Paha
VW user
Подскажите как сдеать!
Прочистил форсунки ультрзвуком - стала немного переивать.
Нужно подкорректировать впрыск в меньшую сторону.
Подтвердите мои догатки:
[Select]
[01 - Engine]
[Login - 11]
Enter 12233 to activate special adaptations,
[Do It!]
Channel 1: injected quantity
??Check the injected quantity at idle, engine warm and all power consuming devices
turned off.
??Specification is 2.5 to 9 mg/h.
??To change the amount of injected fuel perceived by the ECU, go to adaptation
channel 1.
??If you have driveability problems, you may want to increase it to 3 -4 mg/h.
??For slightly improved throttle response, you may try to decrease the value.
Это верно?
[Select]
[01 - Engine]
[Login - 11]
[Do It!]
turned off.
channel 1.
Это верно?
