16891/P0507/001287 - Idle Control System RPM: Higher than Expected.
Possible Symptoms
Malfunction Indicator Lamp (MIL) active
Possible Causes
Throttle Valve Control Module (J338) dirty/faulty
Wiring/Connector(s) from/to Throttle Valve Control Module (J338)
Possible Solutions
Check Throttle Valve Control Module (J338)
Check Wiring/Connector(s) from/to Throttle Valve Control Module (J338)
