| No. | | Current flow diagram designation | Nominal value | | Function/component | Terminal |
| F1 | - | Fuse 1 on fuse holder B -SB1- | - | - | -Vacant | - |
| F2 | - | Fuse 2 on fuse holder B -SB2- | - | - | -Vacant | - |
| F3 | - | Fuse 3 on fuse holder B -SB3- | 5A | - | Onboard supply control unit -J519- (T52a/24) | 30a |
| F4 | - | Fuse 4 on fuse holder B -SB4- | 30A | - | ABS control unit -J104-
ABS hydraulic unit -N55- | 30a |
| F5 | - | Fuse 5 on fuse holder B -SB5- | - | - | -Vacant | - |
| F6 | - | Fuse 6 on fuse holder B -SB6- | 5A | - | Control unit in dash panel insert -J285-
Steering column electronics control unit -J527- | 30a |
| F7 | - | Fuse 7 on fuse holder B -SB7- | 40A | - | Terminal 15 voltage supply relay 2 -J681- | 30a |
| F8 | - | Fuse 8 on fuse holder B -SB8- | 25A | - | Control unit with display for radio and navigation -J503-
Radio -R
TV tuner -R78- 1)
Satellite digital radio tuner -R190-
Multimedia system control unit -J650- | 30a |
| F8 | - | Fuse 8 on fuse holder B -SB8- 5) | 25A | - | Voltage stabiliser -J532- 5) | 30a |
| F9 | - | Fuse 9 on fuse holder B -SB9- | 5A | - | Mobile telephone operating electronics control unit -J412- | 30a |
| F10 | - | Fuse 10 on fuse holder B -SB10- | 5A 1)
10A 1) | -- | Terminal 30 voltage supply relay -J317-
Engine control unit -J623- | 30a |
| F11 | - | Fuse 11 on fuse holder B -SB11- | 20A
30A 6) | - | Auxiliary heater control unit -J364- | 30a |
| F12 | - | Fuse 12 on fuse holder B -SB12- | 5A | - | Data bus diagnostic interface -J533- | 30a |
| F13 | - | Fuse 13 on fuse holder B -SB13- | 15A
30A 2) | - | Engine control unit -J623- | 87a |
| F14 | - | Fuse 14 on fuse holder B -SB14- | 20A | - | Fuel pressure regulating valve -N276-
Fuel metering valve -N290-
Ignition coil 1 with output stage -N70-
Ignition coil 2 with output stage -N127-
Ignition coil 3 with output stage -N291-
Ignition coil 4 with output stage -N292-
Magnetic clutch for supercharger -N421-
Lambda probe heater -Z19-
Lambda probe 1 heater after catalytic converter -Z29-
Fuel system diagnostic pump -V144-
Fuel pump relay -J17-
Automatic glow period control unit -J179-
Electric fuel pump 2 relay -J49- | 87a |
| F15 | - | Fuse 15 on fuse holder B -SB15- | 10A 1)
15A 1)
5A 2) | | 87a | |
| F16 | - | Fuse 16 on fuse holder B -SB16- | 30A | - | Onboard supply control unit -J519- (T52c/42) | 30a |
| F17 | - | Fuse 17 on fuse holder B -SB17- | 15A | - | Alarm horn relay -J641- | 30a |
| F18 | - | Fuse 18 on fuse holder B -SB18- | 30A | - | Digital sound package amplifier -R184- | 30a |
| F19 | - | Fuse 19 on fuse holder B -SB19- | 30A | - | Wiper motor control unit -J400- | 30a |
| F20 | - | Fuse 20 on fuse holder B -SB20- | 10A
15A 6) | - | Fuel pressure regulating valve -N276-
Coolant circulation pump -V50- 1) | 87a |
| F21 | - | Fuse 21 on fuse holder B -SB21- | 10A 2)
20A 3) | - | Lambda probe heater -Z19-
Fuel pump control unit -J538- | 87a |
| F22 | - | Fuse 22 on fuse holder B -SB22- | 5A | - | Clutch position sender -G476- | 87a |
| F23 | - | Fuse 23 on fuse holder B -SB23- | 10A | - | Charge pressure control solenoid valve -N75-
Exhaust gas recirculation cooler changeover valve -N345-
Fuel pressure regulating valve -N276- 4)
Air mass meter -G70- 1) | 87a |
| F24 | - | Fuse 24 on fuse holder B -SB24- | 10A | - | Radiator fan control unit -J293-
Low heat output relay -J359-
High heat output relay -J360-
Additional coolant pump relay -J496-
Motronic current supply relay 2 -J670-
Activated charcoal filter solenoid valve 1 -N80-
Camshaft control valve 1 -N205-
Turbocharger air recirculation valve -N249-
Intake manifold flap valve -N316-
Coolant circulation pump 2 -V178-
Fuel pump relay -J17- 1) | 87a |
| F25 | - | Fuse 25 on fuse holder B -SB25- | 40A | - | ABS control unit -J104- | 30a |
| F26 | - | Fuse 26 on fuse holder B -SB26- | 30A | - | Onboard supply control unit -J519- (T52a/1) | 30a |
| F27 | - | Fuse 27 on fuse holder B -SB27- | - | - | -Vacant | - |
| F28 | - | Fuse 28 on fuse holder B -SB28- | 50A | - | Automatic glow period control unit -J179- | 30a |
| F29 | - | Fuse 29 on fuse holder B -SB29- | 50A | - | Driver seat adjustment thermal fuse 1 -S44-
Fuse 54 on fuse holder C -SC54-
Fuse 55 on fuse holder C -SC55-
Fuse 56 on fuse holder C -SC56-
Fuse 57 on fuse holder C -SC57- | 30a |
| F30 | - | Fuse 30 on fuse holder B -SB30- | 50A | - | X-contact relief relay -J59- | 30a |
