ошибка 02546
  • Автор темы passat b6 1.8
  • Ответы 2
  • Просмотры 19К
passat b6 1.8
украина
авто нет
парни подскажите пожалуйста что это за ошибка
02546 - Упор рулевого механизма
005 - отсутствует или неверные настройки / адаптация
02546 - Steering Limit Stop: No or Incorrect Basic Setting / Adaptation
Possible Symptoms
Steering Assist OFF
Possible Causes
Possible Solutions
Perform Steering Limit Stop Adaptation
Make sure the Ignition is ON and the Engine is Running.
Center Steering Wheel (±10°) and hold it centered for about 5 Seconds.
Turn Steering Wheel completely to the Left and hold there for about 2 Seconds.
Turn Steering Wheel completely to the Right and hold there for about 2 Seconds.
Center Steering Wheel (±10°).
Switch Engine and Ignition OFF.
Switch Ignition ON.
Wait about 5 Seconds.
Steering Assist Warning Lamp should turn OFF (If it doesn't, perform a short Test Drive).
Checking Steering Torque Sensor (G269)
Prerequisites:
Ignition ON
Engine ON (Idle)
System voltage at least 11.0 V.
[Select]
[44 - Steering Assist]
[Meas. Blocks - 08]
Group 001
[Go!]
Field 2: Steering Torque Sensor (G269)
Turn the Steering Wheel multiple times completely to the left and right. The Torque Values should change.
If the Torque Values do change, it's most likely an intermittent Fault in the Wiring/Connectors.
If the Torque Values do NOT change, the Sensor itself or the Power Supply (Terminal 15) might be faulty.
Group 004
[Go!]
Field 2: Power Supply (Terminal 15), Specification: "Term. 15 ON"
[Done, Go Back]
[Close Controller, Go Back - 06]
спасиба за помощь. помогло :blum:
