Fuse 57 on fuse holder C -SC57- | 30a |
| F30 | - | Fuse 30 on fuse holder B -SB30- | 50A | - | X-contact relief relay -J59- | 30a |
Fuse colours
50 A - red
40 A - orange
30 A - light green
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
3 A - purple
| F1 | - | Fuse 1 on fuse holder B -SB1- | 15A | Mechatronic unit for dual clutch gearbox -J743- | Kl.30 |
| F2 | - | Fuse 2 on fuse holder B -SB2- | 30A | ABS control unit -J104- Valves | Terminal 30 |
| F3 | - | Fuse 3 on fuse holder B -SB3- | 15A | Dual tone horn relay -J4- | Terminal 30 |
| F4 | - | Fuse 4 on fuse holder B -SB4- | not assigned | ||
| F5 | - | Fuse 5 on fuse holder B -SB5- | 5A | Onboard supply control unit -J519- Kl.30_REF Battery monitor control unit -J367- 2) | Terminal 30 |
| F6 | - | Fuse 6 on fuse holder B -SB6- | not assigned | ||
| F7 | - | Fuse 7 on fuse holder B -SB7- | 25A | Voltage stabiliser -J532- 2) Control unit with display for radio and navigation -J503- 3) Multimedia system control unit -J650- | Terminal 30 |
| F8 | - | Fuse 8 on fuse holder B -SB8- | 40A | Terminal 15 voltage supply relay 2 -J681- | Terminal 30 |
| F9 | - | Fuse 9 on fuse holder B -SB9- | not assigned | ||
| F10 | - | Fuse 10 on fuse holder B -SB10- | 5A | Lambda probe heater -Z19- Lambda probe 1 heater after catalytic converter -Z29- Magnetic clutch for supercharger -N421- 1) Fuel system diagnostic pump -V144- 1) Automatic glow period control unit -J179- 4) | Terminal 87 |
| F11 | - | Fuse 11 on fuse holder B -SB11- | 5A | Control unit in dash panel insert -J285- 3) Steering column electronics control unit -J527- 3) | Terminal 30 |
| F12 | - | Fuse 12 on fuse holder B -SB12- | 5A | Mobile telephone operating electronics control unit -J412- | Terminal 30 |
| F13 | - | Fuse 13 on fuse holder B -SB13- | 10A 5) 5A | Engine control unit -J623- Terminal 30 voltage supply relay -J317- | Terminal 30 |
| F14 | - | Fuse 14 on fuse holder B -SB14- | 30A 4) 15A | Engine control unit -J623- | Terminal 87 |
| F15 | - | Fuse 15 on fuse holder B -SB15- | 5A | Data bus diagnostic interface -J533- | Terminal 30 |
| F16 | - | Fuse 16 on fuse holder B -SB16- | 10A | Charge pressure control solenoid valve -N75- 4) Exhaust gas recirculation cooler changeover valve -N345- 4) Air mass meter -G70- 4) Fuel pressure regulating valve -N276- | Kl.87 |
| F17 | - | Fuse 17 on fuse holder B -SB17- | 10A 15A | Coolant circulation pump -V50- 4) Fuel pressure regulating valve -N276- 5) | Terminal 30 Terminal 30 |
| F18 | - | Fuse 18 on fuse holder B -SB18- | 10A 20A | Lambda probe heater -Z19- 4) Fuel pump control unit -J538- 1) | Terminal 87 Terminal 87 |
| F19 | - | Fuse 19 on fuse holder B -SB19- | 30A | Digital sound package amplifier -R184- | Terminal 30 |
| F20 | - | Fuse 20 on fuse holder B -SB20- | 5A | Clutch position sender -G476- | Terminal 87 |
| F21 | - | Fuse 21 on fuse holder B -SB21- | 30A | Auxiliary heater control unit -J364- | Terminal 30 |
| F22 | - | Fuse 22 on fuse holder B -SB22- | 30A | Wiper motor control unit -J400- | Terminal 30 |
