01435 - Brake Pressure Sensor 1 (G201)
01435 - Brake Pressure Sensor 1 (G201): No or Incorrect Basic Setting / Adaptation
Possible Symptoms
* Malfunction Indicator Light (MIL) active
Possible Causes
* Basic Setting not performed
Possible Solutions
* Perform Basic Setting
01435 - Brake Pressure Sensor 1 (G201): Electrical Fault in Circuit
Possible Causes
* Brake Pedal Switch (F) faulty/jammed
* Brake Pressure Sensor 1 (G201) faulty
Possible Solutions
* Check/Replace Brake Pedal Switch (F)
o See Measuring Blocks
* Check/Replace Brake Pressure Sensor 1 (G201)
o ABS Hydraulic Unit (N55) may need to replaced
o Perform Brake Pump Bleeding
o Perform Brake Pressure Sensor 1 (G201) Basic Setting
o Replace Brake Electronics Control Module (J104)
Special Notes
* When found in MK60 ABS/ESP Brake Systems:
o Check if the Repair Kit documented in TPI 2024465 with the Part Number 1K0-698-517-B is compatible, using the Repair Kit allows to replace the Hydraulic Unit (N55) and the Brake Pressure Sensor 1 (G201) separate from the Control Module which will reduce the Repair Costs.
01435 - Brake Pressure Sensor 1 (G201): Implausible Signal
Possible Symptoms
Possible Causes
Possible Solutions
o See Measuring Value Blocks (MVB)
* Check Brake Pressure Sensor 1 (G201)
* Check/Replace Brake Electronics Control Module (J104) and/or ABS Hydraulic Unit (N55)
