Alex_2003
После замены клапанов на холодную появляются ошибки, подскажите куда смотреть?
Address 01: Engine Labels: None
Part No SW: 06F 906 056 GN HW: 06F 906 056 EK
Component: MED9.5.10 G00 0184
Revision: 69H04--- Serial number: VWZCZ000000000
Coding: 0000072
Shop #: WSC 00028 028 00001
VCID: 7BFEF5B205BF76C4
2 Faults Found
000833 - Camshaft Position Sensor (G40): Implausible Signal
P0341 - 004 - No Signal/Communication - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100100
Fault Priority: 0
Fault Frequency: 3
Mileage: 178852 km
Time Indication: 0
Date: 2014.11.25
Time: 14:07:17
Freeze Frame:
RPM: 1120 /min
Load: 45.1 %
Speed: 0.0 km/h
Temperature: -12.0°C
000022 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28): Incorrect Correlation
P0016 - 002 - Lower Limit Exceeded - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 0
Fault Frequency: 1
Mileage: 178856 km
Time Indication: 0
Date: 2014.11.25
Time: 16:10:55
Freeze Frame:
RPM: 720 /min
Load: 26.7 %
Speed: 0.0 km/h
Temperature: 50.0°C
Readiness: 1110 0001
Coding: 0000072
2 Faults Found
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Mileage: 178852 km
Time Indication: 0
Date: 2014.11.25
Time: 14:07:17
Freeze Frame:
RPM: 1120 /min
Load: 45.1 %
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 178856 km
Time Indication: 0
Date: 2014.11.25
Time: 16:10:55
Freeze Frame:
RPM: 720 /min
Load: 26.7 %
Speed: 0.0 km/h
Temperature: 50.0°C