| F23 | - | Fuse 23 on fuse holder B -SB23- | 10A | High heat output relay -J360- Low heat output relay -J359- Fuel pump relay -J17- Coolant circulation pump 2 -V178- Radiator fan control unit -J293- Electric fuel pump 2 relay -J49- Charge pressure control solenoid valve -N75- Turbocharger air recirculation valve -N249- Activated charcoal filter solenoid valve 1 -N80- Camshaft control valve 1 -N205- Intake manifold flap valve -N316- Motronic current supply relay 2 -J670- Brake light switch -F- 7) | Terminal 87 |
| F24 | - | Fuse 24 on fuse holder B -SB24- | 20A 15A 4) | Ignition coil 1 with output stage -N70- Ignition coil 2 with output stage -N127- Ignition coil 3 with output stage -N291- Ignition coil 4 with output stage -N292- Fuel metering valve -N290- 4) Fuel pressure regulating valve -N276- 4) | Terminal 87 Terminal 87 |
| F25 | - | Fuse 25 on fuse holder B -SB25- | 30A | Onboard supply control unit -J519- Kl.30_rechts | Terminal 30 |
| F26 | - | Fuse 26 on fuse holder B -SB26- | 30A | Onboard supply control unit -J519- Kl.30_links | Terminal 30 |
| F27 | - | Fuse 27 on fuse holder B -SB27- | 50A | X-contact relief relay -J59- | Terminal 30 |
| F28 | - | Fuse 28 on fuse holder B -SB28- | 50A | Automatic glow period control unit -J179- | Terminal 30 |
| F29 | - | Fuse 29 on fuse holder B -SB29- | 50A | Driver seat adjustment thermal fuse 1 -S44- Fuse 54 on fuse holder C -SC54- Fuse 55 on fuse holder C -SC55- Fuse 56 on fuse holder C -SC56- Fuse 57 on fuse holder C -SC57- | Terminal 30 |
| F30 | - | Fuse 30 on fuse holder B -SB30- | 40A | ABS control unit -J104- Pump | Terminal 30 |
Fuse colours
50 A - red
40 A - orange
30 A - light green
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
3 A - purple
| 1 | - | SC1-Fuse 1 on fuse holder C | - | - | - Not assigned | - |
| 2 | - | SC2-Fuse 2 on fuse holder C | - | - | - Not assigned | - |
| 3 | - | SC3-Fuse 3 on fuse holder C | - | - | - Not assigned | - |
| 4 | - | SC4-Fuse 4 on fuse holder C | - | - | - Not assigned | - |
| 5 | - | SC5-Fuse 5 on fuse holder C | - | - | - Not assigned | - |
| 6 | - | SC6-Fuse 6 on fuse holder C | - | - | - Not assigned | - |
| 7 | - | SC7-Fuse 7 on fuse holder C | - | - | - Not assigned | - |
| 8 | - | SC8-Fuse 8 on fuse holder C | - | - | - Not assigned | - |
| 9 | - | SC9-Fuse 9 on fuse holder C | 5A | - | K145-Front passenger front airbag deactivated warning lamp J234-Airbag control unit | 15a |
| 10 | - | SC10-Fuse 10 on fuse holder C | 10A | - | J492-All-wheel drive control unit | 15a |
| 11 | - | SC11-Fuse 11 on fuse holder C | 5A | - | J446-Parking aid control unit J791-Park assist steering control unit | 15a |
| 12 | - | SC12-Fuse 12 on fuse holder C | 10A | - | J667-Power output module for left headlight | 15a |
| 13 | - | SC13-Fuse 13 on fuse holder C | 5A | - | E256-Button for TCS and electronic stabilisation program E492-Tyre Pressure Loss Indicator button E540-AUTO HOLD button E598-Driving program button F4-Reversing light switch G65-High-pressure sender G238-Air quality sensor G266-Oil level and oil temperature sender J255-Climatronic control unit J706-Seat occupied recognition control unit (only airbag systems for USA/ Canada) K237-AUTOHOLD warning lamp Y7-Automatic anti-dazzle interior mirror Z20-Left washer jet heater element Z21-Right washer jet heater element | 15a |
