Ошибка 008801, 008583, 001287, 008825 VW Passat B6 2,0 fsi
anuar.k
г. Актау
VW Passat B6 2.0 fsi 2006г
Здравствуйте! Подскажите, сегодня загорел чек, воткнул шнурок и получил следюющюю инфу:
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 3C0 907 115 F HW: 3C0 907 115 F
Component: 2.0l R4/4V TFSI 0030
Revision: --H14--- Serial number: VWZCZ000000000
Coding: 0404010A19070160
Shop #: WSC 01029 444 53980
VCID: 2341EBBF9B53
4 Faults Found:
008801 - Boost Pressure Control Valve (N249): Mechanical Malfunction
P2261 - 008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 6
Mileage: 144373 km
Time Indication: 0
Date: 2012.08.17
Time: 15:28:49
Freeze Frame:
RPM: 1525 /min
Load: 13.7 %
Speed: 72.0 km/h
Temperature: 93.0°C
Temperature: 48.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.970 V
008583 - Bank 1; System too Lean at Idle
P2187 - 004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 3
Mileage: 144781 km
Time Indication: 0
Date: 2012.08.26
Time: 19:34:37
Freeze Frame:
RPM: 811 /min
Load: 14.1 %
Speed: 0.0 km/h
Temperature: 91.0°C
Temperature: 57.0°C
Voltage: 13.843 V
001287 - Idle Control System RPM: Higher than Expected.
P0507 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 3
Mileage: 144783 km
Time Indication: 0
Date: 2012.08.26
Time: 19:40:38
Freeze Frame:
RPM: 1048 /min
Load: 14.5 %
Speed: 0.0 km/h
Temperature: 93.0°C
Temperature: 58.0°C
Voltage: 13.843 V
008825 - Leak in Air Intake System
P2279 - 002 - Lower Limit Exceeded - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 0
Fault Frequency: 1
Mileage: 144824 km
Time Indication: 0
Date: 2012.08.27
Time: 19:08:27
Freeze Frame:
RPM: 788 /min
Load: 13.3 %
Speed: 0.0 km/h
Temperature: 93.0°C
Temperature: 59.0°C
Voltage: 13.716 V
Readiness: 0000 0000
Буду благодарен если кто подскажет!
008801 - Цепь управления давлением наддува
008583 - Ряд 1, система определения параметров топливо-возд. смеси
P2187 - 004 - слишком бедная смесь в сист
16891/P0507/001287 - Система регулирования холостого хода,обороты выше номинального значения P0507
008825 - Негерметичность в системе впуска
Смотри прежде всего соединения турбинки,т.к. все ошибки из-за не достаточного давления во впускном...отсюда и обогащение смеси
Как вариант. Проверь наличее подсоса воздуха через клапан вентиляции картера, под кожухом двс черный гриб, через него не должно засасывать воздух во втускной коллектор. ;)
Скорее сам клапан. И ошибки вызваны, скорее всего, либо неправильной работой клапана, либо не работой вообще. Может датчик давления наддува врать (отсюда недостоверность сигнала и ошибка по клапану N249).
На турбированном моторе не может быть подсосов. :) Утечки воздуха могут быть.
Всем привет! Проблема найдена!!!! :yahoo: Все проблемы в подсосе воздуха через клапан вентиляции картера, который находится под кожухом ДВС, вот в ней порвалася резина (извеняюсь, не знаю как называется) из-за него все проблемы были. Всем спасибо огромное :drinks:
может и очень может быть подсос.
