00955 - Key 1
00955 - Key 1: Adaptation Limit Surpassed
Possible Symptoms
Key/Remote Control not operational
Possible Causes
Key/Remote Control not matched
Key/Remote Control operated too often while Out of Range
Possible Solutions
See vehicle specific page for synchronisation/adaptation procedures
00955 - Key 1: Lower Limit Exceeded
Possible Symptoms
Possible Causes
Key/Remote Control Battery low/faulty
01330 - Central Control Module for Central Convenience (J393)
01330 - Central Control Module for Central Convenience (J393): Faulty
Possible Causes
Control Module faulty
Possible Solutions
Check Control Module
Replace Control Module
01330 - Central Control Module for Central Convenience (J393): Voltage supply too high
Possible Causes
Battery Faulty
Charging System Problem
Special Notes
Check Measuring Blocks for Voltage Readings
01330 - Central Control Module for Central Convenience (J393): Voltage supply too low
Possible Causes
Battery Faulty or Discharged
Wiring Problem
Special Notes
Удачи