| 14 | - | SC14-Fuse 14 on fuse holder C | 10A | - | E1-Light switch F-Brake light switch F47-Brake pedal switch F189-Tiptronic switch J104-ABS control unit J250-Electronically controlled damping control unit J255-Climatronic control unit (E94/E95 - heated seats regulator) J285-Control unit in dash panel insert J301-Air conditioning system control unit (E94/E95·-·heated seats regulator) J345-Trailer detector control unit/ preparation trailer operation J533-Data bus diagnostic interface J500-Power steering control unit J623-Engine control unit | 15a |
| 15 | - | SC15-Fuse 15 on fuse holder C | 10A | - | E102-Headlight range control regulator G70-Air mass meter (CBAA, CBAB, CBBA, BXDB) J485-Auxiliary heater operation relay J540-Control unit for electromechanical parking brake J745-Control unit for bend lighting and headlight range control V48-Headlight range control motor V49-Right headlight range control motor | 15a |
| 16 | - | SC16-Fuse 16 on fuse holder C | 10A | - | J668-Power output module for right headlight | 15a |
| 17 | - | SC17-Fuse 17 on fuse holder C | - | - | -Vacant | - |
| 18 | - | SC18-Fuse 18 on fuse holder C | - | - | -Vacant | - |
| 19 | - | SC19-Fuse 19 on fuse holder C | - | - | -Vacant | - |
| 20 | - | SC20-Fuse 20 on fuse holder C | 5A | - | F189-Tiptronic switch J104-ABS control unit J217-Automatic gearbox control unit J255-Climatronic control unit J301-Air conditioning system control unit R149-Remote control receiver for auxiliary coolant heater SC57-Supply for fuse 57 on fuse holder C1) SC58-Supply for fuse 58 on fuse holder C2) | 30a |
| 21 | - | SC21-Fuse 21 on fuse holder C | 7.5A | - | J519-Onboard supply control unit V59-Windscreen and rear window washer pump | 30a |
| 22 | - | SC22-Fuse 22 on fuse holder C | 5A | - | G273-Interior monitoring sensor H12-Alarm horn J641-Alarm horn relay (USA/Canada/Mexico) | 30a |
| 23 | - | SC23-Fuse 23 on fuse holder C | 10A | - | E1-Light switch E538-Electromechanical parking brake button G197-Magnetic field sender for compass G397-Rain and light detection sensor J772-Reversing camera system control unit T16-Diagnostic connection | 30a |
| 24 | - | SC24-Fuse 24 on fuse holder C | 10A | - | J386-Driver door control unit (window regulator) J387-Front passenger door control unit (window regulator) | 30a |
| 25 | - | SC25-Fuse 25 on fuse holder C | 20A | - | F125-Multifunction switch J217-Automatic gearbox control unit | 30a |
| 26 | - | SC26-Fuse 26 on fuse holder C | - | - | -Vacant | - |
| 27 | - | SC27-Fuse 27 on fuse holder C | - | - | -Vacant | - |
| 28 | - | SC28-Fuse 28 on fuse holder C | 15A | - | V12-Rear window wiper motor | 75a |
| 29 | - | SC29-Fuse 29 on fuse holder C | 15A | - | J730-Dual washer pump relay | 75a |
| 30 | - | SC30-Fuse 30 on fuse holder C | 20A | - | J29-Blocking diode U1-Cigarette lighter U5-12V socket U18-12V socket 2 U19-12V socket 3 | 75a |
