Ошибка 01336 шина данных комфорт
01336 - Data Bus for Comfort System
01336 - Data Bus for Comfort System: Faulty
Possible Causes
CAN-Data Bus faulty
Wiring/Connectors from/to Control Modules
Control Module in CAN Data Bus Comfort faulty
Possible Solutions
Check CAN-Gateway Coding
Check Measuring Value Blocks (MVB)
Check Wiring/Connectors from/to Control Modules
01336 - Data Bus for Comfort System: Single-Wire Operation
Possible Symptoms
Data Bus Comfort working in Single-Wire Mode
Possible Causes
Possible Solutions
Special Notes
When found in VW Passat (3B): Comfort System, check Comfort Control Module and Door Control Modules.
Wiring/Connectors from/to Door Control Modules faulty
Comfort Control Modules flooded/faulty
Retrieved from "http://wiki.ross-tech.com/wiki/index.php/01336"
Спасибо. Разве "37-00- неисправен" не указывает на конкретную поломку?
