Очень не опытный водитель.
Имею VW Pointer, после 5 лет эксплуатации не ставится сигнализация (дистанционно). Вероятно села батарейка.
Помогите, как заменить не поломав ключ зажигания (он же ключ - сигнализация)
Battery for the key with remote control - assembly overview
1 - Remote control switches housing
2 - LED
q The LED must light up when the remote control is started.
q If LED does not light up when the remote control is started, the battery is exhausted and must be replaced.
3 - Printed circuit with switches
4 - Sealing ring
5 - Battery
q Two of 3 V each.
q Starting from AP 028193 - Parati and AP 034732 - Saveiro, only a battery of 3V exists in the remote control.
q Remove and install → Chapter
6 - Battery housing
7 - Wrench
Battery for the key with remote control - remove and install
Remove
– Insert a screwdriver into the housing opening -1-, opposite side to switches.
– Move the screwdriver in the direction of arrow and separate the housings from the screwdriver -2-.
– Using a screwdriver, unlock the locks.
– Disconnect the battery -1- from the brackets -2- with a screwdriver.
Install
When installing the battery, ensure polarity and assembly position are correct.
NoteStarting from AP 028193 - Parati and AP 034732 - Saveiro, only a battery of 3V exists in the remote control
– Fit the first battery -1- with positive pole turned upwards on batteries housing. Then, install the second battery, in the same way of the first, until the locks -2- lock.
– Join the two bodies. Fit cover on transmitter housing (do not damage seal).
– Then, engage the transmitter unit with the key.