| 31 | - | SC31-Fuse 31 on fuse holder C | - | - | -Vacant | - |
| 32 | - | SC32-Fuse 32 on fuse holder C | - | - | -Vacant | - |
| 33 | - | SC33-Fuse 33 on fuse holder C | 40A | - | E9-Fresh air blower switch J485-Auxiliary heater operation relay | 75a |
| 34 | - | SC34-Fuse 34 on fuse holder C | - | - | -Vacant | - |
| 35 | - | SC35-Fuse 35 on fuse holder C | - | - | -Vacant | - |
| 36 | - | SC36-Fuse 36 on fuse holder C | 30 A¹) | - | U13 - DC/AC converter with socket, 12 V - 230 V1) | 30a |
| 37 | - | SC37-Fuse 37 on fuse holder C | 15 A¹) | - | E176-Driver seat lumbar support adjustment switch1) | 30a |
| 38 | - | SC38-Fuse 38 on fuse holder C | 15 A¹) | - | J250-Electronically controlled damping control unit1) | 30a |
| 39 | - | SC39-Fuse 39 on fuse holder C | 15A | - | J345-Trailer detector control unit/ preparation trailer operation | 30a |
| 40 | - | SC40-Fuse 40 on fuse holder C | 15A | - | J345-Trailer detector control unit/ preparation trailer operation | 30a |
| 41 | - | SC41-Fuse 41 on fuse holder C | 20A | - | J345-Trailer detector control unit/ preparation trailer operation | 30a |
| 42 | - | SC42-Fuse 42 on fuse holder C | 25A | - | J245-Sliding sunroof adjustment control unit | 30a |
| 43 | - | SC43-Fuse 43 on fuse holder C | 20A | - | J540-Control unit for electromechanical parking brake | 30a |
| 44 | - | SC44-Fuse 44 on fuse holder C | 25A | - | J13-Fresh air blower relay J519-Onboard supply control unit (heated rear window) | 30a |
| 45 | - | SC45-Fuse 45 on fuse holder C | 30A | - | J386-Driver door control unit (window regulator) J387-Front passenger door control unit (window regulator) | 30a |
| 46 | - | SC46-Fuse 46 on fuse holder C | 30A | - | J388-Rear left door control unit (window regulator) J389-Rear right door control unit (window regulator) | 30a |
| 47 | - | SC47-Fuse 47 on fuse holder C | 15A | - | J17-Fuel pump relay J832-Relay for supplementary fuel pump J749-Fuel pump relay for auxiliary heater | 30a |
| 48 | - | SC48-Fuse 48 on fuse holder C | 15A | - | J388-Left rear door control module (central locking) J389-Rear right door control unit (central locking) J393-Convenience system central control unit | 30a |
| 49 | - | SC49-Fuse 49 on fuse holder C | 20A | - | J540-Control unit for electromechanical parking brake | 30a |
| 50 | - | SC50-Fuse 50 on fuse holder C | 40A | - | J126-Fresh air blower control unit | 30a |
| 51 | - | SC51-Fuse 51 on fuse holder C | 30A | - | J774-Heated front seats control unit | 30a |
| 52 | - | SC52-Fuse 52 on fuse holder C | 20A | - | J39-Headlight washer system relay | 30a |
| 53 | - | SC53-Fuse 53 on fuse holder C | 30A 1) | - | U13 - DC/AC converter with socket, 12 V - 230 V1) | 30a |
| 54 | - | SC54-Fuse 54 on fuse holder C | 15A 1) | - | E176-Driver seat lumbar support adjustment switch1) E177-Front passenger seat lumbar support adjustment switch1) | 30a |
| 55 | - | SC55-Fuse 55 on fuse holder C | 15A1) | - | J250-Electronically controlled damping control unit1) | 30a |
| 56 | - | SC56-Fuse 56 on fuse holder C | 25A 1) | - | J394-Sunroof roller blind control unit1) | 30a |
