ремонт акпп написал(а):
Допустим для 01М
001,1,Selector Lever,Position
001,2,Throttle Valve,Voltage,Specification: 0...5.0 V
001,3,Value of,Accelerator Pedal,Specification: 0...100 %
001,4,Multi-Function,Switch
002,1,Solenoid Valve 6,Actual Current,N93 (Specification: 1...1.100 A)
002,2,Solenoid Valve 6,Specified Current,N93 (Specification: 0...1.100 A)
002,3,Battery,Voltage,Specification: 0...15.93 V
002,4,Vehicle Speed,Sensor Voltage,G68 (Specification: 0...5.0 V)
003,1,Speed,,Specification: 0...255 km/h
003,2,Engine Speed,,Specification: 0...7650 RPM
003,3,Driving Mode
003,4,Value of,Accelerator Pedal,Specification: 0...100 %
004,1,Solenoid Valves,Condition
; ?xxxxx = Solenoid Valve 1 (N88)
; x?xxxx = Solenoid Valve 2 (N89)
; xx?xxx = Solenoid Valve 3 (N90)
; xxx?xx = Solenoid Valve 4 (N91)
; xxxx?x = Solenoid Valve 5 (N92)
; xxxxx? = Solenoid Valve 6 (N94)
; 101000 = P
; 001000 = R
; 101000 = N
; 001000 = D/1H (Lever in D, Gear 1 hydraulic)
; 001000 = D/1M (Lever in D, Gear 1 mechanical)
; 011000 = D/2H (Lever in D, Gear 2 hydraulic)
; 011000 = D/2M (Lever in D, Gear 2 mechanical)
; 000000 = D/3H (Lever in D, Gear 3 hydraulic)
; 000000 = D/3M (Lever in D, Gear 3 mechanical)
; 110001 = D/4H (Lever in D, Gear 4 hydraulic)
; 110001 = D/4M (Lever in D, Gear 4 mechanical)
004,2,Driving Mode
004,3,Selector Lever,Position
004,4,Speed,,Specification: 0...255 km/h
005,1,ATF Temperature,,Specification: -40...+170 °C
005,2,Multi-Function,Switch 2
005,3,Gear to be,engaged
005,4,Engine Speed,,Specification: 0...7650 RPM
006,1,Road Inclination,(calculated)
006,2,Hill Factor
006,3,Sport Factor
006,4,Value of,Accelerator Pedal,Specification: 0...100 %
007,1,Driving Mode
007,2,Lock-Up clutch,Slip Slipping,Specification: 0...3820 RPM
007,3,Engine Speed,,Specification: 0...7650 RPM
007,4,Value of,Accelerator Pedal,Specification: 0...100 %
