Alex989
Помогите! не могу найти причину - вдруг мотор начинает троить и выдает
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - Upper Limit Exceeded
16804 - Catalyst System: Bank 1: Efficiency Below Threshold
P0420 - 002 - Lower Limit Exceeded - ìÑπßΓ«⌐τ¿ó
16688 - Cylinder 4 Misfire Detected
P0304 - 001 - Upper Limit Exceeded
16685 - Cylinder 1 Misfire Detected
P0301 - 001 - Upper Limit Exceeded - ìÑπßΓ«⌐τ¿ó
16840 - EVAP System: Very Small Leak Detected
P0456 - 002 - Lower Limit Exceeded
17887 - Brake Boost Vacuum System: Mechanical Failure
P1479 - 008 - Implausible Signal - ìÑπßΓ«⌐τ¿ó
16687 - Cylinder 3 Misfire Detected
P0303 - 001 - Upper Limit Exceeded
16686 - Cylinder 2 Misfire Detected
P0302 - 001 - Upper Limit Exceeded
В чем может быть дело?