| 57 | - | SC57-Fuse 57 on fuse holder C | 1A 1) 25A 2) | - | K226-Trailer towing attachment locked warning lamp¹) J394-Sunroof roller blind control unit2) | 30a |
| 58 | - | SC58-Fuse 58 on fuse holder C | 1A 2) | - | K226-Trailer towing attachment locked warning lamp2) | 30a |
Fuse colours
50 A - red
40 A - orange
30 A - light green
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
3 A - purple
| 1 | - | Fuse 1 on fuse holder C -SC1- | - | - | -Vacant | - |
| 2 | - | Fuse 2 on fuse holder C -SC2- | - | - | -Vacant | - |
| 3 | - | Fuse 3 on fuse holder C -SC3- | - | - | -Vacant | - |
| 4 | - | Fuse 4 on fuse holder C -SC4- | - | - | -Vacant | - |
| 5 | - | Fuse 5 on fuse holder C -SC5- | - | - | -Vacant | - |
| 6 | - | Fuse 6 on fuse holder C -SC6- | - | - | -Vacant | - |
| 7 | - | Fuse 7 on fuse holder C -SC7- | - | - | -Vacant | - |
| 8 | - | Fuse 8 on fuse holder C -SC8- | - | - | -Vacant | - |
| 9 | - | Fuse 9 on fuse holder C -SC9- | 5A | - | Front passenger airbag deactivated warning lamp -K145- Airbag control unit -J234- | 15a |
| 10 | - | Fuse 10 on fuse holder C -SC10- | 10A | - | All-wheel drive control unit -J492- | 15a |
| 11 | - | Fuse 11 on fuse holder C -SC11- | 5A | - | Parking aid control unit -J446- Park assist steering control unit -J791- | 15a |
| 12 | - | Fuse 12 on fuse holder C -SC12- | 10A | - | Left gas discharge bulb control unit -J343- | 15a |
| 13 | - | Fuse 13 on fuse holder C -SC13- | 5A | - | TCS and ESP button -E256- Tyre Pressure Loss Indicator button -E492- Driving program button -E598- Auto-hold button -E540- Reversing light switch -F4- High-pressure sender -G65- Air quality sensor -G238- Oil level and oil temperature sender -G266- Climatronic control unit -J255- Seat occupied recognition control unit -J706- Auto-hold warning lamp -K237- Automatic anti-dazzle interior mirror -Y7- Left washer jet heater element -Z20- Right washer jet heater element -Z21- | 15a |
| 14 | - | Fuse 14 on fuse holder C -SC14- | 10A | - | Light switch -E1- Brake light switch -F Tiptronic switch -F189- ABS control unit -J104- Electronically controlled damping control unit -J250- Climatronic control unit -J255- 2) Control unit in dash panel insert -J285- Air conditioning system control unit -J301- 2) Trailer detector control unit -J345- Data bus diagnostic interface -J533- Power steering control unit -J500- Engine control unit -J623- Heater control unit -J162- 1) Control unit for vehicle location system -J895- 1) | 15a |
| 15 | - | Fuse 15 on fuse holder C -SC15- | 10A | - | Switch and instrument illumination regulator -E20- Air mass meter -G70- Auxiliary heater operation relay -J485- Control unit for electromechanical parking brake -J540- Control unit for cornering light and headlight range control -J745- Heater element for crankcase breather -N79- Diagnostic connection -U31- Left headlight range control motor -V48- Right headlight range control motor -V49- | 15a |
| 16 | - | Fuse 16 on fuse holder C -SC16- | 10A | - | Right gas discharge bulb control unit -J344- | 15a |
