16490/P0106/000262 - Manifold / Barometric Pressure Sensor (G71) / (F96): Implausible Signal
Possible Symptoms
Erratic Idle
Possible Causes
Wiring and/or Connections from/to Manifold/Barometric Pressure Sensor (G71)/(F96) faulty
Leak in Air Intake and/or Exhaust
Engine Control Module faulty
Possible Solutions
Check Engine Control Module Software Version
See Special Notes for Details
Check Timing
Check Wiring and/or Connections from/to Manifold/Barometric Pressure Sensor (G71)/(F96)
Check for Leak in Air Intake and/or Exhaust
Check/Replace Manifold/Barometric Pressure Sensor (G71)/(F96)
Check/Replace Engine Controle Module
Special Notes
On certain smaller Engines we've seen cases where a buggy Engine Control Unit Firmware can cause these fault codes, additionally there are known Problems with the Timing Chain Tensioners which can also result in these fault codes. Please refer to the related TPL/TSB for more instructions.