| 17 | - | Fuse 17 on fuse holder C -SC17- | 5A | - | Control unit in dash panel insert -J285- 4) | 30a |
| 18 | - | Fuse 18 on fuse holder C -SC18- | 10A | - | Multimedia system control unit -J650- 4) Mobile telephone operating electronics control unit -J412- 4) Magnetic field sender for compass -G197- 4) | 30a |
| 19 | - | Fuse 19 on fuse holder C -SC19- | 10A | - | Steering column electronics control unit -J527- 4) | 30a |
| 20 | - | Fuse 20 on fuse holder C -SC20- | 5A | - | Tiptronic switch -F189- ABS control unit -J104- Automatic gearbox control unit -J217- Climatronic control unit -J255- 2) Air conditioning system control unit -J301- Remote control receiver for auxiliary coolant heater -R149- Heated rear window relay -J9- Alarm horn relay -J641- Heater control unit -J162- 1) Fuse 58 on fuse holder C -SC58- | 30a |
| 21 | - | Fuse 21 on fuse holder C -SC21- | 15A | - | Onboard supply control unit -J519- (T52b/1) Rear left door control unit -J388- Rear right door control unit -J389- Windscreen and rear window washer pump -V59- | 30a |
| 22 | - | Fuse 22 on fuse holder C -SC22- | 5A | - | Interior monitoring sensor -G273- Alarm horn -H12- Onboard supply control unit -J519- (T52c/1) | 30a |
| 23 | - | Fuse 23 on fuse holder C -SC23- | 10A | - | Light switch -E1- Electromechanical parking brake button -E538- Magnetic field sender for compass -G197- Rain and light sensor -G397- Reversing camera system control unit -J772- Diagnostic connection -U31- Entry and start authorisation control unit -J518- 1) Control unit for vehicle location system -J895- 1) Voltage stabiliser -J532- 4) 1) | 30a |
| 24 | - | Fuse 24 on fuse holder C -SC24- | 10A | - | Driver door control unit -J386- Front passenger door control unit -J387- | 30a |
| 25 | - | Fuse 25 on fuse holder C -SC25- | 20A | - | Multifunction switch -F125- Automatic gearbox control unit -J217- Mechatronic unit for dual clutch gearbox -J743- 3) | 30a |
| 26 | - | Fuse 26 on fuse holder C -SC26- | - | - | -Vacant | - |
| 27 | - | Fuse 27 on fuse holder C -SC27- | - | - | -Vacant | - |
| 28 | - | Fuse 28 on fuse holder C -SC28- | 40A | - | Auxiliary heater operation relay -J485- Air conditioning system control unit -J301- | 75a |
| 29 | - | Fuse 29 on fuse holder C -SC29- | 15A | - | Rear window wiper motor -V12- | 75a |
| 30 | - | Fuse 30 on fuse holder C -SC30- | - | - | -Vacant | - |
| 31 | - | Fuse 31 on fuse holder C -SC31- | 20A | - | Blocking diode -J29- Cigarette lighter -U1- 12 V socket -U5- 12 V socket 2 -U18- 12 V socket 3 -U19- | 75a |
| 32 | - | Fuse 32 on fuse holder C -SC32- | - | - | -Vacant | - |
| 33 | - | Fuse 33 on fuse holder C -SC33- | - | - | -Vacant | - |
| 34 | - | Fuse 34 on fuse holder C -SC34- | - | - | -Vacant | - |
| 35 | - | Fuse 35 on fuse holder C -SC35- | - | - | -Vacant | - |
| 36 | - | Fuse 36 on fuse holder C -SC36- | - | - | -Vacant | - |
| 37 | - | Fuse 37 on fuse holder C -SC37- | - | - | -Vacant | - |
| 38 | - | Fuse 38 on fuse holder C -SC38- 1) | 10A | - | Control unit for electronic steering column lock -J764- 1) | 30a |
| 39 | - | Fuse 39 on fuse holder C -SC39- 1) | 20A | - | Headlight washer system relay -J39- 1) | 30a |
| 40 | - | Fuse 40 on fuse holder C -SC40- | 15A | - | Trailer detector control unit -J345- | 30a |
| 41 | - | Fuse 41 on fuse holder C -SC41- | 15A | - | Trailer detector control unit -J345- | 30a |
| 42 | - | Fuse 41 on fuse holder C -SC42- | 20A | - | Trailer detector control unit -J345- | 30a |
| 43 | - | Fuse 43 on fuse holder C -SC43- | 25A | - | Sliding sunroof adjustment control unit -J245- | 30a |
| 44 | - | Fuse 44 on fuse holder C -SC44- | 25A | - | Control unit for electromechanical parking brake -J540- | 30a |
| 45 | - | Fuse 45 on fuse holder C -SC45- | 25A | - | Fresh air blower relay -J13- Heated rear window relay -J9- | 30a |
| 46 | - | Fuse 46 on fuse holder C -SC46- | 30A | - | Driver door control unit -J386- Front passenger door control unit -J387- | 30a |
| 47 | - | Fuse 47 on fuse holder C -SC47- | 30A | - | Driver door control unit -J386- Rear right door control unit -J389- | 30a |
| 48 | - | Fuse 48 on fuse holder C -SC48- | 15A | - | Fuel pump relay -J17- Fuel pump relay for auxiliary heater -J749- Electric fuel pump 2 relay -J49- | 30a |
| 49 | - | Fuse 49 on fuse holder C -SC49- | 20A | - | Onboard supply control unit -J519- (T52b/42) | 30a |
| 50 | - | Fuse 50 on fuse holder C -SC50- | 25A | - | Control unit for electromechanical parking brake -J540- | 30a |
| 51 | - | Fuse 51 on fuse holder C -SC51- | 40A | - | Fresh air blower control unit -J126- | 30a |
| 52 | - | Fuse 52 on fuse holder C -SC52- | 30A | - | Heated front seats control unit -J774- | 30a |
| 53 | - | Fuse 53 on fuse holder C -SC53- | 20A 30A1) | - | Headlight washer system relay -J39- .2) Fuse 38 on fuse holder C -SC38- 1) Fuse 39 on fuse holder C -SC39- 1) | 30a |
| 54 | - | Fuse 54 on fuse holder C -SC54- | 30A | - | DC/AC converter with socket, 12 V - 230 V -U13- | 30a |
| 55 | - | Fuse 55 on fuse holder C -SC55- | 15A | - | Driver seat lumbar support adjustment switch -E176- | 30a |
| 56 | - | Fuse 56 on fuse holder C -SC56- | 15A | - | Electronically controlled damping control unit -J250- | 30a |
| 57 | - | Fuse 57 on fuse holder C -SC57- | 25A | - | Sunroof roller blind control unit -J394- | 30a |
| 58 | - | Fuse 58 on fuse holder C -SC58- | 1A | - | Towing bracket locked warning lamp -K226- | 30a |
| 59 | - | Fuse 59 on fuse holder C -SC59- | 20A | - | Control unit with display for radio and navigation -J503- 1) 4) | 30a |
| 60 | - | Fuse 60 on fuse holder C -SC60- | - | - | -Vacant | - |
2) up to May 2010
A - not assigned
Relays of VW Tiguan
Main relay -J271-
Slot A1
Slot A1
Slot A2
Slot B1
Slot B2
Slot B5
Slot B6
Slot B9
Slot B8
Slot B7
8 - not assigned
Slot B3
Slot B4
1 - not assigned
2 - not assigned
2 - not assigned
2 - not assigned
3 - not assigned
Slot 4/2
Slot 5/1
Slot 5/2
Slot 6/2
Slot 8/1
Slot 8/1
Slot 8/2
Slot 6/A
Slot 6/B
9 - not assigned
Slot 6/A
Slot 6/B
8 - not assigned
9 - not assigned
Slot 6/A
Slot 6/B
8 - not assigned
9 - not assigned
Slot 6/A
Slot 6/B
9 - not assigned
Slot 6/A
Slot 6/B
9 - not assigned
